View Full Version : 94-95 Tech
- Autometer ??'s
- t5 question
- How do I increase steering turn in?
- Noid Light and Injector Testing
- Maintenance questions....
- Heads OR Intake?
- What size injectors?
- can you daily drive a stroker?
- Cam’s and drivability what’s the deal
- Superchips...can i buy a burner/software
- Help!!! need some pointers
- Installed Pro M 80mm Maf this evening
- Aftermarket gauges
- ? for the 5.0 gods.....
- Car won't start.
- Took pics of my pass. side fenderwell. What's missing?
- Car running warm.....
- Want some power! PLZ HELP!
- Stock block power #'s
- I need some SERIOUS help...
- MSD ignition mount in fenderwell
- Why is my buddy running such slow times
- Code = ???
- Guage ??'s
- Done the basics, whats next?
- 275/40's all around.....good idea or not?
- Help with wheels
- car runs hot
- HELP with lean trouble code
- Power Seat Problem.
- speedo problems
- Sell complete or part out?
- Mods to a '94 GT/AODE
- squeek when turning
- 306 Block
- AFR 185s
- Those with TOKICO ILLUMINA 5-WAY's get in here!
- Brake Caliper Bolts
- Foxbody shocks, struts, and springs.
- Big Problems with 1 3/4" BBK Headers
- Trick flow Stage 1 or 2?
- HCI Help
- plz help
- Testing CCRM
- Can I use rubber hose for the egr tube?
- I think i need c/c plates
- Wont start, clutch safety switch??
- 24lb Injector Pricing
- Fuel cell question
- hanging rpm at speed
- I blew my botom end!!!!!!!!!:bang:
- Car Won't Start!!! WTF!! Need Help BAD!
- Where to buy ignition tune up stuff
- My power driver's seat has a mind of its own...
- 3000 RPM Stall, What Intake Manifold/Powerband?
- Can I Get Rid of it?
- I'm swapping a 1990 lincoln 5.0 into my 95 v6 stang..have a few questions
- '94 GT Tranny
- vortech supercharger-used. a few Q's
- battery terminals
- t5 rebuild-what do i need
- ? on a Supercharger
- Edelbrock rpm 2 intake help
- New Noise Vid!!!!
- '94 Power Seat Fuse
- Alternator hits my Anderson Valve covers
- Oil Pressure??
- Rockers and Valves????
- Need help with MM c/c plates.
- Car wont start!!!!!!!!!
- which size header fits my ride?
- Strokin' It
- $600 Vert Saga, Chapt 2
- wheel spacers?????
- pinging should i run spout out??
- Please post pics of your lowered 94-95 GT's
- writeups on removing steering wheel?
- I need to find PLEASE HELP!
- Help me with my goals
- Circlip Help
- how long would it take?
- Tokico HP Struts/Shocks... Any good??
- Need some help with parts
- Air Bag Module
- gear install parts?
- weird creek or clang sound
- code problem
- That New Ford Boss Block-Not Impressed
- tranny problems
- Hunsaker Sport Seats..
- 16.833 in the 1/4 mile.......car for sale.....
- X or H pipe with Lts?
- Gears ?
- Autozone Code Scanners not Work
- I need a new engine
- Power Distribution Box Problems
- Weird "Metal Click" Sound
- Need a measurement from a Vert
- EFI or Carb??
- found my vibration
- When to change T5 fluid?
- 24 lb injectors out of 93 probe ?? anyone use these??
- T5 to C4 swap
- whats the best place to get air conditioner exchanger
- found;most obnoxious noise
- I Have A Wierd Noise (the mustang owners motto)
- Gauges....
- why cant i read my codes?
- Please post pics of your rear seat delete
- Need manifold advice
- Synthetic oil?
- Brake info....input please...
- Where to mount the PCV Valve?
- Ok guys... Answer my questions!
- flywheels for stroker
- UPS was just at my door!! (PIC)
- nitrous spark plugs with cobra heads
- fuel pressure setting???
- Strange Struts + MM C/C plates = rattling ...
- roof side molding rmoval
- More progress pics of Project DEBTMAKER
- What Flywheel?
- Pics of Summit Bullitt Spring kit!
- fan not turning on??
- Header Question! Different than the others
- My $600 '94 Vert
- Distributor gear question!
- all experts on t-5 swaps please enter.need help
- Stabbing dizzy???
- AODE to T-45 conversion
- Whats your favorite CC plates and struts?
- A/C problem on 95 GT
- Anyone with a trans harness out of the car, please help!
- MSD Distributor?
- tranny upgrade?
- 90* oil adapter
- mach460 head unit compared to standard head unit
- vacuum reading and fuel pressure
- Wheel Bearing Assembly (?)
- I need spring advice!!!
- Tire question
- trans control switch module 94-95
- Looking for help to get my car running right in Michigan
- Air bag crask sensors
- Factory air box
- odometer stopped working
- Power Brakes???
- Help with power window
- 04 back seats fit into a 95 ?
- Speedo gear
- door locks messed up
- Problems putting in distributor
- Piston Choice for Trick Flow Heads
- got a starting problem
- Anyone know the partnumber for the Trick Flow sn95 intake adapter elbow studs?
- Installing The Convertible Light Bar - Pictures
- Can I Disconnect Alternator Cable
- Quick question about vacuum lines
- People with autometer cluster bezel..
- Noob question....
- need help finding a 295 tire
- Can our radiators be repaired?
- Will MAC long tubes work with Lakewood bellhousing for TKO or 3550 tranny
- What paint gun do you guys recomend for a beginner?
- Missing above 4000Rpm
- fox swap
- clutch advice for a STOCK 95 GT
- slightly vibrating going around 50mph
- fan doesn't come on
- Need some advice on combo
- N2O S/C STOCK MOTOR
- Need new balljoints (Anyway to grease? Cobra A-Arms?, bumpsteer kit/new tierod ends?)
- Car Died On The Freeway
- TKO user chime in!
- AC charging ? Re: vacuum pump
- 1995 Factory Alarm
- Where is the secondary ground wire Located???
- TFS TW heads and Crane cam users please help
- i need a new driver's seat
- Removing Heads Having Problems
- Clutch Help
- Cold Start Issues
- 347m strokers
- 306 and stock radiator: will it work?
- Swapping alternator pulleys
- Bad Coolant leak!!1
- Code 211
- Increase timing to offset $ of better gas (MPG)?
- Help, Car just stalled
- Come and Get It!!! Engine is finally Installed!!! PICS
- Timing Pointers
- Clock Pod Gauge Users ---- Enter
- Belt coming off tensioner
- Lifters?????
- Help with my shifter
- What spacers to get and where for my sprins? Front is too low! HELP!
- ebay deal
- Anyone found a good way to attach side scoops?
- Dont know whats wrong???????
- Water in the pipes
- will my Crane Golds fit under my valve cover's
- what is the stock pushrod length?
- Alarm system
- C&L MAF sample tube question
- milled gt40 cc's
- Fuel pouring out my tail pipes
- Roller rocker install and info pls...
- Which spark plugs?
- installed rear contol arms now popping?????
- The Lifters!!!!!Dam
- Remember when everyone wanted to know what the air deflector looked like?
- Noob question
- what gauge wire should i use?
- BACKFIRES??!!
- ok, so what speedo gear am i gonna need?.
- Bad Iac
- how do you calculate compression ratio?
- Quick ? Red-line on 94-95 Cobra's
- knotchy shifting
- Need help ASAP with smog removal
- vibration in motor,after shift balancer??
- rough idle after h/c,video inside
- Loud pop... when i punched it
- Snow Performance Boost Cooler
- New springs & swaybar
- What size and brand of tires for an 18X10" wheel?
- Question
- Replacing fan...need help ASAP!
- Cheaper Alternative to AL. heads?
- Fan is making noise
- NEED HELP RIGHT NOW!
- Put on some wheel spacers & snapped a few pictures
- Just bought Canton Expansion Tank!
- AODE mounts
- 302 or 351w ignition module?
- Out of nowhere
- Whats the best Shift points for an AODE??????
- how many people have recently had there car hit 100,000 miles.
- Info request: where to find part # listings, and...
- Random Check Engine Light
- Those holes in the valve covers
- Whats best tranny fluid for TKO500
- Cobra Foglight Install Question (pics)
- WTF Happened to My Car!?
- fox harmonic balancer fit??
- Need a new shortblock
- Electric Cooling Fan
- cobra brake upgrade
- 94/95 auto to 5 speed conversion
- a few questions
