PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. How much is to much for GT40 heads?
  2. 24's enough?
  3. Bad vibration at 80+ mph
  4. headgaskets for a 306
  5. Finally Another test Drive and BOOM
  6. Gingerman track day pics from OCt. 2006
  7. Possible distributor noise
  8. New Exhuast setup is done, almost!
  9. 245 mm tire on a 9 inch rim?
  10. 393 stroker in a 94 cobra
  11. Can you make INJ act smaller?
  12. Is this a bad install or just a cheap clutch?
  13. Is this a good brake upgrade deal?
  14. Is this a good brake deal?
  15. Installing fuel pressure gauge
  16. svo extender
  17. installing new headlights
  18. what do you think about these heads???
  19. Tensioner Pulley?
  20. cam headers....
  21. Questions on EGR Valve?
  22. Does anyone have WheelReplicas 17x10.5" ANTHRACITE Bullitts in stock?
  23. installing a tri-ax
  24. 95 cobra springs
  25. 94 Mustang starter problems
  26. Eliminating PCV System
  27. pushrod ?
  28. Battery keeps dieing! Help! - 95 GT -
  29. Multi-layer steel head gasket
  30. 4.6 swap
  31. Help!!......Please
  32. Funny exhaust
  33. all you TREMEC TR3550 guys:
  34. another AODE shuddering
  35. Eibach Sportlines?
  36. Question on o2 Sensors...
  37. Just a quick question on these things...
  38. Putting IAT in the MAF
  39. mach 460 wiring question....
  40. Oil out the dipstick!!!
  41. Forging my block
  42. I need suggestions on a complete exhaust setup
  43. 94 top speed
  44. Help me build my Suspension $1500
  45. Your Advice Appreciated!
  46. rear sway bar...needed
  47. Aluminum Flywheel
  48. Few Questions on this supercharger
  49. another side exit exhaust question??
  50. shifting issue
  51. What Clutch are you 650+rw guys Using?
  52. Check out my dyno graph and let me know what you think!
  53. Some drivetrain Ideas
  54. What's the diff between 5140 Machined Beam Rod and 4340 Ultra Light Weight I BeamRod?
  55. H/C/I fuel system upgrade
  56. Locks acting up
  57. Ignition again ???
  58. Clutch cable question
  59. Alternator taking a dump?
  60. which intake manifold from tfs????
  61. Quick CAI filter mount questions
  62. thinking about changing combo.. Help!
  63. Water Pump gasket
  64. So.. if I went kenne bell, how MUCH HP can I get with 10:1 compression?
  65. Bad Starter?
  66. recommended parts with sportline install?
  67. rearend help
  68. I need some help with what to do?
  69. Gutted the Cats Found another problem...
  70. What rods do I have
  71. Bypassing factory amp?
  72. I'm looking for intake flow comparison chart
  73. Camshaft Help...
  74. Stock head specs?
  75. Fitting Subs In My Convertible?
  76. transmission
  77. what color is this?
  78. New carpet and sound/ heat deadening?
  79. Tire Size for Bilstein BTS kit
  80. Battery relocated under back seat?
  81. I got my AFR 165cc installed and Dyno
  82. Underdrive Pulleys
  83. help me pick a tranny rebuild kit
  84. Fitment, FMS tall valve covers on 94/95 stangs
  85. Tranny Fluid?
  86. Does this sound right? alot of money for used TFS heads
  87. Cobra owners, did any of you have these floormats?
  88. New TPS Fixed my Hanging Idle!
  89. Wanting to paint door cups, how do i get that rubber crap off of them?
  90. Anyone Ever Done This?
  91. Water on passenger floor board, heater core maybe?
  92. No air filter on 1/4 mile run
  93. Quick window question...
  94. heads on a 94 please help
  95. Window Problems '94 vert
  96. I need a 12volt power source in door.
  97. Cobra brake kit
  98. HELP A NOOB OUT!!!real quick!!
  99. Good place to buy a shortblock from???
  100. 331 CHP Engine build-up What cam???
  101. exhuast clearance? copper pipe
  102. so...umm...BBK doesnt make a shorty o/r H?
  103. Raising up exhaust?
  104. Which is a better way to spend my money?
  105. T-56 Install
  106. Help me paint my car!!
  107. help
  108. Thoughts on this intake?
  109. Those of you with 14* timing and anyone who can help, get in here.
  110. exhaust leak??
  111. Do you need the dust shields on the spindle?
  112. Starter trouble
  113. Siemens Deka injectors
  114. Recomend me some brake rotors and pads
  115. From Suspension To Drivetrain
  116. Wow... I feel really dumb
  117. Thinkng about selling my 95 but how much?
  118. Anyonr know anything about hooker aerochamber mufflers?
  119. Reminder: No for sale/wanted threads in the forums and StangNet Terms of Service
  120. Anyone else heard about retarding the cam?
  121. Steeda Lowers
  122. Just not running right, help?
  123. Shake
  124. Opinions. Might buy this 95 GT (PICS)
  125. Weight of removable hard top!?!?!
  126. Stock heads
  127. Can someone help me out?
  128. Car is being slow as hell!!!! How to gut cats!!!
  129. Identify this motor by the heads?
  130. turbo???
  131. Throttle Body Size
  132. air bag light?
  133. Loosing steering fluid!!
  134. Just put in a new distributor but now I have no spark, any ideas?
  135. Horn not working, alternatives?
  136. Problem with used Cobra intake. Need advice
  137. Roll Bar Questions?? KillerCanary can you help?
  138. power steering help
  139. Dead Battery - 95 Mustang GT Charged then went dead - Help!
  140. Jacking front end
  141. ABS delete pics
  142. would 2005+ brakes fit?
  143. would 2005+ seats fit in our cars?
  144. Latest saga of neverending story (pics)
  145. combo question
  146. Need opinions! Checked out a '95 today. Was it a GTS??? (PICS)
  147. What to do with $2,000
  148. What should my 0-60 be?
  149. Surging idle: What worked for me
  150. no compression after lashing valves
  151. fuel pump relay
  152. ? on 95 GT 5-speed 351w swap
  153. Which rims go with my white car??
  154. Has anyone removed their ABS?
  155. Shelby wheels 4 our cars?
  156. finally starting to make progress again.....
  157. supercharger on an H/C/I setup?
  158. Alignment with a 2'' drop....
  159. 1TallMF, Hissin, Grady come in here please.
  160. Polishing upper intake
  161. 10/90 shocks?
  162. next mod
  163. AC LINE + HEADER = PROBLEMS
  164. Jet Hot Coat or Chrome my CAI
  165. 3:73's vs 4:10's.......documented
  166. AFR heads + cobra intake + stock cam = ?
  167. 460 in a SN95
  168. 209K now Knock Sound....
  169. Any one running Accufab Headers on a 95?
  170. best suspension setup for a street car?
  171. 95 cobra has what output shaft drive gear?
  172. Wideband O2
  173. driving without X brace any problems with verts?
  174. motor build block question
  175. JUST BOUGHT THE P'S!!!
  176. removing the EGR
  177. rocker arm
  178. Can i Drive Without a catback on my 95 Gt?
  179. what kinda RPM's
  180. gas mileage and offroad pipe
  181. WRAPPING STARTER?
  182. 90" is the short belt to bypass smog pump
  183. EGR tube replacement? BoLTs?
  184. headers for 94-95 cars
  185. Cheap speedo solution for 3.55:1 or larger
  186. what is extrude honing?
  187. Questions abouit Nittos...
  188. mac shorty headers on E7's or GT40's - fitment ok?
  189. Got a few questions!
  190. 2 breathers ok to run?
  191. Rear end was causing tranny noises
  192. WIRING HARNESS REPLACE
  193. another "it doesnt run" thread...
  194. Hows this setup sound?
  195. Hows this setup sound?
  196. help with install on 76mm c&l kit
  197. Signature required is your friend!!! Don't make my mistake!
  198. T56 Transmission
  199. Was it only 1994 Stangs that had the black trim on the rear bumpers?
  200. new belt screech on startup?
  201. on a budget!!!
  202. Quick tire question...
  203. Opinions on Catted Pro-Chamber?
  204. Installing rack limitors
  205. Help me choose an intake!
  206. Performer vs Performer RPM 1
  207. And another problem....
  208. Strut Tower Brace
  209. AODE, Transgo kit problem, anyone?
  210. Stock wiring harness
  211. Bore size for stock 302
  212. Is my ECU dead?
  213. center cap size for stock bullitt wheel?
  214. Can I use a fox MAF?
  215. TJ's Eaton M90 Build-Up Thread
  216. T5 swap question and fidanza flywheel question
  217. 2 quick questions
  218. lost my key fob
  219. Turbo 95 Dyno results
  220. More Fuel Pump Problems!
  221. fuel pump size to injector size
  222. 1.7 rocker question
  223. Quick... how many teeth on an AODE flex-plate?
  224. GT-40 vs worked E7's
  225. Will 3" tailpipes fit with 17X10.5 wheels and 315 series tires?
  226. Clutch quadrant
  227. what do you think of this camshaft???
  228. Long tubes and P heads
  229. Stock gauge needle question
  230. R & R Help Power Window Motor
  231. Stock H-pipe question
  232. 75mm TB overkill?
  233. rear brake bracket
  234. factory keyless entry install
  235. Just a quick radio Question, plz help...
  236. Smog pump, A/C removal question
  237. installing a c4 in m my 94 ????
  238. Bigger Crankshaft Pulley?
  239. In Car Camera Setup
  240. SPEEDODOMETER NOT WORKING ????
  241. TOB tips
  242. Remove oil cooler or not??
  243. Smoking, idle problems 94 5.0 Help!!!
  244. Starter a bit off...
  245. stock bolts for ebelbrock intake
  246. Need more bling. Which supplier carries these?
  247. Stock V/C's with 1.7 RR's
  248. eibach sportlines and exaust question
  249. Holley systemax II intake?
  250. Maximum Motorsport Cable Question.....too long?
