View Full Version : 94-95 Tech
- Anyone live near Greensboro, NC that would wan't to maybe
- For mustang lovers only!
- ? on UD Pulleys
- What is the size of the stock alternator pulley?
- Favorite AND least Favorite mod you bought
- good part's to get in the 13s
- Sear's BLOWS!!!!!!
- Anyone using UPR Kmember and A-arms?
- (UPDATE) I just joined and just saying hi (Finally pics inside)
- How do I know what injector size my MAF is calibrated for?
- Cheap Place to buy Mufflers?
- makeing some money
- Will longtubes work with an auto?
- steering rack & autocross question
- Vib, I need your help right quick.
- FOR SALE
- N/A Supra wants some...
- Unbelievable beauty that needs to be picked up by someone who'll love her..
- x-pipe
- Any updates to the tweecer faq?
- Need good brake fluid
- 5.0_gt_kid
- need to vent!
- help on timing
- Got my cobra front bumper in yesterday
- AODE upgrades/opinions
- Speedometer, Dome light, and Radio Not Working NEED HELP!!!
- Kenny Brown subframe connectors
- part number for tfs upper intake gasket
- gauge cluster bulbs
- Any one here Wish they had a Mod Motor?
- Going CRAZY
- Car can't handle 87octane
- How many holes did you drill for your Transgo??? (pics inside)
- MAC cold air induction?
- Any Pipes pass smog
- Can someone take a quick look at their headlight adjusters for me?
- HELP!! Car runs horribly and cant get rid of these codes,
- cam break in not required?
- 300 rwhp safely
- Answer me this question, will ya'll???
- Who makes a good engine rebuild kit?
- Center caps
- CLUTCH HELP NEEDED...I THINK...
- Helmets?
- Finally, More Power!
- Has Any Body Bought body kits from Mr.Bodykit.com?
- Steeda 19 vs TFS Stage 1 Cam. More EEC Friendly?
- new best for willie
- Coil Over Kit
- Coilovers should I buy them? - please help asap
- Suspension idiot needs help!
- Backspacing help. Weld pro star xp's
- What to do with $2,500?
- Tweecer help. Car wont run right with the stock tune loaded.
- BBK Longtube/EGR Question
- Clear turn signal bulbs, cant find them anywhere!!
- Who's running trickflow TW heads on their 331/347's?
- clutch cable replaced!!
- Ford racing plug wires
- Is cold air kit worth it?
- which is better
- does anyone know???
- Need help identifying tb
- Just put my prochamber in!
- I just joined and just saying hi .... :)
- Guys with ZEX "wet" kit post here, need help
- JMS TARGA
- PITA Fuel Pressure Gauge
- explorer intake on 95 gt
- Fuel pump questions
- Anyone wish they had not gone with 3.73's?
- Oil pressure
- 65mm-70mm tb
- Finally joined the SN95 crew.
- pinging
- hydroplaning, not a good thing
- Cobra brake pad shim
- Complete cam swap A-Z?
- Pics from today.
- hmmmmm
- Which valve covers are you using????? POST YOUR PICS
- removing smog pump....
- Coupe vs. Vert Weights
- Viper Spec T56 and parts finally arrived (DUW)
- got car dynoed, numbers any good?
- wiring up a msd
- Think i may have fixed my lean problem
- clutch pedal height.
- knocking from valve covers
- Is it worth it??
- Engine stalls and shuts down warm
- anyone have trouble with MAC U/D pullies?
- The tweecer has arrived
- How to raise the idle
- Airbag code - 34 HELP
- wanted: used tri-ax shifter that will fit 95 cobra 5 spd.
- pulley swap bracket?
- Need a/c delete help
- Where can I find this?
- What kind of ATF is best for a stock manual transmission?
- Plugs and wires
- Rockers and cam questions
- Anyone used Lucas products?
- 94 Cobra for sale
- Why I shouldnt get a LS/Lt 1
- Oil in intake
- Got my car fixed! Pics inside
- Width of stock 17" wheel
- Off-road pipe question
- Car is dead could it be the maf?
- Power Steering Pump
- I want to beat LS1's, 302 block or 347?
- Rotors fit?
- coolant overflow under boost!!!!!!!
- stock cast iron gt40 not p combustion chamber size?
- Alternator/Smog Pump Bracket?
- Car won't start after intake valve replacement
- 302 to 302 engine swap, tranny help
- looking for a dyno
- will this bolt to a T5?
- Is this a stock color?
- HELP!!! $200 and I dont know what to buy!
- spec or centerforce
- Heads for a 4.6-whats the best?
- which is better
- Axle removal help!!
- self test input connector
- 24# Injectors.. stock heads/cam, what fuel pressure?
- need Drag ET and 60ft predictions with these mods
- How to test fuel pump if car wont start?
- Is this possible???
- Could you get a 94gt wingless?
- Blue Mustang registry is a reality
- How much is too much for used 99+ GT/V6 front calipers
- Exhaust clip vid
- Is this even possible?
- Help, car wont run right and it just started out of nowhere.
- Shifter Vibration******
- Stang Fever
- Car bucked and died on the freeway today
- Question on Upper and Lower intake
- Someone host this for me please.....Dyno Vid
- buying new car need help choosing
- getting car dyno tuned, what do I need to tell em
- How to get idler pulley out and can I swap it with the tensioner pulley?
- sputtering/loppy idle
- Can the Tweecer be used on more then one car? And where to get it?
- What transmission speedo gear do I need.
- Can Injectors whistle/whine????
- hey guys...
- side exhaust piping
- Are these cheaper anywhere else?
- What happens if you break you ECT sensor, can I still drive my car?
- K member question
- Need Help finding block
- 96-98 tails
- adjusting stock clutch?
- Eibach drop help...
- Chrome Alternator Fried
- Glass VS Plastic rear glass window convertible
- 351 Guys check in here!
- Radiator Fan Seized, super quick question
- Timing question
- Could my flowpath be messed up???
- My first kill
- trick flow heads
- yellow mustang with black cobra r's
- TOTALED 94 yellow stang!!!!!!!!
- 351 swap in my 95
- O2 Sensors, Which to get???
- Superchagrer?????
- hijacked dads user name
- long tube for AODE ?!?!
- anyone signed up for this?
- catback
- 3 inch Exhaust
- OT: my mustang club logo ( pics)
- Holley SysteMAX II
- Getting a chip
- B303 cam install help
- Stangnet Member of the Year
- Billet Grilles?
- How do you take out the center console?
- Tranmission and Gears
- Its getting cold, my car is surging like crazy!!
- center line daggers
- Wheel Studs for Welds..
- 4.10 for daily driving?
- Pre-Paid Power
- Cold White stuff on rear window!
- Cobra gets rearended what rear bumper should I get?
- Will a heavier oil help blow by or help quiet a supercharger?
- Turn Signals Not Working
- Storage for Winter
- Factory Fan Wiring Harness Question...
- My car got hit...
- Finally Ordered Gears
- Who have Nitrous in their Stang
- Dexron III in my Manual transmission?
- 1988 306 INTO 1995 GT what will fit?
- Exhaust System Woes
- New 1/4 Mile Times, Improvement
- Lesson I learned yesterday that might help you or someone you know....
- Anybody try put 87 octane after runing on 93 with H/C/I
- where to buy chrome grill inserts for a 96-98 cobra hood
- Heel/Toe Downshifting******
- safe stockblock rwhp
- Will it live again?
- How to get 10#'s of boost?
- OT--Subaru as wifes vehicle?
- ford b springs, anyone using them?
- those with H.I.D.'s
- emergancy brake light
- A/C blows only through defrost vents
- Pics as promised!
- FAST money. SMALL investment...Make your car FAST the EASY way!
- Adjusting TPS
- I Gotta Technical Question
- Whats this anti-belt slippage stuff at NAPA?
- Verified Intake and Hood Clearance Combo's
- Need to know about wires for 02 sensors
- Good Deal?
- Drag radial questions....
- Sub Frame connectors and LCA recommendations....
- Timing issues
- mid-pipe with forced induction?
- crazy suspension kit
- selecting a cam for my combo!
- TB butterfly position at WOT?
- MAC CAI work w/ Pro-M MAF?
- 500$ to spend what to get
- Anybody running FR500's wheels??? Post your pics please
- Project 418W: Brief update
- 1991 Thunderbird-same engine???
- which o/r h-pipe should i get??
- Tweecer vs. Tweecer R/T
- Using a 95GT to tow another mustang?
- Fox 5.0 belt on 94 5.0??
- used fuel injectors???
- Does New England Drag Way hate people from MA?
- 3" Exhaust tips
- Is this a steel throwout bearing?
- Location of spout, TFI module, and diagnosis of my problem
- Brake System Question
- Andy, painting question
- u/d pullies affect chargingsignificantly??
- Its been awhile !!!
- Last track day for the season and new best
- Where can you buy paint?
