View Full Version : 94-95 Tech
- 4R70W swap?
- gt40p valve springs
- Throwout Bearing Issues!!!
- fuel line question
- Fuse Panel ?
- Rims ?
- PIP malfunction question
- Clutch Question
- Rev Limiter - AODE - I know Search
- 95 Cobra T5 vs 95 GT T5
- cheapest alum head?
- Signs of bad IAC?
- Top Dead center
- Hard starting...
- Help me choose the right suspension setup
- Check engine light after oil pressure switch replacement?
- Cobra guys (or GT guys w/Cobra brakes)
- Somethings Wrong with the Cobra...
- Headlights
- Lowering my car have alot of questions I need help with
- N 41 cam help
- Need Radiator overflow specs please
- Need 2000 Cobra R brembo caliper part #
- E-Brake Cable: Brake Upgrade
- Ford Wheels
- lifter install
- What's this?!
- Upgrading to 31 sline axles and have a quesiton
- TKO and Transmission Mount
- cam question
- Another Thottle Body question.
- Interesting Throttle Body Question!
- 4.10 HELP
- 75 OR 90MM MAF?
- DO I need another radiator for my 408c.i.?
- Long tubes or shorties
- Weight jacker control arms or coil-overs
- Need help to get engine running again!
- Weird problem with oil pressure gauge
- crap
- ok...heres what i bought what else should i save for???
- car has mind of its own on highway
- Code Question..
- Head Gasket install
- 95 Dodge Stratus
- gauges acting up
- Intake Recommendation
- Trickflow street heads torque specs
- Kenne BELL owners with Snow performance I need info?
- Let my friend borrow my car........
- Vortech oil supply, look and see if I have it right
- Fox lower control arms on SN95
- Cracking noise when turning
- Would you buy this car for $1000?
- Anyone ever add a scoop or vents to a 94-98 hood?
- Weird Stuff. I am lost.
- 02 GT 5 speed work in a 95 GT?
- gas cap not holding pressure?
- Spark Jumping to Headers
- Rear differential question...
- Which of these engine would be a better buy?!?
- Air Bag Problem (ADM maybe)
- need help
- thoughts on windage trays?
- 351/408 stroker fuel rails..will these work?
- Clutch install??
- Clutch and gas pedal
- maf probs
- 90mm Maf?
- Trick flow r or victor jr on 351w?
- need parts to build a animal but low budget
- Bad boost gauge, sender, or grond?
- Electrical problem, Please help....
- Aftermarket 4" air box?
- Clutch Question
- How to get enough spark
- hi flow oil pump?
- CCRM FRIED
- need some help with my truck, wont stay on
- Ticking noise from passenger side, please help!!!
- how do i install gears???
- pulling motor !!!!!!! help
- What Gears????
- Rear brake piston?
- Q on installing equal length shorties
- New Fan installed, Won't turn on.
- Bilstein BTS kit anyone?
- xenon
- Just a couple of questions I could use help with...
- New Lifters, are they worth it.
- For people with Ford Racing Springs
- Do manual seat tracks work on either side?
- MM K-member brace
- zero fuel pressure
- What Distributor Options do I have???
- Need opinions on engine problem.
- rear lca
- Just installed 4.10's
- 351 stroker guys
- Replacement Springs
- Coilover instability, any ideas on how to improved this setup? Diagram included =>
- just wondering
- nitrous advice
- deleting pass fender stuff
- Will I Make to the my Dyno Tune
- Guys with proken power seats... (How to MAYBE fix them)
- i know what i'm buying with my taxes....
- Estimated power with this setup?
- Seats installed. A few questions...
- Black or Chrome Bullitts? Poll!
- As you all know, my tires SU...CK. So some questions on tires ....
- Cobra R intake 87-93 fits on a 95 GT??
- I think my Temp Gauge is Wrong
- 18x10 rim & 315 tire on back of a 95 Cobra?
- Engine Start
- Mufflers ??
- Clutch Question.. everybody with a 5-speed
- Need help installing my seats ASAP.
- Difference between Ford B and C springs?
- rodent in engine bay. HELP
- What kind of grease for worm and odo. gear?
- Temp. Gauge
- What pound spring for rear suspension
- Foglight Fuse?
- Which Smog Delete Kit With Vortech?
- Code 118 but temp guage still works
- bowl porting?? gains
- Will she hold together with a Vortech
- Ok I though I knew how I was going to install me new seats...
- gt40 intake gt40p heads
- Never heard pinging so I tried something, check it out.
- Spark Blowout
- Benefits of an Intake Spacer...
- Wierd Ignition problem
- mass air meter question
- i want moreeeee =)
- fuel rail mounted guege?
- Installing CAI
- Modifying lifter for correct push rod length
- hesitation while cold...fine when warm?
- Fuel Pump Etc.
- HELP! Can't get fan motor off fan
- Body Tech
- hey guys got a small problem and some concerns
- Excel file REQUEST
- optima red part# ?
- Got my car Tuned & Dyno'ed, a few ???'s
- Anyone using an S&B filter on their E-Bay CAI for '94-95 Stang?
- gasket material ?
- Timing Chain on a 99 Expedition
- What PSI to run?
- Alright I know...lots of Questions but heres another ..which gears for 408?
- So how low do full length subframes hang?
- So i will feel the difference with subframes right?
- Long or Shortie Headers????
- LOOK WHAT I GOT TODAY *PICS*
- Installed ASP underdrive pullies today
- Anyone used Plastex?
- factory hood shut with tall decks and intake spacer?
- Ok so Im saving up for a nitrous kit. Have a few questions.
- car hesitates below 2000rpms...
- Help w/ ford's POS recall
- Side EXHaust MUFFLER HELP
- Anyone install a C&L 76mm TrueFlow MAF System on a basically stock '94/95?
- Clutch Question
- Tranny Process
- How should I go about this?
- Need wheel pics or photochop, i'm getting desperate!!
- anyone have pics of aftermarket hoods on their cars????
- Power steering relocation kit for going 302 to 351..where?
- Where to find Lazer Red paint?
- Need to find someone to port lower intake
- What Pizza Cutters would go with my car?
- BBK o/r H piped for long tubes question
- front end steering rack replacement
- If you use hood pins, do you need a hood latch?
- and the ups guy shows up again.....
- Does my car need a tune, Don and everybody else?
- Fox tubular k-member.
- 2nd opinion plz..this would work for testing brakes right?
- Need help with pulley sizes (347 w/s-trim)
- 94 Cobra with 15X3 Welds Help!!!
- Clutch and Flywheel
- strut tower bolts are stripped need to fix them how?
- New to GT40's...
- why no holleys?
- Will my Trick Flow 170cc intake runner 61cc chamber work well with 408ci?
- FOB keyless entry I cant find the right one will another work?
- Blue oval ind. control arms???
- daytime running light module ( again )
- Harmonic balancer questions
- Ford Sportsman Block?
- fog light question..
- 1/4 w/ the auto
- What gears and from where?
- Those using Tremec and D/S Spacer come in
- will i need a tune? (asked a lil different)
- Cam Questions
- filter question
- Another exhaust question
- Has anyone ever installed a rear main seal with any success (no leaks)?
- windsor jr / cam
- Would it be worth it?
- Does anyone know of a company near MD or PA that sells these hoods?
- Supercharger or Turbo???
- Overheating problems
- Look what I stole today!!!!
- qucik question
- How Can I Fix This?
- Kooks Header Guys Please Help!!
- Mach 460
- Is a canton oil pan req for 408 to fit our cars?
- Tune by Chip
- Attacking the powersteering
- Best intake for 95 5.0
- another 1/4 mile question
- stupid q's on intakes
- Reverting back to stock
- Suspension Kits
- lowering just the front?
- E303 Camheads in here.
- My car doesn't start, acts like a bad battery but I dont think it is.
- will this shifter work?
- Valve Cover Bolts
- King Cobra kit...do i need anything else?
- Roll bar and a few other questions
- Would a cobra 75mm stock MAF be beneficial to my GT?
- Anyone have SLP Loudmouth...which ones better?
- car stalls after longtubes install
- Procharger fitment with 351
- pro-m mass air meters
- check engine light (not a mustang)
- Those with 2000 cobra r brakes
- ABC Exclusive Saleen Hood problem
- What is the electronic box inside door? Remote Entry?
- Thottle body question?
- Suspension Problem
- Intake help!
- I live my life a 1/4 mile at a time...
- Super Charger Help?
- MAF location for turbo
- camshaft dowel length?
- I need help! I dont know what went wrong...
- TKO Woes, And I Don't Even Have One Yet
- need cold air intake advice/tips
- how much is my T5 worth?
- Comp XE274 with AFR 165s and stock bottom end?
- MSD 6A with iridium plugs?
- Looking for 325 rwhp. Help!!!
