PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. question about spark plug gap?
  2. Brake
  3. PLEASE HELP. CANNOT START CAR AFTER STALL. NEED HELP
  4. ABS REMOVAL
  5. Who's running a 31 spline differential?
  6. How Hard/Expensive to have AC installed
  7. 15W-50
  8. What parts are interchangeable between 95 stangs and foxbodys?
  9. What size Weld Rims/ET Streets to go with?
  10. 94 steering rack
  11. Throttle Position Sensor
  12. Probably a dumb question
  13. mallory ign. box's
  14. MAC CERAMIC LONGTUBES
  15. VACUUM HOSE
  16. Anybody use water wetter?
  17. Lunati 51014??
  18. Header + EGR Trouble
  19. exhaust question
  20. Symptoms of bad O2 sensors? What do you think is wrong?
  21. TFS 1 cam with 1.7 RR?
  22. Is there a trick to gettting the computer back in the kick panel?
  23. Fan switch fuse question...ATTN JT
  24. Stock Front Brake Caliper Nipple Caps
  25. Rear End Blown??!!
  26. Sway bar question
  27. Overheating and now too cold?
  28. Fox body TB swap?
  29. MAF help!
  30. 510 help
  31. S-Trim vrs KB boost comparison
  32. Trying to install Dynotune window switch
  33. Does anyone have a diagram of the steering system?
  34. belt routing
  35. Autometer vac/boost install
  36. CHARGING PROBLEMS
  37. cobra brakes: calipers + ?
  38. Cutting out.
  39. 17x10.5's & tailpipe clearance...
  40. numbers###
  41. fuel filter question
  42. What could be a good budget front suspension setup?
  43. PELASE HELP FAST!!what comes with a kb??
  44. Window Motor Help
  45. Possible electrical problems?
  46. spark plug question
  47. NEW DYNO #'S ARE IN!!!!! (graph inside)
  48. Installed lowering springs today
  49. Wheel chirping
  50. Need Help with missfire on 94GT
  51. A Different Look At the ACT Sensor
  52. please help car wont start
  53. help tracking down voltage drop @ idle
  54. 95 mustang GT ABS Sensor and or Module
  55. Question for my friend
  56. miss at 4,000
  57. Front Main Crank Seal...Labor Cost?
  58. Blower for my 95 cobra
  59. blower for my 95 cobra
  60. Airbag install?
  61. Vert Top Questions... NEED WRITE UP!!!
  62. How do I identify my manual trasnmission?
  63. Fuel Pressure & Boost Gauges
  64. Another cobra brake clearance thread...
  65. Can anyone nail down why my car is squeaking when I hit the accelerator???
  66. I found a beauty! Can anyone help me?
  67. cooling question
  68. Egr Plug.....
  69. Tremec trans in 94-95 (also rebuild cost?)
  70. $8,000 to $10,000 to spend max-engine
  71. Window Tinitng Tricks Needed
  72. what camshaft/heads should i use!
  73. EFI guys HELP!!!
  74. Throwout Bearing
  75. Unusual "what do you think of these mods" thread
  76. head question
  77. DSS Super pro bullet
  78. Bad shake
  79. Tranny Solenoid Voltages?
  80. Ordered some mid-length headers
  81. Help diagnosing A/C issue
  82. Banging from rear
  83. No Fuel Pressure
  84. Found some issues with my ongoing brake problems, more q's
  85. not breaking contact on my coil
  86. vacuum lines under intake
  87. very bad vibration
  88. Buzzing Vibration when turning Left...
  89. Clutch or pressure plate question
  90. V belt to serpentine belt conversion
  91. gcomfx.com HELP!!! TFS Oil Filler tube...
  92. best clutch cable kit?
  93. What can I use to re-attach weatherstripping?
  94. How to remove gas from tank
  95. rear defroster issue
  96. My Cobra was underwater!!!!
  97. Stang Problem
  98. My car as of this morning....wish me luck!
  99. Coolant overflow bottle ?
  100. progress on my little project.
  101. 1rwhp per c.i. = streetable. True or False Thread.
  102. Clutch Replacement
  103. Changed starter, hooked up battery, car jumped forward.
  104. JLT cold air...Will it suck up water with the filter placement??
  105. headers: equal or unequal? that is the question
  106. Ideas on this stupid question
  107. Starter, battery, or alternator?
  108. Made IAC restrictor plate...now what?
  109. Thinking about electric water pump
  110. Waterpump....
  111. Need some advice/suggestions
  112. Differences between v6 and v8
  113. THE 331 WENT ON THE DYNO TODAY!!! *VIDZ**
  114. Paddle Shift / Manutrinic / Triptronic...
  115. Tire pressure for daily driven 315 Nittos?
  116. Manual Valve Body guys ... talk to me!
  117. 97 Cobra STB fitment...
  118. no spark, tried just about everything....
  119. Need a how-to on hooking up a tach
  120. Car will not crank or start
  121. tire sizes
  122. What if
  123. Temp sensor between the T/B and M/A meter.
  124. OK pulled the spark plugs and this is what i found, should i be concerned? *PICS*
  125. Temp after aluminum rad?
  126. Removable Stuff...
  127. What 351W block is the one that i want???
  128. BBK longtube owners...Do you hear ticks through the headers???
  129. Getting a tune, local like...Advice?
  130. 94 cobra value
  131. Some progress pictures of my car getting painted!
  132. Driveline vibration at higher speeds...
  133. Couple Suspension questions
  134. Why did this happen to my Upper manifold gasket??? *PICS*
  135. Anyone used these gears install kits?
  136. Best Economy Shock Absorber
  137. confused on timing and firing order
  138. DYNO DAY!!!!video
  139. starting problems
  140. Tuning guys, question about MAF
  141. Brother's car wont crack just clicks
  142. Anyone Have an 03 Cobra Steering Rack?
  143. Having a hard time finding air Dam.
  144. Any ideas before i shoot my stang!!
  145. Looking for ideas why car wont start
  146. How hot is the "A" in NORMAL on the temp gauge??
  147. supercharger, tt, or turbocharger
  148. Pokageek's Pain thread. 351 stroker (414c.i.) swap PROBLEMS.
  149. I need new springs. Suggestions...
  150. Car too low
  151. flywheel help
  152. What was I thinking-BBK TB Regret
  153. Squeeky TOB
  154. Dam no spark now! Where should I look?
  155. Battery cable replacement..question ?
  156. Gas Leak
  157. New goodies! Need a gear install how-to
  158. Wiring Diagram for Fuse #8 94 GT Vert
  159. Fox TB Swap & Smog
  160. Ignition Module & Coil Pcikup Assembly
  161. Cars Not Starting (Starts When Spouts Pulled Out)
  162. 500 or more RWHP cars and transmissions
  163. ANYONE HAVE OPINIONS ON ZEX DRY KIT?
  164. Fox Throttlebody done -again
  165. Spark plug wires
  166. Cam swap....cant get Romac off!!!!
  167. How to hook breaks up with no ABS?
  168. Fired up the new motor, couple bugs..
  169. Fox throttlebody swap done
  170. Did the search, cant find it...how many grounds do we have and where do they go?
  171. I can hear starter solenoid try to send the juice but starter does not even crank..
  172. More cam swap questions....
  173. vortech s-trim
  174. HELP!? Should fuel pressure show a reading on the fuel presguage if key in on pos?
  175. Quick question about 2000+ PBR front calipers...
  176. How do I know what suspension parts I need?
  177. Has anyone installed a 351W in 94-95 GT?
  178. problems with wiring on starter, kind of techy.
  179. question about front lower control arms.....
  180. 94/95 Battery harness / cable
  181. Seat removal
  182. passenger side mirror wiring
  183. clutch pedals??
  184. Got my 95 cobra done.... then split block?
  185. trans. poblems...
  186. Which way does our motor spin normally?
  187. My new 331 is hard to start when it's warm, is it the tune??
  188. What Flywheel and Balancer?
  189. does our car have a fuel pump relay????
  190. Engine & Transmission Mounts
  191. Clutch problems/questions
  192. head stud question
  193. T-Trim to YSI
  194. Before and after pics of my nitrous install:
  195. Looking for a Supercharger...
  196. Advice for fuel pump install on '94 GT 5.0
  197. 1995 Mustang GT Rear convertible speakers
  198. x2c Control arms....
  199. Question for Grady and others
  200. Cam
  201. Tired of sloppy steering, but what's the fix?
  202. Slight Buzzing Vibration when turning left...
  203. timing light won't work w/ spout out
  204. stock pulleys
  205. What about this blower?
  206. GT40 heads
  207. Tire/ Rims size?
  208. What MSD box for timing retard when using nitrous?
  209. How much timing can i run on 100octane?
  210. a/c control question...
  211. bolt length
  212. Pegging the MAF?
  213. Yet Another Noise...
  214. Roller Rocker Question
  215. Did i use the right coolant???
  216. idle started hanging up
  217. Battery disconnect switch wiring
  218. epa and cats
  219. My Mustang is screwed up!
  220. Fender Flares!?
  221. from the midpipe back....
  222. building high flow cat hpipe
  223. A/C line question
  224. probably a stupid question - phone charger
  225. Stalling when hot.
  226. what injectors should i go with for my 331???
  227. ugh steering rack
  228. AFR165's - Lunati - RPM II + Dyno Pull
  229. My tach needle fluctuates?????
  230. Installing a new clutch quadrant. Help!?
  231. Hot running Turd
  232. another quick question...
  233. Tire Pressure
  234. Cobra intake is on !!!
  235. belt comes off the back of the tensioner
  236. Question about 351's....I want to shank the search function..
  237. S/C Part #
  238. Car Dies While Driving (Help!) TFI?
  239. Engine Swap in my 98 Stang
  240. HomeMade cold air intakes Questions
  241. My project progress - Almost!
  242. New O2 Sensor questions?
  243. What's it take to crack 13s
  244. my race against a 73 to 76 corvette stingray
  245. Best Longtubes for a stock block H/C/I combo
  246. 31 spline VS 28 spline...
  247. how do you separate the motor from the t-5?
  248. SN95 timing cover
  249. Trickflow intake users...What fittings under the upper did you use??
  250. NO REVERSE LIGHTS
