View Full Version : 94-95 Tech
- Opinions on first mods
- After sitting a good while....
- Overheating and measuring
- Alright! Fired up the 347 tonight!!!
- Disconnect vert top cylinders?
- Supercharging a Custom n/a Cam?
- Question about cel codes pulled??
- blew up the t5, opions needed
- Hole in the firewall on the passenger side?
- ? on T-stat
- Largest tire that can fit on the stock waffles?
- Lets Talk Intake Pipe & Air Flow
- alum D/S install Q
- rear bumper cover....
- Seat track swap question
- Good Setup
- Where to connect boost/vaccum hose on intake or somewhere before TB
- CEL on after Sprraying
- HARD shaking
- Switches?
- 3.90 gears...I have a vibration in the driveline..remove dog bone?
- throttle body and maf upgrade?
- Picking up a 95 gt today
- Help with cobra 347
- Which throw out bearing to get?
- Let the Mods BEGIN!!
- '95 Stang overheating
- 5 spd swap
- toasted my cluutch
- cracked Intake?
- hpm megabite jr's and torque boxes
- SS lines for 95 GT work with cobra calipers?
- Those who have done A-arms or an aftermarket K, help
- 94-95 Jegs Exhaust
- Paint Shop VS. SEM paint :: Rollbar
- Build Up
- Manual transmision to automatic swap info needed
- How do you remove old window tint from the back glass with defroster???
- cneter caps
- so, this is weird
- Are these headlights crap?
- What is this?! (pics)
- Going Carb....Good or NO GOOD????/plus others
- WHO MAKES THE BEST "SPEED CAL"?
- TRANSMISSION!!! NO!!!!!
- first start troubles...PLEASE HELP!
- Worried!!!!
- Professional Products 75 mm TB..is there any way to make the throttle push easier?
- Who has got twin turbo’s or knows a lot about them
- Weird Vibration
- #M2320c calipers which banjo bolts?
- HUGE problems in Cobra Land! F***, my new engine!
- Quick question about something on the stock exhaust.
- sn95 fox body transplant?
- Speedometer needle is trippin.
- POS Car!!!!!!!
- Trick Flow Stage 2 cam?
- GT40 intake vs cobra intake?
- big problem removing computer! AODE to T5 swap guys...
- fuel pressure gauge
- Intake options with tweecer?
- need help
- Accu 75 added...spooky looking plugs !!!
- Fox vs sn95 KB snout differences?
- Max tire size on stock 16'' wheel
- Cam Question... "F" vs "E" cam
- which gears?? kinda long
- Remember my video when i break tranny , here is rematch against that 69 Camaro
- surging idle problem
- Do I even need C/C plates?
- So help me come up with a 393 combo then
- Audio geeks
- Can any 10lb bottle be hooked up to any system? Like nos to zex?
- so....one more question guys
- hmmm....problems, help please..tad long
- Wheel Studs
- How long does a 10lb bottle of nitrous last?
- Pulled Two Codes
- will bad iac pull cel? please help
- Bolt size? Cat back to mid pipe
- Finally tuned 262hp rwhp
- Car is getting alittle hot.
- Indy Mustang
- AHHHHHH SUSPENSION HELP PLEASE CANT CHOOSE A SETUP
- Still leaking oil...
- DSS or CHP?
- Got my new head lights. Any trick to installing these?
- May have ran some water through my engine
- whats a good wide band o2 with tweecer?
- nitrous ? injectors
- Took my 347 Cobra to the track
- Please help with recharging AC (I have searched)
- Need help with Injectors?
- Rear End?
- 94-95 Cobra mass air
- 94 GT 'vert rear window ?
- Throttle body spring ?
- 351w question
- valve job questions
- how to find the production number of a cobra
- 393w hp estimates?
- Question about my theory on timing chains & pinging
- Left turn signal not always working
- Help Please
- Will a 95 Cobra MAF work on a fox?
- California SMOG test time!!
- Cam, Rockers, or what? (more power/bang for the buck)
- Coolant Leak?
- High-quality fog light retrofit?
- lift bar fitment ques?
- A/C Compresssor
- Had a code pulled
- Quick q on adjusting my idle.
- mass air flow
- NEW CAM???
- Cast Iron GT40 heads
- Will the Cobra STB clear the RPMII intake?
- Found my stumbling problem, now I need to fix it.
- Headlight Sealant/Adhesive
- strut mount help
- those wit eldebrock rpm or vic jr heads
- clutch pedal *pop* i hear/feel
- Where does this vac line go?
- Cam queston?
- Best price on Taylor sparkplug wires?
- Need help with power windows (again)
- 275/40 on a 8" wheel?
- Tomorrow Is Dyno Tune Day!
- how much can I get for my shortblock?
- Flat Tappet Cam
- 351 Heads?!
- At what PSI are you rolling ?
- Car makes noise when I am stationary and turning the wheel.
- My low budget Engine Combo...
- How To : Install Ignition Switch
- how about $695 for this block?
- didnt get a reply in 5.0 tech maybe u all can help!!
- Car idles high- 2k+rpm- pulled some codes
- Draw.......wth
- Mass Air Meter ?s
- please help! clutch problems
- what gears in my 94 GT
- CAR STarts then Dies...What's up?
- What should this car run in the 1/4th
- stock H-pipe to catback ???
- the cobra mach stereo system....
- Anyone have a Cranecams HI-6?`
- A9L swap completed. Need help with fan wiring and sluggish feel.
- I am so pissed I am about to be through with this
- I think the guy balanced my engine with the wrong flywheel!
- 255 intank enough for 550whp?
- What size gears?
- Hot idle problems... (searched)
- Question about surge on Highway
- Cams that will pass the smog...
- relocated battery need help!
- progress
- MSD Blaster Coil v.s Screamin Demon?
- temp sensor bad?
- any chromed out engines?
- Belt Help, PLEASE
- power seat track swap wiring
- Fuel rail fittings
- Just installed 86-93 AFM power pipe on my 95
- Please help, overheating problems
- Aftermarket Amp Install ?'s
- 95 stang door locks
- UPR DS safty loop users
- Engine stalling sometimes?
- some MAF questions
- MY IDLE IS DRIVING ME F****N CRAZY!!!
- First visit to the track, check out my times and give input.
- Zex Help?
- PORTING GT-40X heads
- Drilled that sucker
- will an NX bottle work with a Zex kit?
- Pinging problems, and some more questions.
- 95 3.8 to 5.0 Swap
- 95 Cobra help?
- AODE to T5 question
- cobra computer
- Shorties on when dropping in 347?
- found an exhaust.....
- Romac balancer spun? Can't be...?
- which suspension/chassis upgrade next?
- How do you flush power steering fluid? Changing rack...any tips???
- Installed Fluidyne radiator ,temp is down , pics here
- Will GT40 Manifolds With Egr Spacer Built in fit??
- A/C finally works, now my car heats up.
- emissions??
- a/f gauge, bad o2's??
- '87-'93 vortech s-trim?
- cobra caliper brackets can be bought where?
- LOW OIL light! Help
- 393 stroker guys - post your combos please
- AODE / "Jerry Mod" questions.
- stock fuel lines?
- Install tips for Upr boostmaster pipe for Vortech?
- AIRBAG CODE 52???
- Tell me about Ignition systems
- Broken Power Windows
- 15 inch rim
- o/r pipe = poor gas milage
- Foglight and instrument woes
- Electrical trouble shooting ???
- Factory CD player.... Guage Pod?
- which professional products balancer?
- Stock Head Porting question
- Got My Pig Dyno Tuned Yesterday! Very Happy!
- PROBLEMS FINALLY FIXED!!!!!!!!!!
- Intermittent Won't Start, Does this sound right??
- Hopefullynot a dumb ques.. Fuel pressure and nitrous ..
- Odometer Cable
- Laval Motor Center
- how to put on a spacer....
- Dynotune results (slip inside)
- Who is runing 26x10.5x15 ET Street's please post here
- Air Fuel gauge install
- TFS Track Heat VS Cobra intake , dyno #s and video are here
- I fixed my car!!!!
- wire hiding experts in here!
- Electrical probs. I hate those...
- anyone have a custom cam and stock computer?
- AFR 185's vs edelbrock 2.02/1.60 heads
- come talk me out of getting 4.30 gears(or in)
- 1.7rr question
- Oil for 347? 20w-50?
- Where is the radiator fan control relay?
- One wheel peel
- clutch cable snapped
- 17s front, 18s rear?
- Just bought a 95 GT Problems Already...
- 393W for $2199 ... damn
- Zex users help with install!!!
- Upgrading rear end?
- Simple nitrous question
- 95 mustang gts rear end question
- when idling at red light rpm goes from....
- Welder claims he can't weld rollbar ??? fumes too bad?
- where can I find a cheap radiator?
- wiring new tach in 95 gt please help
- Hoses for oil cooler
- autometer tach in 95 mustang gt (help me)
- 95 stang converted to carb help
- best way to spend the money
- speedo gear stripped again! this one only lasted a week!
- Bullseye Power Module
- Fixed my stall problem.....I hope
- Band Clamps with Magnaflow cat-back
- Help me make my car shiney again.
