View Full Version : 94-95 Tech
- how much HP/porting and polishing stock intake
- some street/drag race suspension ideas.....
- Fuel pressure Question
- Quick help, s/c belt hits waterpump pully....
- new clutch and I still have TOB noise!!!???WTF
- cobra intake manifold prob
- Typhoon VS GT40
- Didn't gap the plugs :-(
- Need new stang
- transmission questions???
- belt came off
- Cobra R hood...Opened the cowl up...
- c&l question
- Cam?
- Front brake pads
- BIGTIME milkshake!!
- Timing/Temp????
- BBK LT install questions - PEASE HELP
- Electrical Problem
- SN95 aftermarket VC owners: help needed
- Guys who installed there own sytling bars.
- Universal or Cal'd for 42's MAF?
- Bad Ignition Module (Stator)??
- Lifters, Timing Chain, Pushrods?
- Felpro Gasket?
- Forced Induction MAF question
- S/C 331's COME ON IN
- T5 teardown: how do you remove the 5th gear synchronizer hub?
- How to remove 5th gear synchronizer hub
- New 1/4 ET. Hit my goal
- Ok so the TKO-500 is ready to put in, any hints or tips for me(pics)
- Self Porting - What bits do I need?
- Tel Star Wheels
- Installing rail mount fuel pressure gauge...QUICK QUESTION
- Stiff gas pedal
- dissapointed with track results last night
- Pulled Codes: Results
- Vortech Install Complete
- 17 inch wheels
- Installed a Mac cb and ca tonight
- WTF? I got the wrong connectors on my new MAF. Any suggestions?
- pushrod length help...
- Interior restoration
- ARP torque specs??
- I Still Have Rear 4x4 Look
- Anyone know if side-exits are legal in MA?
- Hardest part about installing a Vortech?
- Who here has Eibach sportline springs?
- 50 Foot Pounds On Rocker Arm Bolts!???
- c&l mass air meter
- Smog stuff and the pipe that goes down to the h pipe question.
- 514 Engine
- Bottle Feeders...
- base timing and timing lights
- where to get stock style radiator hose clamps
- Wiring problem
- Transmission Cooler For Manual Trannys?
- Intake runner length ?
- going to track tonight, should I use my 18x9 cobras or stock 16X8's for best time?
- Cowl mount fuel pressure gauges
- Got my TKO-600 today...any tips on install?
- Typhoon intake deal
- Is This Combo Worth It?
- Buying a used axle - please inspect these photos.
- Question - Adjusting the valvetrain
- charging problems: search function not helpful
- Help w/ Mid Pipe Selection Please
- Trans. cooler position
- will a worn rag joint make the car "wander"?
- 5.0 help
- WEnt to the track last night...
- new clutch....breaking it in
- is 30 psi ok for 18's?
- spintech side exit
- 302 Street Build
- 93 Computer Swap
- Are These Hub-Centric?
- gt40p headers
- hci curiosity
- Tune Up Question
- eibach lowering spring question!!!!
- How Hot Are You This Summer?
- Disconcerting sound + loosing oil fast!
- something dripping under the hood?
- Switching Cams What kinda power difference
- Owners Manual
- what you guys think? should i use the subframes?
- Aluminum or Steel?
- Where to find SVO side skirts?
- Tweecer And Wideband Question
- Installed rear control arms (lower), now lots of issues:
- Dyno Tunes? Tell me more please?
- Question about Rear SPeaker Wire Colors
- I want to updrade my hood. Any ideas?
- Stupid airbag light...
- Posi Q's
- Helpppp Burning plug boots!!!!!
- Fpr Vs Fmu
- HP est?
- puttin in the cage
- Est. quarter mile time?
- slight rattling under the car
- max boost?
- lifter question
- something broke
- what is hp motorsports website?
- How much can you port AFR 185's?
- best place to get 315 drag radials
- vortech install ?
- Fuse/Fuse Box Questions for '94 GT
- 331/347 With NOS...Anyone?
- Intake manifold's which is best???
- VP Racing Fuel's StreetBlaze
- Little Black Nipple On Axle
- Part Number
- Advice From Nitrous Experts
- just installed BBK intake, having problems
- What does it take to go 13's??
- Pa Performance Alternator
- Started the S/C Install Today
- recover my seats in leather? options anyone?
- Convertible Top Replacment
- Under drive pulleys.... whats the diameter
- Cobra brake upgrade question.
- aluminum flywheels?
- c/c plates.....where to get em?
- hey RC, another part for you to *bling*
- Help a dope out please
- Failed emissons in N.J.......help........
- Quick clutch question
- Pro M went out of business
- o2 question
- More 347 build up questions?
- #1 fuse keeps popping. I think I know the cause, but could use some advice.
- HELP! Car overheating
- Anyone have- MKVIII fan connector/plug....
- 95 cobra clutch problem
- Can I use an 8.8 axle housing from a fox body?
- Found an explorer engine, is it a good deal??
- Looking for lower intake torque specs and pattern
- RPM needle acting funny
- Adjustable Fuel Pressure Regulator ?'s
- Do I need cobra master clyinder for 13" brake upgrade?
- Pulled the codes...
- Standard VS Sport Seating
- header bolt question
- Vacuum Line Q's
- mac longtube install today.....any pointers?
- Nitrous!?!?
- 351 dilemma
- Crossmember
- hot idle problems anyone help...
- Oxygen Sensor Part Numbers
- Big problem, My front right wheel sits farther back in the wheel well??
- Tell me why a '91 Explorer rear axle won't fit.
- eibach lowering springs?
- Think I'm gonna drive the stang tomorrow.
- Ball joints???
- Oil fill spout
- Injector Questions
- just got mac h pipe in, it rattles,help!!!
- MSD/Taylor
- ford racing 347 short block?
- Need definitive answers please
- Anyone ever run these Hookers?
- Explorer GT 40 intake
- pro m mafs and 42 lb injector help
- Eliminating Catalytic Converter's
- Fickle minded AODE
- This is driving me crazy!!!!!
- Parts????
- measurments of a/c condenser?
- swapping header gaskets, any tips
- who has done the rear abs speed sensor??
- Can I spreay a little bug and tar remover in the intake where the MAF sensor is?
- Hi speed fan ?
- Alternator....130 or 200 amp
- Whole lotta shakin goin on!!!!
- 1/4 Track Question and Weight.
- BBK short o/r h-pipe for LTs are the same for SN95 and Fox stangs?
- '94 Cobra and GT what are the differences?
- push rod length with new tfs tw's?
- Suspension questions, Advice needed.
- drivetrain vibration and other questions
- harmonic balancer?
- 4 bolt main?
- Help on getting a special tool?
- Your thoughts on DSS. short blocks
- Best Brake rotors for the money?
- I need a shortbelt length for everything except the smog
- Check Engine Code 332
- Nitrous Installation...?
- whats it worth?
- Are our alt brackets the same from the Fox bodies?
- BBK LT header question (routing secondary exhaust lines)
- full lenghts what to get
- Stupid $hit on this car is pissing me off......HELP
- mac u/d pulleys
- Good head for my 306/nitrous combo
- Pics of my new headers. Any install tips????
- Alignment question
- Head Experts?
- i THINK MY BRAND NEW 306 BLEW UP!!!!!
- fuel coming out of exhaust
- Car won't start
- ebrake light?
- OK to clean throttle body?
- Nitrous 150 shot on stock bottom end?
- will my ride get any smoother? bilstein owners help please.
- Best way to paint engine?
- Where exactly is the idle screw and how do you turn it? Did the search...
- Intake manifold gasket cut-away..
- Can't figure it out!
- Supercharging a 347
- long tubes on lowered 94?clearance issues?
- dissapointing night at the track
- vortech kit
- fuel everywhere,!
- Why does my car weigh so much?
- edelbrock performer 5.0 installation-craftmanship is terrible
- too much timing???
- Will these valve covers clear?
- went to track wtf happened?
- Symptoms of a bad/dead alternator?
- help before my car enters shop
- A side effect of it's MI origin?
- Catted ProChamber???
- Installed my gauges today
- Temp gauge problem after intake install
- Exhaust/Emissions experts please!!!
- Air Temp vs H.P. loss?
- Spintech Pro Streets > *.*
- Overheating Question
- Welding question.......
- Ripped out AC system
- Car burning oil......
- Car not starting...help plz
- Is it my CCRM?
- Re-Setting The Computer
- Weights
- BBK SSI Series Intake
- Off road vs Catalytic
- AODE Locked in Park
- Alternator?
- compression ratio question...
- buying intake hae questions on stuff???
- Going to change motor mounts, any advice???
- what would you do next?94 gt
- MGW shifter?????
