PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. gauge install
  2. dyno results
  3. Vortech MAF?
  4. How well does a manual rack and pinion drive?
  5. parking brake adjustment
  6. Cap & Rotor Question
  7. charging problem?
  8. intake or stall converter,shift kit
  9. When installing a new fuel pump, any computer changes needed?
  10. Those runnin a 28" Slick
  11. Off road h pipe that fits good??
  12. 5-lug question
  13. Engine Mount Help!
  14. Should I put a cam in my 94 Cobra?
  15. Do S281 Spoilers cover both holes?
  16. I gotta job!!!What are these mods gonna do?
  17. What mod would you do if...
  18. Bleeding Brakes
  19. tranny swap
  20. Relocating battery to trunk
  21. Headers keep leaking
  22. TDC: necessary?
  23. Which camber plate?
  24. Vortech Supercharger Question?
  25. Gasket Question
  26. corner light rubbers
  27. Car question/problem.....not Stang related
  28. Anyone tried UPR "EL-GLOW gauges"
  29. What would cause one this rear end issue...
  30. Driver's window
  31. gas or oil pressure?
  32. Intake swap
  33. SN95 RPM Extender Part Number?
  34. want 400+ rwhp....iron or alum. heads?
  35. Crane Hi-6 users, Did you get the optional wiring harness?
  36. Clutch help--which adjustment setup?
  37. Weatherstripping - Where do you buy it???
  38. just drove the turbo mustang
  39. where is the bumpstop?
  40. pre-94 T5 Users
  41. Bearing Retainer Installation
  42. power steering pulley tool kit?
  43. Remanufactured Dizzy or MSD Dizzy?
  44. Where to buy 18" chrome Saleen wheels
  45. Where to buy Saleen body kit ???
  46. Thermostat questions
  47. Starting Preformance Upgrades
  48. Diablo Delta Chip?
  49. Water found on both sides of trunk? WTF!
  50. auto shift handle
  51. MAF guestion for 306 with kenne bell
  52. Anyone swap a dash out in a 94/95?
  53. 13" Cobra brakes on front, WHAT TO DO WITH REARS out of these 4 choices?!?
  54. pro-stars on rear of cobra?
  55. 94 gt won't start after intake swap
  56. What are the best gears for STREETable HP? Big difference?
  57. How can you make a basically stock block handle more than the 450HP mark?
  58. K/B: these plugs ok?
  59. Boost Question
  60. Plugs and Wire suggestions ???
  61. Painting....Flex additive?
  62. Will a set of heads drive my CPU crazy???
  63. Original tri-bars 17" wheels will clear cobra/bullit 13" brakes?
  64. Got my new brakes (pic), question...bleeding and what fluid?
  65. T5 stuck in fourth
  66. 95 Stang Overheating
  67. Winshield
  68. Collapsed lifter after new heads/springs
  69. Giving up on the band aids, Seriously thinking of going to town on the Stang!
  70. o/r x-pipe or h-pipe, which is better?
  71. Canton 7 Qt. oil pan and dipstick question?
  72. Cobra VC's
  73. how safe is a 100 shot on a 5.0
  74. Took off the slack
  75. B & M megashifter AODE?
  76. Loss of power, maybe a little sputtering from the engine?
  77. Where to get Line Lock, and where to locate button?
  78. What to do next on a Cobra
  79. Trick Flow Kit
  80. Diamond Head Lights
  81. question
  82. fuel filter
  83. Please Help Which Setup and what kind of numbers???
  84. aode problems
  85. what do you believe to be accurate?
  86. people with aftermarket oil pressure gauge?
  87. Read my S. Plug
  88. lockup or non-lockup People with Edge
  89. where to get cobra intake
  90. Fuel pressure reg. HELP!!
  91. another pcv question (application specific)
  92. Anybody here running an F303 Cam?
  93. Anybody here running an F303 Cam?
  94. Anybody here running an F303 Cam?
  95. Headlights to low.
  96. Fuel Pump issues... any help is apprec...
  97. Charging Problems !!!
  98. Removing Rear Quarter Panel?
  99. Is there any point to the breather on the left valve cover?
  100. Air Bag Light
  101. What do you think of these alternators?
  102. Wiring an auxillary ground
  103. MGW Shifter
  104. Changing oil pump
  105. which aftermarket overflow tank are you using?
  106. Engine bay molding: new panels or fill in holes???
  107. need help?? 94-95 convert rear windows...
  108. Code 511 & Code 137 KOER - Help
  109. possible to pull oil pan without pulling motor?????
  110. Deleting PCV? Should I do it?
  111. My A/C Makes a noise
  112. Noise when I turn right
  113. door adjustment
  114. are these 3.27s?
  115. Post pics of polished Cobra Upper Intake
  116. HELP: Manual fan switch for track use
  117. Oil in upper/lower intake on a supercharged car....pcv?
  118. Quick timing help
  119. Froze My 5.0
  120. Convertible top rear window.
  121. Maf & INJ Basic Info
  122. Symptoms of a Bad Tie Rod End?
  123. My car idles good 'til....tweecer help needed
  124. Got myself a mustang...
  125. What is a "respectable" quarter mile time?
  126. putting in a 93 cobra i have the elbow and valve
  127. HELP sn95 aode transmission to a 88 aod
  128. fuel pump priming over and over and slow starting !!!
  129. fuel pump priming over and over and slow starting !!!
  130. smog pump comming out.
  131. Which MAF???
  132. Best place to buy Pro-M MAF?
  133. Code 538
  134. Adjusting Timing
  135. fox valve covers on my 94
  136. Lowering springs
  137. Deciding if it is time for a torque converter???
  138. Eibach lowering springs + 315s in the back...
  139. dark red frpp injectors ??!???
  140. Need Help,car Died And Wont Start
  141. How do you get to the #4 plug?
  142. My overdrive button won't work when car is cold.
  143. Trickflow H/C/I vs. AFR setup
  144. idler puller torx bit size
  145. Thumper E7 guys come in
  146. Installed BBK 70mm T/B now idle hangs???
  147. Canton oil pan
  148. how to get door panel on
  149. Need some quick gear help so I can place order!!!
  150. Can I just load the pro-m for 24# injectors in my maf transfer?
  151. 95 GT mass air ???
  152. Clutch Pedal Assembly
  153. Torquing pulleys?
  154. iron gt40 heads
  155. Well this blows, wrecked my car :(
  156. ok changed plans on the intake
  157. Darn electrical gremlins
  158. GT-40P's
  159. New block to be released by for in 2006
  160. 95 cobra trunk and wing
  161. Which is the most practible method of boost?
  162. C&L guys-quick question on tubes/inj?
  163. Pinging after CAi installed
  164. UPR Clutch Quadrant - How much slop?
  165. how to get shifter handle off auto
  166. White smoke and idling rough
  167. I need help..something is really wrong..
  168. More help w/Combo...
  169. Is the IAT really needed?
  170. Not Again
  171. bullit suspension:Does it come with swaybar bushings?
  172. rear caliper trouble
  173. Tweecer CalEdit update
  174. Breather cap question
  175. after market steering wheel?
  176. 95 Factory Cobra Intake
  177. #24 injectors??
  178. How much would a shop charge to install heads?
  179. Rear Brakes Rubbing
  180. Broke key in ignition
  181. Too much head !!!!!
  182. Lokar throttle cable for 94-95?
  183. How hard to degree and FTI Cam?
  184. Car is BackFiring, has a High Idle, and Reeks of Gas. Exhaust Leak? Bad O2's? Help!
  185. Transmission Wiring Diagram
  186. bullit suspension: offset front bushings and different swaybar bushings?
  187. typhoon intake and valve covers
  188. Tried the search on this, maybe I need to up my search skills but J4J1 and Pro-m...
  189. Backing Break Cable Snaped
  190. Replacing Power Steering Pump, Tips or Suggestions?
  191. aode to tko swap- jumping wires didn't work
  192. some tune-up info needed....
  193. Tips, Tricks?
  194. Foxbody throttle body swap
  195. FRPP MAF and Computer
  196. massive cooling problems
  197. PCM Equivalent of Carb Accelerator Pump ?
  198. OEM 60mm TB & FRPP 65mm TB INFO
  199. MAF Meter..is sodering a must?
  200. I need a new balancer?
  201. underdrive pullies
  202. I can't get my parking brake off HELP!
  203. Educate me about gauges
  204. Low oil light question
  205. Smog and A/C delete (belt size)
  206. Drags today.
  207. Odometer quit yesterday
  208. Power Steering Fluid Shooting From Cap!
  209. Need rear brake help Please.
  210. How the hell do you get the @#$%ing fuel pump out!!???
  211. Anyone here from PA ??
  212. 31 spline diff - opinions please
  213. Removing factory leather seat covers..
  214. is it worth it?
  215. T-5 into SN95 questions
  216. Buying parts today. Few questions
  217. twisted wedge or afr's?
  218. Anyone with 94/95 Black & Gray Interior update Console??
  219. Help Car won't start... working on it now
  220. I can pull my key out
  221. ignitione <<i think thats french for ignition
  222. ignitione <<i think thats french for ignition
  223. Best H/C/I combo for stock 302 bottom end?
  224. wet or dry Nitrous.
  225. explorer intake
  226. sun visor
  227. Figured out the Bogging problem!!
  228. How much weight does the A/C Delete save?
  229. Boost ret ???'s
  230. Gauge installation.
  231. sticky steering
  232. would you or wouldnt you
  233. Replacing 94-95 intake with 93 Cobra
  234. idle issues
  235. Hellp
  236. Anyone know the height of the stock valve covers off hand? It's late..
  237. Hmm... with larger valve covers..Am I going to need a spacer for the TF intake?
  238. GT40 tubular upper help...
  239. Competition Engineering Roll Cage
  240. All of a sudden car has high idle?
  241. What size injector did ford use in a BB
  242. If I drain the anti-freeze and it is below freezing, will the block crack?
  243. Trouble Getting MGW Shifter into T56?
  244. Parts that just break and those that wear out?
  245. Doesn't want to start....sometimes?
  246. HVAC fan speed control only works on 4?
  247. Distributor
  248. Searched to no avail...
  249. Are these the clips for the trim pieces under the door? Mine is missing some....
  250. Going from hard line to AN fitting Q
