PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Well I finally made it to a dyno
  2. power #'s
  3. Clutch pedal assy--button??
  4. Those with glow guages: what wire to get power from
  5. Gauges
  6. A/C valves: removal/replacement?
  7. WHICH HEADER GASKETS FOR AFR 165s?
  8. Repainting Interior
  9. SLP line lock work will work on 94-95s
  10. What motor oil you running
  11. rev limiter question
  12. All the new parts are IN!!! ED CURTIS is the MAN!!!!
  13. Engine Bay and K-member pics (before, during, after)
  14. Help, Suggestions to clean Proportoning Valve before install?
  15. HELP
  16. A tip for everyone who gets one piece headlights.
  17. Subframes for side exhaust?
  18. Subframe Question
  19. Timing Chain
  20. How much would
  21. Tremec TKO 500
  22. wheels and slicks
  23. Popping In Exhaust Around 5,500 RPM
  24. Strange noise coming from the back wheel.
  25. any one able to run a vin # for me
  26. what is it
  27. Headlight removal.
  28. Headlight Problem
  29. 95 cobra stock pulley sizes?
  30. belt tensioner problem
  31. Does a Pro Chamber from a fox fit on SN-95's?
  32. How To: Remove Dipstick
  33. Online Tutorials for fear install in 8.8 rear?
  34. ac compressor removal.
  35. What Vacuum with cams.
  36. Rear Sway Bar Hardware
  37. Dyno Tuned yesterday...... something isnt right..... 404hp 396tq??
  38. who makes a good rear seat delete kit?
  39. sold 98 v6,cant make up mind on new car
  40. for some reason my car idles.....
  41. 380rwhp 306c.i. engine naturally aspirated
  42. afm b-41 cam on a n/a 5.0?
  43. Need Help Finding Source of Problem
  44. Purple?
  45. Anyone bought the eBay racing seats?
  46. RRAAGGGHHHRRRHRHAH!!! Water in oil problem.... for the 3rd time.
  47. weird sound from trans
  48. Corroding Brake Lines
  49. Injectors and horse power
  50. Raising idle?
  51. Taillight covers
  52. wow u think i need new plugs?
  53. Buying a 95 gt with mods, need help
  54. Phenolic Intake Heat Spacer
  55. Changing headunit in a 95.
  56. Any pics of a Terminator hood on an SN95?
  57. reading material
  58. Did I break my gears?
  59. Popping on acceleration
  60. et/mph gain by removing timing retard and fuel dump in a 94 cobra?
  61. Trick Flow kit - why no 94 - 95s?
  62. Gauge questions
  63. How to: 13" Baer Rear Upgade Kit!
  64. Doesn't idol right smokes out of the tailpipe
  65. Header Collector Leak - Will This Gasket Set Help?
  66. do i need to change this?!?! please look! PICS...
  67. Need your opinion on a shortblock upgrade
  68. Is this what I use to catch the oil from the PCV?
  69. Best nitrous kit for the money.
  70. Anyone ever replace their rubber e-brake trim with a leather boot?
  71. SUPERCHARGERS?
  72. Brakes with high HP and 15" welds
  73. mac lt headers?
  74. I have a dilema involving a 99 IRS, opinions are appreciated
  75. 95 cobra tranny, how do you distinguish the difference
  76. Cylinder Heads & Tune Problems
  77. will not start
  78. What could cause this power problem?
  79. no start
  80. couple of clutch/bellhousing questions
  81. Looking for new rims but worried about poor quality during extreme loads
  82. What driveshaft to get when swapping to TKO if I dont want to use a spacer?
  83. Is the Tremec bellhousing for 87-93 the same for our cars? (TKO SWAP)
  84. going to the track with this setup
  85. Buying new 18" Chrome Rims - But I need YOUR help.
  86. Car barely running
  87. I need help on deciding
  88. Cylinder Head Q's
  89. Ordered the "Edge" today.
  90. Guys what is this thing?
  91. Guys with aftermarket oil pans......
  92. help me finding intake air temp sending unit
  93. Narrowed down the ticking
  94. How Hot Should I Bake It
  95. please help me figure out my mystery problem, vid inside.
  96. CAI for 93 TB conversions.
  97. Cold start issue
  98. Front End alignment with CC Plates
  99. Aftermarket Fuel System, Single or Dual Feed?
  100. How Many Passes on a Set of ET Streets
  101. Remote Mount Oil Filter Kit?
  102. Aftermarket wheel studs?
  103. Tranny Questions
  104. Flywheel dowell pins?
  105. Need info on what clutch fork to use...
  106. will a bad pip/stator cause a check engine light?
  107. king cobra pedal feel?
  108. I need help with the quickness
  109. code 311 and 332
  110. wheel fitment question
  111. SN95 Twin Turbo (Re)Build
  112. Dyno tune results
  113. e cam help needed
  114. injectors
  115. oil dipstick interferance
  116. whats wrong with my car, winner gets a prize
  117. Help !! AODE shifting problem whit B&M shift kit
  118. Bought Springs, have Qs now...
  119. New #'s 331 T-Trim
  120. Overheating
  121. whats that company that makes subframes for sideexhaust?
  122. Draglites on a sn95
  123. [B]Anyone know where I can find this brake line in SS braid?[/B]
  124. advice on fuel,ignition,suspension upgrades
  125. First time at track with new combo
  126. DID AODE TO TKO-600 SWAO, NOW CAR RUNS LIKE ....
  127. valve cover gasket for tw heads?
  128. Help I keep burning up ignition control modules!!!!!!
  129. Project BLOW AWAY new standard vette....
  130. Good News, Bad News!!!!
  131. Code 157
  132. 1/4 ET not good, lets work it out!!!!!!!!!!!
  133. ford extender
  134. I hate new Vette's
  135. Wheel question.
  136. If you have jegs or summit rotors come in!!
  137. EBC GREEN FRONT BRAKE PADS GOOD 4 DAILY DRIVER ?
  138. problems, problems.
  139. MT 255/50/16 DRs vs BFG 275/40/17 DRs
  140. Drop In Replacement Differential? Help Needed
  141. Which plug gap with spray?
  142. finally started the project.....
  143. Front Coilover Suspension
  144. Engine misfiring?
  145. Power Steering
  146. Anybody know why my balancer did this? (pics)
  147. cooling fan not coming on
  148. Question for whoever might know on smog pump removal
  149. Bassani Street Comp Cat-Back
  150. Putting on PS Pulley
  151. 94-95 Powerdyne Super Charger
  152. wb new o2 senors needed?
  153. Car bucks at 1500 rpm and below
  154. Charcoal canister.... full again!
  155. 94 Cobra running rough (PLEASE HELP)!!!
  156. running lean
  157. About to replace the stock catback! Any problems with my choice?
  158. Should I get larger injectors?
  159. PSSSSSST!!!
  160. Smog Pump Dead
  161. 60' times and suspension
  162. Fresh 275/40/17 rubbers.. now i got questions!
  163. Squeeking??????????????
  164. some new pics of my turbo kit.
  165. 351w swap.. what long tube headers can I use?
  166. Where do you cut your C Springs?
  167. Saw the New Cobra
  168. Quick Fuse ?
  169. Problems after Tranny Install Please Help
  170. A Zex nitrous kit for 87-93 should work on our cars right?
  171. Car won't start, because of the alarm.
  172. accessory brackets
  173. car running rich....
  174. Which other car can I get a spare tire from?
  175. How do you know if you have floating valves?
  176. little rust question
  177. need a little help......E303 guys
  178. Recommend any good oxygen sensors?
  179. 5spd vd C4
  180. REAR END NOISE
  181. preping fiberglass bumber
  182. Attn: punisher302
  183. Radiator Problems
  184. Radiator Problems
  185. Fog light question
  186. how much noise is normal??
  187. Egr Pipe Adapter
  188. does anyone know where i can find something like this......
  189. gear install
  190. new gears about to install
  191. New Recall?
  192. Video of my car *just installed the x*
  193. remote start
  194. Fuel Pump?
  195. Has anyone had a collapsed lifter?
  196. o2 Sensors
  197. Battery cables-no start problem
  198. 94 gt with longtubes...mini starter?
  199. Here's an easy one! (hopefully)
  200. anyone got a summit or jegs roll bar in a convertible?
  201. x2c motorsports and fox t/b ?
  202. Temp gauge works sometimes.
  203. What ignition componentes will make a car run like CRAP?
  204. Is a water temp guage that reads up to 240 degrees enough??
  205. girdles
  206. Rio5.0 and whomever else can help.
  207. T-56?
  208. gas in intake--help!!!
  209. Speedo gear install
  210. EGR Removal?
  211. starting prob
  212. I pulled some codes and this is what I got.
  213. blower or h/c
  214. anyone know the part number......
  215. T5 from fox
  216. Need new driveshaft, what to get?
  217. What is the 95 Mustang stock ride height
  218. what do you think I should do?
  219. Timing Chain....
  220. SHIFTING TO 351
  221. Mach 460?
  222. 1994-95 Tensioner / Pulley bolts
  223. aode guys with deep pans- what filter are you using?
  224. 03 cobra seats
  225. torque specifications on puttin stuff back together.
  226. Headlight Bulbs.
  227. 306cid camshaft?
  228. What color to paint my car?
  229. Best place to get G-Force T-5 Trans kits
  230. Waitin to find out if I hurt it bad
  231. gears question in gt aod
  232. Pulling rear wheel bearings and seals
  233. Electric Fan amp draw
  234. Wiring Questions
  235. Those with MM Coilover struts come in
  236. Outer tie rod ends...which ones to get
  237. For all those who power shift...
  238. Timing cover / water pump bolt set
  239. What kind of tires to get?
  240. new times
  241. Side Vents...How to remove them.
  242. What Tires You Running These Day? How Are They?
  243. Couple Tire Questions.
  244. Fuel Pressure Gauge?
  245. Spec clutches suck (more inside: pics)
  246. Vortech Problems, Vacuum Related?
  247. Always get shocked after turning off car?
  248. Car has slight popping on acceleration
  249. QA1 K-member & motor mount issues
  250. Guys with big brakes.....!
