PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Fun Ford Weekend: My first visit to a dragstrip!
  2. disassemble an alternator??
  3. went to paint my taillights..
  4. how much is a rebuilt c4 worth?
  5. swapped out pedals now brake lights dont work
  6. Dr. Gas?
  7. Will BBK LT headers works with MAC H-pipe
  8. Narrowing Exhaust Choices
  9. Will 10'5" wheels fit with Flowmaster cat-back
  10. How off will speedo be?
  11. subframes or not ?
  12. pro m problem
  13. Spark Plug Gapping
  14. Mustang GT need opinion fast-thank you
  15. ah...gimmee a break...
  16. A Couple Questions..Exhaust and Gears
  17. Got caught by cops without cats
  18. Horn and seat track
  19. Is this what i need?
  20. GT40p Header help
  21. spring is here..let's see your rides
  22. Need help fast, My car is slower that a damn Yugo
  23. Mad Detonation! Need To Fix Quick!
  24. broke t-5 and new l/t
  25. question about super chargers help please
  26. lower Control Arms
  27. ds spacer?
  28. Cobra IRS?
  29. Are my flows on backwards? Help
  30. torque specs
  31. Rattling/squeaking front brakes
  32. Shifter dimensions?
  33. some exhaust system questions
  34. Car idles at 3500 RPM!!! What is going on here?
  35. Do I really NEED my air-pump/tubing
  36. Good street/strip cams for a 5.0?
  37. Do you think this is an X or an H pipe?
  38. Rear Reflector
  39. 98 cobra parts?
  40. removing top starter bolt. cant get to it
  41. Should I keep these 20's or trade them for a new Vortech SQ? DUW
  42. 18's on a 95
  43. Air compressor advice
  44. Tri-ax / 5th gear problem resolved
  45. the much anticipated pics of the cobra bumper
  46. 2.05 valve on twested wedge !!!
  47. Yay More problems for me!!
  48. 94-95 X-pipe question! Help!
  49. relocate p/s and a/c?
  50. cam install/bumper clearance issues
  51. Cobra front bumper ?
  52. Went to the track...........
  53. 2 drain plug's
  54. Car Issues AGAIN
  55. Those with mechanical gauges
  56. starting troubles
  57. Vibration problem after T5 swap... part 3
  58. Upper To Lower gasket wet
  59. Stock gear ratio
  60. Meziere electric water pumps ready
  61. short belt
  62. driveshaft bolts
  63. Just to let everyone know...
  64. 351 HCI Info
  65. Will 99-04 GT's aftermarket catback fit on 94-95 GT's ???
  66. cooling issues are still issues.....
  67. Car finally back on the road! And PICS of my winter work!
  68. Cobra getting a little make-over
  69. ordered a new oil pan gasket form summit for my 94
  70. Parts shopping
  71. Routing, red and green vacuum lines?
  72. Double clutching?!?!
  73. oil filter
  74. Exhaust Cutoffs?
  75. d00e-c
  76. Constant power point/cigarette lighter?
  77. Update on 03 Cobra Front Bumper
  78. Cobra/Griggs Front Bumper
  79. Changing Harmonic Balancer - any tips?
  80. anybody know where to get a large magnet?
  81. Control arm bushings, How hard? Sceialty tools req'd?
  82. Dyno Numbers and 1/4 Mile Times
  83. Painting tail light bezels.....
  84. Quick Question, vacuum line to fuel pressure regulator
  85. SN95 Wheel Bearing Replacement. How hard?
  86. Need Power Estimation DSS 331+JRVic+RPMII
  87. Emergency brake boot?
  88. Cam guys, How much vacuum do you pull?
  89. reduce 60 ft times?
  90. check engine light comes on around 4000-5000rpm??
  91. Anyone have pics of tailpipes with 10,5" wheels (or 10"+)
  92. should i go back to 3.90's
  93. cobra bumper finally on!!
  94. Odd Gas Consumption Pattern
  95. Can GO But Need To Stop!!!!
  96. tips for removing oil pressure switch
  97. OT , anyone have bazels for stock 94-95 GT/V6 hood
  98. aod-e to T-5, T-45 swap?
  99. 331 Stroker....94-95 5.0?
  100. parts store radiators
  101. Picked up the car today
  102. Is it time for a rebuild?
  103. bad news... well for me anyways.
  104. do i need bigger injectors for these->E303 Cam and NEW up and low intakes
  105. whos got the 94\95 Black Cobra in AnnArbor
  106. Look what i did today!!!! pictures!
  107. Do i need bigger injectors???
  108. Why You Should Clean Your MAM Filter.
  109. A few more pics of my "new" yellow stang
  110. Cheap Ford Racing Gears
  111. Stock Valve Covers and TW Heads, how'd you do it?
  112. washed my car...
  113. Does a 89 8.8" rear fit a 95 (QUICK)
  114. Help Guys (I'm a novice!)
  115. AODE harness change to T-5 ???
  116. First pics of the season :)
  117. Plugging th PCV installing a breather cap
  118. Anybody try this EGR Simulator?
  119. Big fuel problems..Need your help guys
  120. 95 Stang takes a long time to start!
  121. 50oz vs 28oz
  122. 95 GTS Mod Questions
  123. Installed New Bullitt's Today!!!
  124. a few problems
  125. Please Change this Sub-Forum BACK to 94-95 SPECIFIC
  126. Dam tailpipe
  127. fixable?????
  128. power pipe blows!
  129. what else with a S/C?
  130. bumper removal
  131. CAI help
  132. 94-95 Ecu/Computer ?
  133. 94 5.0 questions
  134. 1.7s too much??
  135. Car keeps dying!!
  136. Need Help, Charging problems
  137. what gauges should I get??
  138. who is AMP ?
  139. Alarm systeme, Astra-777 , any good ?
  140. BBK UD Pullies = Shorter Belt??
  141. Heads and intake are on!!!
  142. Car doesnt have the power it should.
  143. More parts on the Way!
  144. Brembo & Baer rotors
  145. 215 what
  146. HP Guestimation
  147. Leather Seat Covers
  148. how to remove rear abs sensors with out breaking them?
  149. Difference between American Thunder and Delta Force (Flowmaster)
  150. I really need help!
  151. pics- of my 94 black vert
  152. AODE to t5 swap help... Come on in!
  153. car crapped on the hwy
  154. can someone photoshop for me
  155. front chin spoiler/air dam
  156. 331 hp search results = 0
  157. Damage Pics
  158. How do you know when your belt tensioner is shot?
  159. S/C or Turbo....???
  160. Car is out of comission for awhile
  161. New Energy Suspension Kit
  162. Help needed
  163. Help! Rough idle, hanging idle
  164. Tools needed to install upper / lower intake
  165. A/F Ratio Gauge/pillar gauge pod install Questions...
  166. Chrome Dress up kit question?
  167. Custom "X" pipe is on!
  168. modification planning tips
  169. H/C/I tips
  170. 5th gear syncro going bad?
  171. Edelbrock Performer Install
  172. Convert roll bar
  173. AFR/FTI Combo Results?
  174. aluminum heads
  175. should I get these??
  176. 347 Install need lots of advice and parts :) Read on
  177. Pics of painting progress(DUW)
  178. Eibach drag launch kit ?s
  179. Idle and surge problems when engine warm
  180. knocking...pinging....clanking...some sort of funny noise... PLEASE HELP
  181. Found a straight 96 with a blown motor for $1000. Worth it to throw a 5.0 in it?
  182. pro 5.0 shifter doesent spring back
  183. Anyone use these shocks
  184. terrible day for me
  185. Installed PBR front calipers, here is a few things to know
  186. Does anyones 95 track straight?
  187. Fuel Pump issues and a question?
  188. Help air-bag light goes off now
  189. Need Advice For Alt. Support With Vortech Off.
  190. Anyone hit up Great Lakes on saturday?
  191. Question about buying a 94/95 GT
  192. what would this sound like???
  193. Bad Catalytic Converter
  194. FI Q? running rich
  195. Parts came today! yay! (pics) Got a question or two.
  196. Wrong Info ! ! !
  197. Odometer Rolled Back and Frozen
  198. Wont stay in 5th Gear
  199. New Wheels=What Tire??
  200. 17 vs 18 inch wheels
  201. Drivers side window problem
  202. quick easy question!
  203. Lower balljoint Q
  204. How to use an orbital buffer properly ??
  205. Getting my stuff put in
  206. question about 4 lug
  207. svo side exhuast questions?
  208. what's next??
  209. TURBO Q's?
  210. convertible problems
  211. Chick that needs help.....
  212. Who has the best prices on X pipes?
  213. lets see some donut pics
  214. Polishing Factory Fogs
  215. 245's fit on a 10.5 rim?
  216. Running Weird
  217. Installing battery relocate kit today HELP!!!
  218. Ohio Collector plates law/rule?
  219. Tri-ax adjustment
  220. Keep TALK out of Tech
  221. Best $6 and an hour spent!
  222. What would make my fan not run?
  223. Weird Freeze Plug/Cooling Q.
  224. pulling problem
  225. Opinion: Built 351w or supercharged(centrifugal) 302
  226. Issues with PCV/Crankcase Pressure after autoX!
  227. Will it happen?
  228. aode is giving me.....
  229. Just polished my engine plaque.
  230. Getting new short block need advise
  231. I dont understand "ford tech" language.
  232. Back again - rough running
  233. explorer intake/polishing...tmoss!
  234. 3550 crossmember mods?
  235. Tranny install done....new problems
  236. New Pics(bad) of Hood Pins, Wheel Spacers, New Emblems, New Hood and Zainoed 94 GT!
  237. Mod bug got me
  238. Parts Needed for Cobra Intake Install on GT???
  239. While The Vortech is Off.....(need some advice)
  240. New balancer = I now know my REAL initial timing
  241. Broke rear swaybar
  242. chassis stiffening
  243. Needle in a haystack
  244. H&R Sports Springs or Eibach Pro-Kit ?
  245. No Power past 4100 Rpm's...GRRRRRR
  246. Car is fixed!!!
  247. Squeaking after Start...
  248. Turbo??
  249. feels like slipping
  250. stang rant!
