View Full Version : 94-95 Tech
- whats the best-( not break) Rear sway bar for my 94-95 GT convertible
- Had nothing better to do so I pulled another motor.
- noo-bee q
- cobra R rims
- 347 Oiling questions
- can i use my 1.7s pedestal mount rockers on my edelbrock heads
- Suspension set up
- 89 H pipe fit 95??
- Any experience with these wheels
- o2 sensors
- gauge install questions!
- fox powerdyne on a sn95
- Blew a gasket, got a question, YEA!!
- shaker intake
- AODE acting up
- 351W in my 94 AODE Vert
- squealing clutch
- Anybody know Airbags?
- Something is hitting!!!
- Anyone tried PowerSlot rotors
- FordRacing M-5400-A SN95 Handling Kit???
- i've got a quick dumb question too
- Quick Dumb Question
- 1.7's on a stock motor?
- Trick Flow Lower Intake Problem
- stock header flange?
- Cog setup for a 95 KB Cobra?
- Fuel Pump BS!!!!!!!!!!
- 1/4 Mile Guys, HELP. Analyze My Timeslips
- Should I be worried about my distributor? (pics)
- CEL on!!!
- Remove Quad shocks?
- What's jacked with my temp
- Need More HP from my 302
- Confused about smog pump delete
- How do i measure rim width
- 94 problems
- Question about AC bybass
- Strut tower brace that clears a SuperCharger
- How do i tell if my car is detonating?
- Pwr Steering Delete
- Big Prob! Smog Pump Delete and ABS Motor
- HELP PLEASE 94 GT
- if i do a smog delete?
- Learn from my mistake
- What backspacing i need with aftermarket 15x8 wheels
- A/C Help! (Getting hot)
- Idle Problem after Smog Removal
- Car Pulls to Left on the Brakes
- TPS voltage
- C4 tranny swap.
- ANYBODY EVER CHANGE THE QUARTER GLASS WINDOW?
- A/c stopped blowing
- AC Delete Belt Size
- Advice on nos system, and on idle problem
- Stang needs lose some weight , where to start
- Pushrod RANT
- H/C/I/ decisions..
- help....anyone know much on 351's
- Anderson valve covers, do they fit?
- Just some quick info
- this noise is eating at my brain
- Luk - Clutch cable and good for 94-95 5-speed
- Quick Ratio Steering Rack
- My convertible top will not , go back up .... Sensor which ???
- Ok ,I am finally going to fix my TO bearing problem.
- Preparing for new clutch
- Doing smog delete, need remove tube on head?
- Question about smog delete
- Shifter vibration and rough engine idle
- PICS- TSW RAZORS on my club members car
- PICS- Finally installed my Black Y2K Cobra wheels
- need to know psi for fuel
- HellllllP MEEEEEEEe!
- Black 95 GTS has trouble cranking
- loose header bolt = excessive valve noise?
- Can i run M/T ET Streets tubeless
- NEED HELP NOW...MEANING TONIGHT
- Need a info on new exhaust system
- Engine hits!
- BUCKING BELOW 1500 RPM
- DSS331
- PLEASE HELP!!!! Clutch cable problem
- shoud i keep TFS1 cam?
- Fox Cruise cable with Fox TB swap?
- don't read the thread about a 95 stang w/50k miles. its a dong. mods pleas delete.
- 94 v6 to a 5.0 what would I have to change?
- Need a clean 94-95 GT Chassis around NEPA
- caliper bracket
- Can i Get - ARP Bolt's for pressure plate and Flywheel ? 94-95 GT
- Could injectors cause car not to start?
- Rear End Noise...did research still need help
- gt40p questions about headers
- 2500.00 to spend. WWYD?
- What Clutch for Vortech'd 94 GT
- 347 into our Cars??????
- 94 GT Shell price
- spend my money
- 1 yr later still trying!
- JBA headers anyone?
- saleen center caps?
- Head Gasket?
- Running out of gas
- Oil Pan again
- Sloppy Trac Lok Unit
- Wanted middle to low 12's
- 17x10.5 or 18x10 rear rims?
- fox k member on sn
- Pro M Harness
- where to buy gt40 valve springs?
- If I add Nitrous....and PIC of winter project
- double trouble: 94GT & Cobra
- Fried my alternator!
- Who using Drag Radials on V6 rims ? post here
- My engine manufacturer says no to forced air and yes to nitrous?
- Couple questions while doing my new shortblock.
- what do you guys think about these headers
- Dipstick!!!????
- 1.6's or 1.7's
- What rims are good?
- Braking Noises
- Blowing Fuses Like Paris Hilton
- Powerdyne kit
- Which computer
- big problem with heat and power loss
- Anyone Installed LATCH?
- Where is the cheapest place to buy magnaflow catback?
- Alternator died....what should I get for a replacement?
- Fox V/C's how much
- spacer for cam!!!!!!!!!??????????
- Feels like I'm hitting a rev limiter
- anyone with a vortech and a fox throttle body conversion needed.....
- Looking at a 94 GT... suggestions?
- Help with AC
- NEW MOTOR PICS (P/S DELETE)
- 95 Mustang Stalls/Dies, already replaced TFI & Dizzy
- Burnt the O2 plug, need help wiring it.
- Broken thrust plate!!!!!
- Torque specs on the rocker studs???//
- 03-04 Cobra Steering Rack
- I'm determined to get a Vortech aftercooler in my '95.
- Opinions needed on these seats...
- upr coilover kit
- 96-98 speedometer work in 94-95 car
- pinion shaft lock fastener bolt
- What widest DR tire will fit on 94-95 V6 rim 15x7
- helll yeah!!!!!!!!!!!
- Anyone do there own rear gears?
- Best 18" Tire set?
- help please
- E Brake
- Power sterring removal?????
- Computer code 543
- Stock Stang___H/C/I or Vortech ???
- Turndowns / Dumps off the H-Pipe?
- Rapid change in gas mileage
- Used Blowers
- It Runs!!!!!!!!!!!!!!!!!!!!!!
- Are Good Street Manners and Performance Compatible?
- swap to a 351
- Bad news!
- Vortech With Numbers!
- Several weird supercharger problems with new vortech install.
- T-56 6 speed swap, anyone done this??
- A terrible squeal
- Computer Problems
- Powertrax Lock-Right Locker Installed
- Oil Pan Replacement
- Will my rockers always make noise?
- What's up with my compression!?!?!?!?!!
- Annoying squeak driving me nuts!!!1
- leaking egr
- Brake Question
- Polishing my Upper?
- struts on 94 cobra
- HELP! which oxygen sensor wire?
- what intake?
- Glow gage question
- Those with a fluidyne and s-trim...
- sway bars
- Just a couple questions.... HELP!!!!!!!!
- Torque Specs
- Dam hopefully not a problem.
- Finally bit the bullet and bought some killer heads.
- zex wet nitrous kit questions
- At what point is a professional tune worth the cost?
- Everything is great in COBRA LAND! Engine pics!!!
- Building my own rear seat delete kit. Any tips?
- Who has summit univ. Rad. (HELP)
- What is the lentgh of a 94 gt rearend
- Fuel Pump Wiring Question
- Power Seat Question
- not really sure.....
- So my power seat is now dead
- 2 months in Seattle does this to Brembo rotors
- question about clutch adjustment
- Hard to start when hot
- vacume hose diagram
- heads questions and which heads?
- Where are the blocks coolant drain plugs?
- Help with AC compressor
- Vert dont go up or down
- wierdness in lower rpms
- Should i Buy a Billet Flywheel or Iorn ???
- C&L 76mm MAF with 42lb injectors. if you have this combo please reply
- Removed O2 Sensors
- changing automatic shift points
- Suspension Techniques Rear Sway Bar
- Where to get Nitto DR tires
- 90mm MAF connector for our cars.
- Stock pulleys?
- 94 cobra h pipe??
- Thinking of several power options...Questions.. Please Help!?
- Co$$$$$T for a tune gone UP??
- Cheapo Tires! Whats good?
- Sun Hyper Voltage System and Hyper Grounding System. What do you think about it???
- injector question
- Help With 94-95 Cobra Intake Gaskets
- Whats best King cobra or Spec & Clutch Cable ??
- HEADERSSSS
- Steeda Bump Steer Kit Worth it?
- mustang stalled on me when i put in gear
- Fluidyne Sucks
- TRICK FLOW STREET HEAT VS 95 COBRA INTAKE??
- Falken Tires, any good ?
- How to test a torque converter?
- what did you wire your ignition box to?
- Torque convertor going bad..
- volts up and down. bad ground??
- short shifter
- 94' supercharged
- Ford part #'s for timing chain cover & oil pan?
- FRPP Headers and unk. H-pipe install
- 94-95 to 93 computer swap
- exhaust heat
- installing a damper w/no keyway help timing
- 94' supercharged
- Hood Clearance
- Car getting hot at hight speeds for extended periods.
- Pypes X Pipe
- HCI swap done NEED HELP!
- egr bung cap 5/8" - what thread pitch?
- Rear Brake Pad Install / E-brake help
- Help! what should the alternator voltage be?
- t56 install problem
- What's the max lift cam I can go and pass emissions..?
- How do i make it possible to know my fuel pressure from inside my car?
- Removing cats?
- Well I finally made it to a dyno
- power #'s
