View Full Version : 94-95 Tech
- Interior progress...Pics
- got some pics of the 94 for u guys!
- 150K Plus, Do I Need a New PCV?
- After Driving for Awhile, In "D", tranny Slips into Neutral Under Load..
- E-303 vs Steeda
- What size front sway bar bushings do I need?
- Suspension setup
- How to get passenger kick panel off to get at cpu
- Posting for a friend ... Coolant leak
- What are the Symptoms of Bad Lifters?
- How can you find vac leaks?
- Neutral Safety Switch? Manual Lever...What?
- I put in my h-pipe
- Congrats to Willy, a new bar has been set...
- Air Bag Warning light....
- stator (hall effect sensor) or tfi module?
- bumping my timing
- time to port and polish the cobra upper intake
- Manual steering vs Power steering
- To those who responded to my Beginner's Mod post..
- Pissin antifreeze.....
- how to install my Kenwood w/MACH 460
- OT-History Channel show Full Throttle at 9PM EST.
- 95 Cobra Weld Draglite Front RIm size?
- Whats the ratio of our first gear in our stock trans (t5)?
- Nitrous~~Fuel pressure safety switch question
- a few polishing questions:
- Tell me about gasket matching please!
- Low Oil Light Help
- 351w??
- OT: Escort GT
- sound like a stator problem?
- Recommendations.....
- bad vibration?
- 3" exhaust???
- Here's the "footwork" video you all wanted...
- Parking the Stang for a year. What do I do?
- Looking for polished intake...
- Could I do such a thing???
- Exhaust Hanger kit for our car?
- can you dim/shut off autometer gauges?
- FPR
- oil pan, pickup, pump...
- Gas....
- Dino vs Synthetic Oil
- Installed MSD---HUGE improvement
- Rate my "Beginner's Mod" list!
- What can a Custom Chip do for me?
- Need help with a vibration problem.
- OT: My Opinion of AFR
- Car darts hard Left on Burnout
- while i'm waiting.....
- headgaskets
- OT: check this out..
- 94 EFI to carb
- Wheel Spin Question
- Just got back from the Dyno
- Just found out I had a MAC exhaust instead of flowmasters
- Place to mount fuel pump?
- Happy Birthday to me!!!!!
- Hiding Wiring Harness
- Pics of Your Work Place...
- AODE SHIFT POINT ??'S NEW TO AODE'S
- Will a Typhoon upper intake fit the Performer lower?
- can you clean your o2 sensors?
- Intake?
- Tweecer question about Ede Performer
- 347 into 94 gt
- Gear Ratio
- whats up with my sportlines?!
- 16x7 inch pony rims for track duty?
- projector headlamps,cool or not?
- SUSPENSION HELP NEEDED
- Getting Full Length SFC's This Week!
- Transmission Question....
- Door Panel is done.
- OT: What do you all think of Probe GT's?
- throttle body theory??
- longtubes in nj???????...........
- Trouble revving the car when cold.
- Help installing front lowering springs
- Trickflow engine kit? should i buy it?
- Looking into getting a new exhaust
- mix/match of upper & lower intake
- ANNOYING SQUEAK FROM ABOVE LEFT KNEE DASH AREA
- Dyno results - I want some opinions!
- steering wheel squeeks.
- Funny Noises
- OT - Took an '05 GT for a ride Saturday
- What heads can I use/port 94-95 GT
- Movin' On Up
- EFI to carb wiring in sn-95?
- stock fuel pressure?
- Cooling issues!!
- what would your next mod be?
- indoor "dome" light is acting fishy
- Happy 229th Birthday Marines!
- Is a MSD Next for me?
- Dyno tune this Tuesday
- Help - Best Winter Tires
- BBK LT ?'s
- first mod of winter?
- TPS Voltage Question
- It lives!
- Hood Question
- Finally got to run my car..
- Anyone else with GOLD Member Problems?
- Made an in car video for those that wanted to see it...
- Timing Problem
- tire and trans leaking problem
- pinging on medium grade octane?
- Power Question? TFS TW's, TS Street heat, TFS Stage 1
- Still With Oil Leak...What to Check Next?
- Trickflow Head Users, I need your HELP!!
- Vote for my next Cat-back exhaust
- HELP ASAP CAR OVERHEATING(IVE SEARCHED)
- torque specs for lower intake?
- Should I gut my stock MAF?
- Who is in the MA Area, and where did you get your tune?
- Im still Running my stock maf. How much am i losing?
- 347 Cast or Forged ??
- svo supercharger on 94 cobra
- Holley systemax kit???
- offroad x-pipe sound clips
- 75mm pro-m maf worth it?
- My new Mustang V6
- Polished Ceramic VS. Stainless Steel
- Problem: OIL Dipstick pops out... rpm's rise when cluch is in
- Noisy stock valvetrain?
- Fox V.Cover-What Breather
- Transgo AODE: What is yours set to???
- Please Help...Motor cutting out @ WOT/misfire
- blown head gasket
- help with homemade cold air intake
- Desperate for 12's, Eaton, axles, LCA's all on
- OT I AM #1
- Painting my car, can anyone throw some pics at me?
- Where can I get a hood like Oink's
- hey greenlantern,ported intake?
- 94 95 front spindle part #
- cold start
- Nitrous questions.
- intake
- New BBK intake
- TKO600 Install Tips-Pics Inside
- Flowmaster Owners Check In!!!
- have question on 94 5.0
- How easy is it to swap fuel pump ?
- Been a good run!
- Battery cables
- Gears How to tell if you have them already
- My Baby Need's 300RWHP this winter.
- help with pro50 shifter
- putting ported heads back on tommorow,advice?
- Calling all people with an o/r h or x pipe
- is it worth it
- Anyone heard of Autronic ECU's
- O/R X question
- VORTECH MSD BTM....Question
- Problem with aode to t-5 swap, need help?
- quick and last gauge question help please
- Help with Tweecer and MAF
- Bell housing blues... please help
- OT: Red 05 GT on THE OC
- Owners from SE WI
- Another Windshield Decal Question
- 03 Cobra hood?
- DON'T CLICK THIS
- How many of you Degree the cam in when you do a swap?
- who's running a 31x19 radiator in their 94/95's
- Where to get a new back window?
- Ran car at track
- Question On ECU Re-map Chip
- Posted in Tech going to try here as well.
- Fixed my Turbo problems now ready to hit track!
- Is cheap chroming possible??
- Idle
- Who have home made Drilled brake rotors
- Funny Clip. Bet you Tri-State area drivers wish you could park like this!
- for those that have deleted EGR!! LOOK!
- New times from tonight, broke 12's! Slips inside
- Help with Tune Up!!
- OT: Black96VertGT is now BlackVert
- Passenger side mirror
- How much inital?
- BBK shorty h to X-pipe
- ford racing 1.6 roller rockers
- First Drive after headswap etc.....
- OT- Going to Afghanistan Monday
- 94/95 PCM & Tweecer Basic Info Great Stuff if you want to learn!
- Lets see pics of installed Valve Covers! - also a question.
- 94-95 Cobra tranny
- After Alignment my car steers to the left!!!
- Let update the 1/4 mile list.
- Project high rev blown 327 has began...
- Help me prep and paint my engine bay
- Should I get a Kirbian ADJ. Fuel Regulator?
- OT- You MUST see this
- More progress pics
- will this work for a rebuild
- cobra up on blocks in barn,latest update
- Saw 05 on road
- Does this really work?
- New Engine Pic....Easy Polishing Mod
- I almost cried!!!!!
- Best Spindles,
- a/c removal
- Autolite 25 nor Bosch Platinum could take the heat!!!
- HEATING SPRINGS
- How do Pro Car Parts Headlights Fit?
- Amplifier Rack
- Installing suspension, anything we should know?
- Calling ALL Mustang GT Convertible Owners!
- 94-95 SN95 Rear end width?
- airbag delete
- Launching.....Killercanary clear your pm box...
- Dyno Numbers Finally
- Which Headlights?
- A few questions about rocker arms
- radiator coolant...dont know, help plz
- clay bar
- OT - Election Day..
- GT-40 intake manifold
- What gauges to get?
- Surge with idle???
- header questions
- HELP please
- EGR DELETION
- While my car is apart, should i switch to Explorer injectors?
- how to get the light swithch out
- Help me decide what tires to get!!
- OT- Mustang Mach 3
- Vortech Super Charger in a 94 Convertible?
- Head light problem
- Is a Power+Plus Typhoon intake the same as a performer?
- Horn Relay
- need some info on my injectors
- For you guys with flowmaster catback
- Can You Believe this!! Broken RR'! PICS:
- Shift problems in 94 GT (HELP?)
- Are the fox body and sn95 electrical engine harness the same?
- Starter problem round II
- Need Headers/Midpipe Need Suggestions
- Everyone WATCH OUT!!
- X and H pipe question
- Which MAF and injectors?
- Will this pass emissions?
- Gearing
- Trying this (Sound System)
