PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. HELP I have melted vac lines....
  2. Cam shaft Lube hurt blower?
  3. qa1 coil-over kit, adjustable ride height?
  4. aluminum block
  5. ZeroRT's new ride
  6. tires
  7. For 94-95 Cobra Owners
  8. 295, 305, or 315 on a 18x10 rim
  9. Painted speedo needles
  10. 24 lbs Injector question
  11. Uh-oh, that didn't sound right...
  12. Banjo Bolts... I now hate them
  13. Help
  14. tuning options question
  15. How do you register the EEC Analyzer at .......
  16. H/C/I and supercharger at the same time?
  17. Where are your battery Cut/Offs?
  18. need new hood what are some good hoods to get
  19. Need some help - Check Engine Light - Trying to Sell Car
  20. 95 Cobra Intake Manifold
  21. 306+what= 325 streetable horsepower
  22. anyone know of any wheel spacers threads and where can get some at
  23. I need some quick help...car not starting.
  24. speedo not working after t5 swap
  25. guys how much should gear's and trq converter cost
  26. 95 GT brake problem
  27. Painting numbers on a balancer - question
  28. problem installing convert top
  29. temperature knob doesnt change hot or cold
  30. Similar Idle adjusment procedure??
  31. 42 lbs injectors
  32. Balancer installation question
  33. U Joint Replacement
  34. Anyone using UPR K-member kit?
  35. t5 wont go into gear with the car on
  36. car wont start after H/C/I
  37. 4.10's = awesome
  38. 93 Cobra Intake Plaque or something else?
  39. Weight?
  40. Rear AODE seal
  41. Can carb cleaner damage the MAF?
  42. LTs problems
  43. Tranny Woes
  44. Question about method for installing sub-frames...
  45. Flushing The Radiator.
  46. quick answers needed (cobra parts for a gt)
  47. rpms fall slowly when stopping
  48. AFR head and intake combo help
  49. Simple Header question...
  50. Negative battery cable smoking?
  51. Melted headlight switch plug
  52. o2 extensions for LTs
  53. Need help. Pro-M mass air to fender filter.
  54. Innovative LC-1 wideband
  55. Short Belt/Deleted Smog Question.
  56. charging question
  57. What size tire on a 18" rim
  58. 95 gt wont shut off
  59. Stock Intake
  60. Tweecer just came in :)
  61. Another problem - Balancer fell off. Suggestions?
  62. Electric Water Pump
  63. Should the upper intake ever be too hot to touch?
  64. Where to buy an OBD I scan tool with display
  65. Cowl Hood
  66. What vacuam line is needed for the A/C?
  67. New numbers with the port matched 75mm TB
  68. Fox boddies have a different radiator?
  69. Transmission Leakage question
  70. tweecer, what is it? Where can I...
  71. How hot is too hot?
  72. Laptop for Tweecer
  73. Where do i get a Crankcase ventilation breather?
  74. gas/exhaust fumes
  75. guage cluster problems
  76. Slight Rattle or Knock?
  77. 42 lb injectors - what MAF?
  78. Injectors differences and such
  79. Motor Build
  80. Vacuum Question
  81. problems with my march underdrive pullies
  82. What Throttle body should i get, and some more ?'s
  83. street heat/stock lower question
  84. Going Kenne Bell (again)
  85. 6 speed on a 5.0?
  86. Cobra and underdrive Pulley Question
  87. no strut tower brace
  88. Alternator fuse screwed up..
  89. How to tell if port was leaking?
  90. RIDE QUALITY with h&r ss and bilsteins
  91. cleanin air filter on CAI
  92. Mickey Thompson ET Street Radials???
  93. 3/8" intake spacer w/cobra intake fit under stock hood?
  94. DAMMIT!! Idle surge is back, bucking is worse
  95. Blower or Nitrous?
  96. Compat Questions
  97. Transgo shift kit on the way!
  98. 03-04 Cobra wing
  99. HELP?! Anyone!
  100. CAI install, rough idle....Help
  101. why in the H is my car busting trannys and driveshafts!?
  102. Fail Emissions
  103. questions about stock gt and cobra pulleys for 94-95
  104. Problem with stock , Autometer and Tweecer TACH
  105. hot start problem
  106. Rather than buy a new strut tower brace, modidify the old one...bad idea?
  107. Got a Vac. Tester, where does it go? HELP QUICK
  108. C&L causing my problems?
  109. Oil Pan
  110. Ford SVO coil fitment Question
  111. Are all 94/95's this slow? Help Plz!
  112. Maybe a common problem?
  113. All I can say is wow..
  114. Any experience with GT40p CCM-9495 header?
  115. Help me solve my power problem
  116. header questions
  117. Need Some Quick Help!
  118. Quick question... 2 or 4 o2 sensors?
  119. what the heck would cause this?
  120. Fuel rail hose
  121. Deleating powersteering and A/C questions
  122. Pinion Snubber + Sportlines... a must?
  123. Lower intake install tips
  124. WTB/WTT: 94-95 GT Automatic... Cheap! :D
  125. Anyone use the delta fan controller?
  126. Need help here!! Mach 460 related
  127. can anyone help me?
  128. Supercharger?
  129. HELP!! Electric Fan
  130. Sub-Frame install
  131. Can a wrong-rotating water pump cause strange cooling issues?
  132. 285s on a 9" wheel?
  133. Need parts!
  134. FINALLY!! She runs GREAT!!
  135. tweecer owners
  136. ebrake cable problem
  137. gearing different in cobra trans vs gt?
  138. trans problem.. no 2nd gear!!??
  139. Cylinder Balance Test results:
  140. Cylinder Balance Test Results: Need ideas.
  141. Finally found out the reason for chitty performance
  142. 302 Stroker Pricing Question.
  143. $11,500 to spend and looking to make my stang a 500hp daily driver, what should i do?
  144. oil pick up clearance issues
  145. belt is squealing, a/c + smog delete quesiton
  146. Got the tweecer to datalog! Got some questions, Grady!!
  147. Gear Time!
  148. Modded 95 vrs Modded 05 Dyno Results Inside
  149. stock 97 shifter knob fit 94 cobra
  150. A/C Line
  151. pushrods
  152. Failing tq converter?
  153. rims need help
  154. Pro3i LCA or the Granatellis?
  155. Another One....Thinking O2's (sorry kinda long)
  156. will this be ok?
  157. no more mach one chin spoiler???
  158. Check out my rack!!!
  159. Need help with some codes- Please
  160. magnaflow mufflers
  161. New Toys arrived PICS (and an offer on my car!!!)
  162. Evidently My Car Runs Like Crap?
  163. Coolant leak???
  164. thinking of buying a tweecer!
  165. fox prop rod work on our cars??
  166. Borla/SVO Side Exhaust Guys - Read - URGENT!
  167. All new suspension/ what to get?
  168. Back from the Dyno - What next?
  169. 94 GT not starting
  170. Pedal Assembly Pics - What Year?
  171. Noob ?
  172. Fox Body TB Conversion Questions
  173. is this right?
  174. Just got a edelbrock performer.....
  175. Turn downs to clamp on muffler?
  176. Upper Control Arm problems
  177. EEC or Tweecer? Which one is better?
  178. 94 5.0 not starting
  179. Stressing on A/C
  180. header to exhaust bolt's ???
  181. Speedo/Odometer stopped working
  182. Anyone have a Targa top?
  183. Brake problem
  184. sway bar broke
  185. pro3 control arms
  186. cleaning k&n filter
  187. Bad knocking sound from passenger side head
  188. coil wires
  189. Fixed car, kinda. More questions
  190. Anybody have a spare 50oz flywheel counterweight?
  191. Ring Gaps
  192. tuning for intake??
  193. Comp xe276hr cam
  194. Will it fit??
  195. HVAC blower motor problem...thanks
  196. Just drove the car for the first time in 4 months!!! Need help! Bucks,doesnt Idle,etc
  197. Time to pimp my ride! Tuning suggestions.
  198. AODE and codes! Help
  199. Car Died! Need Help!
  200. Shifter bezel same for Auto as Manual?
  201. Still can't datalog, can't get the fuel set with twEECer
  202. Headlight mount
  203. My clock not working ? ?
  204. Tail Ligts with amber fields...
  205. Got my 418 started.
  206. Does anyone have 94-95 ECU wiring diagram ???
  207. Just finished putting the car back together and it wont start......Starter????
  208. My flows 2 chambers are too loud for me..alternatives?
  209. Oil leak... Rear main seal, or oil pan?
  210. How long for a break-in period for a new motor?
  211. HELP ! Swapped an 89 engine. Now it doesnt start !
  212. Exhaust clips of my 351w setup....
  213. NASCAR "Race Glaze"....
  214. Datalogging with RT?
  215. Had smog done last week in CA, surprisingly below maximum emissions...
  216. Installed fuel pressure gauge...what should it read?
  217. TwEECer issues
  218. Where is the most restrictive part on your intake?
  219. twEECer installed, but problems
  220. Whats with this POS car!?!?
  221. Wierd noise from the engine
  222. Engime Miss Fire??? Help!!!!
  223. How to install twEECer to PCM?
  224. Need a calibrated Mass air for S/C?
  225. Got my twEECer in!
  226. Shocks/Struts???????
  227. Upper control arm install and recomendations
  228. Buyers Beware!!!!!
  229. 4 inch hood
  230. Tweecer getting recognized on TV!
  231. Timing Question for KillerCanary or anyone else...
  232. Lowering Springs?, whats the difference?
  233. Wire Harness HELP!
  234. EXPLORER INTAKE-Is it worth it? What gains from it?
  235. 418 is in but i can't get it started. Tweecer tune issues.
  236. Need a quick reply, does this seems like a fair deal ?
  237. Leak Down Results....DARK Day In Gotham City :(
  238. Possible Temp issue
  239. Please help with weird brake problem!
  240. tan top injectors
  241. PCV Grommet Woes
  242. Adj. Fuel Pressure Regulartor Ques.
  243. 95 Cobra Tranny
  244. Which Ignition System? Expert Opinions Wanted!!!
  245. t5 questions
  246. axles-steeda or FRPP
  247. Mac 1 3/4 shorty
  248. 306 in.... Cooling problems...
  249. Check it out......New progress with the car..PICS,1 DAY LEFT BEFORE I LEAVE FOR USF!!
  250. AOD convert to manual?
