PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Dynoed on motor, and 100 shot
  2. where to get wheels stripped and polished
  3. Intake Swap
  4. Which Tires?
  5. 95 Cobra Long-tubes??
  6. Question About Touch-up Paints
  7. Gauge Cluster Question.
  8. Need help finding the correct parts?
  9. Spacer needed for tall ford racing valve covers?
  10. Air Bag code....HELP!!!!
  11. T5 swap question
  12. HELP: FUSE PANEL MAP
  13. 94-95 Mustang Cobra 5.0 Typhoon Intake 70 Throttle Body
  14. lightning maf plug
  15. Are Pro-M MAF good?
  16. Guys with wheel spacers, I NEED HELP!
  17. Is 300hp/tq reasonable with my combo?
  18. Removing taillights???
  19. Run Flat Question
  20. Which fuse is for the cigarette lighter?
  21. Finally blew a tire
  22. IDLE PROBLEM...SOLVED...SORTA!
  23. fuel pressure
  24. Cobra Front control arms
  25. Help! front end is clunking
  26. Removing corner lenses.
  27. ok, so what is EVERY part i will need to do the H/C swap
  28. oil pan question
  29. AFR 205's or CNC'd TFS 205's?
  30. Will this T-Rex work?
  31. Rear taillight ?
  32. BBk Underdrive pulleys????
  33. Longtube install on AODE convertible done!
  34. 99 explorer upper and lower intake
  35. FloPro's RUNNING single turbo gts!!!
  36. Strange Struts and shocks
  37. Just bought the steeda CC plates... right move?
  38. Black tail light bezels.
  39. She died(car) on interstate coming home
  40. paxton novi on a 95?
  41. blower cams?
  42. Can aode d/s be used on a t-5?
  43. E-Brake Boot?
  44. Where can I find GT40 Heads?
  45. anyone running steeda 19 cam?
  46. what flow rating on stock fuel pump?
  47. stock TB size
  48. To cam..or not to cam?
  49. Cobra brake upgrade
  50. MAF Torx Screw
  51. Car boggs after pickup coil replacemnet
  52. stock fuel pressure...
  53. Revalation......Could 02 senors be at fault?
  54. 87-93 cobra intake , will it work
  55. Pro M 80mm - Worth it to replace C&L 76mm?
  56. Mequiars PLASTX plastic cleaner / polish
  57. Anyone have a 6-pt cage?
  58. Need help with line lock , where to buy good one BUT not expensive
  59. speedo gear
  60. 94-98 Service Manual CD - Anyone Have It?
  61. in the middle of a intake swap
  62. Mach 460 Buzzing sound.. Driving me crazy!!!
  63. Stall After Revving?
  64. Damn brake lines.....HELP!
  65. Would a new intake be a benificial mod for me?
  66. My H-pipe came apart!
  67. i still cant figure it out
  68. Can someone please help me identify where this alternator wire goes? Help ASAP!
  69. ARP: studs or bolts
  70. Weird Knock...
  71. Aftermarket hood helo
  72. Fuel Pressure/Timing?
  73. Brakes are gone....
  74. Vortech Pulley Sizes? #'s of Boost
  75. steering wheel noises
  76. Engine Code T???
  77. Walbro 255lph pump enough?
  78. Rear Drivers side tire rubs when I hit bumps.
  79. Go with aluminized or stainless Bassani X?
  80. Shock ,Struts ,and Springs Oh My
  81. Any New Jersey Tuning shops?
  82. Car smokes after turned off?
  83. Are GT-40X Turbo Swirl Aluminum Heads from FRP a good bolt on?
  84. T5 Conversion kit
  85. Ring and Pinion
  86. Cylinder Compression Questions
  87. What fuel pressure after MAF and injector
  88. cobra upper and gt40 lower?
  89. Cost of T5 rebuild?
  90. 95 cam and injector questions
  91. Will This MAF Sensor Work?
  92. Spring rates and spring lengths for t/a phb
  93. TPS, IAC Adjustments
  94. Changing Turn signal/Wiper thing
  95. Explorer Lower Intake?
  96. fuel pump installation
  97. Getting my gt40's ported. Need advice.
  98. Distributor Squeaking??? What?
  99. What other uses is there for a Tweecer than "beefing" up an aode.
  100. Stock heads milled ten thousandths
  101. H/C/I questions...
  102. Hows this sound? OPINIONS NEEDED!
  103. list update
  104. Help! Frozen Engine
  105. Supercharge my Cobra?
  106. What Bolt-on Next?????
  107. T-5 Transmission noise
  108. 347 Installed but won't start...please help!
  109. Speed adjust for '95 t-5
  110. About to order heads...
  111. where can i get a re-key set
  112. sucking oil in the pcv valve
  113. Lug Nuts for 95 cobra rims
  114. Best Gear for Blown Cars
  115. Water Pump Heater Plugs
  116. how does this setup sound
  117. Heating problems
  118. Recoloring Ford Emblem
  119. TAX MONEY what sould I do????????
  120. rocker arm upgrade?
  121. What need to change for it to work?
  122. What to do with my suspension???
  123. Speedometer/Odometer Problem...STILL!!
  124. RPM type intake on stock heads and cam... but with boost
  125. My TwEECEr helped me diagnose a problem
  126. Crap..One wheel peel..
  127. Anyone know whats intake port opening on TFS Twisted Wedge
  128. anybody know about holley inline fuel pumps
  129. Window Switch
  130. Timing cover gasket
  131. Power Trip
  132. Think I solved my motor issue
  133. VIN number decoding
  134. I too, am getting very worried.
  135. wickedly stupid question
  136. Setting Timing for Blown Cars
  137. Question About Side Exhaust Companies
  138. Ran out of gas
  139. What cable, quad, and adjuster to buy?
  140. quick idle decell
  141. Ford Cam Time... (Clearance)
  142. Bad Transmission?
  143. Valve covers
  144. performance modules?
  145. More ignition problems
  146. Guys with AODE/GEARS...Come on in!
  147. Idle Reset Question...Hmmm
  148. MSD 6AL
  149. H/C/I Pics Inside....
  150. Idle surge
  151. Does an A9L connect directly where the old computer was?
  152. AFR Install?'s
  153. GT-40 Heads
  154. Airbag light.....?
  155. Original Water Neck?
  156. 95 Stang GT nitrous
  157. I'm wanting to buy a cobra intake but have a ?
  158. Which Engine choice to go
  159. Help me.....im feeling pretty worried
  160. what is this ?
  161. ebay aode's
  162. Question about scantool and 02 voltage
  163. Help me shop (heads)
  164. finally got dynoed
  165. New paint job.
  166. H/C/I Install Done Today!!!
  167. Beggining My Engine Upgrades
  168. A little rough running
  169. Which front bumper for airflow...
  170. side exit question
  171. AFR-FTI-Edelbrock Combo Questions
  172. How much LESS power do you make going to carb?
  173. Brembos Are On *Pics*
  174. Magnaflow H?
  175. removing bearings from alt.
  176. Oil pressure Sending unit questions
  177. EBC Red Stuff Pads
  178. SLP Loudmouth II CATBACK?
  179. Dyno Comparison Vortech SQ vrs KB Blowzilla
  180. Lots of smoke coming from breather and dipstick
  181. Subframe connector install $?
  182. Rearend Problems
  183. What lifters i need on my 302
  184. Fan wiring question
  185. Tranny help!
  186. BBK or MAC headers? or keep cobra headers (HELP!)
  187. fuel tank capacity
  188. Old School 408 transplant
  189. Does anybody make longtube headers for our cars besides BBK?
  190. Where does the shop plug in when doing a dyno? What port where? Thanks...
  191. 5 questions about finishing my engine!!!
  192. Mechanic can't get a connection to the driver's side console..huh??
  193. What is the difference between 87-93 and 94/95 bearing retainers? Because...
  194. throttle body worth it?
  195. Stock deck clearance?
  196. camber plates needed?
  197. Stock frontend bushing job?
  198. What size fuel rails after stock size?
  199. best low price mods
  200. What water pump you guys using?
  201. Arghh Help :(
  202. Gaskets for h/c/i
  203. SS Radiator cover for 94-95 mustangs?
  204. Anybody out there Convert Coupes to Convertible hardtops?
  205. Kenne Bell Purchase
  206. vert top weatherstripping need pics
  207. TKO vib...(pics)
  208. regular shorty headers on gt40p heads?
  209. Hal QA1 C/C plates
  210. pulley info help
  211. Edelbrock SDT sound files (cat-back)?
  212. what fork for tko
  213. Foxbody TB Swap Question and $400 to spend
  214. pcv + blower = high idle ...
  215. victor 5.0 intake
  216. Who in here is running 2.02/1.60 valves???
  217. Rocker Question
  218. Need opinions on my new set up
  219. Help me spend my money
  220. 94 GT: Temp guage wags & car sputters?
  221. Identifying a KC clutch?
  222. converting throttle body
  223. aod to 5 speed
  224. A9L CPU Question?
  225. Valve covers and the 93 Cobra intake?
  226. Bad gas?
  227. What Sensor feeds the Temp Gauge on the Dash?
  228. New heads + 1.6rr's = more piston valve clearance?
  229. Lobe Separation ?
  230. What springs?
  231. Ball Joinsts,struts,tie rod ends??
  232. new here, have a few questions.
  233. Powerdyne Blowers
  234. What gasket do i need with TFS Track Heat intake
  235. Will this "safely" get me in the 12's
  236. want build a 351 in my 95GT need help
  237. Help me choose suspension setup
  238. Adj FRP: pressure dropping after key on, but no leaks
  239. !!!!!Everyone Please Look, Really important questions!!!!
  240. Ford Racing Catalog Cobra R
  241. Harmonic balancer
  242. snow performance or afm mr. freeze
  243. What size inj. would I need?
  244. Would a MAF solve this?
  245. HELP!~~!!~!~
  246. Is our water pump the same as fox's?
  247. Tell me if anything in my purchase looks bad .... Killer, RC get in here :)
  248. Check out these wheels!!!
  249. Rust Removal (U/D Pulleys)
  250. Another Exhaust Question
