View Full Version : 94-95 Tech
- CRANK HARD TO TURN ??
- Where is the correct spot where these hoses go?
- Anyone With a Starter Shield???
- 332 code-insuficient egr flow detected
- Rear-End Swap: brake line placement
- T Moss porting
- New Project UNDERWAY!!
- PRIMING OIL PUMP ??
- Identifying these two brackets...
- silver rear end fluid
- If you have an Edelbrock Performer intake get in here!
- What would you do?
- MAF, AIC, TPS.... WTF?
- 10% ethanol junk has junked my car
- A short break from my huge car troubles..Cool Distributor question!
- please help me with my oil issue
- Water pump bolts question
- changing steering wheel
- NO A/C and its hott outside..relay problem?
- cam swap -- w/ engine still in?
- Rattle from tranny area
- No Turn Signals
- 95 Stang EGR/Smog Pump connector at Cat's
- Dodge Viper Fan
- WHY WON'T IT IDLE????
- Car "skipping" WOT ?
- a/c problem
- Manual to Power windows
- High Water Temp on stang
- supercharger ?
- Cam swap in car.
- Time for a rebuild
- Quick stereo question
- Will 99-04 seat covers fit 94stang
- water pump help ??
- keeps stalling
- Fuel Line Question, Help!
- For those who are using FOX valve covers
- turndowns on stock h-pipe?
- Alternator I THINK...
- BOLT SIZE ??
- This is gonna sound kinda stupid...
- Battery Relocation Kit Questions
- 95 GT - Overheating Problems
- Wheel offset?
- Tranny problems...
- turbo 302 vs. NA 331
- Major disappointment and set back
- Idle jumps between shifts?
- starting issue!
- Help Diagnose my low rwhp issue. Any experts?
- TKO 600 an clutch cable cover
- 9007 100/80 watt bulbs?
- pushrod length(need help with the math)
- 5 speed swap???Worth it?
- Factory waffle pony offset
- To cobra clone or not?
- This combo would work and what kind of # should i expect?
- Window motor bushings (Pics)
- breaking up from 4,400-4,900!!!
- accufab tells me bigger throttle bodies are useless on our cars
- MSD Digital 6 Question
- 96 Cobra Hood on 95
- Picture Request - EGR / Air Pump Vacuum Routing
- Cobra Caliper Bracket Bolts?
- WHAT SIZE BELT ?
- noise
- check engine light in low rpms
- why does my car have vtec?
- Not running like it was at the track last year.
- codes help for someone new...
- 351W Headers?
- 190 lph
- Do I have aftermarket headers?
- TRANS ?
- What's that sound?!?!
- Bad front lower control arms?
- Mr Freeze Vs. Snow Meth Injection Kits
- OIL PAN ????'S
- Bushing Grease??
- Dead CCRM??? Buzzing.
- air fuel wire
- Valve Cover Baffles?? Remove or Keep?
- quick vortech question
- ABS compatability
- Street heat upper to track heat upper?
- So i took out the Hypertech. Could my problems be resolved?
- New to the game and want to play...advice??
- D-day
- rocker sweeps
- LOUD POP while driving! No starty....Help!?
- Another Fox TB Conversion Question.
- Ticking
- Front Control Arm Bushings
- Are Dynomax ultra flo welded and ultra flo SS mufflers the same??
- Fuel Pressure Problems
- valve covers
- GT40 Vs Cobra intake?
- Surface rust!!! Flywheel HELP.
- Oil seperator steeda, husky
- 95 gt mileage HELP!
- Waterpump leaking, need gasket and having trouble
- electrical issue
- Brake Upgrade...Options?
- electrical issue
- New Thermostat Housing
- Transmission question
- Driveshaft Balance.
- stang wont start
- How To Replace Fuel Filler Tube Gasket*pic's*
- Couple Gremlins: fuel leak & fan direction
- steps for takin off heads
- need help
- What intake gaskets?
- lower intake want come off
- top speed run gone bad
- 95 GT problems...
- Water pump, bottom bolt..
- Bad fuel pressure regulator???!!! HELP NOW PLEASE!
- aode to t-5 swap ?
- wires arching
- What woud a cam give me now?
- 351W engine weight
- 95 gt will not idle
- Accufab Throttle Bodies
- bad problem
- Mach 460 wiring help! (time to upgrade)
- Question about fitment of these rockers...
- ASP Underdrives, problem.
- Quick question...??
- code 122
- Question About Rocker Arm Install
- everything needed to use fox throttle body
- spring isolator question
- Problem with starting and taking off
- This will blow your mind
- HELP needed
- A/C Leak
- 331 question
- Odometer stopped working
- Hot Start up Stumble/surging... SOLVED !!!!
- NO POWER?????????
- Stupid Fan Again
- another ABS question
- when shifting rpm,s jump
- Rear Supsension
- DISTRIBUTER CAP HUMMING ??
- Cobra Bumper
- Help with Changing Carpet
- Brake lights not working??
- how hard to replace oil pan
- need a measurement right quick...
- Can someone help me out with my 1994 Mustang GT
- methanol injection
- Fuel filler gasket
- Turning torque converter under the car.
- PA performance wire kit routing?
- Head Bolt Problem/Question
- new spring install
- 93 gt40 on my 95 question fit
- no start again ????wtf
- Coil over swap?
- 95 Cobra = Stalls
- #8 Fuse popping
- Do I still need this anymore?
- Weird stumble
- How To: Timing Cover Install - Manual and Automatic Transmissions
- Thought I would pass on the knowledge
- Will the Holley Systemax intake fit under a stock hood?
- Ignition questions for the HCI crowd
- Rear end solutions (v6 rear)?
- For those of you wanting to use an AGR Power Steering pump...
- Zeitronix ZT-2 WB data logging Need Input
- MSD 6AL good?
- Cobra ecu in Stock GT???
- Maximum coil overs
- Flowmaster 50 Series
- runnin rich
- Questions about my combo...
- emission test failure
- Steeda Fuel pressure gauge!!! HELP!!! ASAP!!!
- Will this work to replace my stock balancer?
- Minor Timing Cover Install SNAFU
- windshield tint
- 95 cobra thinking of converting to carb help please
- Odd problem....
- The dreaded smog removal...
- Balancer question
- air regulator?????????
- For those with FTI Camshafts.
- WTF is wrong with my Fuel Injector!!!
- How many runs with 10lbs bottle of nitrous?
- Head Gasket Install
- anyone with a manual 94-95 gt
- Has anyone used the air pump to create vacuum
- Which intake? And related question.
- AODE to TKO 600 Swap..Maybe?
- E303 & AODE
- Posessed Door chime!
- 0-60mph
- T-5 3rd gear synchro
- EGR tube?
- Stock Cam Specs needed
- this shifter any good?
- smog pump ?????
- Engine-Tranny-Rear End...Anyone Ever Yank Them ALL at Once?
- leaking lower intake???
- Where's it coming from...
- T5 swap ahrness question
- Resolved most of my surging idle problems
- Rear control arm questions. Please help
- Brake Help
- 3-inch exhaust
- tune up problem
- Secret to moving A/C Condensor?
- REAR END!!!!!!
- Timing Pointer Position
- no power, takes forever to rev up in gear
- lifter tap
- vortech v1 T trim
- Camshaft, roller rockers, Valve springs??? what else???
- Painting Dashboard--How To--WARNING---Ton's Of Pic's.
- Long tubes with twisted wedge heads?
- cobra Brake booster?
- Misfiring, loss of power, popping. Where to start?
- Tach square wave signal source
- Hitting Rev Limiter WOT 1-2 shift AODE
- Harmonic Balancer Install---How To---
- Airbag Code 32
- 1995 computer??
- kyb shocks and struts
- Brembo owners, quick pad q'
- Wire harness
- So if the mid-pipe doesnt't come with the tube for smog...
- Question About BBK Header and FelPro 1415 Gasket
- Help- o/r h-pipe and o2 sensor question...
- Push Rods + There Location on Installation?
- Quick PTV ?
- What computer for this swapped car?
- Need brake line help!
- Mustang Fender Flare
- Bought Heads and Intake....but...
- So.........I lost a brake pad!!
- EGR TUBE TO SHORT HELP??????
- 1967 289 heads on my 95 roller motor
- Autometer Fuel Level Guage install, what ohm is sender?
- oil pan gasket
- INJECTOR CAN I START THE CAR???
- Headlight side markers bulb, 1 or 2 contacts ?
- ignition box ?'s
