View Full Version : 94-95 Tech
- Tach Tap for Nitrous or Etc
- Help with Cold Air Kit Install parts
- Cooling fan options
- Bodywork
- Cleaning the LMAF
- Squeeky door hinges
- Volume REALLY low after taking out cd player
- Just got my Maximum Motorsports C/C plates...
- Upgrading to 31 spline diff and axles?
- Carpet removal/install
- Paint Code
- T-5 Tranny mount WAY off line! WTF??
- 94 AC/Defrost vent issue
- Ground Wire
- What's the easiest way to get the front brakes off?
- Diff rebuild ?
- new clutch...potential problem??
- does anyone know where to get oem leather seat covers?
- AFter market A/C compressors any good?
- coolant temp guage...
- Another hanging idle...I've tried it all!
- egr spacer required w/ rpm2?
- exhaust thoght
- I think I am going to rebuild a new T5 for her
- It was my head gasket
- Timing question
- rearend
- any one have march performance series pullies and ford racing a/c delete??
- More ECU problems....
- car is getting taken away today...
- I have about HAD IT!!!!
- Trick Flow Oil Filler Kit....
- Nitrous Plugs...
- How to adjust rear brakes? 95
- what are my piston ring groove sizes?
- Will this shorter belt routing work? (pic inside)
- H/C/I: Cam questions
- Heads Questions. Valve springs, valve locks, and 0-ringed or not?
- BBK Longtubes FOX on a SN95 DONT!
- 325's mounted on 15" welds for a SN-95
- Unplug MAF sensor, Car still runs!
- working on 5.0 in this body
- Drivers side window has been Creaking loud on roll down...gonna die?
- Stroker recomendations??
- anyone running cobra front brakes w/ gt rears?
- Battery cable questions
- Getting a S/C, which one?
- S-Trim guys in here please
- Trick Flow Top End Kit.......which emissions legal Cam???
- Are our cars REAR ABS?
- If I remove the a/c AND smog pulley..will my serpentine work?
- Car feels choked for brief moments
- Help me put togehter a cheap wheel and tire combo for the track...
- Looking to get new heads and a cam...
- 69Clark!
- After-market dip-sticks??
- How do Nitto 315's compare to normal 315's?
- $800 to blow.
- Quick valve cover ?
- having trouble starting
- What tires?
- cant figure it out
- Loud Squeek Noise on Start Up in Rain
- Remote mount Fuel Pressure Regulator?
- For those who have done the FOX tb conversion?
- Anti Lock Light
- e-brake springs on rear calipers...
- Blower VS H/C/I
- Gonna do intercooler, will my intake work flipped?
- Basic Mods
- Which suspension components to replace/upgrade?
- k&n filter + eBay CAI
- Help no spark on #1 cyl only
- AFR165s and holley systemax, thoughts...
- Car dies suddenly
- Stummbling under 2k, Fine if i give it gas quickly
- New Gauges Now Alternator Not Charging
- autometer just made my day
- Who can port my stock GT40 heads?
- 351 supporting mods
- how to remove the needles on instrument cluster gauges?
- Cobra R Hood Question - Cervini - Fibertrends
- Electrical gurus, I need wiring help on my AirRide system...
- cobra gauge cluster install problem with volt gauge
- Sway bar woes
- leaky rear axle seal
- Remove stock alternator pulley?
- Anyone swap out their battery tray?
- IN-Line fuse for alternator?
- Electric Water Pump help
- Game Time!! Name that plug
- Burning oil
- Fuel gauge creeps to full when car turns off, Normal?
- Cam Indexing...
- Pulley Difference?
- This does not look good
- Firing order!?!?!
- tranny question
- car wont start
- teach me about cams.
- So i got her back
- how hard is it to get brackets out??
- my car wont go in reverse
- Supercharged 331c.i. what h/c/i to run with it?
- What mustang seats work?
- C-4 in a 95GT
- MAF plug
- Broken door hinge?
- Steeda tri ax problem
- HELP with timing, why does the timing change with spout?
- Fuel pump question.....
- 4r70w 2-3 accumulator spring
- ZEX Box mounting locations?
- Belt size?
- Need Information ASAP
- Clutch to pressure plate question
- windsor jr. heads
- Blower with Trickflow HCI?
- Using fox body t-5 in our cars?
- AFM B-31 Cam...Anyone?
- Engine Problems-Help!!!!
- Pressure Sensor
- Valve cover differences
- Best N/A A/F Ratio?
- Running no pintels
- Fuel pump diagram?
- Is this where the bolt should be?
- Ported lower intake
- 351w heads worth anything?
- Anyone with a solid steering shaft?
- click from front driver's wheel
- Help! Pick up Sensor
- Remove A/C?
- UV Dye coming from A/C...
- I can close the Idle control switch and the car does nothing????
- random rpms
- Need help with Airbag Annoyance
- 1 inch GT-40 Intake Phenolic Spacer
- wheel stud question
- HP Limits for the Following!
- Getting gears, should I get a rebuild too?
- Adjustable Stall??
- DASH CLOCK
- A/C isnt working, can if be refilled?
- CAI Couplers
- Heads...now what???
- TrickFlow vs AFR's
- Need Flywheel Help!!! c4 guys inside!
- Nitrogen-Filled tires for street?
- what alarm should i get?
- School me on the smog system
- Street heat vs Track heat
- Harmonic Balancer instal
- Where to Find 12V Power Under the Hood (Drivers Side)?
- What fan to use?
- ARP Oil pump driveshaft...is it a DIRECT REPLACEMENT with a MSD dizzy???
- Drilling Fuel Injector Holes?
- c4 shifter mounting???
- Do 94-98 Mustang air bags interchange?
- Trick Flow heads question....
- ENGINE PROBS AFTER MODS!! HELP!!!
- Idling
- Help Quick steeda tri ax question
- Help me decide: 302 based stroker or 351?
- How to eliminate all the smog stuff??
- header problem
- EGR sim question
- Elbow for a typhoon intake
- Ignition problem?
- 351C into a 95 GT?
- Teflon Rear Main Seal - Wrong part or hard to install?
- next mod on a 95 GT?
- Rough, Lumpy Idle (long)
- Header bolts
- 02 sensor thread + pitch?
- next mod.
- new problem with engine bog, NOT PIP
- Stock strut tower + Explorer intake?
- Typhoon Throttle Bodies
- Running on E85?
- Cobra injectors on 5.0L??
- S-trim'd 347 dyno numbers
- Help with setting timing on Prof. Prod Balancer
- Clutch Fork Cover, HELP!
- Car is running....but problems....
- Looking for CAI couplers
- woo hoo.....now im having electrical problems...i love my car.
- oil question
- Got some time........
- water in oil
- New 02's installed!!!
- Do heads have to be on to pull a block?
- Powersteering pump squeel
- Speaker problems
- K member guys/guru's
- What's Involved With Changing Carpet?
- Question about Stronger Blocks!
- Question on roller cam installation
- 300 rwhp.. blower or mild h/c/i
- I've been searching for an hour.....Grady(or anyone else)!
- Window Switch Install/Programming
- What can I expect from this setup?
- Changing Interior
- Where can i buy the bulbs for the instrument cluster?
- ANYBODY KNOW WHERE I CAN FIND....
- Which quadrant and FWA ?
- More problems...
- Finishing up cam install.
- teach me about superchargers
- Is this the correct tip for a 24lb injectors??? *Pics*
- What would cause the rear passenger side to sag?
- Installed O/R H...Wont stay started...WTF???
- How do U recomend keeping inj from draining fuel when changing motors?
- Any opinions on clutch to handle 500WHP?
- Who here runs or driven a car with McLeod Dual Performance Clutch Disc Blue printed
- Injector cap down combustion chamber
- Vortech T-Rex install
- someone tell me if this will fit?
- Rear spring question
- Picking my edelbrock heads, 2.02" or 1.9" intake valve?
- injector voltage ???????????
- What does the "KING COBRA" Clutch Kit look like???
- Riddle me this batman
- Blown vs. Turbo
- Quick Question :)
- t56 tranny question...
- wheel hub/bearing install
- Where do they sell those 5 gal buckets to pour waste into that are sealed?
- Pros and cons going from stock 192* thermostat to -> 180*?
- egr hose
- My parts list and my problem!
- Just picked this up, Garaged since 2002
- Codes 121 and 125, should I replace TPS?
- Line lock questons
- Fan motor pigtail melting
- 351 Heads on a 302?
- Weight jacker lower control arms.
- gear install
- First time swapping my clutch, help.
- 94 Cobra trans in a Fox?
- Question on fluids for my car
- Brake dust
- Will 91'Motorsport lowering springs work?
- Please help!? Build Data for 95GT
- Will hypertec chip for a 94 work on a 95
- lost my wheel lock key.....HELP
- Stock 95 1/4 times?
- Bullitt and Eibach Combo...Pics?
- Can the Granatelli mass air meters be recalibrated?
