View Full Version : 94-95 Tech
- stock ring and pinion gears?
- Need to replace the output shaft bushing on your T5? Here's the tool to get.
- Quick Question on PCV Grommet
- Cobra Owners - Need to replace your old oil cooler hoses?
- 4.10s back to 3.55s ???
- Wheere is the computer?
- installing 2 rings on FWD clutch (included in transgo AODE shift kit)
- Yet another Timing Question
- 94 GT runs like crap...have EEC test codes
- Misfire Under Load
- Cigarette/Cigar Lighter Amperage?
- Replace Passenger Fender
- Speedo / tranny problems
- explorer parts
- vert fog light removal
- PIP sensor
- fox body tb fit a 94gt?
- instrument cluster bezel
- Good SoCal trans rebuilders
- ECT Sensor Questions
- Airbag Code 32
- Squeaking front suspension won't compress
- runs like crap when cold
- just tell me what to do!!!!
- wheel help
- need help!
- march u/d pulleys
- RIM/TIRE SIZE QUESTION
- Biggest Tire for a 95 on 15" rims???
- help me pick a new intake/head combo
- TPS + AODE
- Electric water temp gauge hookup
- wire hiding help under pass fender
- Please post your Hurst shifter setups!
- Transmission cooler
- auto wont shift into 3rd
- TR6060 six speed swap question
- ignition question
- D&D Motorsport CC plate question
- voltage regulator wires
- Project WEEK 12 Almost Done...Car on the Road!!
- which mod next? debating
- 3.73 gears installed, now odometer won't work
- My dash clock died
- Hoping To Get Car on the Road Saturday.
- guys with 4.10s get in here
- New Moser axles what's the tolerance acceptance?
- 5.0 Intake manifolds that clear stock STB?
- Any ideas for enging miss/cutting out
- Clutch is dead, how much ?
- as ricer as this sounds
- Aeromotive Controller 94 95 Mustang
- Snap... Goes the water pump bolt...
- belt size for u/d
- Where to buy new AC vents. Please Help.
- engines codes please help
- Rear main seal Question... replacement
- Anyone else have this electrical problem?
- Replaced switch, still no A/C
- Idle Problem. Please Help!
- Just bought a 94 Cobra - question on front suspension
- caster camber with coilovers?
- May be a dumb one!!!!!!!!!!!
- TOO LOW--Ideas?
- 2.02" or 1.90" for street stroker
- 5- Point Harness Install question
- Convertible back belt moulding
- Borla mufflers?
- KB vs centrifugal vs turbo
- new to the dark side
- Need Help ASAP--Rear Lowering Spring Install
- Did 3g alternater
- 94 and 98 fenders different?
- smog delete ?
- rack and pinion.
- NA 418, 347, 5.0, & Blown 5.0 Dyno Pull Compare-O
- Help With AutoMeter Shift Light Install
- My 1995 Mustang GT.. Fuel filter???
- What would cause....
- Low beams don't work
- 4rw70 trans massive fluid leak
- trickflow street
- stock size tail pipes...any idea what size diameter?
- Vortech question
- everytime i turn left the car squeels/whines
- I need to get all teh air out of my power steering system...
- anti theft system...help
- Quick help with a fuse, owners manual
- Transgo shift kit
- Rim Identification and help!
- Need help removing B-Pillar above door windows....
- bumper removal. NEED HELP FAST
- advise on tapping the oil pan
- guys who hid their wires, in here please
- 94 GT gauge faces...
- Rear Sway Bar...Problem After Control Arms Install.
- DSS306 or 331!!!!
- dyno worries
- Odometer doesnt work, how do I fix it?
- Starter problems....
- Manual Belt Tensioner
- Another strange problem
- Transmission mount
- Vibrating Steering Wheel
- Disc brake Backing plates??
- Convertible rear window motor access
- BIGGEST Wheels!
- tranny problems or not?????
- aode to 5 speed swap! anyone know??
- biggest tire to fit on a 17x8 rim
- what is this
- Non Standard Crank Pulley Source
- bbk or frpp 70mm T.B?
- street heat on gt40 heads
- Nissan CV joints
- new clutch making noise-NEED HELP
- Rear Brakes????
- swapping fox wiring into 94-95GT ???
- Idle Problem
- Valve or lifter noise on my new engine
- Safe Way To Disable Ignition
- car starts with out key
- Swapping my fox stuff into 94 Cobra, differences?
- 1995 GT OBD2 Problem
- im curious if someone knows this answer
- crate engines?
- DTC 556
- Long tube Headers on my 95 GT AUTO
- How do I clean the MAF ?
- 24# injector and mass air calibration
- Electric Fans
- Starter issue
- Rearend Slop Driveshaft Rotates
- heading to track for first time
- Saleen Wing and Lowering
- How do i remove the tie rod and ball joint?
- Week 10..We Have Ignition AND Liftoff!!
- (New member!) Intake question??
- Anyone with a write-up to installing MM C/C Plates?
- do i have an aftermarket tranny?
- Need help on picking a cam
- electrical problem
- terrible idle after install
- Aftermarket oil pan???
- Front speaker depth?
- Power Steering Pump Lines
- Power Steering Pump Filter
- where is the air bag control module?
- Convertible top not working??????
- driveline rubbin
- Getting Air Out of the Power Steering Pump and Lines
- stock fuel pressure
- Manual rack
- 95 Mustang...smoke/sulphur smell
- CHECK THIS OUT! Long-tubes no scrapee. Excellent idea...
- which rotors are better?
- 94 mustang driveability
- Installed my 70mm Edel Throttle Body (had 65mm)
- looking to upgrade fuel rail and hoses, what do you have?
- Is this a sign of a bad fuel pressure regulator?
- Anyone with TwEECer Run Autometer Wideband?
- Quetion for those with MSD Distributor.
- Help Locating Stock Water Temp Sending Unit Wire!
- Length: Bumper to Bumper
- Stock 94/95 Battery Cable Length?
- Cant keep oil in the motor...and will any 5.0 shortblock work in a 95?
- to change all or just the heads
- 5.0 radiator swapped into a 3.8?
- Magnetic trigger in distributor
- Fire wall adjuster.
- Coolant Question
- Vacuum sources created equal?
- What's the difference between the Cobra and GT Crank Pulleys?
- Deleting Heater
- Back and with issues..
- Fuel smell on dip stick/ need help bad
- 331 stroker questions
- Removing EGR and SMOG stuff Need your advice
- computer number
- computer
- Tach jumping & Car Breaking Up
- HEeehlp me!
- CEL Blinks 4 times.
- losing a/c freon
- MIL eliminators?
- need help with timing
- Help me replace my 1/4 panel
- Mystery CE light
- questions about some 351W heads
- Mix and match combo questions
- windsor jr heads
- Little Red Hose?
- Replace A/C Valve
- How to convert a 94-98 Mustang radio bezel to the 01+ double din
- new engine has some new problems
- Car won't Idle, and dies.
- Auto Stalls when put into Drive or Reverse
- intake manifold advice.
- Fan control device
- smog pump bolt size
- Refilling Steering rack and Pump
- Should I get 58 or 64cc GT-40x heads?
- breaking up at mid-high RPM
- Where do you get your painting supplies
- super charger??
- rear mount turbo help please
- Idle Air Control question...
- Idle Issue and RPM drop
- Car dies when shifted into reverse after cranking when motor is at operating temp
- Urgent....please help
- getting ready to start 347
- Power Steering Cooler
- finally decided
- Still Having Hard Time Finding Hood Pins
- C&L Trueflow Inlet Pipe Question??
- New engine or rebuild?
- Vortech owners!
- 03 cobra wheels on 95 ? and few more ?'s
- A/C fix....never would have guessed.
- Am I gonna have to change my whole steering rack?
- Saleen Rear Bumper---Price Vs. Quality.
- New Alternator Issue?
- intake pipe
- Need some opinions...aluminum heads or 3.73 gears, which should I do next??
- Heads/Cam w/ 1.7 rockers and PTV clearance
- Torco Accelerator Race Fuel
- 95 intake
- spark knock??? pinging?
- How to clean out the PS lines?
- msd install help
- 94-98 seat interchange questions!!
- valve covers
- Vibration at idle and acceleration
- which rear lower control arms??
- Procharger Pulley Offset
- transgo shift kit owners, I need intructions
- update on h-pipe install
- Anyone run glasspacks? :)
- This should tell the story. Unported procomps vs afr 205's pics.
- Reverse lights don't work... help!
- MSD 6AL-2 mounting: Is it ok to mount the box in the trunk?
- HELP! Locked keys in car :(
- Zoom aluminum flywheel
- Need help ASAP!!!!!
- HELP! PA Perf Alternator install
- Two power steering pumps in one month...
- WTH I'm really getting tired of this...
- shift light mounting
- Rear wheel spacers
- Knocking and pinging at 3000 to 3500rpm
