View Full Version : 94-95 Tech
- Transdapt Shiftkit... Questions.
- QA-1 suspension set up.. what a yah think
- engine swap difficulty
- OBD I or OBD II?
- Neutral Safety Switch
- LITTLE PROBLEM
- which way does IAC plate go?
- Which Power Steering Pump
- Which roller rockers clear SN95 valve covers.
- has anyone heard of autologic chips?
- What starters are u guys running on 10+:1 compression motors?
- best methods/products to renew old and damaged paint?
- Eibach springs on crappy shocks/struts
- Replacing calipers and rotors - any tips, advice?
- Shudder on turning take off - diff?
- engine swap
- Time for seafoam..Brake Booster Line????
- drag shocks vs. fully adjustable shock
- Detailed Axle Measurements Needed!
- Cruise Control Cable (foxbody conversion)
- guys with fti/custom cams and stock botom ends....come here
- 94 cobra Epoxy coat on INSIDE?!?! of intake runners???
- torque arm mounting points (long)
- Rear caliper groan bracket
- Trick Flow TW EFI Kit Questions
- Brake Problem
- Car cranking, but not starting. Diagnosing the ignition system.
- Considering wheel swa! 17" rim and tire questions
- i killed the drone
- Sidegapped plugs?
- Which Manual Transmissions fit in our cars/how easy do they go in??
- tko electronic speedo
- Anyone running Iridium spark plugs on a supercharged motor?
- Raybestos Replacement calipers - anyone?
- Running bad
- Pypes X-pipe REVIEW
- Who has a Torque Arm?
- looking for a cobra r hood w/factory style scoops
- Upgradin front brakes.
- cp engineering injectors...
- Timing Blues
- built my own panhard bar
- Dizzy Bolt Removal!?!?
- Do 05 Mustang Wheels Fit Our Cars?
- 10.5" Bullitt wheels--will they fit?
- Need help with pulleys for V-2 SQ, afraid of overspinning the blower
- GT Verts and C spring pics needed!!
- Maximum Motorsports delivers!
- First Drive
- How To Properly Advance My Timing...
- Stud mount rocker Push rod length???
- about to start porting a set of e7's
- Aluminum Driveshaft
- Need help on front end noise
- Autolite 23
- What could be wrong?
- Ok Im stumped..
- code332 and xpipe question
- Help Please nitrous
- MAP sensor for Wideband Commander?
- Whats the easiest way to get the spark plugs out?
- Gear install, anything else needed ?
- Finished project today...HAPPY-no idle surge...yet
- Front wheel bearings - sealed or not?
- power seat motor
- Which nitrous kit for a newb?
- Powder Coating Question
- Rear Wheel Goofin'
- Loose Battery Cable....Maybe?
- Oils and Fluids
- Pinging Problem
- Glue all over shift boot :(
- ? on stall converter....help
- Exhaust Tips?!
- Catco H-Pipe- Review
- nozzles - where to buy?
- My vert handles like garbage, help please!
- aode almost out!!! But...
- Where to buy interior door panels?
- Started cat today ?'s....
- Anyone else have a large draw to battery?
- Holy frayed injector leads Batman!
- Cervinis 2 piece speedster cover owners inside please
- TW Track Heat Heads, stockish pistons, small cam....1.6 or 1.7 rockers???
- What Parts to Use
- What bellhousing to get?
- Advantages to stud mount rockers, rather than pedistal mount??
- 1.6 to 1.7 Rocker ratio lift conversion???
- T5 Swap difficulty ... t5 swappers in!
- Lowered too much?
- 'Vert speaker questions
- is 91-93 cougar and thunderbird timing cover the same as sn95?
- Putting new top on convertible?
- 90 GT T-5 donor car.
- Will an 04 CD Player/Radio work in my 95?
- Injectors???
- only question about my combo...
- Which kit/tc for AODE
- What other spindels fit our sn's?
- So cal installers
- Air Bypass, Power Pipe
- overkill??
- Windsor Jr. Heads
- Anybody running 2 chamber Delta flowmasters?
- Looking for a good drop
- $1200
- Should i give Cometic Head Gaskets another try??
- Nitrous Setup Question
- best tire size for front
- x compared to h
- Should new exhaust make my car shake a little?
- Everything is buttoned up tonight.
- Cold Air Intake ?
- Factory Cd player install HELP!!!!!!!
- I think i might have an exhaust leak
- How do I remove LCA bolts?
- Octane ?
- urethane motor mounts
- REALLY QUICK..... MAF connectors
- What new Axles for the Cobra?
- 05 gt wheels
- Oil Change
- Vortech Installers, Question
- 331 stroker soon, but for now?
- Bellhousing Question
- Steering leak problem
- Kirban AFR.....just checking if I got it right.
- Eibach spring install problem
- is a cam worth the time?
- Block Plate
- Wiring Location's 1995 Mustang GT Convertible
- Cobra Power Booster?
- What's The Problem ! Did a Auto too T-5 Swap And ...
- fuel pressure
- Fuel Pump?
- Who's coming to help........?
- anyone using the milodon 7qt fox oil pan in a sn95 car?
- Which size fuel pump to use
- Header Porting?
- Fox ECU
- Trick flow high ports, mild cam, stock pistons???
- ball joint spindle just spins, can't tighten or loosen.
- When To Upgrade to Race Bypass Valve?
- Arghhh, need help... Timing cover differences between years
- Air bag light
- Installed Pro-Kit springs...questions and I have a hum noise.
- gt-40 intake ?
- Speedo Problem Solved...CLUSTER!...What Next?
- best high performance quieter muffler?
- Polish Vortech S-Trim?
- 94gt h/c/i
- Electric supercharger
- Burnt Brake Piston Boots
- Question about 94-95 and 96-98 spindles
- Pretty sure the answer to this question is no...
- Fox TB Conversion Observation
- DSS problem, don't make my mistake
- How to remove the proportioning valve?! upgrade it? (pics)
- In-Dash Tach Question
- so the delivery guy came this morning.....
- MSD BTM?
- 2 ?'s. TPS vols.....stock fuel pump psi
- those with fuel pressure gauges,where and how to mount it?
- 95 Stroker
- Advancing Timing
- tf street or track heat?
- Kenne Bell or 03-04 Cobra?
- Easiest Way to replace the Fuel pump?
- Those of you who have owned 5.0/5.8 and 4.6..
- Diffence between 94-95 GT and GTS?
- Newbie coolant flushing question
- Where to buy clips for the sideskirts?
- Stangnet 94/95 meet......???????
- side exit exhaust
- Anyone with Mech. Gauges under the Radio or in a clock pod?
- Bracket bolts....where to buy?
- movin to a 4.6
- Which Gauge Clusters Fit?
- Darn BBK!!
- Need New Radiator Advice PepBoys / AUtozone ?
- Airbag Simulators
- RRRR. Anybody with new TB, help
- low coolant
- retrofitting HID's
- How to test O2 sensors?
- Getting new posi rear..Splines?
- Stuck Tach
- What TKO do i have?
- 80mm Ford MAF user's
- Spark Plugs for GT40 Heads
- I'm in the market for WB o2s
- Just installed "Kustom" Pro Motion clutch kit thanks Killercanary for advice
- snap crackle pop in my exhaust
- Lugnuts for Cobra R style rims? Anyone
- Just changed my belt, now my car shakes.
- mac cold air hoses
- Weird electrical problem
- Who makes the best replica Saleen Wheels
- What parts are suppose to be cut out on the saleen heat extractor hood?
- Where can I find the reflectors on the back bumper?
- HELP with parts list PLEASE
- Why won't my Stang Idle?
- Another stupid question....
- Stupid Question
- Anyone using UPR Triple Pick-Up or Speed Release Quadrant with Double Lock Adjuster
- Removing AC and Smog pump?
- pcv valve relocation?
- Rear Control Arms
- bore of edelbrock throttle body adapter?
- Rail Fuel Gauge?
- Heads, Iorn gt40's and boost
- Inline Fuel Pump.
- does the 05 bullit wheels fit 94-98
- Cobra Front Bumper Fog Light Size? !!ASAP!!
- stud mount rocker question(s)
- Help me fix my car.
- What starting point on fuel regulator?
- what processor?
- 75mm throtle body
- Suspension and bushings help
- Valvoline durablend ok for rear gears?
- Eibach sportlines and which shocks/struts?
- Upstream and Downstream Oxygen sensors
- Broke My Locking Lug Key
- brake light problem.....someone please help
- name that plug.
- Intake valves are going to hit my pistons....what are my options?
- Oil leaks
- STILL GOT A VIBRATION !!!!!!!!!!
- AFR 165 heads or T5swap?
- 351
- what injectors
- Help with rim questions please
- what the difference b/w polyurethane and solid motor mounts?
- how to get abs ring off axle???
- Help please! I dont know what to do!
- 112 degrees or 114
- Gauge Pod, 3 Hours?
- Pics of the New Engine!
- Need some clarification
- Knock....Tensioner Pulley?!
- Nitrous Question
- Need Help, What is the plastic panel above the radiator called?
- Check engine light problem
- My car beeps.
- adj. fuel reg...anyone
- Need Help pleeeease!!!!!!!
- Front driver's side wheel...thingy
- Getting the most out of GT40Y heads?
