PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Is this common??
  2. Cause Of Odometer & Trip Odom Not Working.
  3. New best Timeslips..LOOK
  4. vibration
  5. Head gaskets installed backwards???
  6. taillights are so ugly
  7. CraneCams Valve Spring Kit
  8. Gas mileage and fuel injectors...
  9. Drilling a hole into the firewall?
  10. Christmas is coming and I need advice...
  11. 90 motor?
  12. Thinking Twice
  13. Alternator covers?
  14. Do i need an adaptor??
  15. Can you please reccomend me a good cam?
  16. what h/c/i
  17. Cobra Intake Users Please Help
  18. Bolt turns with nut!! No access to bolt head -HELP!
  19. noise coming from aluminum ds??
  20. How many amps does the stock alternator put out?
  21. Stupid FUSES, Question?!
  22. New seats!!
  23. Looking for 94-95 with blown 351 (pix)
  24. Trick Flow Street Heat Install Comments
  25. lookin for torque bar and panhard bar
  26. TrickFlow Engine Kit
  27. Bumpsteer Kit install
  28. TB question
  29. Installed my MAC Headers and H pipe
  30. Opinons on SPRINGS much appreciated...
  31. Once I hit 4500 the car misses and spikes lean, what could that be?
  32. What would you change before you started to beat on a car? (Tweecer)
  33. Spring isolaters
  34. tranny cooler
  35. What Gears?
  36. Question about rims i bought
  37. MSD dizzy
  38. Cleaning the upper intake
  39. For all of you handling suspension gurus..
  40. Ignition problem, out of ideas.
  41. Finally Decided to get Blown
  42. seats and ????
  43. A couple question regarding tuning and exhaust fitment
  44. What to do?
  45. E7 head shootout!!!
  46. WTF car wants to stall whenever the A/C is on
  47. AODE taking a crap on me?
  48. Rear Main Seal
  49. Replaced Quad shocks yesterday---they DO make a difference!
  50. Overflow(reservoir0 question
  51. Interior replacement parts?
  52. HCI with AODE questions
  53. owner's manual says 5w-30 or 10w-30?
  54. timing again..
  55. 03 cobra complete front end on a 84-98
  56. CRAZY vibration
  57. Mr GRADY.........and all (Tweecer)
  58. dyno tune
  59. If anyone is interested....
  60. has anyone modified or removed their heater tubes?
  61. exhaust question
  62. ford racing supercharger ??
  63. Traction Severely Limited, New Tires Needed
  64. big HP diff between a TFS intake vs an RPM?
  65. Transmission wont stay in first
  66. Rear Bushings Need Replacement;sources?
  67. Computer conversion questions
  68. Question on O2 sensors/tweecer Q
  69. Cheapest place for a aluminum driveshaft?
  70. Dart block over an aluminum?
  71. Would you reccomend a blower for a DD?
  72. 31 Spline Rear Build Up
  73. Factory stereo amp location
  74. paper towel in motor URGENT
  75. trade vortech for kenne bell???
  76. Tuning help
  77. Self Tuners enter here - help is needed.....Here goes Grady
  78. Rear wheel backspacing
  79. where to find "Drivebelt wheels"
  80. T-Handle shift knob
  81. T-Trim Initial Dyno
  82. Bump Stop
  83. can I benefit from porting my lower Performer manifold?
  84. Dallas Area
  85. aode cooler and fluid change
  86. C-Clip eliminators on 94 & up cars?
  87. head light question
  88. heads installed-car hesitates sometimes
  89. heads installed-car hesitates sometimes
  90. How much would an R302 block cost?
  91. Tweecer or AEM ?
  92. Anyone have FRPP M5230M51 cat-back installed?
  93. Do the 94-95 Cobra seats have "Cobra" embroidered on them?
  94. Track Heat Intake And S/C
  95. Back Spacing help
  96. rebuilding my tranny... questions/suggestions ??
  97. ANOTHER gear question...
  98. Anyone Heard of This (Electric)
  99. will a fox tfi work
  100. computer chips
  101. Cobra Seat Wiring HELP!!!!
  102. dyno tune question
  103. chip reburn after intake change?
  104. 2nd gear == loud bang?
  105. 89.5" or 90.0" belt for smog bypass?
  106. Installing Sony cdx-m8800 into car, what harness do i need?
  107. Will 93 Valve Covers fit a 94?
  108. Done...well almost
  109. Replace T-5 but with what?
  110. obd1, and obd2 ports
  111. Tremec TKO
  112. What type of Horn system do we have?
  113. TB Questions
  114. FMU question
  115. adjustable fuel pressure regulator
  116. threadchaser // tap n dye
  117. Urgent Belt Question!
  118. Who has an aftermarket head unit?
  119. anyone ever put a 03-04 cobra bumper on your 94-98?
  120. Would Higher Octane Gas Make Your Car Slower?
  121. clutch cable bracket
  122. what comes with the prokit
  123. Ugh, my problem continuation
  124. Specific Mods Question...
  125. Anybody with a JLT Intake?
  126. LT/prochamber question
  127. I broke my car!!!
  128. 94-95 ported cobra intake for sale
  129. Alternator Whine?
  130. Backed my timing off - lots more driveable
  131. Brake blowing fuses, Any ideas?
  132. Lost Power
  133. for those that said my car didnt have enough bling.....
  134. Running Hot and Rich Help
  135. Stupid Car!
  136. Homemade CAI or Ebay?
  137. Do Trickflow Heads come with Head bolts?
  138. convertible trunk vs coupe trunk
  139. Cheap Supercharger?
  140. just bought a cobra intake
  141. would a rotted gas line smell?
  142. New guy here! Annoying resonating noise from supercharger...
  143. oil change after seafoam...
  144. Best clutch? Opinions wanted!
  145. Beehive springs on our heads???
  146. gas tank
  147. Car died on Highway, need some help.
  148. transmission experts, advice needed
  149. Car fixed, Distributor to blame! GRRR, YAY!
  150. do these pics look like my heads have moved/slid?
  151. Bogging!!!
  152. Dyno Numbers for cheap/free mods.
  153. Under hood Cobra art
  154. How low can I go with side exits?
  155. home made egr delete
  156. Chin spoiler
  157. clutch problem
  158. How do you recalibrate an OEM MAF???
  159. Why NOT the TFS intake ????????
  160. Gutted 94.... any ideas?
  161. 95 gt want more power
  162. settings on tokico 5 way adjustables
  163. is the bbk pro plus shifter any good?
  164. is the bbk pro plus shifter any good?
  165. Do phenolic intake manifold spacers work? What do they do?
  166. accelerator pedal modification
  167. 94-95 combos!
  168. Chris!! (donjohn) What happened to your exhaust page?
  169. Rpm Extender
  170. Grady....Log Analyst
  171. Take a look at my rear shock busing (top) is this bad?
  172. newbie questions
  173. Spring Tech struts ANYGOOD????? suggestions
  174. HELP with Cats
  175. New speedo gear
  176. Cam and Intake Choices
  177. stalling
  178. Gears ?
  179. stiff shifter
  180. Cooling ?
  181. Stock Radiator's Shot- Need Help What To Buy?
  182. Did I Mess My Clutch Up?
  183. Maxed it.
  184. How to take off cowl?
  185. Stock Oil Pressure Sending Unit, how was it installed?
  186. Injector Break Points - Per EA
  187. Oil behind lower intake
  188. Widdest tire in the back?
  189. couple questions... help on parts!
  190. Fuel Demand question for the experts
  191. timing problem
  192. Please Need Some HELLLPPPPPP!!!!
  193. Help With 3.8 Mass Air!
  194. Opinions on possible setup..
  195. Rear Suspension Noise?
  196. 3:55 or 3:27?
  197. Can I run no pcv system?
  198. Need help with Header selection
  199. Another strut/shock thread
  200. Bassani X Pipe for Long tubes
  201. fox body lower intake
  202. Dealer Only ?
  203. Opinions On These
  204. Who has pics of Chrome/Polished pulleys?
  205. Good tip for you AODE guys.
  206. What next?
  207. Help with suspension noise
  208. PCV Help
  209. Something in my intake manifold?? Help please
  210. 99/01 cobra fuel injectors
  211. Car Accelerates When I Press Decel on Cruise Control
  212. Cruise Control button
  213. I did a tweecer data log. Man i think someting is wrong with something.
  214. Actron Ford Module?
  215. More Self Tuning Tweecer Info
  216. Is this what I use to flush my coolant?
  217. Intake Manifold ?
  218. converting to fox accessories, losing a/c, questions about balancer
  219. sticky idle
  220. Decided on a combo...which MAF with this?
  221. Opinions on These Engines?
  222. Underdrive Pullies + Alternator Problems = questions
  223. Wheel Spacers...Does Brand Matter?
  224. 87-93 alum D/S... whats needed to make it work
  225. Which sensor triggers ECM to turn Elec. Fan on?
  226. How to shut off EGR with tweecer
  227. can an overtightened lower intake spread/move the heads?
  228. Need a picture guys (PCV line)
  229. Underdrive Pulleys, How long a belt do I need?
  230. Idle problem
  231. My Car
  232. best control arms?
  233. What suspension mods are fairly easy to do with basic hand tools?
  234. The infamous bogging...how do I get rid of it?
  235. Pullies
  236. Are our cars factory alarm ready??
  237. Tweecer IDLE on "warm-up" question....
  238. Cobra Calipers
  239. tune-up done
  240. Adjusting MMR coil overs?
  241. driveshaft removal
  242. Weird engine temperature
  243. Need Help Installing new Intake
  244. How does the trickflow kit work with an AODE?
  245. Diff/Axle Q's.....WHAT IS NORMAL????
  246. Stock GT dyno numbers
  247. how'd you tuck the tweecer back into the kick panel?
  248. question about tire fittment
  249. Rear end gears
  250. matt, heres the "p" head thread....(matthiasj)
