PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Headers Walkthrough
  2. electrical problems!! please help
  3. Summit now offers TB's for our cars...
  4. TWINTURBO SETUP! i need opinons
  5. Oil Pressure gauge question
  6. picture of firing order?
  7. missing when hot
  8. Exhaust leaks do matter
  9. Dyno Tune Tomorrow Need advice
  10. Jensen Amplifier Question.
  11. Questions about my transmission swap?
  12. Porting Lower in Progress....
  13. Running Tokico's & MM's? Get in here!
  14. Cooling Problem HELP
  15. WAY Down on Power... I Hate my Car
  16. Where to buy motor mounts?
  17. Switching back to 180* T-Stat?
  18. Draw Through v.s Blow Through?
  19. lifter type need replies soon!
  20. Guys with PA Racing K-Memebers in here!!
  21. 94 cobra premium sound
  22. GRRRRRRRRR Cracked Head....
  23. Doing some work on the stang, but I need some advice.
  24. AODE controller options
  25. ITS BLOW TIME! NEED HELP
  26. Hp guessing time!
  27. What would you do H/C/I or Vortech.
  28. relocated battery to the trunk....completed
  29. 95 Engine Swap
  30. Fuse#18 20Amp
  31. Harmonic balancer problem
  32. Need help posting pics??
  33. whining noise
  34. A pic of me at the track
  35. What is this vacuum line for and ground strap
  36. What can cause bucking below 2k rpm?
  37. Innovative LM-1: digital air fuel meter w/rpm converter
  38. 94 gt headers
  39. mufflers vs. resonators
  40. Zex wet kit
  41. What's your gas mileage??
  42. I think I know whay my car was running hot.
  43. If you are are installing an aftermarket water temp gauge...
  44. 5.0 from 88 GT?
  45. Tach wiring...?
  46. tfs high port heads?
  47. Wheels
  48. blackvert's n/a buildup thread
  49. overheating problems
  50. Searched speedo.Mines electric. Help
  51. H/C/I what to do?
  52. How to start own car site w/pictures...Need help
  53. squeak
  54. air compressor ?'s
  55. urgent alarm wiring problem!
  56. Intake Problems
  57. Fox catback fit 94?
  58. Lets play "Name the Part"
  59. What is the normal operating temperature and oil pressure?
  60. Need help w/ wiring for electric water pump
  61. BBK SSI
  62. Burning off oil after heads were at machine shop, need some help
  63. how do i build a 347ci shortblock?
  64. new parking brake cables
  65. pro products typhoon intakes, yes or no?
  66. new car parts!
  67. porting stock upper?
  68. speedometer and odometer not working
  69. next level
  70. A/C not working
  71. AODE to T-5 missing part question
  72. DISTRIBUTOR POSITION
  73. Power Window issue (not the bushings)
  74. UNTIMEABLE TIMING
  75. n20 times
  76. header bolts are kicking my a$$
  77. Weird problem when trying to lock out timing (spout out)
  78. does anyone know if they make a plain rear bumper cover to fit a 95 cobra
  79. Where to get a nice aode?
  80. lets see what you guys think *HELP*
  81. Loosing power @ WOT above 3000 - need help
  82. Odometer
  83. hood weight?
  84. LOUD horn
  85. Advantages and disadvantages of pushrod, modular, and aftermarket blocks...DISCUSS
  86. What would you do with this 351 shortblock I have? DISCUSS!
  87. does anyone know if they make a plain rear bumper cover to fit a 95 cobra
  88. what size intercooler
  89. What size torx head do I need to get my grill emblem out?
  90. aftermarket body parts
  91. How much E.T can you gain from driving?
  92. For those of you who havent seen the new Fast and Furious.
  93. Gas Tank Straps RUSTED
  94. Any clearance issues on tailpipes with a Flowmaster catback and Eibach Pro springs?
  95. Will a foxbody phenolic spacer fit on a 95?
  96. How good is the stock catback? MAC LT w/ o/r x-pipe owners enter!!!
  97. How good is the stock catback? MAC LT w/ o/r x-pipe owners enter!!!
  98. GT40 P's
  99. Code Puller
  100. car will not idle down
  101. PRICE MY CAR PLEASE!!!!
  102. Supercharger install
  103. Starting Question
  104. Dumb Wiper Blade Question
  105. Water pump noisy?
  106. Torque converter
  107. anderson valve cover
  108. need tranny, which ones will work
  109. should i do heads/cam/exhaust myself?
  110. My car got broke into.
  111. for those who have an A-Pillar gauge holder....
  112. Quick Question about Fuel Inj/MAF/New Setup
  113. Need hose type / size for smog connection
  114. What are the differences in a T5 (V8 vs V6)?
  115. Testing O2s
  116. crossmember question
  117. 95's have wheel speed sensor's
  118. Body work progress...PICS!
  119. very hot temps,slightly different from others
  120. (pics inside)Found 2 cracks on my block, will these affect anything?
  121. about TPS voltage..
  122. Car runs hot, dont know why.
  123. just curious about race gas smell
  124. High Spd Fan supposed to come on with A/C Max?
  125. turbo questions...
  126. Is it possible to paint my cobra r's?
  127. AODE Question
  128. mlps
  129. Lightning 90mm MAF and Cold Air for 94/95 5.0
  130. Clutch Saftey Switch?
  131. weld wheels
  132. the darn white smoke
  133. idle is rock solid again
  134. Car is back (info about problems)
  135. code 632 and 639
  136. ABS Question quick
  137. What Cam/Intake.....
  138. Tach jumping, engine missing, me pist
  139. what cam would be best.
  140. who makes good quality hoods?
  141. Car won't crank...acting strange
  142. how to clean MAF & other ant other suggestions
  143. Gear Questins
  144. Parts list to prep/paint my car....what am I missing?
  145. intake help
  146. Whats this?
  147. what cold air fits?
  148. header question???
  149. Will 315/35/17's fit???? L@@K
  150. rear axle trouble????
  151. List of Suspension Upgrades and Your Opinions
  152. MANUAL TRANNY HARNESS....
  153. Brake Lines and Bleeding
  154. ECT possibly faulty
  155. Clutch not adjusted = cruise control problems
  156. smog pump eliminator?
  157. Torque converter questions
  158. Strut Tower Brace
  159. Weird power seat problem
  160. Sumitomo HTR tires
  161. HELP! Power seat, can't drive car
  162. 94-95 Car with Fox intake - options for blower
  163. ROH wheels on 94-98s. Anyone have pics????
  164. 95 mustang frictien noise
  165. Horrible Misfire
  166. Where is the engine ground strap located???
  167. Cam Question
  168. Anyone know the stock fan cfm output?
  169. Dual Valve Cover Breathers?? How did you do it??
  170. Well, back from the dyno.
  171. 90mm Lightning Maf price?
  172. What does your computer look like???
  173. going back to n/a
  174. going back to n/a
  175. Is Big Block power worth it?
  176. Need help with some codes....gurus help
  177. Oil Pressure Gauge Install ?'ss
  178. where to buy 0 2 sensor??
  179. orifice tube??
  180. Do they make a colder plug than autolite 103's?
  181. Getting ready to prep (stprolla and others come on in)
  182. Vert owners rear window problem
  183. Need help removing wiper cowl
  184. what size water pump bolt
  185. 2 questions
  186. No Spark During Hot Restart
  187. 95 idles is very low and rough?????
  188. Need Good Some Advice - Cam/Thumper Heads
  189. chome rims flaking
  190. Need pics of clutch cable
  191. Help! In need of a radiator!!!
  192. Blown head gasket - I think. Questions inside
  193. Wierd Problem
  194. IS there a way to view air intake temps?
  195. Where can I find this electrical connector? (Fuel Pump)(PICS)
  196. size threads on the oil pressure switch
  197. 95 GT to Cobra brake swap experts, come in
  198. Kenne Bell Installed + dyno results
  199. what springs are these
  200. Ill be installing a water temp and oil pressure gauge next weekend.
  201. Header help please...
  202. Hit a frickin bird- need a new coolant overflow tank
  203. thinking about going n/a again
  204. Subtle popping noise after changing the struts
  205. why does hot, humid weather kill my car?
  206. werid tranny noise
  207. ditch the quad shocks or keep em with new LCA's
  208. Water in floor when I turn the vent on!
  209. I need a new CCRM
  210. I need a new CCRM :bang:
  211. Edge Stall or tweecer R/T
  212. Lowering springs just installed, got a question....
  213. coated shorty headers
  214. Stupid: Went to put brakes back on, need help asap!
  215. new plugs: +1 or +2 ranges cooler?
  216. What radiator to get for my 94
  217. is porting the factory intake worth it?
  218. FMS 30# injectors vs Accel 36# injectors
  219. create motor vs rebuild
  220. 354 start up,Bad injector???
  221. car is running like crap
  222. can a chip fry the ecu?
  223. Oil seperater... what side of t-fitting?
  224. Good Looking Emblems?
  225. Auto Shifter Console = Manual Shifter Console??
  226. Stalling & No-Restart
  227. Fuel Injectors...
  228. 351 build up
  229. trickflow R intake
  230. what are my shift points?
  231. twEECer and Emissions?
  232. Parts List Question
  233. Where is a good place to mount a shiftlight
  234. questions about Canton pan
  235. Is there really a 'better' set of wires for our cars?
  236. Need Radiator Help QUICK!
  237. Intake help to 75mm accufab
  238. fuel leaking out of my regulator
  239. getting a 1/4 In. Air Compressor Filter how do I...
  240. Clutch Issues with Stock T5. I need suggestions!
  241. Looking for a show in Los Angeles/Orange county California is HARD!!!!
  242. Question about plug on tranny
  243. 12#'s Too Much?
  244. missing and backfire
  245. can you upgrade your A/C?
  246. Could an Oil Seperator Increase Oil PSI???
  247. crane optical distributor?
  248. Thinking about selling the car! LONG!
  249. solid roller cam?
  250. Vibration when braking, alingnment?
