PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Which plugs for a 347 with Victor Jr.s?
  2. had an install day
  3. PCV keeps popping out!!
  4. thumper/tmoss combo at track=not happy
  5. Update on my 418 setup. Now I got vic jr's and a spyder.
  6. What happens if I beat on a new clutch?
  7. Walbro 255lph on stock motor
  8. Holy Smokes, and a buttload!!!
  9. Ticking sound from x-pipe.
  10. I'm not convinced the fox swap is a good idea....PART 2
  11. P600B Blower Clip
  12. Guys with BBK o/r H-pipe and MAC long tubes headers post here, please
  13. what suspension
  14. New Exhaust..BBK L.T. & Shorty H-Pipe
  15. shorty BBK H-pipe???
  16. Cobra Body Kit
  17. Where to get good brake pads??
  18. slight spark knock
  19. Running Rich
  20. Running Rich
  21. What causes steering wheel shake???
  22. stalling after tfs intake install
  23. Thinking of getting a Vortech
  24. Edelbrock catback info +++ Anybody???
  25. 03 Chrome Cobra's
  26. Launching with stall
  27. Cobra Centercaps??
  28. 3.55's
  29. Got tires any track tips?
  30. crazy electrical problem with fuel pump. PLEASE read and help if you can.
  31. Very hot and very slow, cats?
  32. HELP !! Rear Rotors!!
  33. Any one know where to buy Pro3i products
  34. gt-40, 1.7s, e303 too much?
  35. gt-40p headers
  36. Vibrations on the highway
  37. pulley's
  38. broke my convertible top glass this weekend
  39. DIY Oil Separator
  40. clutch quadrent
  41. A few mods that I couldn't "feel" a difference
  42. Same Problems once again
  43. stalling
  44. hot start problems...
  45. Gear Oil
  46. Why don't more folks choose Kenne Bell Superchargers?
  47. what the heck is this?
  48. crankshaft damper problems...maybe???
  49. poll for which heads i should get
  50. Gear whine or ???
  51. C&C plates needed with C-springs
  52. Am I missing anything for a dynotune?
  53. still MORE questions
  54. Does anyone know where to find CDC's aero rear bumper???
  55. It Broke!
  56. what is the compression on a 5.0 302?
  57. Loud Thud When Banging Second Gear
  58. Car I'm interested in
  59. Does anyone know about charging their A/C and stuff like that?
  60. Went to the track in my vert..
  61. What brands should i be looking at?
  62. What valve covers??
  63. How much are these heads worth???
  64. Car is running again!!
  65. Master Cylinder Fittings
  66. ATF oil in T5? LOOK!!
  67. Changing diff cover gasket- anything to look out for?
  68. Went nuts today
  69. New cam = new vibration???
  70. Slightly erratic idle after Cobra Intake Install - normal?
  71. I Need some Mach 460 advice
  72. no spout
  73. heads and cam Question
  74. Guys who have Flowmaster American Thunder i need some help here
  75. Stock Strut Tower Brace, whos got one layin around?
  76. coilovers
  77. BBK Catalytic Converters
  78. SFC's question
  79. hood and fenders
  80. Fun Ford Weekend: My first visit to a dragstrip!
  81. disassemble an alternator??
  82. went to paint my taillights..
  83. how much is a rebuilt c4 worth?
  84. swapped out pedals now brake lights dont work
  85. Dr. Gas?
  86. Will BBK LT headers works with MAC H-pipe
  87. Narrowing Exhaust Choices
  88. Will 10'5" wheels fit with Flowmaster cat-back
  89. How off will speedo be?
  90. subframes or not ?
  91. pro m problem
  92. Spark Plug Gapping
  93. Mustang GT need opinion fast-thank you
  94. ah...gimmee a break...
  95. A Couple Questions..Exhaust and Gears
  96. Got caught by cops without cats
  97. Horn and seat track
  98. Is this what i need?
  99. GT40p Header help
  100. spring is here..let's see your rides
  101. Need help fast, My car is slower that a damn Yugo
  102. Mad Detonation! Need To Fix Quick!
  103. broke t-5 and new l/t
  104. question about super chargers help please
  105. lower Control Arms
  106. ds spacer?
  107. Cobra IRS?
  108. Are my flows on backwards? Help
  109. torque specs
  110. Rattling/squeaking front brakes
  111. Shifter dimensions?
  112. some exhaust system questions
  113. Car idles at 3500 RPM!!! What is going on here?
  114. Do I really NEED my air-pump/tubing
  115. Good street/strip cams for a 5.0?
  116. Do you think this is an X or an H pipe?
  117. Rear Reflector
  118. 98 cobra parts?
  119. removing top starter bolt. cant get to it
  120. Should I keep these 20's or trade them for a new Vortech SQ? DUW
  121. 18's on a 95
  122. Air compressor advice
  123. Tri-ax / 5th gear problem resolved
  124. the much anticipated pics of the cobra bumper
  125. 2.05 valve on twested wedge !!!
  126. Yay More problems for me!!
  127. 94-95 X-pipe question! Help!
  128. relocate p/s and a/c?
  129. cam install/bumper clearance issues
  130. Cobra front bumper ?
  131. Went to the track...........
  132. 2 drain plug's
  133. Car Issues AGAIN
  134. Those with mechanical gauges
  135. starting troubles
  136. Vibration problem after T5 swap... part 3
  137. Upper To Lower gasket wet
  138. Stock gear ratio
  139. Meziere electric water pumps ready
  140. short belt
  141. driveshaft bolts
  142. Just to let everyone know...
  143. 351 HCI Info
  144. Will 99-04 GT's aftermarket catback fit on 94-95 GT's ???
  145. cooling issues are still issues.....
  146. Car finally back on the road! And PICS of my winter work!
  147. Cobra getting a little make-over
  148. ordered a new oil pan gasket form summit for my 94
  149. Parts shopping
  150. Routing, red and green vacuum lines?
  151. Double clutching?!?!
  152. oil filter
  153. Exhaust Cutoffs?
  154. d00e-c
  155. Constant power point/cigarette lighter?
  156. Update on 03 Cobra Front Bumper
  157. Cobra/Griggs Front Bumper
  158. Changing Harmonic Balancer - any tips?
  159. anybody know where to get a large magnet?
  160. Control arm bushings, How hard? Sceialty tools req'd?
  161. Dyno Numbers and 1/4 Mile Times
  162. Painting tail light bezels.....
  163. Quick Question, vacuum line to fuel pressure regulator
  164. SN95 Wheel Bearing Replacement. How hard?
  165. Need Power Estimation DSS 331+JRVic+RPMII
  166. Emergency brake boot?
  167. Cam guys, How much vacuum do you pull?
  168. reduce 60 ft times?
  169. check engine light comes on around 4000-5000rpm??
  170. Anyone have pics of tailpipes with 10,5" wheels (or 10"+)
  171. should i go back to 3.90's
  172. cobra bumper finally on!!
  173. Odd Gas Consumption Pattern
  174. Can GO But Need To Stop!!!!
  175. tips for removing oil pressure switch
  176. OT , anyone have bazels for stock 94-95 GT/V6 hood
  177. aod-e to T-5, T-45 swap?
  178. 331 Stroker....94-95 5.0?
  179. parts store radiators
  180. Picked up the car today
  181. Is it time for a rebuild?
  182. bad news... well for me anyways.
  183. do i need bigger injectors for these->E303 Cam and NEW up and low intakes
  184. whos got the 94\95 Black Cobra in AnnArbor
  185. Look what i did today!!!! pictures!
  186. Do i need bigger injectors???
  187. Why You Should Clean Your MAM Filter.
  188. A few more pics of my "new" yellow stang
  189. Cheap Ford Racing Gears
  190. Stock Valve Covers and TW Heads, how'd you do it?
  191. washed my car...
  192. Does a 89 8.8" rear fit a 95 (QUICK)
  193. Help Guys (I'm a novice!)
  194. AODE harness change to T-5 ???
  195. First pics of the season :)
  196. Plugging th PCV installing a breather cap
  197. Anybody try this EGR Simulator?
  198. Big fuel problems..Need your help guys
  199. 95 Stang takes a long time to start!
  200. 50oz vs 28oz
  201. 95 GTS Mod Questions
  202. Installed New Bullitt's Today!!!
  203. a few problems
  204. Please Change this Sub-Forum BACK to 94-95 SPECIFIC
  205. Dam tailpipe
  206. fixable?????
  207. power pipe blows!
  208. what else with a S/C?
  209. bumper removal
  210. CAI help
  211. 94-95 Ecu/Computer ?
  212. 94 5.0 questions
  213. 1.7s too much??
  214. Car keeps dying!!
  215. Need Help, Charging problems
  216. what gauges should I get??
  217. who is AMP ?
  218. Alarm systeme, Astra-777 , any good ?
  219. BBK UD Pullies = Shorter Belt??
  220. Heads and intake are on!!!
  221. Car doesnt have the power it should.
  222. More parts on the Way!
  223. Brembo & Baer rotors
  224. 215 what
  225. HP Guestimation
  226. Leather Seat Covers
  227. how to remove rear abs sensors with out breaking them?
  228. Difference between American Thunder and Delta Force (Flowmaster)
  229. I really need help!
  230. pics- of my 94 black vert
  231. AODE to t5 swap help... Come on in!
  232. car crapped on the hwy
  233. can someone photoshop for me
  234. front chin spoiler/air dam
  235. 331 hp search results = 0
  236. Damage Pics
  237. How do you know when your belt tensioner is shot?
  238. S/C or Turbo....???
  239. Car is out of comission for awhile
  240. New Energy Suspension Kit
  241. Help needed
  242. Help! Rough idle, hanging idle
  243. Tools needed to install upper / lower intake
  244. A/F Ratio Gauge/pillar gauge pod install Questions...
  245. Chrome Dress up kit question?
  246. Custom "X" pipe is on!
  247. modification planning tips
  248. H/C/I tips
  249. 5th gear syncro going bad?
  250. Edelbrock Performer Install
