View Full Version : 94-95 Tech
- 03-04 Cobra wing
- HELP?! Anyone!
- CAI install, rough idle....Help
- why in the H is my car busting trannys and driveshafts!?
- Fail Emissions
- questions about stock gt and cobra pulleys for 94-95
- Problem with stock , Autometer and Tweecer TACH
- hot start problem
- Rather than buy a new strut tower brace, modidify the old one...bad idea?
- Got a Vac. Tester, where does it go? HELP QUICK
- C&L causing my problems?
- Oil Pan
- Ford SVO coil fitment Question
- Are all 94/95's this slow? Help Plz!
- Maybe a common problem?
- All I can say is wow..
- Any experience with GT40p CCM-9495 header?
- Help me solve my power problem
- header questions
- Need Some Quick Help!
- Quick question... 2 or 4 o2 sensors?
- what the heck would cause this?
- Fuel rail hose
- Deleating powersteering and A/C questions
- Pinion Snubber + Sportlines... a must?
- Lower intake install tips
- WTB/WTT: 94-95 GT Automatic... Cheap! :D
- Anyone use the delta fan controller?
- Need help here!! Mach 460 related
- can anyone help me?
- Supercharger?
- HELP!! Electric Fan
- Sub-Frame install
- Can a wrong-rotating water pump cause strange cooling issues?
- 285s on a 9" wheel?
- Need parts!
- FINALLY!! She runs GREAT!!
- tweecer owners
- ebrake cable problem
- gearing different in cobra trans vs gt?
- trans problem.. no 2nd gear!!??
- Cylinder Balance Test results:
- Cylinder Balance Test Results: Need ideas.
- Finally found out the reason for chitty performance
- 302 Stroker Pricing Question.
- $11,500 to spend and looking to make my stang a 500hp daily driver, what should i do?
- oil pick up clearance issues
- belt is squealing, a/c + smog delete quesiton
- Got the tweecer to datalog! Got some questions, Grady!!
- Gear Time!
- Modded 95 vrs Modded 05 Dyno Results Inside
- stock 97 shifter knob fit 94 cobra
- A/C Line
- pushrods
- Failing tq converter?
- rims need help
- Pro3i LCA or the Granatellis?
- Another One....Thinking O2's (sorry kinda long)
- will this be ok?
- no more mach one chin spoiler???
- Check out my rack!!!
- Need help with some codes- Please
- magnaflow mufflers
- New Toys arrived PICS (and an offer on my car!!!)
- Evidently My Car Runs Like Crap?
- Coolant leak???
- thinking of buying a tweecer!
- fox prop rod work on our cars??
- Borla/SVO Side Exhaust Guys - Read - URGENT!
- All new suspension/ what to get?
- Back from the Dyno - What next?
- 94 GT not starting
- Pedal Assembly Pics - What Year?
- Noob ?
- Fox Body TB Conversion Questions
- is this right?
- Just got a edelbrock performer.....
- Turn downs to clamp on muffler?
- Upper Control Arm problems
- EEC or Tweecer? Which one is better?
- 94 5.0 not starting
- Stressing on A/C
- header to exhaust bolt's ???
- Speedo/Odometer stopped working
- Anyone have a Targa top?
- Brake problem
- sway bar broke
- pro3 control arms
- cleaning k&n filter
- Bad knocking sound from passenger side head
- coil wires
- Fixed car, kinda. More questions
- Anybody have a spare 50oz flywheel counterweight?
- Ring Gaps
- tuning for intake??
- Comp xe276hr cam
- Will it fit??
- HVAC blower motor problem...thanks
- Just drove the car for the first time in 4 months!!! Need help! Bucks,doesnt Idle,etc
- Time to pimp my ride! Tuning suggestions.
- AODE and codes! Help
- Car Died! Need Help!
- Shifter bezel same for Auto as Manual?
- Still can't datalog, can't get the fuel set with twEECer
- Headlight mount
- My clock not working ? ?
- Tail Ligts with amber fields...
- Got my 418 started.
- Does anyone have 94-95 ECU wiring diagram ???
- Just finished putting the car back together and it wont start......Starter????
- My flows 2 chambers are too loud for me..alternatives?
- Oil leak... Rear main seal, or oil pan?
- How long for a break-in period for a new motor?
- HELP ! Swapped an 89 engine. Now it doesnt start !
- Exhaust clips of my 351w setup....
- NASCAR "Race Glaze"....
- Datalogging with RT?
- Had smog done last week in CA, surprisingly below maximum emissions...
- Installed fuel pressure gauge...what should it read?
- TwEECer issues
- Where is the most restrictive part on your intake?
- twEECer installed, but problems
- Whats with this POS car!?!?
- Wierd noise from the engine
- Engime Miss Fire??? Help!!!!
- How to install twEECer to PCM?
- Need a calibrated Mass air for S/C?
- Got my twEECer in!
- Shocks/Struts???????
- Upper control arm install and recomendations
- Buyers Beware!!!!!
- 4 inch hood
- Tweecer getting recognized on TV!
- Timing Question for KillerCanary or anyone else...
- Lowering Springs?, whats the difference?
- Wire Harness HELP!
- EXPLORER INTAKE-Is it worth it? What gains from it?
- 418 is in but i can't get it started. Tweecer tune issues.
- Need a quick reply, does this seems like a fair deal ?
- Leak Down Results....DARK Day In Gotham City :(
- Possible Temp issue
- Please help with weird brake problem!
- tan top injectors
- PCV Grommet Woes
- Adj. Fuel Pressure Regulartor Ques.
- 95 Cobra Tranny
- Which Ignition System? Expert Opinions Wanted!!!
- t5 questions
- axles-steeda or FRPP
- Mac 1 3/4 shorty
- 306 in.... Cooling problems...
- Check it out......New progress with the car..PICS,1 DAY LEFT BEFORE I LEAVE FOR USF!!
- AOD convert to manual?
- can you get tinted glass instead of a stick on film?
- Guys with TwEECer RT and PLX Wideband I need help with installation PLX wideband
- Need help with installation of 5" Autometer Tach
- AFR165 users: answer asap!!
- Is my cam going to clear my valves? IM SCARED TO DEATH!!!
- Will not having a bigger fuel pump have negative effects on my stang?
- What order do the drivetrain components need to be installed???
- Whats the best brand of window tinting?
- mustangtuning/procarparts cobra clears
- Well, it wasn't the gas.....
- Pro-M 80mm outside diameter
- Stock Mustang Weights (w/ pics)
- Engine Gasket Kit Needed
- Grady!! 30pt maf transfer conversion program?
- What oil does everyone use and what oil to use for engine break-ins??
- How cam I attach my engine hoist to my engine with everything on?
- Best lowering combo ?
- Anyone Want These..cheap
- Got the Tri-Ax in!
- Fox Blocks and Sn95 blocks question
- How do I install rocker arms on my Twisted Wedge heads??
- Leak Down Question...Part Deux!
- Car did run after mods, now doesnt
- 331 ci is where its at
- Car idles fine but cuts out half the time at a stop. Ideas?
- Rim's search has started, please help, Lee
- What holes do I need to block with Trickflow Twisted Wedge heads? PIC
- FRONT coil-overs: which STRUTS?
- Can I install my engine with......
- hot start issue
- What did you guys torque your alluminum heads to?
- Torque Box Re-enforcements?
- AC Compressor Part #
- will a 03-04 cobra grill emblem fit a 95?
- 95 GT speedo fuse ?
- Aftermarket radiator suggestions?
- WTF Mallory Box Dead? Please help!
- car is running,now it wont idle.
- Cutting wheel studs for wheel spacers
- Swapping sn95 engine with fox engine
- What short block?
- Experts, which injectors to get? Thanks.
- Is my car doomed to be slow?
- Timing Question
- Turbo guys..gravity feed oiling system?
- Fan went out, any suggestions?
- Front suspension help needed
- New guy question
- Power steering pulley question-yes I searched
- Question: EEC fuse burning out - Please Help!
- Could the stock intake be part of our pinging problems?
- dumb question about my car
- Ping Ping Ping, all i hear is friggin Ping
- Innovate Motorsports vs PLX Devices M-300 Wideband
- Anyone know whats height of SummitRacing Sheet Metal valve covers
- Best Intake...Give imput
- romac balancer question
- help with spark plugs
- Air/Fuel Gauge question.
- Weight Reduction
- Will window switches from a fox body fit our cars?
- E85 ethanol fuel?
- CLUCH need help quick (please)
- Weird rear-end hop
- what size belt for asp pullies
- why so slow
- Alternator...quick help
- messed up car
- Antenna delete?
- What damper fits our cars?
- How to remove these vacuum lines?
- Window regulator acting up!
- Got the new heads and intake, and a question.
- dyno tune or off-the-shelf chip benefit?
- clutch
- What the hell?!
- 275/40/17's, Will they fit?
- aode shifting at 55!
- no start post #5934233
- Fuel Problems...Starts, but dosent stay on.
- Help with lower intake ASAP!!
- which K-member?
- Would it be better to make a gasket or use RTV sealant?
- 351w efi valve covers?
- All with sn95's with slicks and skinnies come here
- New shocks and struts?!
- Pics of my shortblock assembly, woot.
- just seafoamed, got questions
- high speed fan doesnt work with a/c on
- 96 MAF in a 95
- Spark Plugs?
- Vortech or Procharger??
- Leak Down Test - Help.
- Car sounds like its dragging something...
- Crank case pressure issues
- Can I use engine assembly lube instead of camshaft assembly lube?
