PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. GT40 P's
  2. Code Puller
  3. car will not idle down
  4. PRICE MY CAR PLEASE!!!!
  5. Supercharger install
  6. Starting Question
  7. Dumb Wiper Blade Question
  8. Water pump noisy?
  9. Torque converter
  10. anderson valve cover
  11. need tranny, which ones will work
  12. should i do heads/cam/exhaust myself?
  13. My car got broke into.
  14. for those who have an A-Pillar gauge holder....
  15. Quick Question about Fuel Inj/MAF/New Setup
  16. Need hose type / size for smog connection
  17. What are the differences in a T5 (V8 vs V6)?
  18. Testing O2s
  19. crossmember question
  20. 95's have wheel speed sensor's
  21. Body work progress...PICS!
  22. very hot temps,slightly different from others
  23. (pics inside)Found 2 cracks on my block, will these affect anything?
  24. about TPS voltage..
  25. Car runs hot, dont know why.
  26. just curious about race gas smell
  27. High Spd Fan supposed to come on with A/C Max?
  28. turbo questions...
  29. Is it possible to paint my cobra r's?
  30. AODE Question
  31. mlps
  32. Lightning 90mm MAF and Cold Air for 94/95 5.0
  33. Clutch Saftey Switch?
  34. weld wheels
  35. the darn white smoke
  36. idle is rock solid again
  37. Car is back (info about problems)
  38. code 632 and 639
  39. ABS Question quick
  40. What Cam/Intake.....
  41. Tach jumping, engine missing, me pist
  42. what cam would be best.
  43. who makes good quality hoods?
  44. Car won't crank...acting strange
  45. how to clean MAF & other ant other suggestions
  46. Gear Questins
  47. Parts list to prep/paint my car....what am I missing?
  48. intake help
  49. Whats this?
  50. what cold air fits?
  51. header question???
  52. Will 315/35/17's fit???? L@@K
  53. rear axle trouble????
  54. List of Suspension Upgrades and Your Opinions
  55. MANUAL TRANNY HARNESS....
  56. Brake Lines and Bleeding
  57. ECT possibly faulty
  58. Clutch not adjusted = cruise control problems
  59. smog pump eliminator?
  60. Torque converter questions
  61. Strut Tower Brace
  62. Weird power seat problem
  63. Sumitomo HTR tires
  64. HELP! Power seat, can't drive car
  65. 94-95 Car with Fox intake - options for blower
  66. ROH wheels on 94-98s. Anyone have pics????
  67. 95 mustang frictien noise
  68. Horrible Misfire
  69. Where is the engine ground strap located???
  70. Cam Question
  71. Anyone know the stock fan cfm output?
  72. Dual Valve Cover Breathers?? How did you do it??
  73. Well, back from the dyno.
  74. 90mm Lightning Maf price?
  75. What does your computer look like???
  76. going back to n/a
  77. going back to n/a
  78. Is Big Block power worth it?
  79. Need help with some codes....gurus help
  80. Oil Pressure Gauge Install ?'ss
  81. where to buy 0 2 sensor??
  82. orifice tube??
  83. Do they make a colder plug than autolite 103's?
  84. Getting ready to prep (stprolla and others come on in)
  85. Vert owners rear window problem
  86. Need help removing wiper cowl
  87. what size water pump bolt
  88. 2 questions
  89. No Spark During Hot Restart
  90. 95 idles is very low and rough?????
  91. Need Good Some Advice - Cam/Thumper Heads
  92. chome rims flaking
  93. Need pics of clutch cable
  94. Help! In need of a radiator!!!
  95. Blown head gasket - I think. Questions inside
  96. Wierd Problem
  97. IS there a way to view air intake temps?
  98. Where can I find this electrical connector? (Fuel Pump)(PICS)
  99. size threads on the oil pressure switch
  100. 95 GT to Cobra brake swap experts, come in
  101. Kenne Bell Installed + dyno results
  102. what springs are these
  103. Ill be installing a water temp and oil pressure gauge next weekend.
  104. Header help please...
  105. Hit a frickin bird- need a new coolant overflow tank
  106. thinking about going n/a again
  107. Subtle popping noise after changing the struts
  108. why does hot, humid weather kill my car?
  109. werid tranny noise
  110. ditch the quad shocks or keep em with new LCA's
  111. Water in floor when I turn the vent on!
  112. I need a new CCRM
  113. I need a new CCRM :bang:
  114. Edge Stall or tweecer R/T
  115. Lowering springs just installed, got a question....
  116. coated shorty headers
  117. Stupid: Went to put brakes back on, need help asap!
  118. new plugs: +1 or +2 ranges cooler?
  119. What radiator to get for my 94
  120. is porting the factory intake worth it?
  121. FMS 30# injectors vs Accel 36# injectors
  122. create motor vs rebuild
  123. 354 start up,Bad injector???
  124. car is running like crap
  125. can a chip fry the ecu?
  126. Oil seperater... what side of t-fitting?
  127. Good Looking Emblems?
  128. Auto Shifter Console = Manual Shifter Console??
  129. Stalling & No-Restart
  130. Fuel Injectors...
  131. 351 build up
  132. trickflow R intake
  133. what are my shift points?
  134. twEECer and Emissions?
  135. Parts List Question
  136. Where is a good place to mount a shiftlight
  137. questions about Canton pan
  138. Is there really a 'better' set of wires for our cars?
  139. Need Radiator Help QUICK!
  140. Intake help to 75mm accufab
  141. fuel leaking out of my regulator
  142. getting a 1/4 In. Air Compressor Filter how do I...
  143. Clutch Issues with Stock T5. I need suggestions!
  144. Looking for a show in Los Angeles/Orange county California is HARD!!!!
  145. Question about plug on tranny
  146. 12#'s Too Much?
  147. missing and backfire
  148. can you upgrade your A/C?
  149. Could an Oil Seperator Increase Oil PSI???
  150. crane optical distributor?
  151. Thinking about selling the car! LONG!
  152. solid roller cam?
  153. Vibration when braking, alingnment?
  154. Do we have this on our cars?
  155. Yet another Intake question??
  156. Where to buy brake caliper bolts?
  157. Last few questions before firing up
  158. Breaking Rear Break Shims, Bad SQUEEK.
  159. ECU questions
  160. Stalling Problem, While on the gas
  161. Backfire when warm and downshifting
  162. will a fox body rear sway bar fit??
  163. New 354 and TKO are in! pics
  164. People with Catted Bassani X's
  165. Understanding Timing
  166. Pinging at full throttle ??????
  167. MSD superconductor wire's, too small?
  168. Lowered the car = passenger rear sags...
  169. I'll be fine with 30lb right?
  170. What do I need to get an A/F ratio gaugfe and actually use it?
  171. 306 dyno results
  172. summit sport seats on special
  173. mass air ?
  174. Reviews on Summit Shorty Headers?
  175. need to conver my 94 TB to older style87-93
  176. '69 302 block
  177. '93 Cobra intake DOES NOT WORK!
  178. how to remove AC pump
  179. 95 GT Brake upgrade
  180. What would cause a rich idle smell?
  181. Stock Catted H-pipes same or diff in Foxs/SN-95s?
  182. Stupid Brake Lines
  183. Fan only blows at feet when switch is set on mix
  184. how much power am i losing without rear end shimmed?
  185. air pump?
  186. New wheels, new problems.
  187. Does this fan pigtail fit our cars?!?!?!
  188. Torn rubber on emergency brake.....
  189. There's a lot of heat...
  190. ****! Balancer?
  191. Steering Stops?
  192. Overheat and pony lackin power
  193. Zex users, get in here!
  194. please help with new t-5 swap
  195. Exhaust fitment questions
  196. t-5 swap
  197. 331 Stroker
  198. cam help please!!!
  199. "C" Lowering springs.
  200. Additional inline fuel pump wiring.
  201. The lowdown on vert top motors
  202. Thanks...
  203. Red Radiator Hose
  204. SPOUT Connector?
  205. Getting ready to fire it up for first time
  206. odometer not working
  207. 95 EEC disconnect problems!
  208. Pinging/Rattling Sound
  209. Best Exhaust setup
  210. Vacuum leaks?
  211. Knocking noises over bumps
  212. Does EGR delete + SCT Tune = Pass emissions???
  213. Will this fit?
  214. Heads/Intake -- Cam?
  215. Hesitation...power loss
  216. Oil Pump Pick-up Tube???
  217. Compatibility Parts With 3.8l...Buying a junker!
  218. Car dies constantly... atleast today.
  219. PLEASE POST SALEEN OR XENON SPOILER PICS
  220. axles from an 01 gt
  221. transmission problem
  222. Strange Idle?! HELP QUICK PLEASE!!!
  223. Which exhaust is better?
  224. Idle issues on restart
  225. Autometer ??'s
  226. t5 question
  227. How do I increase steering turn in?
  228. Noid Light and Injector Testing
  229. Maintenance questions....
  230. Heads OR Intake?
  231. What size injectors?
  232. can you daily drive a stroker?
  233. Cam’s and drivability what’s the deal
  234. Superchips...can i buy a burner/software
  235. Help!!! need some pointers
  236. Installed Pro M 80mm Maf this evening
  237. Aftermarket gauges
  238. ? for the 5.0 gods.....
  239. Car won't start.
  240. Took pics of my pass. side fenderwell. What's missing?
  241. Car running warm.....
  242. Want some power! PLZ HELP!
  243. Stock block power #'s
  244. I need some SERIOUS help...
  245. MSD ignition mount in fenderwell
  246. Why is my buddy running such slow times
  247. Code = ???
  248. Guage ??'s
  249. Done the basics, whats next?
  250. 275/40's all around.....good idea or not?
