View Full Version : 94-95 Tech
- Want to know production numbers for my car.
- Getting Ready to Order Upper, Lower, and Throttle body. Help Me Out!
- Cobra R question
- Whistling from Front End
- alternator maybe?
- feels like i gained40hp!!!!
- what to use to clean maf sensor???
- I've got Problems
- Spec stage 1 or King cobra?
- Recomendations for full tune up.....????
- heads/cam/intake kit????
- I've got a slight "engine" vibration, any ideas?
- 1/4 Time Estimates?
- Bad Hose
- Electrical Problems
- Super-Rich Starting; But No Codes
- c&l maf...blackvert grady... maybe you can help?
- help.. cars still sluggish on take off...
- intake questions
- h/c/i set up??
- Dyno Results
- Got an alignement done with sotck "CC plates" after drop
- T-Bird supercharger on a 95 5.0. IS IT POSSIBLE??
- Cant see timing marks.
- got the fuse blues
- Can I just buy a new MAF housing?
- A/C Delete Questions
- Distributer install
- 87-93 5lb vortech fit in 95????
- Should I go bigger than 24lb injectors?
- Intake Manifold Instalation.... Need A List...
- how to tell if you have a bad injector....
- what do you think ill run?
- what's a good 26 spline clutch...
- t5 swap aod trans
- Ouch this looks bad......
- Overheating problem!
- need help finding info please help!
- 94/95 351 ... kooks headers?
- pass. side rear tire rubbing on inner liner
- what makes a t5 explone..ideas?
- 115k too high for vortech????
- Freakin 315s are rubbing
- 5 qts. of oil right?
- 90 MM LMAF
- HELP!!! Car completely and suddenly dies while driving!
- What psi for nitto drag radials
- Best Headers
- New o2 sensore = better gas milege?
- clutch cable problems
- i need a part please
- CEL flashed on a few times.
- Help w/HCI setup
- spark plug arcing
- E-brake light
- I need to see your rear end.
- 331 or 347
- Kaenen Performance
- C4 Swap
- headers vs. intake manifold
- Blown Rear End-What To Do? Please Help
- Opinion Wanted
- Wheel ?'s
- Trick flow H/C/I kit????
- Oil Pressure a bit low
- A9L
- Direct port DRY nitrous? Can it be done?
- FUSE Problem
- advanced timing??
- what gears?
- Ground/Short Problem?
- Pushrod length-afr165's and 1.6RR's
- stock times for a 95 gt
- Where To Find Cobra RR Hood
- Wideband Sensor Placement
- (IAT) intake air tempeture
- ive got a question , header install
- Noisy fuel injectors???
- Clutch Cable Going South?
- Help with belt bypass
- Looking For Aftermarket Forged Pistons
- Who here is running a supercharger with a stock block?
- Dropping the Fuel tank help!!!!
- Anyone looking for a all in 1 deal...
- putting in crankshaft,how is plastic gage used?
- WHAT THE!!!!!!!
- Replacing Rubber Seal Around Headlight.
- Where are the bolts that hold the overflow tank bracket in?
- whats the best performance chip for my car???
- Fuel system for 347 N/A
- powerpipe help asap
- Ignition timing problems
- spark @ coil wire but not @ sparkplug wire?
- Where is the harness (Distributor) For Timing?
- What do yall recommend(nitrous)?
- AODE slippage!
- high rpm bucking and smell gas! Help!
- Stroker kits? Sizes? I'm confused..
- FUll Turbo set up????????????
- tranny rebuilt cost?
- Upgrades?
- another timing question....
- New owner, Need more HP. (94 GT)
- what spark plugs do you guys use? whats the optimum gap?
- All You need to know about NOS KIT for 5.0L
- Does anyone elses e-brake "rattle?" Drives me nuts. Sounds like the spring..
- anyone have complaints or regrets about the QA1 k-member?
- difference in 94/95 and fox LT headers?
- Got any tips on relocating battery? (pics inside)
- my next project
- white smoke, not losing water
- Should I be afraid to hit the nitrous? I haven't tried it yet....
- Anyone have pics of installed UPR Caster Camber Plates
- Wanted: Traction at the track
- how to remove paint on exhaust tips?
- Help!! my mustang has a really ****ty idle, i dont have a clue what is wrong.
- What could this oil be from?
- Header questions??
- Normal Oil Loss????
- Shifter Vibrations
- bad injectors?
- What causes this symptom?
- Car Shaky At 100 MPH
- I bought 3923 spark plugs from amazon (1 plug cooler) but problem HELP!?
- anyone know size of TPS bolts? need to replace
- this thing could cool hell
- Best way to flush coolant
- Borla Catback Install
- Anyone Got A Replacement for the Rubber Intake ?
- Saggy sportlines...
- owners manuals
- Bear Decelarotors?
- whats the correct timing for 95 cobra?
- Need a few random Parts...Where to buy?
- Wow... will 315/35/17's fit on my vert???!
- I need to ditch the straight pipes.
- SuperCharger and Vaccum
- Bought a used CCRM
- Where can I get an odo gear?
- Help me make a plan to fix the lack of oil pressure....
- my car started on fire and i need some opinions
- Anyone Got Link To A Clutch Install Write Up???
- help backfiring....
- Rocker arm selection
- Wheels don't fit!!! Help
- Can I toss the Weight on Clutch fork 94 cobra
- 95 transmission help
- Need help fast!!
- SMOG TUBES GRR
- Question about box upper intake
- Runs great cold - hesitates and bogs when hot!! Help!!
- Any1 have pics of 94-98 w/ stock front and saleen skirts?
- Has my mechanic betrayed me?
- I NEED A LIST OF TOOLS THAT ARE NEEDED FOR CHANGING GEARS?
- Cooling systems questions
- Grind when letting clutch out after shift
- what sound would my car be making if my pushrods were a hair too short?
- t-bird water pump?
- Spark Plugs?
- Water Pump
- Car shut of while driving
- Intake for twisted wedge heads?
- Starting issues.
- Vacuum
- Help me build 347 !!!!!!!
- what the he--,I keep stompin on it,and it keeps running great
- powered by ford t shirt
- Pulley ?
- Idle issues (idles at 2000 rpms)
- Header question
- GEARS INSTALL COST?
- where can i find a fuel pressure regulator cheap?
- Help me diagnose this problem
- Misfire or AODE?
- Car dies at idle after hci swap
- "P" heads with oversized valves? worth it?
- pilot bearing Vs. bushing
- Fried A/C pully clutch
- DIY Underbody Refinishing
- GTR performance???
- any had this problem w/ an IAC....
- Is the MSD Blaster TFI Coil worth getting for my dry nitrous? Will it help?
- Mac Long Tubes
- lakewood traction action lift bars
- 3" wheel studs
- Hot Start Problem and More....
- NEED SERVICE MANUAL PAGES SCANNED!!
- Timing Issues
- Custom Gauge Cluster Set-up
- 94 Mustang GT Hesitation (I believe...)
- Oil in my Cold air intake tubing?
- Cooling issues.UGH!!!!!
- Common Issue with AODE cars?
- confused about speedcal
- 95riosnake - need info on cleaning up the underbody
- finding a pipe
- Question about the relationship of MPH, RPM, and HP/TQ
- Paint SUPPLIES...Links For Purchase?
- Spec stage 3 or FMS HD clutch
- 331 vs 347???
- What Springs do I have???
- Loud drivers side bank valves and rockers???????
- Gauge Pods_A-pillar or Instrument Cluster Bezel
- HELP PLEASE! 95 GT
- Question about heat soak...
- A Good Carb 351 Build For $3,000 Dollars
- Finaly its ALIVE!! :)
- Gettin some Tint on the windows what %?
- quick question..
- To build or not to build . . . that is the question.
- Looking for some nice engine kits
- newe and need help please
- bad computer maybe, possible bad ignition+
- Weird problem when cold out.
- What wire is the "output voltage lead" for the TPS? HELP!?
- Anyone know where to buy one of these
- turbo manifold/headers???
- 347 guys what kind of total timing are you running?
- Anyone here run a spool?
- 31 Spline diff questions
- Alum driveshaft.... for my 94 AODE?
- Side Exhaust Clearance
- 02 Sensor
- Need to tune up my '94
- Front end popping?
- Mounting of nitrous bottle?
- You think a new CCRM would fix my problems?
- Anyone have the dry nitrous set up? Any suggestions when installing?
- Loss of power - Tried troubleshooting, could use some sug.
- Creaking from the front end
- alarm broken?
- WTF!!! My car still drives like the front end is all loose!!!!
- General Exhaust ?'s
- can I use these LCA's?
- Oil dripping from breather
- Finally, some answers to the H vs ProChamber questions.
- Explorer Motor
- cam install
- cam install
- Gt40/ Gt40-p Head install???
- 450 rwhp from a 408w - what injectors?
- Help Car Is A Paperweight!!!!!!!!!!!
- don't anyone make 351w long tubes?
- dumb question
- dumb question
- are roller rockers loud?
- A/C pump pulley cover
