View Full Version : 94-95 Tech
- Which taillight fits on a -94 (model year)
- Would this work ? (axles + ABS)
- Car runs horrible after 42# injectors and lightning maf install!
- Question for Guys with Nitrous
- A few teflon braided fuel line q's.
- Car runs like crap when it's hot
- Opinions on fuel pressure regulators
- Grill Question
- guys with 2031 cam
- Symptoms of a Bad Fuel Pump?
- Check Engine light problem
- vehicle speed sensor
- ?purpose of running FPR with and w/o vaccum?
- Brisk Spark Plugs: Another wonder deal ?
- n2o question on the day
- Questions on 306/331/347,( about pistons)
- Will an PRMII intake fit under the stock 94 hood?
- car staling
- What kind of 60' on stock
- Installing Cobra Intake
- Running Open Headers
- Symptoms of a Bad Timing Chain?
- Group Buy for Saleen S281 Wing?
- Oxygen Sensor Extension
- car stalls when hot only hot..
- Pro star users inside...
- Glue for Side Mirror?
- 255/40-17 Fit on stock 94 GT RIMS ?
- Red hot headers
- Got codes 181, 189 - car pings under load
- o2 sensor question
- Cooling Fan Not Working
- Nail in the front tire, how fixable?
- Setting Base idle...Does it set idle for park or drive?
- rim width????
- Smog Pump Idea?
- Traction control ?
- Disapointed
- which wire is it on throttle sensor for zex
- Power VS Suspension for lower ET's
- Is this a stupid suspension idea?
- belt length to bypass the a/c and the smog pump.....
- Porting Stock T/B and Mass Air Housing
- 306 Questions....Benefits?
- supporting mods with gears
- Attn. Seventymach1
- Lean or rich question
- UPDATE...When I Turn the Dizzy, Car "Clicks". MUST DRIVE by TOM.!
- intake manifold ?'s
- A/C compressor not kicking on. Any ideas?q
- Guys w/Explorer engines...
- Got a Cobra Intake, have a few ?'s
- engine ping
- Car rattles under heavy acceleration
- Rear window for vert won't go up! HELP!
- Boost and Fuel press. gauges
- Automatic. Big Diffrence?
- Oil coming from dipstick,leakdown results, Am I getting blow-by?
- Problem with tach...
- Bad Day, Car Won't Fire
- 95 shortblock
- Will I have problems getting an alignment?
- Cost for a 302-306 overbore?/What's it mean to balance an engine after assembly?
- A9l conversion removal... Please help!
- Cast/Camber plates needed for 94GT; what should I buy??
- blk/blk 94 mustang GT for sale!!!!!!!!
- best location to put zex nitros nozzle on intake
- T-5
- FLowmaster Catback ??????
- Sportsman vs. Stock
- Pics of the Brembos and some of the car..
- decided on vortech s trim...q?
- Popping noise
- No Oil Pressure.
- Weird compression test numbers!
- Putting on a vortech
- Show me your EGR delete plate.
- average price to refill a nitrous bottle ?
- spark plugs --> mpg?
- Muffler Question
- Drive shaft angle???
- 20amp fuel pump fuse blowing
- help! car died
- Guys with adjustable LCA's get in here!
- code 121
- Attn. SeventyMach1
- 351 belt length
- Rear shock installation
- broke rocker arm
- Please help me ID this connector
- At What Point are hardened pushrods needed?
- Thinkin about this Package
- First Try at Fox VC Install...ALREADY Problem (nobody told me)
- Noises in front right
- Dyno Charts Rock! Almost stock GT!
- ultra clear foglights
- Car did pefect after intake mani. install...reset idle, now it sputters!
- Car not running right after injector and MAF swap! Help
- AODE Owners, going to the track tonight , questions....
- Header HELP
- Quiet your exhaust! Grover mod strikes again.
- Installed my adjustable LCA/UCA's
- "Check Engine" help
- ECU 4 a 5 speed
- street heat VS track heat????
- Thinking of CHOPPING SPRINGS IN FRONT
- 331 Stroker Kit: What all do i need besides the kit?
- Throttle Positioning Sensor
- AODE still leaking. I am out of ideas. Help!
- just installed a fan switch
- NITTO Drag Radials!!!
- Got Some Oiling Issues! Need Help!
- IS this possible for $2,000?
- How to remove the clutch assembly?
- the winning combo?
- Silicon tubing?
- Big Wheel DR speeds.
- Installing my control arms tonight, any suggestions?
- Replace the Mach 460 - who's done it? Advice please.
- QUICK maf screen, do i install it?
- DSS 331, Vic Jr., RPM II -- What Cam?
- PMS question
- rpms bouncin all around
- Wtf!!! Backfire!!
- Cig. Lighter is 12v right? How come I am only getting .2? (Zeitronix Install)
- cobra rocker installation
- Header ?'s
- Magna flow Vs. Flow master......
- Msd distributor..Will it fit on my car?
- MSD distributor..Will it work on my car?
- Weird Gear ratio's
- Header help
- header questions
- bent valves?
- 150mpt sound bad???
- c springs without isolators
- 3.73 or 4.10.....that is the question.
- I pulled my codes, now I have a question?
- pulleys...crank rotating?
- Mac Lts, Vrs o/r x, magnapacks... have a Q
- lightning mass air question
- gauge wiring
- Paint question
- How do i remove seats and paneling?
- Are Zex kits universal? Looking to buy.
- powerdyne or procharger
- Help with sway bar end links...
- my 1/4 times seems odd
- Steeda #19 cam any good??????????
- I Got 13's!!!!!!
- Suspension ?
- Which one Subframe connectors are better
- bottom end strength of a 302
- has anyone....please help
- Whats the difference between MAF's?
- vert fender well weight removal
- front sway bar question
- Good Street Strip Clutch?
- Was i supposed to grease to bearing?
- Getting Gears...what else?
- Can anyone help me out??
- yet another suspension question
- Pro-M 80 with turbo
- 2.73's to 3.73's
- Speedo Calibration
- what mods should i do
- Well, Autolite 25's won't fit (WTF)
- GOING INSANE...HELP!!! - Installing Tach...tach bounces with bass
- Ready to fire new engine. Have a timing question?
- URGENT: pushrod help
- GT40p head thread :D
- mac 1 3/4" longtubes fitment????
- Belt Tensioner Help
- Tune in Southwest VA
- NOS question
- Symtoms of a cracked Block/Head???
- just finished gear install
- 95 Cobra :Electrical Problems:
- '95 GT Long Tubes
- New cat's rattling!
- Paul Here is your TECH/ Debate thread.
- fog lights
- Where the hell is the PCV valve???
- correct plugs for combination
- Chirping Pully
- cylinder heads
- Suspension
- New K, A arms, coilovers, CC plates
- New Dyno and 1/4 #'s
- Knocking.... but only when the car warms up....??
- How much HP are #30 Injectors good for?
- Coating headers?
- Anybody install an Edelbrock Vic EFI intake?
- FUel Pressure Test Results...
- Looking for info on the 95 Cobra R
- Stangnetters in maine??
- Rio95
- Eaton blower?
- Running wires through the firewall. Some??'s
- No harmony "harmonic" balancer!
- transmission control switch
- how to get a 95 Cobra in the mid-low 13's
- oil pressure sending unit
- MAF sensor and spout connector
- Supercharger IDEA...would this work?
- Is an upgraded torque converter harder on the rest of the tranny?
- Valvecover Question
- anyone have pic of 3" tips?
- Been a long time coming but my car runs!
- FRPP 65mm throttle body?
- How mych HP/TQ i lose for not having bigger Throttle body
- FOX PRO CHAMBER (will it fit?)
- Gears?
- HELP : idling problem, since mods added
- cam/rocker question
- Tire Width for traction
- wheel hop
- 14.45@102
- Steel retainer
- So here's a question I don't know many people will know...
- Aode Stock Pan, How much fluid?
- New Best Time!!!!!!!!
- Takin the tranny out this weekend, anyone got any tips?
- Switching from V6 gauges to GT?
- header gaskets
- how to advance timing?
- Decent night at track
- This Darn Fuse!
- Read This if You Have a Vortech Tensioner Piece!
- What do I need to run 3.73's?
- Project White Balls..... FR500's
- A Stang, err Strange Power
- Apde To 5-spd Maybe, Cant Decide...
- where to install gauges..
- Wow, my car takes a chitload of oil!!!
- C4 Install *pics* **DUW**
- Timing Question
- Installed Performer Intake
- MSD 6 BTM hook-up....how to???
- 1 of 16 pushrods too short..... ????
- Possible Valve Clearance Issue?
- fuel pump kill switch in a 95
- Finally Got A Dyno Tune
- How much quieter is magnaflow w/ high flow x-pipe?
- Billet grille insert?
- WIll catted / offroad Pipe sound Similiar?
- Header Wrap
- Belt size for smog delete w/BBK pulleys
- EGR delete plate
- Anyone with Bassani o/r X & long tubes, come in here please
