PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Headlight choice....
  2. 5.0's what happened
  3. what is the stock set timing for a 5.0??
  4. A/T fluid leak
  5. Pictures of 94-98's with Aftermarket Wheels
  6. Loud Thottle Body Whistle!
  7. Help 1995 electrical problems.
  8. went to charge a/c, now my service port is leaking
  9. Carpet Help
  10. Will an oil pan for an 82 GT fit our cars??
  11. Cloth Convertible Top Kit
  12. Fox struts C&C plates???
  13. Nitrous Nozzle Location
  14. Looking for...
  15. Do i really need a main support girdle???
  16. a/c compressor keeps kicking on/off continuously
  17. What the FREAK is wrong with my steering?!
  18. What parts are needed when installing KB?
  19. starting....
  20. Stereo Ruckus
  21. 95 rear bumper for cobra replacement
  22. Play in crankshaft- need advice
  23. What size tires are you guys running on your 18" wheels?
  24. Help making a bumper decision
  25. Lets talk about brakes
  26. What cable goes to starter??
  27. gears question
  28. car wont start plz help
  29. How to pass emissions without cats
  30. need help front end fix
  31. vert rear seat delete?? help me find one...
  32. What Offset for Rear Wheels?
  33. Project Help
  34. valves rattling
  35. supercharger pulley question...
  36. gears question...new to the forums
  37. What is this blue NOS piece I have here? (Nitrous piece)
  38. Black or Red...You Decide!
  39. need some help and info
  40. Good choice for headers?
  41. miss fire
  42. Bad fuel pump?
  43. Anyone else have this problem while changing a clutch?
  44. MAF question
  45. HELP! whats causing this!?
  46. GT40P's Stock Cam?
  47. 95 Mustang Clutch Switch BY-PASS
  48. Getting 347, What else will i need?
  49. may have problems
  50. Spedo is acting weird...
  51. M&M C/C plates not adjustable enough....
  52. Power Window Gremlin is Back!
  53. car dying at idle and...
  54. Do I need bumpsteer kit?
  55. Ignition lock tumbler again!!!!
  56. High RPM Miss at WOT
  57. smoke threw the vents/dash
  58. Little bit of white smoke
  59. blown header gasket
  60. N/A or Vortech s/c on stock block
  61. power steering problem?
  62. motor falls off at 5k....
  63. Idle hanging up?
  64. Surgy clunky 95
  65. Anybody have (or know where to get) the EGR tube that came with BBK unequal shorties?
  66. Bushing on the end of the A-Arms...
  67. Guys with M&M C/C plates...
  68. Anyone using different shifter handle with Pro5.0 shifter base
  69. Ok fellas a couple more questions....
  70. Hailine Crack in cylinder ?
  71. White smoke equal compression
  72. Who is running twisted wedge heads?
  73. A/C guys quick general question?
  74. Wanting to run boost
  75. acceleration problems!
  76. High rpm white smoke, thoughts?
  77. Maf Info
  78. where to find plug wires....
  79. removing poly bushings from rear end. any tips?
  80. Roller rocker question
  81. Tie-rods
  82. underdrive pulleys
  83. supercharger bearing ?
  84. Car is stalling while using Cruise Control
  85. Bosch O2's. What part #?
  86. Removing wheel spacers.........they don't want to come off
  87. Dyno Q
  88. Tailpipes?
  89. Is $1700 a good price for a kenne bell?
  90. Timing chain question
  91. Trouble codes 311 & 314?
  92. U-Joints
  93. Issues after Intake/MAF/TB Install
  94. Door Locks and Trunk pop not working
  95. weird problem HELP ME!!
  96. Please help me out guys!!!
  97. wired up fan switches, almost caught the car on fire
  98. Two random problems
  99. oil pan question?
  100. H/c/i vs kenne bell + supporting mods
  101. headers trouble
  102. Do these cars have limited slips or no?
  103. Vacume hose from valve cover to CAI, do i need it???
  104. How to remove rear parking brake cable from 94 GT caliper??????
  105. Which O2 Sensors would you buy?
  106. this wasn't one of y'all was it?
  107. MSD Box for Nitrous
  108. whats a good underhood switched +12V power source
  109. Dyno disappointment!!
  110. eibach pro sitting weird
  111. junkyard search
  112. 96 swap to 5.0
  113. Guess my Horsepower
  114. new clear corners - condensation
  115. MSD coil issue!
  116. distributor issues... please help
  117. spark plug wires...please help
  118. Where does the EEC read RPM?
  119. Weird Noise?
  120. The covering on my sun visors is falling apart
  121. How to take off headrests?
  122. Parts store rant
  123. FB vs SN95
  124. fox 8.8 in my sn95
  125. Convertible top replacement
  126. Lightning MAF on HCI car?
  127. cobra vs gt gas mileage
  128. Inner tie rod ends
  129. oxy acetylene + control arm (need advice)
  130. Is it ok if the fan does not cover the entire radiator?
  131. Where to buy fuel pumps?
  132. I failed track Tech inspect.
  133. Car running horrible =/ help!!
  134. High speed vibration
  135. Setting timing
  136. help timing issue....
  137. Drive shaft question
  138. Does this sound right?
  139. upgrading alternator
  140. Do I need tfi module if...
  141. bouncing oil pressure guage
  142. issue when car gets hot....
  143. Opinions needed.....colder spark plugs
  144. 94-95 COBRA INTAKE ON 347 WOULD IT WORK???
  145. need help with engine harness connections
  146. wierd hard starting problem
  147. Going to try to start the car after sitting for while.
  148. for those who removed spoiler
  149. strange noise
  150. Harness connector for new radio...
  151. autometer dual gauge cluster
  152. Smeding Performance Engines
  153. Anybody know the stock fan CFM
  154. is a 4 inch pipe too big??
  155. my motor is almost back together....
  156. Sluggish/backfiring only when warmed up? Need help quick!
  157. DANGER! Contains sodium azide and sodium nitrate contents are poisonous!
  158. High temp, battery light, low voltage, and it won't start with out a push.
  159. Almost got a good deal!!
  160. Rag joint
  161. Car is running real bad
  162. ACT + Warm weather (AGAIN)
  163. Cam Decisions
  164. New top pics
  165. Check engine light
  166. trickflow stage 1 cam and 1.7 rockers
  167. 94 Cobra T5
  168. Quick Battery hardware question
  169. Air BagLight is on......
  170. Timing jumps when i put spout back in.HELP!
  171. Where/How can I get better traction?
  172. Car broke down on me again :(
  173. XE270HR-14???
  174. Custom cam wait time...
  175. HELP! Replaced intake gasket now wont start...
  176. New intake baffle fabbed up for oil control!!! (pics inside)
  177. People who have done a brake install, Help Me.
  178. Cooling problem???
  179. A/C line valve leaks, any suggestions?
  180. wheres that link on checking codes?
  181. Battery woes
  182. shuts off going down the road
  183. Max. Motorsports coil overs????
  184. Help With CEL Light
  185. Would gears make a clunking sound like almost a month after install?
  186. lowering spring question (isolators)
  187. Which manual transmission?
  188. I am re-running the the wires to my speakers this week...
  189. i have 2 fight my steering wheel to turn it and fight it back to return 2 center!
  190. wheel and tire question
  191. Eibach ???
  192. Anyone have/heard about Intrax Lowering Springs?
  193. Pulled out distributer, do i need to reset timing?
  194. Stereo wiring harnesses - am I just crazy?
  195. Lower manifold gasket blown, check this out...
  196. T5 Swap Kit - Good Price?
  197. Duplicolor Laquer Paints?
  198. Idle Air Control
  199. More than a little concerned....
  200. Nitrous experts... need your opinions.
  201. BBK Springs. Post pics?
  202. 02 EXTENSION / OFFROAD X-PIPE
  203. 1995 302vacum lines????
  204. Fox body rearend difference
  205. T-5 or Tremec swap
  206. can I change my TPS myself?
  207. Quick Question about TREX fuel pump?
  208. The black plastic between the windshield and hood
  209. Update! intake manifold swap god bad.
  210. weight difference between 295 vs 315
  211. AODE with no 'P'ark
  212. Help! Does anyone know where this small vaccum hose goes? Comes of the brak booster
  213. Injector stuck open, which one
  214. Deleting Smog; What To Do About Holes In The Back of The Cylinder Heads...???
  215. AODE to T5 Swap; Do I Need Another Tranny Crossmember?
  216. Turn on A/C, car gets hot....
  217. 94-95 A/C system any different??
  218. How does my clutch and Flywheel look?
  219. Deleting egr valve on 5.0
  220. a/c blowing warm
  221. Tie rod ends + control arm question
  222. Opinions Needed: Hood & Bumpers
  223. Where does the interior battery guage read from?
  224. Which powerpipe for 75mm fox style t body
  225. Nitrous kit question.
  226. not your normal U/D pulley question??
  227. 245 x 16 tires on front of 94 GT??
  228. well the truck is gone.....
  229. N/A vs. supercharged
  230. 31 spline axels whats involved?
  231. Wrong bellhousing or do I need a spacer?
  232. porting e7 pics.
  233. IF my AODE Were to Crap Out.....
  234. where to get deep trans. pan for AODE?
  235. TPS problem, could use some help...
  236. seafoam
  237. What is this?
  238. Tire size question...
  239. MAF and IAC
  240. Dumb Nitrous Question, but i need to ask
  241. Little help please - passenger side accessory bracket
  242. Replacing factory sound system...stereo guyz get in here
  243. Clutch adjustments
  244. started taking off my heads....
  245. whats the best way to change oil pan gasket???
  246. HIding wires! Can I use industrial strength velcro to attach my TFI Heat sink?
  247. what do short pushrods sound like
  248. Removing power steering pulley?
  249. How do you replace the reverse lights?
  250. pre-alignment check
