PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Car not running right after injector and MAF swap! Help
  2. AODE Owners, going to the track tonight , questions....
  3. Header HELP
  4. Quiet your exhaust! Grover mod strikes again.
  5. Installed my adjustable LCA/UCA's
  6. "Check Engine" help
  7. ECU 4 a 5 speed
  8. street heat VS track heat????
  9. Thinking of CHOPPING SPRINGS IN FRONT
  10. 331 Stroker Kit: What all do i need besides the kit?
  11. Throttle Positioning Sensor
  12. AODE still leaking. I am out of ideas. Help!
  13. just installed a fan switch
  14. NITTO Drag Radials!!!
  15. Got Some Oiling Issues! Need Help!
  16. IS this possible for $2,000?
  17. How to remove the clutch assembly?
  18. the winning combo?
  19. Silicon tubing?
  20. Big Wheel DR speeds.
  21. Installing my control arms tonight, any suggestions?
  22. Replace the Mach 460 - who's done it? Advice please.
  23. QUICK maf screen, do i install it?
  24. DSS 331, Vic Jr., RPM II -- What Cam?
  25. PMS question
  26. rpms bouncin all around
  27. Wtf!!! Backfire!!
  28. Cig. Lighter is 12v right? How come I am only getting .2? (Zeitronix Install)
  29. cobra rocker installation
  30. Header ?'s
  31. Magna flow Vs. Flow master......
  32. Msd distributor..Will it fit on my car?
  33. MSD distributor..Will it work on my car?
  34. Weird Gear ratio's
  35. Header help
  36. header questions
  37. bent valves?
  38. 150mpt sound bad???
  39. c springs without isolators
  40. 3.73 or 4.10.....that is the question.
  41. I pulled my codes, now I have a question?
  42. pulleys...crank rotating?
  43. Mac Lts, Vrs o/r x, magnapacks... have a Q
  44. lightning mass air question
  45. gauge wiring
  46. Paint question
  47. How do i remove seats and paneling?
  48. Are Zex kits universal? Looking to buy.
  49. powerdyne or procharger
  50. Help with sway bar end links...
  51. my 1/4 times seems odd
  52. Steeda #19 cam any good??????????
  53. I Got 13's!!!!!!
  54. Suspension ?
  55. Which one Subframe connectors are better
  56. bottom end strength of a 302
  57. has anyone....please help
  58. Whats the difference between MAF's?
  59. vert fender well weight removal
  60. front sway bar question
  61. Good Street Strip Clutch?
  62. Was i supposed to grease to bearing?
  63. Getting Gears...what else?
  64. Can anyone help me out??
  65. yet another suspension question
  66. Pro-M 80 with turbo
  67. 2.73's to 3.73's
  68. Speedo Calibration
  69. what mods should i do
  70. Well, Autolite 25's won't fit (WTF)
  71. GOING INSANE...HELP!!! - Installing Tach...tach bounces with bass
  72. Ready to fire new engine. Have a timing question?
  73. URGENT: pushrod help
  74. GT40p head thread :D
  75. mac 1 3/4" longtubes fitment????
  76. Belt Tensioner Help
  77. Tune in Southwest VA
  78. NOS question
  79. Symtoms of a cracked Block/Head???
  80. just finished gear install
  81. 95 Cobra :Electrical Problems:
  82. '95 GT Long Tubes
  83. New cat's rattling!
  84. Paul Here is your TECH/ Debate thread.
  85. fog lights
  86. Where the hell is the PCV valve???
  87. correct plugs for combination
  88. Chirping Pully
  89. cylinder heads
  90. Suspension
  91. New K, A arms, coilovers, CC plates
  92. New Dyno and 1/4 #'s
  93. Knocking.... but only when the car warms up....??
  94. How much HP are #30 Injectors good for?
  95. Coating headers?
  96. Anybody install an Edelbrock Vic EFI intake?
  97. FUel Pressure Test Results...
  98. Looking for info on the 95 Cobra R
  99. Stangnetters in maine??
  100. Rio95
  101. Eaton blower?
  102. Running wires through the firewall. Some??'s
  103. No harmony "harmonic" balancer!
  104. transmission control switch
  105. how to get a 95 Cobra in the mid-low 13's
  106. oil pressure sending unit
  107. MAF sensor and spout connector
  108. Supercharger IDEA...would this work?
  109. Is an upgraded torque converter harder on the rest of the tranny?
  110. Valvecover Question
  111. anyone have pic of 3" tips?
  112. Been a long time coming but my car runs!
  113. FRPP 65mm throttle body?
  114. How mych HP/TQ i lose for not having bigger Throttle body
  115. FOX PRO CHAMBER (will it fit?)
  116. Gears?
  117. HELP : idling problem, since mods added
  118. cam/rocker question
  119. Tire Width for traction
  120. wheel hop
  121. 14.45@102
  122. Steel retainer
  123. So here's a question I don't know many people will know...
  124. Aode Stock Pan, How much fluid?
  125. New Best Time!!!!!!!!
  126. Takin the tranny out this weekend, anyone got any tips?
  127. Switching from V6 gauges to GT?
  128. header gaskets
  129. how to advance timing?
  130. Decent night at track
  131. This Darn Fuse!
  132. Read This if You Have a Vortech Tensioner Piece!
  133. What do I need to run 3.73's?
  134. Project White Balls..... FR500's
  135. A Stang, err Strange Power
  136. Apde To 5-spd Maybe, Cant Decide...
  137. where to install gauges..
  138. Wow, my car takes a chitload of oil!!!
  139. C4 Install *pics* **DUW**
  140. Timing Question
  141. Installed Performer Intake
  142. MSD 6 BTM hook-up....how to???
  143. 1 of 16 pushrods too short..... ????
  144. Possible Valve Clearance Issue?
  145. fuel pump kill switch in a 95
  146. Finally Got A Dyno Tune
  147. How much quieter is magnaflow w/ high flow x-pipe?
  148. Billet grille insert?
  149. WIll catted / offroad Pipe sound Similiar?
  150. Header Wrap
  151. Belt size for smog delete w/BBK pulleys
  152. EGR delete plate
  153. Anyone with Bassani o/r X & long tubes, come in here please
  154. Got my Cobra Intake
  155. anyone using a spec stage one? come in here?
  156. Another summit radiator thread!!!
  157. How bad to run AODE w/no cooler?
  158. Sup NOS guy's?
  159. Installing sway bar end links...
  160. Here is the deal
  161. Tweecer datalog/Calcon doesn't works any more NEED HELP
  162. My car would not start. Somebody please HELP.
  163. causes for car running hot
  164. fixing light dimming problems?
  165. How accurate are our/your odometers?
  166. Spring help
  167. ok, car goes into back country shop!
  168. Need help?
  169. Anyone think they can figure out why my car runs so hot?
  170. Hello everybody..........
  171. Rebuild or buy new..?
  172. Need Help Fast!!!!!!!! Edelbrock Intake Install
  173. SVO block
  174. code help
  175. Vibration @ 1100 rpm after balencer install
  176. Low speed fan not turning on.
  177. Locking Lug Nuts
  178. Car Died 5-6 Times at Stop Sign Today!
  179. quick question
  180. Windage tray, should I use one or not?
  181. Cooling Problems Help
  182. Why is my 95 gt vert a dog?
  183. Surging is basically gone! 6AL and plug wires...
  184. Which Rear Shocks ?
  185. How much nos
  186. Anyone with undercar fron end pics?
  187. New Clutch fork?
  188. intake worth it??!!
  189. Do GT40P's have regular EGR stuff?
  190. Who has the Steeda Ajustable Clutch Quadrant Kit??
  191. Brake Bleeding Kits
  192. power robber
  193. Hacked BBK orH install + vids
  194. Gears, Driveshafts, and trannys
  195. Heads!!!
  196. Power Seat not working!!
  197. power steering with out ac and smog pump
  198. just bought tires!!!!
  199. aluminum d/s shorter?
  200. selling engine, whats it worth?
  201. Pushrod Length Checker
  202. Tore down my GT's engine this weekend...
  203. Is it ok to run open header? Will I hurt anything??(longtubes)
  204. receiver hitch
  205. Advance timing
  206. Tire Size For 17x8 and brand
  207. v6 aode fit my 302
  208. 95 GT vert cat-back opinions
  209. Anybody want to hear my new combo!!!
  210. 95 shell....what could i do with it....
  211. Help with reverse light switch
  212. does this sound right (gear whine)
  213. Best code scanner?
  214. Diablosport Chips
  215. wrecked stang
  216. Changed the springs on my Cobra and look what I found....
  217. what do i need to install a autometer oil pressure gauge
  218. oil question
  219. Just Got My First 1/4 Mile Time...
  220. best drop springs for a vert?
  221. Sniper Special Forces for 94 Cobra
  222. Curious, does a S\C fit on a stock motor ?
  223. I need hope, whose.....
  224. Cometic Head Gaskets = Not cool......
  225. Question on Springs
  226. What 31 axles to use? price?
  227. Should I lower compression?
  228. Throwout bearing = tweety bird
  229. Fox body TB swap worth it??
  230. Belt Length for Underdrive Pullies
  231. Low speed front end clunk when turning wheel
  232. Need Help! Install 96/98 Hood Latch on 95GT? Possible? Dealer's comments...
  233. Valve clearence?
  234. Replaced ECT / Sending unit / 180 termo ???
  235. got the squeaks
  236. adjustable clutch cable?
  237. Headlight connector keeps melting down
  238. Check out these tires.
  239. Aftermarket intake to hood clearance?
  240. Few questions.. maybe serious maybe not..
  241. fuel pressure constantly fluxuating/rapidly bouncing up & down w/bad driveability
  242. Removed heads and found this mess
  243. chassic brace?
  244. What suspension do i get?
  245. Will Fox springs work on my 95 GT???
  246. Squeaking clutch pedal
  247. tranny swap
  248. AODE 2 5 speed swap
  249. Curb Rash on my Cobra R rim
  250. How can I tell if I have Anti-Lock brakes?
