PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. A gutless 94 gt! Here are the codes... What do you think?
  2. How do you add an aftermarket coolant resevoir???
  3. D and D trans ????
  4. T-5 fluid, what brand?
  5. wheel question
  6. New engine, Coolant issues
  7. my tps voltage too high on a 95 gt 5.0
  8. 331 or 347
  9. looking for PN 56124-s smog tube mounting bolts HELP
  10. just installed new distributor...
  11. pull dipstick = sucking noise
  12. Dyno Numbers in on a Gt40p setup...
  13. spline question?
  14. Banging sound from rear of car
  15. 99+ PBR upgrade.....what SS brake lines do I need?
  16. Alternator?
  17. will these work on stock headers
  18. What is this and how do I fix it?
  19. 99-04 gauges in our cars?
  20. Kenne Bell 1994 GT
  21. newb needs help! what more do i need
  22. Coolant Color
  23. Gas gauge doesn't work???
  24. Crankcase Evacuation: Pan evac setups anyone?
  25. i need a lil info pleaseeee =)
  26. exhaust valve question
  27. Check engine and acceleration problems!!!
  28. 99 GT brakes on my 94 gt?
  29. who is running a 28" tire for the track.
  30. New Cloth Convertible Top Next Week
  31. Thremostat Housing Bolt Broke!!!!!!!!!
  32. Heater Core??
  33. oil pressure question...its high, that ok?
  34. exhaust rubbing gas tank...concerned
  35. swaybar question
  36. 96-98 taillights on 94 GT
  37. Brake Questions / Opinions
  38. 20 inch wheels?
  39. water pump
  40. Radiator Fan on the way out?
  41. cam swap: reinstalling romac balancer
  42. 96-98 cobra hood
  43. Help Me Identify This Part!
  44. cam swap: forgot where timing pointer goes...
  45. TPS Question
  46. smoke threw the vents/dash=solved
  47. Should I delete my ABS?
  48. stripped out smog tube hole on back of head
  49. Where the hell is the oil going??
  50. Codes: 314, 311 & 332
  51. Window motor?
  52. turn signal on pass. side fast flash???
  53. Summit throttle bodies?
  54. Air Bag code 52
  55. Help? Anyone running a underdrive crank pulley with a pioneer balancer?
  56. Shelby GT500 rims on SN95
  57. 94 cobra without the punch
  58. First time installing an intake.
  59. GTS vs Fully Loaded GT
  60. Stock Fan Not Spinning
  61. code 176
  62. Key for locking lug nut
  63. MSD Wires
  64. Progress and Problems....
  65. Hard to shift...
  66. Aftermarket Overflow tank options
  67. Distributors
  68. Steeda Tri-Ax Shifter Vs MGW Shifter
  69. Howling noise comming from rearend/driveshaft area.
  70. Stupid questions, BUT? Hissin, Grady, or Killer maybe you can help?
  71. Aode...does it have a vaccum modulator?
  72. Going to push car off cliff!
  73. catalytic converters
  74. Not the usual 4:10 Gear question
  75. code 117 help
  76. Stock 86-93 HO intake to 94/95 issues
  77. two qeustions
  78. Are 03 cobra a-arms and 04 mach a-arms the same?
  79. Need stock repacement Torque converter, help w/ application...
  80. Five Lug Ponys w/brand-new Yokos
  81. PROJECT TIME
  82. aftermarket steering wheel/crusie control
  83. FOX TB CONVERSION EGR HELP
  84. Need help with combo...
  85. 90mm mass air
  86. C&L MAF cause both banks to go lean??
  87. Question about New belt rotation
  88. Head options for 347/S-Trim
  89. What goodies did the 94-95 Cobras come with?
  90. Couple of issues
  91. Charging Problem?
  92. FRPP Coolant hose kit
  93. Banging Swaybar
  94. Low oil sensor
  95. Is this a Good Engine Combo? And what kinda numbers?
  96. oil light
  97. A/C Compressor
  98. question about spark plug gap?
  99. Brake
  100. PLEASE HELP. CANNOT START CAR AFTER STALL. NEED HELP
  101. ABS REMOVAL
  102. Who's running a 31 spline differential?
  103. How Hard/Expensive to have AC installed
  104. 15W-50
  105. What parts are interchangeable between 95 stangs and foxbodys?
  106. What size Weld Rims/ET Streets to go with?
  107. 94 steering rack
  108. Throttle Position Sensor
  109. Probably a dumb question
  110. mallory ign. box's
  111. MAC CERAMIC LONGTUBES
  112. VACUUM HOSE
  113. Anybody use water wetter?
  114. Lunati 51014??
  115. Header + EGR Trouble
  116. exhaust question
  117. Symptoms of bad O2 sensors? What do you think is wrong?
  118. TFS 1 cam with 1.7 RR?
  119. Is there a trick to gettting the computer back in the kick panel?
  120. Fan switch fuse question...ATTN JT
  121. Stock Front Brake Caliper Nipple Caps
  122. Rear End Blown??!!
  123. Sway bar question
  124. Overheating and now too cold?
  125. Fox body TB swap?
  126. MAF help!
  127. 510 help
  128. S-Trim vrs KB boost comparison
  129. Trying to install Dynotune window switch
  130. Does anyone have a diagram of the steering system?
  131. belt routing
  132. Autometer vac/boost install
  133. CHARGING PROBLEMS
  134. cobra brakes: calipers + ?
  135. Cutting out.
  136. 17x10.5's & tailpipe clearance...
  137. numbers###
  138. fuel filter question
  139. What could be a good budget front suspension setup?
  140. PELASE HELP FAST!!what comes with a kb??
  141. Window Motor Help
  142. Possible electrical problems?
  143. spark plug question
  144. NEW DYNO #'S ARE IN!!!!! (graph inside)
  145. Installed lowering springs today
  146. Wheel chirping
  147. Need Help with missfire on 94GT
  148. A Different Look At the ACT Sensor
  149. please help car wont start
  150. help tracking down voltage drop @ idle
  151. 95 mustang GT ABS Sensor and or Module
  152. Question for my friend
  153. miss at 4,000
  154. Front Main Crank Seal...Labor Cost?
  155. Blower for my 95 cobra
  156. blower for my 95 cobra
  157. Airbag install?
  158. Vert Top Questions... NEED WRITE UP!!!
  159. How do I identify my manual trasnmission?
  160. Fuel Pressure & Boost Gauges
  161. Another cobra brake clearance thread...
  162. Can anyone nail down why my car is squeaking when I hit the accelerator???
  163. I found a beauty! Can anyone help me?
  164. cooling question
  165. Egr Plug.....
  166. Tremec trans in 94-95 (also rebuild cost?)
  167. $8,000 to $10,000 to spend max-engine
  168. Window Tinitng Tricks Needed
  169. what camshaft/heads should i use!
  170. EFI guys HELP!!!
  171. Throwout Bearing
  172. Unusual "what do you think of these mods" thread
  173. head question
  174. DSS Super pro bullet
  175. Bad shake
  176. Tranny Solenoid Voltages?
  177. Ordered some mid-length headers
  178. Help diagnosing A/C issue
  179. Banging from rear
  180. No Fuel Pressure
  181. Found some issues with my ongoing brake problems, more q's
  182. not breaking contact on my coil
  183. vacuum lines under intake
  184. very bad vibration
  185. Buzzing Vibration when turning Left...
  186. Clutch or pressure plate question
  187. V belt to serpentine belt conversion
  188. gcomfx.com HELP!!! TFS Oil Filler tube...
  189. best clutch cable kit?
  190. What can I use to re-attach weatherstripping?
  191. How to remove gas from tank
  192. rear defroster issue
  193. My Cobra was underwater!!!!
  194. Stang Problem
  195. My car as of this morning....wish me luck!
  196. Coolant overflow bottle ?
  197. progress on my little project.
  198. 1rwhp per c.i. = streetable. True or False Thread.
  199. Clutch Replacement
  200. Changed starter, hooked up battery, car jumped forward.
  201. JLT cold air...Will it suck up water with the filter placement??
  202. headers: equal or unequal? that is the question
  203. Ideas on this stupid question
  204. Starter, battery, or alternator?
  205. Made IAC restrictor plate...now what?
  206. Thinking about electric water pump
  207. Waterpump....
  208. Need some advice/suggestions
  209. Differences between v6 and v8
  210. THE 331 WENT ON THE DYNO TODAY!!! *VIDZ**
  211. Paddle Shift / Manutrinic / Triptronic...
  212. Tire pressure for daily driven 315 Nittos?
  213. Manual Valve Body guys ... talk to me!
  214. 97 Cobra STB fitment...
  215. no spark, tried just about everything....
  216. Need a how-to on hooking up a tach
  217. Car will not crank or start
  218. tire sizes
  219. What if
  220. Temp sensor between the T/B and M/A meter.
  221. OK pulled the spark plugs and this is what i found, should i be concerned? *PICS*
  222. Temp after aluminum rad?
  223. Removable Stuff...
  224. What 351W block is the one that i want???
  225. BBK longtube owners...Do you hear ticks through the headers???
  226. Getting a tune, local like...Advice?
  227. 94 cobra value
  228. Some progress pictures of my car getting painted!
  229. Driveline vibration at higher speeds...
  230. Couple Suspension questions
  231. Why did this happen to my Upper manifold gasket??? *PICS*
  232. Anyone used these gears install kits?
  233. Best Economy Shock Absorber
  234. confused on timing and firing order
  235. DYNO DAY!!!!video
  236. starting problems
  237. Tuning guys, question about MAF
  238. Brother's car wont crack just clicks
  239. Anyone Have an 03 Cobra Steering Rack?
  240. Having a hard time finding air Dam.
  241. Any ideas before i shoot my stang!!
  242. Looking for ideas why car wont start
  243. How hot is the "A" in NORMAL on the temp gauge??
  244. supercharger, tt, or turbocharger
  245. Pokageek's Pain thread. 351 stroker (414c.i.) swap PROBLEMS.
  246. I need new springs. Suggestions...
  247. Car too low
  248. flywheel help
  249. What was I thinking-BBK TB Regret
  250. Squeeky TOB
