View Full Version : 94-95 Tech
- cam shaft end play problem. Please help
- 347 stroker ppl come in...
- weight reduction Help!
- Largest rear tire on a 17x9
- car up and running, but bad missing
- Side Emblems
- PLEASE GOD HELP!!! CRACKED HEAD!?!?!?!?!?!
- Question about checking piston to valve clearance
- Pulleys and 3.73 Gears in...
- Are all 302 Crankshafts the same?
- Any experts know if I cant run the Crane HI6s with a 10:1 compression?
- Help me if you can this sucks
- My '94 GT's rear tail lights don't turn on
- car wont shut off
- Need help...
- Just got done with AODE to t5 swap and trouble
- does your car pull on uneven roads?
- anybody wire an illuminated switch to replace the spout connector
- Coolant Leaking form Water Pump ?
- engine been sitting on stand for 2 years - will it run?
- why cant i adjust my tps?
- Looking for good numbers
- MM C/C Plate Question
- Cooling Issue
- Whats the size and thread pitch for O2 and IAT sensor?
- Stud rockers and 94-95 Cobra Valve Covers
- anyone have a stock bottom with afr 185's?
- What to lube new A-arms with?
- Cobra oil diverter gasket/seal?!?!
- strut tower brace
- Fix Suspension - can i do it at home?
- '94/'95 5.0 CAI options. Which system are u runnin?
- Car Shakes like Crazy!
- overheating and exhaust
- Just got done W/ T-5 conversion.. need help please!!!!!!!!!!
- Bad Gas Mileage!!!!!!!
- Got the CEL Codes
- Oilpressure AutoMeter Phantom doesn't work right ,anyone know how to troubleshooting
- So what do you guys think about these mufflers?
- Tuner suggestions
- I'm runnin 15w40 rottella and its sweet
- Cobra MC Install Question
- How long is a brake booster good for?
- CC Plate Install
- which wire for air fuel gauge??
- '94/'95 tail lights. about to paint mine???
- h/c/i combo opinions wanted
- How to remove IAT sensor?
- Rear end Gears
- Alternator Positive terminal burning, car running on battery problem.
- Fuel leaking from tank...ugh...HELP PLZ!!
- steeda x2 balljoints : leaving spacers out will lower car?
- Electrical help
- Help me with my idle problems...please!
- how do i hook up my boost controller with a TT
- 255/40/17....sidewall too small thin??????
- Which pulley kit did u install on ur 94/95 5.0? BBK or March?
- a/c fixed, now car stalls a lot
- Differnces in Crown Vic and Mustang block?
- is this intake ported?
- Advice on racing with Drag Radials
- Is this possible?
- Quick Ball Joint Question
- Another injector thread...
- Which headers do I go with?
- Need a set of stock bare heads in west palm beach to borrow
- re-wiring headlights
- Over Heating...Need advise
- Which one is my low pressure switch?
- Track heat upper plenum
- 7 tooth speedo gear drive
- Need some help identifying these codes...VIDEO ATTACHED!
- Does MSD make a difference????
- need some advice
- 94 Gt vert supercharged opinions.
- My Heads/Cam/Intake swap: pics and progress
- Max timing with the spout out with a churbocharger
- Compressor seized
- Got the engine... :)
- Those with 1 piece headlights with Halo rings...
- Stalling problem, used search engine
- header help
- T5 Problems
- exhaust leak or something else?
- What does pinging sound like exactly?
- Lacking power and misfiring
- Valvetrain geometry setup problems and questions
- reparing a tear in leather
- Is 14* initial timing too aggressive for the 94-95 5.0 HO?
- which head is best
- Tach Wires
- anyone have a spare EGR tube?
- oh ****, cracked intake manifold help! (pics)
- How much for a clutch on a 95 GT?
- horsepower estimate
- water pump pulley removal yes I searched
- putting my backseat back in
- 427 Too big for KB?
- Transmission upgrade
- Should I take my u/d pulleys off?
- ccrm problem?
- need help!!!! broken lower intake bolt
- Very strange problems...Tune related?...Video inside
- Beginner Questions
- Whats a good clutch?
- how much to install intake manifold
- Spring suggestions
- I need the steeda #19 card; RIO?
- Exhaust
- Oil gauge is going crazy
- moved the battery to the trunk, making room for the turbo
- new engine
- made some more progress the last couple days.....
- backwards speedo
- 2005 mustang rims on a 95?
- cobra RR hood cowl GAP by back weatherstripping
- help with trunk swap
- Dyno Tune with New Motor
- Bogging, so I pulled codes. Take a Look.
- stock gt pcm to cobra pcm?
- what times?
- 98 Cobra o2s on my car.
- Blueovalindustries clear light set
- brake upgrade
- those with DSS shortblock! come on in!
- Opinion on Anti Roll Bars
- so i feel like a dummy........
- where do I put the A/C compressor/ PS pump
- hmmm....ideas, anyone?
- 94 GT, Dashboard Gauges Out
- I'm needing another ecu..
- Q? About Motor Mounts
- No Spark 95 GTS
- Is there any way we can "adjust" our e-brake?
- stroker shortblock
- Distributor help
- x303 5.0
- x303 5.0
- A/C Service Ports Leaking
- SERPENTINE BELT measured by CANS?
- EGR delete, what size are the bolts?
- Vert Rollbar Mounting Points ??? - pics or description
- msd box location
- 3.55 gears and white speedo gear????
- BIG ****ING PROBLEM, NEED HELP NOW!!!!
- Blew two alternators, what's the problem????
- H/C/I + SCT Tune = Dyno Sheet Inside!! How do the numbers look?
- What Transmission?
- Removal of Front seat headrests
- CAM TOO BIG FOR STREET?????
- need help with headlight installation
- Alright so my dad beefed up his Z28 vert LT1 with 4.10's..is he gonna beat me?
- New Cats
- got trouble codes with upgrades
- Will I die if I do this?
- Which Cam Dowel?
- WTF Son! AC compressor- how to move it?
- Friends giving me a $5k paint job but need help choosing paint... House of Kolors?
- Where To Buy?
- power windows
- Spring/drag launch questions..
- 87-93 5.0 valve cover questions
- Replacement Starter, Reman or New?
- How much should I retard my TIMING?
- Need some opinions guys.
- would this cut power?
- windsor jr or sr head users, need help with valvetrain
- Need some GOOD plug wires
- Help please
- looking for a set of SAFE wheel spacers?
- trade my 24#'s
- ROLLCAGE
- Mustang's getting new paint, What are some good looking Blue metallic paints?
- weird noise from shifter...
- WTF i cant get my seats out! help !
- Spring confusion
- opinions needed on black bullet 17x9 DD wheels...
- balancer removal/install
- A/F Ratio Monitoring, How To Do So
- aftermarket hood alignment
- What are the biggest Wheels/Tires I can put on my 95 GT
- trouble starting 95 gt
- difference between steeda and ford racing ques.
- car running too hot
- HELP, starter does not start. Where to start looking?
- Lightest 17x9 wheel <$200?
- quick clutch question
- engine is done what do u think it is good for?
- 94-95 Cobra 500hp help
- Serious 1/4 milers......here's a question
- AODE........1st to 2nd shift????????????
- WTF is this ?
- need help/ electrical question/ short circuit/ brake problem/I REALLY HATE MY CAR!!
- dash questions
- sn-95 brake lines
- STROKE IT OR NOT????
- Rockers and Valve Covers???
- Rough Idle and Stall problem
- What spark plug gap?
- SWITCHING TO 24'S
- HOW TO GET AROUND WEAK ECU???
- Rough idle, intermittent missing
- Photoshop project - wheels!
- what EXACTLY happens with blow by?
- loud popping???
- strange window problem...
- A/C gets hot when accelerating.
- need help bad
- Code 511, 189, 111
- Need help now! header bolt removal Q
- how hot do you get with the A/C on???
- 94 Cobra puttin +500rwhp?
- will stock maf work with cold air
- Speeometer Issues
- Removing IAC?
- oil drain plug stuck
- for those with ford racing valve covers.
- New to A/C Work
- adjustable clutch quadrant
- Cranks and cranks but no fire
- 94 cobra fuse panel
- AODE to T5 swap has anyone done it
- Timing Screwed up...Need Help!!!
- Wheel weights...
- New Oil Pan problems......HELP
- Random stalls, almost fuxed my rim!!!!
- Fuel Pressure Question, Regulator Operation
- AC pulls to much power
- new motor
- dang! stock and still sucking oil thru the pcv!
- Oil leak: valve cover gasget, questions *DUW*
- OH **** Water mixed with oil in the intake
- valve springs ?
- fuel line removal
- Which Torque Conv
- Headers Walkthrough
- electrical problems!! please help
- Summit now offers TB's for our cars...
- TWINTURBO SETUP! i need opinons
- Oil Pressure gauge question
- picture of firing order?
- missing when hot
- Exhaust leaks do matter
- Dyno Tune Tomorrow Need advice
- Jensen Amplifier Question.
- Questions about my transmission swap?
- Porting Lower in Progress....
- Running Tokico's & MM's? Get in here!
