View Full Version : 94-95 Tech
- tranny mount question
- Exhaust Leak
- Fuel Filter
- AODE slips???
- 347 adn exhaust questions
- Opinion on parts wanted
- 94-95 Mustang Cobra GT Kenne Bell Blowzilla 2.2L
- oil change
- Nitrous Installation Questions..
- torque specs on accessory bolts
- Opinions on These Control Arms
- How to tell GT vs. GTS
- Which spark plugs with Vortech & Boost cooler?
- This is driving me nuts!
- idle problems
- 95 cobra 351 alternator won't mount
- Anyone sorry they bought a tweecer? Lots of head-banging going on..
- Installing LT Headers
- Compression Results
- Weird Coil Problem
- Cobra GT40 heads, any good? what kinda hp?
- tranny help
- size of bolt for tensioner bracket?
- Cost of Porting Cobra Intake?
- Need to bore my block how much is 2 much
- Wiring help for MAF
- how do you remove the back seat in a 94 coupe
- Do they make a kit u can buy to swap aode to t5?
- my leather seats have started cracking
- How Much Boost Will My Combo Make?
- car shaking violently
- What hurts this combo most?
- b-303 camshaft ???
- Leaking timing cover
- My seat just took a S***
- What psi to run mt e/t street radials at?
- holley systemax Ii
- 94 gt roller rockers - ?
- Front Struts...C/C Plates Install ???
- Power Steering Pressure switch
- ECT & Coolant Temp. sending unit confusion with autometer gauge install
- rear gear install question
- 11's or bust?
- Drive a while... Turn off car.. Problems
- Quad shocks question
- 95 GT DynoTune??
- Catback Question
- Bad gas mileage possibly other problems
- Finally!!!!!!!!
- How can I get around the shift retard?
- MAF problems need quick help
- Does more cubes equal less boost?
- Surging issues, any suggestions?
- hood recall?
- LC-1 wiring setup
- What plug wires do you all suggest?
- 93cobra intake on a sn95
- 1st gear too low?
- Car Wont Start, No Power To Distrubuter
- geting a clutch
- Suggestions/Opinions for 347 combo
- Never quite got an answer on this..flat top pistons..head limitation?
- High RPM Cutout
- tfs stage 1 cam...how bad w/our eec
- My idle SUCKS! What can I do??
- LC-1 wideband came in today!!
- WTF Car cuts out and stalls when i go in reverse
- body panels not lining up
- RPM II with Different Lowers?
- Are bullit swaybars better than stock GT sway bars?
- Dry Nitrous?
- My new exhaust Part 2
- Tri-Ax might have shifted it's last shift!!
- Tweecer Help?
- Less exhaust popping\backfires with 94 octane ?
- 70 mm TB
- need pics of E7's
- SN95 Electric Fan Question
- Will urethane front control arm bushings make the car ride harsher?
- cutting only 2 cats?
- Coolant Problem
- Car won't start, HELP
- Questions for those with Cobra front bumpers...
- 4.6 or 5.0 any major differences ?
- fuel pump question
- Bbk X-pipe Fitment Issues
- Extra drivetrain loss from TKO-500??
- vibration/shaking at idle
- piecing together combo, first step, opinions wanted
- Which turbo can get me to my goal.
- whats the best way to do side exhaust?
- One wheel peel; rearend question
- Spark Plug Wires 94-95?
- clutch question
- which spark plug wire?
- Is the smog pump required by emissions??
- Cobra Intake // Svo Motorsport
- Which Intake?
- Tweecer......
- 95 COBRA Running Rich
- wanting to get h/c/i
- Please help, out of ideas
- PIP circuit fault
- how to lower?
- Will a lightining mass air meter work?
- torque these bolts.. you're kidding right?
- Oil leak... Power steering rack?
- AFRs not all they're cracked up to be?
- PCV Question- LOTS of Oil
- sprak plug help
- NEED 70mm MAF transfer for 5.0 (not 93 cobra)
- New dyno #s , Damn this is crazy !!!
- Question - dropping the oil pan
- help with clutch
- Best way to install clutch cable
- Cobra Intake
- Procharger filter relocation
- Rear suspension carnage
- anybody running a chrome upper intake???
- REAL injector sizing, everyone's HP guesses
- Some Cobra Brake Upgrade Questions, what about rotors?, Please Help
- Tb for a 95 cobra intake
- installing headers
- supporting parts needed to run s/c
- Weights?
- stock heads + intake what potential??
- i have decided on my h/c/i combo
- Gas mileage ugh...
- Header Bolt Length
- Disappointment At Track Tonight..
- Monroe Sensa trac Vs Gasamatic?
- alternator question
- Car doesn't start....sometimes
- vortech ???'s
- will this work?
- Belt tension
- major coolant leak...
- where can u get paint pens at to fill in keyed places?
- Is this dangerous??
- Fuel pump removal help
- long tube headers will they fit
- Buying a n20 bottle and piecing together the rest. What all is needed?
- Cobra Brakes
- 3.73 installed. strange noise !!
- 99up front end on a 95?
- ford alarm problem
- header bolts ???
- tranny swap
- which C/C plates for coil overs????
- 5.0 Water Pump
- New 3.73's...
- a/c drip...caused hole H-pipe
- Going With Nitrous.. Now Which Kit?
- 5.0 buy or no??
- Annoying Problem
- Rollbars!!
- MMR coilover install **PIXXX**
- Window Motor Question
- Removing tie rods and ball joint from spindle
- stock atlernator question
- looking for car cover recommendations
- 1994 Radio Problem
- Do I need caster camber plates...?
- Questions
- Why is my car pinging!? grr
- C4 Swap information?!?!
- Installed MMR front coilover kit today*MY COMMENT'S*
- opinions of NEW MAC catback?
- TFS Street Combo with AODE...
- got $8,000 to build engine/trans combo and need some ideas
- driveshaft
- Leather Seats
- pedestal mount rocker guys!!!!
- avereage HP from a 347?
- what size are stock rotors?
- turn signals/flashers having a problem?
- 95 Cobra Radiator Fan HELP!!!!
- Need the BEST Throwout Bearing out there!!
- Magnapack on a 94-95
- Does anyone do custom burnt chips anymore?
- Window wont roll up
- Edge Performance Torque Converter
- When removing the a/c, can that big grill come out in front of the rad?
- help with hew car!
- Aluminum Heads for under $300
- TCS switch (Transmission control switch)?
- Cleaning intake manifold with Seafoam
- How rich is my car? Flame throwing rich!!
- I cant get the car to idle well, just tried reseting the idle.
- Cam Question
- Is the any body with a tweecer in NY or NJ that knows how o work this thing??????????
- Painting Stripes
- will 315/35/17s fit in the back???????
- Which brand H-pipe Fits correctly?
- Intermediate poopyness
- power steering hose intall
- Cobra Intake Manifold Installation
- door window weatherstrip replacement
- Which computer can i get?
- Another Wheel Spacer Question
- big undertaking
- what size bore headgaskets?
- trans question
- Is Fix-A-Flat Bad?
- BOO switch?
- Cars vibrating, can it be my driveshaft or do I need to look elsewere?
- NMRA License frame
- guideplates for pedestal mound heads?
- EGR cap?! Where the hell is it?!?!
- Tweecer help and FMU question
- Tranny Shift Problems After Gear Install
- Question for you head porting experts.
- Low end is rediculous! Automatics must read!
- car idols up and down
- car spuddering...
- Tire Size Help
- Do you put silicone on the balancer/crank bolt?
- power steering quick fix
- Alternator dead??? Or what!!
- Safe RPM to shift at?
- Deleted my AFM Powerpipe = short issue gone
- Low Oil, and Low Oil Pressure
- SC kits fox vs 94-95
- 15 inch drag radials what size to get?
- Intake Manifold Install
- Car Shuts Down At 5300 Rpm
- tie-rod help
- Compression Ratio Question
- $1000 to spend, What to buy
- Bassani tips??
- CEL getting these codes
- Bucking/Surging/Dying question
- tonnenue (spellcheck?) covers on non verts?
- hi there, new to the forum
- WTF My Damn Seat Broke
- What would you do with $25k?
- transmission fluid help
- HELP I have melted vac lines....
- Cam shaft Lube hurt blower?
- qa1 coil-over kit, adjustable ride height?
- aluminum block
- ZeroRT's new ride
- tires
- For 94-95 Cobra Owners
- 295, 305, or 315 on a 18x10 rim
- Painted speedo needles
- 24 lbs Injector question
- Uh-oh, that didn't sound right...
- Banjo Bolts... I now hate them
- Help
