View Full Version : 94-95 Tech
- exhaust questions
- Whats needed to put aod into 95 GT
- Tire Question
- B-303 has less lift than stock cobra cam!?
- Vortech Injectors question?
- Cam Selection Advice
- Irritating power window problem
- Where to buy rear caliper tool?
- Let's talk TURBOS!!!
- Short shifter problems...Wont stay in gear
- 94 cobra mach 460?
- MSD Vs. FRPP
- wet shot still need tune?
- Car wont start
- some suspension questions
- getting bummed...help somethings wrong
- Coil over guys help
- EECtuning.org...all you Tweecers please chime in
- Valve cover screws keep backing out.
- Question on wrapping headers...
- Thinking about dropping the gt
- home made side exhaust
- Vortech Question
- I figured out my problem, now how to fix it (Runnig Rich)
- Whats the best product for engine sluge
- My car is freaking out
- removing flow bar in stock maf,ok to do?
- c&l 76mm maf
- Does a Fox Body Driveshaft fit our cars?
- What else needed for heads?
- Once again new E.T. ,this time thanks to 75mm TB
- throttle body ?
- Those with MM Caster Camber plates come in here
- odometer problems?
- Switching to Performer upper and Extreme Energy mounts-questions
- Where to obtain B Pillar? (Xr8ted)
- strength of a stock 351w?
- Spark Plug Connectionq
- belt length with no AC
- UPR Boostmaster Vs Andersons Powerpipe Choices..
- A/C no workee
- 3.08 to 3.73, what kinda 1/4 gains?
- ccrm pin 17 grounding URGENT!!!!
- Car spuddering
- 1 grand!
- Some questions
- Hissing noise....
- EGR plunger
- stock maf electronics in a pro-m setup?
- Intake Choices
- ABS / tire size question:
- Attn: Killer, Vib, 94turbo
- Will a 80mm MAS from a 96-98
- HP on a budget
- Rattle from under car while accelerating
- Weird feeling through brake pedal
- UCA's
- Tokico Strut question
- Aluminum driveshaft for a 95 Gt auto ?
- what speedo gear for 373s?
- HELP: I blew a fuse/created a short
- FMS lifters
- blue ovals intake package
- For Those Who Have Installed Their Own Steeda C/C Plates:
- what cam?
- Where to put Vacuum line through firewall
- Throttle Body recommendations for a 94 Cobra?
- NEW project
- Cobra R hood ?
- idle problems...
- Just made some purchases, what to buy next?
- wheel bearing issues
- Quickest BOLT ON 94-95 Cobra(Intake to Oilpan, stock)
- High idle after long drive?
- Oil pan for 351w swap?
- Anyone running a SCT meter
- Passenger Window Auto-Down?
- Is there anyone using the VSS 400K Ford security system
- X-pipe questions
- starter problems
- guys with brake upgrades please come here
- passenger window switch
- went to the dyno....
- Tune-up/Maintenance
- Quick question about MM LCA's
- Fox body suspension parts?
- One of my sparkplugs is oily
- Flooding Concerns
- Transmission ?
- Any ideas for getting two PIA smog pump bolts off??
- Swap Starting Monday!!
- Brake pads?
- drilled slotted rotors?
- What tire sizes should i get?
- Dead battery...right?
- best tire size for 17x9 wheel
- Throttle Body Install
- vaccuum problems!?!?!
- Which turbo company is better???
- gauge hook up help
- Gauge Cluster ????
- Noise gets louder with A/C. What is it?
- code 136, now what
- T-5 Rebuild Time
- maf and TB questions
- Where ecactly does the GT40 lower need port work?
- 95 GT - Need pics of steering cooler ON car.
- GT-40 Lower Manifold
- Need piston ring recommendations
- ways to check fuel pressure
- Tranny Troubles
- How do i modify my crossmember to fit a TKO600?
- How to install manual fan switches
- Time to Upgrade Blower...Q's
- Tune up help
- NEED INPUT! Idle surge and dying with AC and Heat.....
- Dipstick and FMS shorties, question.
- Mass air meter question
- Tore engine apart kinda baffled???
- Time For a Rear End Service....
- pushrod guide plates
- Help with fuel leak
- D&D t56 and MGW Shifter- Will It work?
- White smoke, leaking oil, weird noise??
- 1st datalog using Tweecer
- Valvoline HP gear oil, Friction modifier still needed?
- A/C Switches Tweaking Out
- Anyway to do a temp patch on a fpr diaphragm?
- trick flow head users qustion
- AODE will explode, need help!
- Anyone wanna calculate my shift points
- Started car--idle issues
- street edge vs the rest
- Need help! Urgent, taking drive shaft to pinion off...
- spring isolator help
- Harmonic Balancer MISSING?!
- Car backfires when shifting.
- For those who hid your engine bay wires but kep A/C
- VIN / VCL (Vehicle Certification Label) Decoder page
- Rear Seat Delete
- CAI bolts
- proper way to heat cycle new rotors????
- quick stupid question - stud or pedestal mount - pic
- ? about foxbody cobra intake and adapter.
- *QIUCK* is brake cleaner safe for zinc washed rotors?
- Help me remove a trim piece w/o breaking it
- H/C/I vs. Supercharging
- CCRM..topless!
- Cobra Intake Installed.
- Driveshaft alignment??????
- car problems
- Start up
- 331 vs 347
- hunting for 2 lucas 38# injectors
- thumper E7 vs GT40p
- Help me stop breaking stuff.
- Tweecer issues and questions: Please help!
- Anyone use a rear coil over kit
- Mustang
- All You KENNE BELL GUYS......
- Smog Pump Delete
- Can you port the stock throttle body ?
- Are Vert sunvisors different then coupe visors?
- Edelbrock Subframe Connectors?
- Need new shocks and possibly gonna lower......
- Will a '93 5.0 fit a '95 w/ a v6?
- questions about 4r70w
- Vertical Door Conversion Qs
- Polished Master Cylinder Done (Pics)..How to Put In?
- 10" or 12" coiover springs, what's the difference?
- springs?
- Fuel pump
- need 95 tfi module
- Advice wanted What next
- I Smell Gas...
- Car dying in reverse
- DSS Engines...Differences Between Them?
- GT40p Sparkplugs....what ones for boost?
- I Need Your Help!!!
- Location of the ECT sensor
- Smog pump delete..what size bolts behind the engine block? And h-pipe how to?
- Are SLP LoudMouth and MagnaPack the Same Basic Package?
- How to remove abs system
- Differences between a coupe frame and vert frame?
- Coil over problem
- Odometer Gears, where to find
- going to fix power windows this weekend, questions
- Help Please!!!!!!!!!! Anyone?
- steering wheel alignment
- Gonna Install my suspension stuff this weekend, anyone got any hints or tips??
- What year were gt40 heads and gt40p heads on explorers??
- got balancer installed..what a bi**h that was
- Phenolic spacer and EGR problem
- What points do I use to convert 9 pnt MAF to 30? (EEC Analyzer)
- Stock Cam Lift specs?? What will work well?
- block off plates (crossover)?
- Coil question??
- no spark-good coil 95 cobra
- how big of a power increase with budget build up?
- Intake Torque #'s
- Rear Seat Delete Question.
- My Ford Racing M-5400-A is on its way... What else should I do?
- Fuek pump not working? HELP!!!!!
- Felpro Manifold Gaskets
- sensor in cai
- What size air filter goes
- Got Tweecer installed
- Think Its The Fuel Pump...
- New speakers for my vert?
- PI stallion questions
- Car running poorly; need advice *have codes*
- Copule of questions (steering, fuel economy)
- Removal of low pressure hose at a/c compressor side?
- Fuel Pressure Test
- Battery distribution to the fuse box
- Is an aftermarket coil needed?
- long tube headers o/r h
- Headlight problems
- will i need a adj. fpr for dyno tune chip? and other ??
- Trying to trace down an oil leak - Suggestions?
- Spark Plug Question
- got a baseline, how much is on the table
- Almost Finished......
- harmonic balancer going bad?
- bad CCRM ?!
- cobra mass air question
- oil press. sender (autometer)???
- 93 headers fit sn95?
- Is it worth it to rebuild my Tremec 3550?
- Cars acting weird, do i need a new MAF and if so what kind?
- newbie q's
- Should I use pushrod guide plate?
- Stock Bolt sizes for Strut tower Brace
- please help me figure out what his noise might be?(kinda long)
- Bbk Afpr Q...
- Cam bolt specs?
- Twisted Wedge vs Track Heat
- affects of old fuel filter and spark plugs
- Scan said code 542???
- belt diagram?
- Did I overdo it with my injectors?
- Just Placed My Order W/ Summit
- No Power - Jerking - Feels like its Missing
- Fuel Pump Installation, Help please...
- please help some advice on c/c plates on lowered stang im looking at
- fox pedal assembly?
- Fog Light Assembly Replacement
- 306 vs 331
- dosent want to start when cold. help?
- heater bypass question
