View Full Version : 94-95 Tech
- Adj FRP: pressure dropping after key on, but no leaks
- !!!!!Everyone Please Look, Really important questions!!!!
- Ford Racing Catalog Cobra R
- Harmonic balancer
- snow performance or afm mr. freeze
- What size inj. would I need?
- Would a MAF solve this?
- HELP!~~!!~!~
- Is our water pump the same as fox's?
- Tell me if anything in my purchase looks bad .... Killer, RC get in here :)
- Check out these wheels!!!
- Rust Removal (U/D Pulleys)
- Another Exhaust Question
- very strange tps problem
- Grinding gears
- question about a/c vent....
- Will this work on our cars?
- LOCKING header bolts
- Squeaky Steering noise
- What header gaskets to get with TrickFlow heads/Mac Longtubes? Also,header gasket ???
- foxbody t/b converions
- Cutouts? Anyone try these?
- 2 1/2 inch tail pipes-where to buy?
- fuel injectors?
- Need height measurements of TFS Track heat intakes
- Guys with TFS intakes ,post your pics of engine bay
- Upgrading intake to TFS Track Heat , polished/ported Cobra intake coming off
- Throttle body adapter TFS vs SVO
- Which Struts?
- Fuse location questions, and an electrical tip
- Any difference between Cobra & GT40 *lower* manifolds?
- Help with custom grind cam, please!
- Mac Pro Dumps
- For those with Autometer tachs......
- sluggish?
- 240hp/265tq. THIS IS BS!!!
- ATP Balancer
- DynoJet Wideband Commander?
- Anybody know of a good place to take you car in MD for a tune?
- all those wanting new gauge cluster
- G-force T-5 - TKO's Opinions
- Torque Thrust IIs did not clear Cobra breaks
- rear problem
- Balancing flywheel
- This isn't important...right?
- BBK sent wrong EGR tube...
- TECHNICAL ELECTRICAL
- Aftermarket rotors- Are They Alll the same??
- SN95 Tech info needed
- What's that smog tube at the back of the heads?
- inline fuel pump ?
- X or H pipe Ques
- anyone got fireball?
- Mexican block?
- Timing question
- This is what I get for letting someone drive my stang. Can anyone help me fix it?
- #5 low Compression.. Ideas?
- How to route a-pillar gauge wires???
- Will low voltage from the alt make the CHECK ENGINE light come on?
- What cam for SN95 331 AODE?
- will a Cervinis ram air hood fit over kenne bell?
- Clutch decision. I am lost. Any help?
- Re-furbing the main engine wiring harness?
- Help! Car loads up unless set to 15 degrees timing...
- Nitrous safe/performance parts list help
- Gears and 60' times
- glp
- What size tires???
- Alignment
- can injectors be too big?
- still having problems.. help
- GI-NORMOUS Repair BIll
- Flowmaster American Thunder
- How low can i go?
- Clunking in front end!!
- is this clutch enough for my set up?
- Sluggish at low RPM
- Which rear end & axles to go with?
- rebuild a kirban regualtor?
- no smog pump + stock H pipe = problems?
- PLEASE HELP!!! MAF stress!!
- PULLEYS, PRICES, THE BEST...
- bosch injectors
- Bad setup or am I nuts?
- GT40 HEAD BOLTS
- Clucking sound from front left wheel.
- Whats up with these roller rockers, input needed
- staring to collect parts for t5 swap, what flywheel?
- Fresh clutch, 600 miles later and disengage/engage problems
- ABS abd Parking Brake Light on??
- ATI procharger experiences?
- stock cobra hood
- Cobra brakes using fox rear end on sn95
- Nitrous- whats your opinion
- 95 GT problem
- Anybody know the bolt sizes for the stock vert x-brace???
- What all is involoved in swapping to 96-98 tail lights?
- 87-93 alt. bracket work for 94-95?
- Got cobra bumper w/ lip... What license plate bracket do you suggest?
- Will 87-93 Long Tubes fit a 94-95 GT??
- Hood question, 351W, TFS box intake in a 95GT
- New clutch and flywheel?
- Rear brake upgrade??
- fuel injectors
- Which Brands for Tune up
- sorry to ask again (13" front disks).....
- stall converter questions
- Stock 16's w/Cobra brakes? Any way?
- c/c plate question
- How hot do you guys run on the hwy??Ge
- Code 556 fuel pump primary
- How long to Adjust Rockers?
- Thermostat Questions...
- H/C/I + blower combo Q's
- conv top motors are friggin expensive
- Automatic Transmission questions...
- smog pump
- Need some help figuring this out
- I need to Know what valve stem seals i Need
- PVC Valve
- Those with G-force trans-need opinions
- I need a new clutch kit
- What does it take to run with the 03/04 cobra
- Who makes 3" exhaust?
- loose axles
- Please critique yet another combo.
- Yet another HELP ME THREAD
- Where is the test connector on a sn95??
- brembo 4 piston calipers
- 70mm or 75mm Throttle Body
- I/P Fuse Panel - Fuse 8
- Foxbody TB Swap Question
- Couple Newb Ques
- what motor parts from 87-93....fit 94-95?
- What are your thoughts on this?
- Heeeeeelp!!! Trying to put a 94 back together.
- maf question
- Tell Tell Signs of a blown head gasket
- Crane PowerMax 2020 cam, good idea???
- Prof. Products Intake Manifold...
- worn pistons????
- Exhaust clearance
- Suspension Junk
- vert operation question
- please estimate my hp
- Cervinis heat-extractor hood
- 17X8 Bullitt Style Wheel Black w/spinner
- Low Oil and coolant.... According to my gauges.
- quick question
- how much power out of lt over shorties
- Help with tourqe converter problemo
- Best place to buy new center caps??????
- How many different PCM Codes
- BLOWN AND STROKED
- Which Alternator for 94 vert? Why 200Amp vs 130? What does it do?
- Where to buy?
- summit brake rotors - good?
- Alum flywheel on stock motor
- stock valve spring lift?
- How To Find TDC #1 Without Using Balancer?
- how much hp through stock T5 and with what clutch?
- Gunk ValveMedic...?
- Anyone with a similar setup??
- Impact Sockets
- Timing help
- tko 500?
- Another just got back from the Dyno thread..
- CRAP! I scratched the side of the stang up.
- exhaust ques. i tried searching
- help...blower or h/c/i for my car?
- QUICK, how much oil in our engines????
- aode question
- alternator mounting (turbo and supercharge people)
- Engine rebuild
- BYPASSING LOW OIL SENSOR
- Starter Sounding Funny
- dyno #'s,is this ok for stock cam car
- mach 460
- 8.8" rear question
- MAF recalibration PRO M HELP!!!!!
- Does the stater/pick-up coil eventually die?
- Total newb question
- Anybody know anything about '98 V6s?
- stupid check engine light
- Strange idle loop
- Supercharger high miles
- Smog Delete Pulley
- Need SERIOUS opinons and quickly!
- AODE Question !!!please help!!!
- 94 Cobra
- SUSPENSION
- Performer heads + custom cam
- Alt. internals...those who have taken apart
- Nitrous Plate
- 440rwhp looking for more
- Does porting the stock MAF help any?
- Blown Head Gasket Quest.
- MAF Screen
- 1st gear
- FR500's
- Strange transmission question
- Pics of car... Tuned now.
- are the rear brake pads same as the fronts?
- Stripped out header bolt hole on alluminum head, how can I fix this?
- Vortech S-trim Questions
- Arp Head Studs
- 302-351w swap questions
- Misfire at idle
- hitting the rev-limiter...
- My valve springs are binding . . . questions on new ones!
- caster/ camber needed?
- Anyone taken the rear seats out? Help.
- Is my Car Possessed or terminaly ill
- Distributor install, stator install, all the above
- 94 GT 5.0 performance problem help
- Seat rails broken...
- Wiring gauges question
- underdrive pulleys on a blower
- Loss of ignition...
- Computer Removal
- Blew a head gasket
- Cam Degree?
- Installer/tuners in Los Angeles area...
- Smog Pump Removal questions
- New Sub Forum, I need your thoughts.
- Clutch Problem
- Tryed starting the Car Yesterday...
- What are your opinions on aftermarket fenders?
- GOT A FUNNY VIBRATION UP FRONT ! ANY CLUE WHAT IT IS ?
- Brake Light
- Valvetrain Power Loss
- Cylinder head and machine shop question
- upper intake question
- March performance spacer. missing bolt locations
- Finally got my car to stop dumping fuel but one problem..Help?
- Kudos for Cobra_Dusten and 98gtblue Leo
- Exhaust again: No drone please
- What lenth belt After Smog delete
- Replace Vert K-brace with this?
- BULLIT WHEELS
- stupid brake noises
- SPARK changes in AFTERMARKET HEADS..,??
- 15x3.5 + long trip= good/bad idea
- T-5 to Auto (Trades)?
- Where is the IAC air bleed screw?
- To those with Saleen door stripes:
- r134a with leak sealer
- All AFR/FTI/EDELBROCK guys in here NOW!!
- Quick TKO question
- what tranny
