View Full Version : 94-95 Tech
- Question on Springs
- What 31 axles to use? price?
- Should I lower compression?
- Throwout bearing = tweety bird
- Fox body TB swap worth it??
- Belt Length for Underdrive Pullies
- Low speed front end clunk when turning wheel
- Need Help! Install 96/98 Hood Latch on 95GT? Possible? Dealer's comments...
- Valve clearence?
- Replaced ECT / Sending unit / 180 termo ???
- got the squeaks
- adjustable clutch cable?
- Headlight connector keeps melting down
- Check out these tires.
- Aftermarket intake to hood clearance?
- Few questions.. maybe serious maybe not..
- fuel pressure constantly fluxuating/rapidly bouncing up & down w/bad driveability
- Removed heads and found this mess
- chassic brace?
- What suspension do i get?
- Will Fox springs work on my 95 GT???
- Squeaking clutch pedal
- tranny swap
- AODE 2 5 speed swap
- Curb Rash on my Cobra R rim
- How can I tell if I have Anti-Lock brakes?
- What is the best way to FLUSH radiator?
- Can I drive car without electric fan & shroud?
- Quad Shock / New UCA, LCA question
- computer recommendations
- Inches
- New Track Times!!!
- Is an AODE X member diff. than a t-5?
- brakes
- v6 to v8 swap....DIFFICULT??
- prochamber vs. x pipe
- Good aftermarket fan system?
- Links.......
- window wont roll up
- quick injector question
- Tuning question.
- 94 foglights same as 99+?
- OINK! Tell us about your TT progress...
- Seatbelts
- Wiring Diagram/Pics
- 14.018 @ 99.08
- Plug Question
- 13.795 @ 102.21
- running rich hurting TQ??
- Help! Can't get into gear
- 94-04 5 Speed Pedal Assembley the same?
- Who sells brake rebuild kits? Anyone have the PBR swap info?
- GT really messed up, looking for help
- AODE tranny cooler guys
- Where do you get HPM motor mounts?
- What suspension upgrades for $1500-$2000?
- might be parting out the car....advice.......
- Anyone ever try these sparkplug wires( stainless steel braided)
- What size MAF and Injectors for my setup?
- computer problems!!!
- Speedo Gear?
- air only blows on defrost
- Rework the stock control arms?
- Scored some GT-40 Heads
- Ignition cap $45??????
- It's official, I hate them
- 315's rubbing
- GT-40p Users In Here!
- fox throttle conversion: need tubing for mass air to throttle
- Paint
- Sooo.... I busted my T5 tonight
- Fastest Natrualy Asparaited Mustang...
- Why are my lights still dimming in and out????
- finally ordered gears.
- What would cause my car to backfire?
- Saleen Body Kit
- aluminum driveshaft rubbing?
- $ for an upgrade
- Does your AC Compressor ALWAYS spin
- Grind metal noises from the exhaust ?
- car doesen't want to stop!!
- Failed Emissions!!!
- Driver Power seat
- My brakes are hard!!!
- Sportline springs came in the mail today... Any install how-to's or tips??
- E-Brake Light
- squeak in steering
- People who have bought h/c/i packages through Ed C. in here
- Steering shaft wont go all the way back in
- 351 W, how much power?
- For those contemplating a Spec Stage 1 Clutch
- Odometer
- New Wheels + New Paint = New Pics!
- ignition problem
- clutch decisions
- Steeda subframes?
- PCV location pic w/TFS intake?
- Clear 94-05 taillights
- Straight Pipes
- HELP: Mac LT + BBK H?
- Would a King Cobra clutch be good enough for my car?
- Should high mileage O2 sesor be changed out?
- Quiet when cold, sewing maching when warm
- Proper Head / Block Preperation for HG install ???
- Burning Smell After Clutch Install
- if i have a small oil leak around the oil pan seal, should i still spray?
- steering problems
- any online dealers for granatelli?
- Oil question
- Throttle Body Adapter
- advice on sticky tires
- Cost of GT-40 h/c/i swap?
- New Best Time!!!!
- Question where do these lines go? (PICS)
- Name these sensors/plugs (PICS) (trouble shooting)
- car might be rich
- Which heads Trick flows or AFR's
- Installing tach, quick wiring questions
- Stuck injector
- codes
- The 10k plan
- 95 mustang
- What do you guys think?
- Lets Discuss High Boost/Detonation/Headgaskets
- Who removes their front sway bar for the track?
- Cobra Auto Design Hoods
- Going to the track tonight
- Quick Help!!!!!
- Odd request! I need the stock battery measurement please! Help!
- tuner just said 95 mustang is tuneport injection
- Headlight Switch....Plz Read!
- Carpet Replacement
- T-5 swap help...
- Seems to finaly be all good
- Will there be a problem?
- Purchasing Parts
- coolant overflow issue
- cost of T-5 conversion
- 5.9 Dakota???
- First track results ...BAD NEWS
- My track day
- AOD tranny and the proper usage?
- GT vs Cobra TB...same thing?
- track results part 2
- 30, 35, 40, 45....245, 255, 265....so many numbers!!!
- clutch pedal position ...hmm
- Weird Clutch Feel
- Help! Transmission Woes
- Can you put a 1989-93 EEC-IV computer in a 94-95 GT
- Pros and Cons of Dumps
- HELP, trying to change T5 output seal, many questions
- '94/'95 Cobra Motor
- Vortech--Results of "Damage"
- Dyno numbers
- Exhaust Noises when Hot
- Does your stang have this problem on acceleration?
- 95 seat rear seat cushion removal?
- Those who have busted their T5 - How long did yours last?
- 300RWHP Daily Driver Recipe?
- LT Header Question
- GT40P's and long tube headers
- Spout Connector - Quick Q
- Side gapping and polishing; give your opinion NOW! please?
- Where exactly do I lube my TOB to get it to stop squeaking?
- Something is squeaking when I turn my steering wheel.
- Flowmasters and stock setup
- Bullit Suspension help
- Everyone help me pick out front Coil-Overs
- Im looking to lower my stang.
- Can A driveshaft be REBALANCED?
- How much HP are long tubes worth?
- Cleaning CLoth seats + carpet!
- Lookin for same 302 block like 94-95 have,what other years use same block
- Anyone have pics of these headlights? what do u think?
- 30 lb injectors + c&l = horrible idle
- Where to buy cheap 8 point roll bar/cage for Convertible
- stock sway bar size?
- Looking for an Aluminum Driveshaft
- runnin lean--why
- Radio Error
- How much does the whole fog light assembley weigh?
- oil running back up through my dipstick!
- Yeah, Gears in
- I have not been on stang net for some time.
- Kenne Bell Question?
- New Mods...bench racers wanted!!!!!
- Where can I get a s-trim
- *Sigh* Yet Another Sound... In Dash?
- Vibration before transmission...help!!!
- How bad would it be to run New Maf before injectors get here
- strut bar
- Parking brake adjustment on a 95 Cobra
- 295's 305's or 315's ??????
- exhause combo need help!
- questions on air conditioning?
- Rear-End Nosies?
- K-member brace question...
- Overdrive?
- 87-93 fuel tank fit our years??
- Need help with location of vacumn lines in Edelbrock Performer.
- 99+ brakes on a 94 GT?
- why am I having a problem finding battery cables?
- What fuse controls power seat?
- Mail Order Chip vs Dyno Tune Chip vs EEC Tuner
- 95 Transmission
- Front Strut install question
- What RPM is the FMS alum D/S balanced to?
- Howl
- Motorsport sparkplug wires
- Crane Gold rockers... Any better?
- i need this emblem
- 73mm= how many inches?
- wicked info look! also what do u think...
- Alternator Question?
- Grinding when downshifting into 1st
- please read
- cluster/tail lights
- If you ever used Nitto tires, come in here!!!!
- fuel presure
- header question.
- NEW oxygen sensors
- Engine questions?
- Intake back fire!!???
- Does a permanent fuel pressure gauge on fuel rail = broken gauge?
- bassani o/r x
- Trac-Loc Rebuild Price
- tie rod question should they swivel?
- Rad/cooling problem.
- Does a fox fuel tank fit a 94-95?
- Car won't start...No Spark
- steering wheel shimmy
- Nitrous.. which should i go with.. and how much
- Anything to be worried about?
- Need Pics...Side Exhaust/Xenon Body Piece Specific!
- is this product an 'oil in intake from PCV' solution??
- how are the valve guides lubricated?
- what does an exhaust leak sound like
- Which distributor for 351W
- New Vortech MAF won't fix this will it?
- electric power steering pump?
- Trac-Loc
- Gears and Nitrous
- Trouble codes with no solution?
- Summit Radiator... pics?
- Running rich?
- '94 valve covers DO clear TW heads w/ 1.7's
- CF cobra R style hood
- AFP regulator
- Fuel Pump and Nitrous
- They need to make the new Cobra Heat-Extractor Hood for SN95s
