View Full Version : 94-95 Tech
- AODE guys - need some help and opinions
- 18" drag radials....are any of them worth any in 60 ft times?
- wheel studs thread size
- supercharger question 94 gt
- Got snow pics?
- Not as big as 5.0 Mustangs Mag.... but got a small feature.
- Intake Gasket Question
- Is there a way to get your a/f close?
- Has anyone ever rebuilt a power steering pump?
- Is my car lowered? (pics inside)
- Vortech Price Drop
- gas mileage
- Opinions on Wheel Replica 17" bullits
- Tire size for verts
- Just got a 95 GT. Have some questions.
- gt hood and cobra bumper prices
- Off Topic Are you a Racer or Ricer? Find out Here
- help..installed gears and clutch and have a vibration now and a whine!
- thinking out loud, n2o
- Does anyone make a special wrench for the distributor hold down?
- u/d pulleys from fox 5.0 fit 94 5.0?
- Anyone use a quarter master clutch?
- Cheap Nitrous kit...To good to be true?
- Part Number Difference between GT and Cobra Engine Blocks?
- knock in differential
- Who's got a C4???
- Ping: Killer Canary
- will these fit?
- Dyno Difference
- Mach 1 front spoiler
- Create A PCV Valve Bypass System
- A REAL exhaust poll
- I've never asked this before so just once would be ok, right??
- 95 Cobra Clutch recomedations please!
- Distributor Took a *****
- Weight Check
- Weight Check
- My seat broke today
- Added a new stang to the stable
- Odometer froze
- what kind of power?
- GTR Car Show
- Exhaust poll
- home made air dam today
- Really tru-trac?
- Going crazy on polishing under the hood again
- proper camshafts selection
- Cobra intake manifold
- t-lock installation??? How to???
- Atco
- can you go to big with a fuel pump?
- Any tips for a idle/surge on SN95 with cam & AODE
- Installing the Edelbrock Intake Tomorrow...
- eibach sportlines w/ stock suspension/wheels
- lighting help
- Vacuum hose question.
- Verifying a VIN number?
- Anyone in San Diego Area know a good tuner?
- BBK Throttle Body/Idle Problem
- exhaust
- Painting the 95
- how to replace stock shift knob?
- sn95 Fan control
- werid issue....any insights???
- heads/cam/intake or supercharger?
- Which 5 speed computer do I need?
- Sturt Tower Braces
- What gears does my 94 GT have?
- Here's some pics from the race this weekend... DUW
- 95' Mustang Cobra
- Anyone interested in swapping in an explorer motor: here is what youll need.
- Preliminary times for project "SLY return"
- Convertable top replacement
- Does anyone know what RTV stands for?
- Winter mods
- New Spec Stage 3 "Hybrid"
- Aftermarket ECU users, questions..
- Blew HG at the track ---> New Combo
- VSS Wire Location
- What's a Stock MAM Worth?
- what gaskets?
- tweecer/tuner guys...need some quick help
- Whats my 94 Gt Worth?
- Underdrives
- AZ 95 5.0 FOR SALE
- Knock Sensor Location?
- PhotoShop of My Hood, Please?
- killer canary
- 94 GT wiring diagrams and schematics
- Ditching some heads
- Shades of blue for my 94 cobra...?
- Anyone need a carefax let me know!!
- Help Please
- Clutch question for all
- Tell my the best nitrous kit for my 95 Gt
- What do you guys think? (buying GT)
- H-Pipe Help: Check engine light
- BRAKES!!
- OT- Should I buy a bike??
- Need Help with fox TB swap
- Throttle Body
- I think I reach my e.t. goal, i'm done
- Symptoms of a Bent Valve??
- Going to the track tomorrow
- Fuel Pump??
- Exhaust Prices!
- c&l mass air
- OT: Cobra addition to family
- Do we have "world class t-5's?"
- What is the best radiator for the buck ??
- Voltage suspect in idle problems i have
- Which catback system?
- densecharger opinions???
- Havn't been on in forever, just saying whats up?
- Anyone swap from auto to stick and still running aut computer?
- Aftermarket seats?
- A Little MAF and TB Help Here.
- 5.8 and cobra r 2000 hood
- Clutchless T-5
- 95 vert rear defrost
- need some rear end advice
- Why must you die?
- C & L to a 65mm TB???
- TB on my Cobra
- widest stock rims
- Doing H/C/I how can I make sure my block is good?
- I'm wheel retarded
- Friendly grudge matches on here?
- If Anyone Cares: New Best times.
- best shorty headers??
- MAF Gasket?
- Good day in Mustang land!!
- car will not start hlpe plz
- Need new brake pads which ones?
- Anyone have the FCC ID on the back of their remote?
- my sounddomain page
- best lowering springs
- 3.55 vs. 3.73 Gears
- Which intake on my 331??
- Will my computer like my cam?
- Why do X-Pipes come in 3 pieces?
- Sprayin the 5.0 now.... soon to be LS1EATR!!!
- Need help with Wheels and tires....
- Will a Fox supercharger fit a SN-95?
- MELTED headlight switch harness
- Question for a friend; 94 GT
- how to tell bad cats?
- swap 95 5.0 v8 into a 96 coupe with a 3.8 v6?
- Can't find the keyless entry module
- Need a favor ? about Flows
- Hey whats up guys....i got a prochamber question....
- GT40 Iron/AFR 185 Interchange on 331?
- New lifters or reuse old ones with new parts.
- Buying motor Double Check for me Please
- Dilemma, wut to do with a tired motor
- Drive shaft Spacer or Custome Driveshaft
- Stock TB on cobra
- Is a 2200 stall useless???
- Power seat track...
- Boss 302's...
- 95 MARK VIII leather seats installed in my Stang ,tons pics
- Looking for a new block that can handle +550 easily. Does this make sense?
- New Pic
- bad idle problem :(
- T5 Tranny Problems
- Need Help Quick
- It was hard, but i let the stang go yesterday
- How bad would it be running if....
- shaking on take off
- smoke screen
- summit H-pipe?
- 93 valve covers on a 95?
- BAD Idle lope/hanging idle fixed!
- timing question 94 white cobra
- new canton over flow tank pics
- Hey fellas, some Turbo questions.
- Quick! rust on h-pipe?
- harmonic balancer
- gas mileage
- Which Headlights?
- Track video...
- how do I route the belt when bypassing smog pump
- pics of my 94
- bumper inserts
- Strange Rear End Noise
- E-Brake Lever / Handle Alignment
- FITMENT
- Auto guys with stalls, in here!
- Here's a video of my most recent runs...
- Bassani vs. BBK
- 351 intake ???
- 306 n/a 418 hp on 93 octane
- Car STILL running too hot!
- drive belt help
- Odd noise, Need help!!
- Motorvation Computer Chip
- need to choose cold air intake
- runnin so sweet I put the insurance back on
- 315 tire on 18X9 Wheel?
- 351w Guys, I Need Help!
- lol i feel stupid.
- Easiest way to swap AODE for a T-5
- Anyone refinish their gauge pointers/needles?
- taking out stock h pipe....
- Head swap on a 94-95 Cobra - Who's done it?
- How much power can this block handle ?
- Is this the leak down tester I want?
- Anyone with 99+ Replica Saleen kit???
- 98 cobra gauges in a 94
- TKO 600 on the way... follow the leader
- anyone running procharger?
- Will 87-93 pro-m fit our 94-95
- Clutch or transmission? need help
- water pump install
- Tar and Wax Problems!
- Starting Fox Swap Need One more Part
- Damn Ins on our cars is expensive
- Bear brakes are on
- Throttle response
- What do yall think about this?
- Thinking about running turndowns...how loud?
- fox flowtubes
- Computer Recalibration?
- Condensation? BLownHeadgasket?
- info about changing shifter?
- oil pan gasket leaking
- Fox Tranny mount on a 95'
- MM caster/camber plates
- please help asap...Why use 79-93 Shocks/struts in my 94? Can I use 94+?
- s-281-E vs. T66 Supra
- just put engine back together
- Exhaust Leak
- A9L Conversion
- Raced an 05 gt.
- Fitment of Fox VC's
- 94-95 Brake Master Cylinder
- Help me with my trans!!
- Flywheel on a 1994 cobra?
- Should I be ashamed????
- 3000 Stall or T-5 Swap???
- i know im really swaying here....but heads maybe
- pilot bearng
- Question about TB setup
- How hard is it to learn with the Tweecer R/T
- Header bolts
- Dyno Chart question
- Raised my own "bar" with new track and dyno numbers
- Fuel Pump Relay
- Any information on Tokico D-spec shocks/struts?
