PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Speedo problem..
  2. rear axle shaft question
  3. H&R Sport Springs on a vert
  4. Whats wrong with my suspension?
  5. computer help quick!
  6. Why does my car sound like it has a Cam?
  7. How to Replace the Oil Pan Gasket?
  8. 1/8" hole in TB butterfly....is it worth it
  9. Have to replace rear main seal- Which one to go with?
  10. Tools needed to change out U-Joint?
  11. HELP please !
  12. 94 Mustang Electrical Problems Please Help!!!
  13. how do i take my door apart
  14. Tokico HP Shocks?
  15. Can I use Fox Taylor wires on the '95
  16. Is a fox intake swap worth it?
  17. Why doesn't anyone use the AFM PMS?
  18. Need help with AC!
  19. FRPP 3.73 Gears..Two Thumbs Way UP!!
  20. 42lb injectors with a Cobra ECU..What MAF???
  21. Trickflow H/C/I finally on!! Got Q's
  22. AODE to AOD in sn95 swap
  23. Mid pipe for BBK long tube headers?
  24. Summit H-pipe Question
  25. What Is It? 2nd Maf.
  26. wheels
  27. Which control arms?
  28. Quick Question About Power Steering Pump
  29. Polishing Cobra intake
  30. Problem with X-pipe installation
  31. AODE w/3.73's I need a chip, which one?
  32. What do i need
  33. Bassani Exhaust question
  34. Help im Having a Problem
  35. waterpump
  36. Where can I find my paint code?
  37. 392x autolite plug question
  38. sloppy clutch pedal
  39. 3 inch tailpipes?
  40. Why do my car use alot of radiator coolant ?
  41. FYI Found the Airbag code clearing plug
  42. A/C help needed!
  43. Calling all those with polishing expertise
  44. Tranny slipping/broken?
  45. TWEECER NEWBIE HERE! Need help fine tuning: Idle & Bucking problem
  46. what do i look for?
  47. What is this, and do I need it?
  48. Another Seafoam question.
  49. Im screwwed...main cap cracked
  50. '98 Cobra center caps on Cobra Rs?
  51. Where to get 3M Tape?
  52. lamp swith. Need help fast
  53. Pcm????
  54. Any Anderson/Bassani 1 3/4" shorty headers users?
  55. LT header install problems
  56. Car Idles Better With Spout Out...why?
  57. Feels pig rich....
  58. New Times With Torque Converter
  59. V6 and V8 brakes the same? For fox five lug swap
  60. Problem with plenum spacer
  61. Will a mac h-pipe work with jba headers?
  62. Pics of lowered stang with 17/18in rims
  63. How low can you go on springs?
  64. wooo whoooo got a kill first time out
  65. Lets talk cams... Custom, Off the shelf, I want to know.
  66. Car won't stay cool
  67. ATTENTION ALL GUYS WHO BOUGHT AFTERMARKET HEADLIGHTS- (MATTHIASJ and OTHERS)!!!!
  68. Tire size
  69. Ahhh Crap...
  70. AC tech's I need your help
  71. Vortech install problems on 94 cobra...Help needed
  72. What is a Crane 2031/Steeda #19 worth on a stock Cobra motor?
  73. I want to cut my Eiback Pro-Kit springs?
  74. Clunking from front, anybody have ideas??
  75. Mounting Trans Cooler
  76. What wrong with my car!!
  77. Will i have driveablilty issues?
  78. Help...Car runs like total chit!!
  79. What brake line for PBR calipers?
  80. cam for a daily driver...
  81. Another "How much is my car worth?" thread
  82. I finally got my wheels mounted!!! (pics inside)
  83. Problem with short belt
  84. Removing spring isolators - Good idea or bad?
  85. Need advice about where to get my car tuned in USA?
  86. Engine shut off after fast changing positions
  87. Cobra lower intake oil baffle
  88. Will a Panhard Bar work with the 4-link
  89. Two stage rev limiter , TwEECer guys needed help here
  90. Alrighty, I need a little help
  91. Look What I Got
  92. hp/tq suffering??
  93. Water Wetter???
  94. My 5.0 Bird needs help!
  95. location of fuel filter
  96. Tomorrow is the Day..
  97. Drag Springs???
  98. Help Me out with my Black 1994 Mustang GT
  99. Installed manual fan switch
  100. GT40 on a 331?
  101. Symptoms of a Bad Distributor?
  102. Difference of Fox and SN95 T5 trans?
  103. Putting Heads back on in about 2 hours...
  104. passenger air bag
  105. Can a T-rex be used to supplement the stock fuel pump?
  106. 90mm tb gasket with 80mm tb?
  107. Painting rear bumper letters and horse on center cap this weekend
  108. BEST way to clean MAF?
  109. Tubular A Arm over Standard? any reason why not
  110. Broken Seat recline, Break out the Welder?
  111. Manual fan switch
  112. Looks like a shotgun blast
  113. Weld 15" rims on the front
  114. Why do more people get DSS instead of CHP?
  115. 4R70W swap questions
  116. Need flowsheet for Pro-M 80mm PLEASE!
  117. HELP! Car shuts off as soon as I hit 2nd gear since SCT chip install (LONG)
  118. Need help lowered car now makes noises
  119. which control arms should i get?
  120. what to do/buy to make car launch hard
  121. 302 weight vs 351 weight
  122. Tranny Swap
  123. steering wheel rattle
  124. Kenne bell fuel pressure reg????
  125. Messed up my chin spoiler, can it be painted?
  126. Thinking of buying these coil overs
  127. Interior Ideas
  128. Sticky Clutch
  129. Need cam help RIGHT NOW!! Please
  130. Drivers side window isn't working
  131. long rod kits?
  132. Need help please (bad ticking sound)
  133. Side Pipes Legal in MA?
  134. 210 freakin degrees!!
  135. 210 cc Intake Runners too big for Street Heat?
  136. K-members, which brand holds up to street/strip?
  137. Just got my Side Pipes in!!!!
  138. cooling issues...
  139. problem starting her up
  140. Stock Exhaust
  141. AODE long tubes. what do you have?
  142. Mac 1 3/4 lt's on an aode
  143. Car runs rough at idle, smooth in higher RPMs. If it is shut off, won't start back..
  144. gas milage with O/R H-pipe
  145. Cobra Intake?
  146. Can banging sound at speed = bad D/S?
  147. How long does it take to install a supercharger kit?
  148. i have intake elbow questions..please help
  149. 94-95 Aftercooler?
  150. Passenger One Push Down Window
  151. Knocking Sound From Rear End.
  152. Vortech on Stock Pistons???
  153. Need some torque specs
  154. Venom 400?
  155. AODE: 2nd gear shift hangs after H/I/Blower, etc.
  156. DSS 331 update pics.
  157. Some update pics of the egine bay clean up
  158. To those who have swapped to 99+ PBR brakes.....
  159. When to upgrade from 24lb injectors?
  160. Car dies randomly at idle
  161. question about timing and supercarger? HELP
  162. How hard is the t56 conversion
  163. how much power for t-5?
  164. long tube header ?
  165. I think I have a busted water pump
  166. Hiding wires/removing stuff..two questions
  167. Where to find NEW T-5???
  168. 96 cobra brakes/rotors--- direct rear swap for 95 rear brake setup?
  169. Fellas check this out....almost blew me over
  170. 93 tb setup on a 94?
  171. removing paint off tailpipes
  172. Original D/S Questions
  173. Blackverts turbo setup finished ( PICS)
  174. MSD tach output for multiple devices?
  175. problems with x-pipe install
  176. throttle body
  177. Link: Ultimate Guide to 5.0 Cylinder Heads
  178. Vortech supercharger help
  179. GT 40 Heads
  180. Picking up the car!
  181. Age Classic hood. Best way to install it and fit it with the fenders?
  182. painted strut tower
  183. tire and rim fitments
  184. T5: rebuild or replace?
  185. overheating
  186. Tighten ebrake?
  187. Intake Manifolds...
  188. PLEASE Help With Speedo Gear ASAP
  189. Wierd rattling sound
  190. air tube on the h-pipe
  191. bassani x install
  192. has anyone changed oil pan gasket?
  193. Question about installation of Axles
  194. Odd electrical problem...this ever happen to anyone else?
  195. Does this headgasket look blown to you? Just pulled the head off (PICS)
  196. 3 row fluidyne
  197. 347 build
  198. Do I need a tune?
  199. installing x-pipe....?jacking procedures?
  200. Steering and what to do, any ideas.
  201. It's Aliiiive....She came to life at 1:30pm 5/27
  202. T-5 swap parts list please.
  203. Which Bilsteins should I get?
  204. Crane Hi-6S Ignition Kit
  205. Converted to carb
  206. Radiator for '94 with AODE
  207. T Rex fuel line question
  208. Air conditioner recharging?
  209. Longtubes vs Shorty headers
  210. anyone hear or know about these Torque Plus intake gaskets?
  211. K-member/Manual rack
  212. mesh screen under PCV valve in lower intake
  213. Easy question...cylinder numbers...
  214. BXR madness
  215. drag car
  216. pulley kits..
  217. 95 Help
  218. Which is harder on the short block - supercharger or h/c/i?
  219. Schrader Valve
  220. Got the Car going this weekend!
  221. differences in the 86-93, 94-95 cat backs?
  222. Is there a performance shop in MS?
  223. Tsb.....
  224. Getting Wheels Chromed or Polished
  225. Why a 95?
  226. maf & injectors,gears
  227. where's the best place for replacement cobra headlamps
  228. Wiring Question: multiplying the cigarette lighter plug
  229. Speedo is not working
  230. need help with power window
  231. Help!!! Asap!!
  232. 3.73 gear install
  233. performer intake install advice
  234. anybody using tall ford racing valve covers?
  235. Need cam & head advise on 357
  236. need info on throttle body's dont laugh
  237. Starting Problem?
  238. driver window only goes down sometimes!
  239. I need a door
  240. What does this go to??????
  241. Just wanted to say thanks
  242. Car stalls (certain condition)
  243. Head gasket installation question...
  244. C4 swap in a T-5 car. What's the one wire connector for?
  245. will a 00' gt fan fit/work in our cars?
  246. e-brake question
  247. Which Brake Lines?
  248. running very rich please help
  249. Crush Sleeve for 8.8 Rear
  250. Just Curious -- 302 Output
