PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Maf
  2. Small Engine Bay????
  3. head swap
  4. how big of a shot can i use...?
  5. FOX STEEDA QA1 K Member
  6. mounting tranny cooler w/o stock lines??
  7. Ford Parts VS. Auto Zone parts.
  8. New 05 GT badging
  9. Flowsheet #'s for a PRO-M 80 MM w/ #42's Calibrated for a S/C
  10. Flowsheet #'s for a PRO-M 80 MM w/ #42's Calibrated for a S/C
  11. Shift Light
  12. Rim Quetion
  13. 14.90 down to 13.61
  14. Which c/c plates?
  15. powershifting
  16. Got my gauges installed, pics inside.
  17. BBK LT header install
  18. spout connector
  19. No FPM power? Code 543
  20. 1/4 mile gain from gears?
  21. Mpg
  22. Is it the tierod ends or is it the balljoints?
  23. Before Intake Manifold Install, Idle in Park was 1K, in Drive 600...
  24. How to bypass heater core
  25. How long to install a crate motor?
  26. will trade
  27. Black interior conversion pics w/Summit sport seats
  28. Foglight Bracket Questions
  29. QUESTION NEED AWNSER ASAP. (how much to chop off springs for 1/2" drop)
  30. how to smoke headlights?
  31. Tan to black interior: How to
  32. Backup light
  33. Car is Down 50hp...Suggestions Welcome
  34. My TwECCer is In FMU yes or no?
  35. Fluidyne ?
  36. KB 2.2 600 hp possible?
  37. What RPM does your AODE shift at WOT??
  38. need help removing a body panel
  39. Oil Fitting Assembly (Screws to Blower) Where to Buy?
  40. 95 Cobra high idle
  41. Urgent! Car leaking gas from gas tank??
  42. If you run nitrous please come in
  43. Help! Car slips when hot
  44. Coil is humming
  45. Vette hot on my arse!
  46. Are gt fuel pumps loud?
  47. Aluminum Heads....which ones for me?
  48. 10 PIN (SALT & PEPPER) LOCATION???
  49. Who has clear-coated engine bay parts?
  50. Frustrated, advice needed
  51. Piecing Together Suspension...Questions
  52. I got a problem....
  53. sweet ram air
  54. Broke into the 12's
  55. heavy vert possible 11's?
  56. ABS.... is this normal?
  57. Q about hp #'s and track times
  58. rolling fenders??
  59. interior spray?
  60. How will my car sound with this setup?
  61. to clean MAF or not to clean
  62. Header ?'s
  63. Suspension kit on Ebay
  64. dies at idle
  65. Car will suddenly just die?
  66. I wanna change my name
  67. Borla Side Pipes Are On The Way!
  68. Got my gauges in, couple install questions.
  69. aluminum steering rack bushings?
  70. installed underdrive pulleys
  71. Data Logger
  72. Need an Alternative to Cometic Head Gasket
  73. Started running hot all of the sudden...
  74. Code PO158
  75. Stall Converter Question
  76. Guys...don't kill me
  77. stock wheels vs. aftermarket (track time)
  78. Hate Rear Gears
  79. Harwood Hood ???
  80. MAF placement in CAI....?
  81. Prices for 347 build
  82. Airbag code 64 and 24 HELP
  83. rear seat delete q's
  84. High RPM problem
  85. need help quick
  86. Exhaust leaking, Can I plug these?
  87. street edge converter came in today
  88. Center console button?
  89. Cam Q
  90. Anyone....Everyone....HELP!!!!!!!
  91. How do i find horsepower
  92. Just took my vert to the strip
  93. wierd power band?
  94. Bleeding The Brakes.
  95. Stage 2 G-Trac
  96. Vortech Back On....Car's RUNNING! (So Far)
  97. found the problem with the trans..
  98. aftermarket intake question
  99. PA Super Streeter AODE from Summit Question
  100. Engine Transport
  101. throttle body trouble
  102. Is timing worth anything??
  103. dash painting/air bag cover help and opinions
  104. quick quarter panel question
  105. Air bag diagnostics....help
  106. 96 Cobra hood Clearance???
  107. bilstein vs stock shocks and struts
  108. Would ported Trickflow TW heads be a good for my combo?
  109. Nos And 373 Install Report
  110. how hard to install adjustable clutch quadrant?
  111. GT-40 intake install
  112. Should the chip come next?
  113. Whats wrong here?
  114. Ported Lower
  115. Cleaned IAC, car has high idle
  116. Best of Both Worlds? AUTOX Vs. DRAG suspension
  117. Rough Ride
  118. 31 Spline Axles
  119. Biggest tire on 18x9 wheel
  120. Codes 113 157 172 and 173 on 94 GT
  121. where do i get center caps
  122. will fox radiator fit sn95s?
  123. cam questions
  124. axle 101
  125. UPR Quadrant and firewall adjuster Q?
  126. Selecting Coilover sping rates
  127. Best New Times
  128. Stock T5 and Powershifting???
  129. What is the web site of the place that sells new ford wiring connectors?
  130. MMR Coilovers - good?
  131. Driver's side window came off track?
  132. bad alternator?
  133. take a look at this x-pipe, is it worth buying?
  134. will an 88 longblock work
  135. Need more clearance for fox tb swap
  136. 4R70W fit in my 94?
  137. 5.0 died... 5.8 commin up? (please help)
  138. Kenne Bell Setup, How much power?
  139. A couple questions about Axles! Help!
  140. oil pan bung for vortech
  141. 70 mm vs 65 mm Throttle body
  142. fuel injector size
  143. Website for turbos?
  144. Gears...
  145. 5.0 cranks
  146. AOD tranny work in our cars??
  147. Guys w/Cobra brakes & skinnies come in
  148. need help with ABS
  149. 351 Swap For Our Cars
  150. AODE slow to shift from 1-2, again
  151. Bad Oil Pump...
  152. VSS Removal
  153. Exhaust pipe rattle
  154. Who makes good radiators/fans?
  155. anybody know the "by the book"way to adjust rockers?
  156. fox cobra intake
  157. about timing
  158. where to buy SVO side exhaust?
  159. Daily Driver Build up
  160. Someone please set me straight with my firing order
  161. NEW Vert top needed
  162. finally got started this weekend
  163. need help with coil harness
  164. New Best Track Times!!!!
  165. ok...new transmission
  166. Why is my
  167. Friends 95 Gt has a "surging idle"...goes from 250rpm-800rpm...IAB? Alt? MAF?
  168. Labor Time estimates
  169. The Death Trap
  170. Wheel offset,Back spacing???
  171. Nitrous users...Have a small problem
  172. putting 94/95 5.0 in Fox; Fuel lines? Harness?
  173. ecu help
  174. 94 indy svo
  175. Brake install question >>>Need Help<<<
  176. 95' engine/computer harness removal?
  177. egr
  178. does it work?
  179. Got the tranny out and apart, why cant things ever go easy?
  180. Quick Fox TB question
  181. Quick Fox TB question
  182. Weird Sound just noticed today...
  183. Round 1 of 418 install
  184. 2 questions
  185. AODE tranny fluid
  186. cobra intake
  187. Just bought Cobra Wheels, What size Lug nuts and are they the acorn type?
  188. New motor running way to hot in 95 cobra
  189. help
  190. Better times with 3.73-4.10's
  191. new to site
  192. Why I'm A Mechanical Dumba$$ (feel free to disagree)
  193. proper way to install new torqe converter
  194. brand new performer manifold has all needed hardware?
  195. need to find a used 302 for 94 GT
  196. sell the 94 for a foxbody...?
  197. polished alternators
  198. When to change oil in a new engine
  199. Please Help
  200. granatelli maf sensor
  201. subframe connectors where do i weld them?
  202. people with underdrive pulleys
  203. how much gain with p&p e7's
  204. What maf to get for the vortech s/c kit
  205. New best e.t.!!!! mph!!!!
  206. What spark plugs should I run??
  207. How much to rebuild a shortblock? Is this all I need?
  208. air bag
  209. I need a flow sheet for Pro-M 80MM
  210. NEED AN ANSWER ASAP Head Gasket Direction...
  211. Clock wiring harness
  212. can i use 96-98 o2 sensors?
  213. Is the stock pressure plate worth anything?
  214. Who has Cervinis body parts?
  215. what motor in 1995 gt? firing order?
  216. 94 5.0 A/C Comp - Clutch&Bearing Help
  217. 93 and 95 have same injector harness?
  218. Spark Plug change Question
  219. HCI or new motor
  220. If we only did a Head Swap then?
  221. What is my problem?
  222. any difference if you remove the smog pump
  223. which speedo gear?
  224. AOD-E + TQ Converter
  225. is 220 too hot?
  226. Temperature guages, there's too many!!
  227. Long Tube w/ cats options??
  228. Bmn Nitrious Window Switch Question
  229. Bump steer
  230. Need help, rust in fuel rails
  231. Problem shifting...
  232. MRT, T Racing hood scoops
  233. Cutting springs, but not the usual question.
  234. need some quick questions...
  235. 255lph Pump OK With Stock Injectors?
  236. summit racing seats
  237. fabricated air intake dam really working well.cooling
  238. Which taillight fits on a -94 (model year)
  239. Would this work ? (axles + ABS)
  240. Car runs horrible after 42# injectors and lightning maf install!
  241. Question for Guys with Nitrous
  242. A few teflon braided fuel line q's.
  243. Car runs like crap when it's hot
  244. Opinions on fuel pressure regulators
  245. Grill Question
  246. guys with 2031 cam
  247. Symptoms of a Bad Fuel Pump?
  248. Check Engine light problem
  249. vehicle speed sensor
  250. ?purpose of running FPR with and w/o vaccum?
