View Full Version : 94-95 Tech
- wheel pics please!!!!
- 351 under stock 94 hood
- OT: Baddest C5 i've ever seen.
- short belt
- 1994 GT Value
- Just got my cutouts installed!!
- vibration
- anyone have 245/45's on 9 inch rims?
- Battery Relocation............wiring help
- isolators on springs
- tensioner bolt?
- slowpost day, whats everyones production #
- PLEASE HELP!!! :)
- OFF TOPIC: DODGE TRUCKS
- Swap questions?
- Cam question
- CHI-Town
- Techy Question
- your thoughts please
- Rear Control Arms and Lowering springs
- Please help me!! I need a carfax done bad! [read inside]
- New Times; Best and Worst ever!
- Gear install
- 5.0 94-95 Good First Car?
- almost fishtailed on freeway exit.. fun
- Tweecer guys, and other tuning gurus. Important question.
- just got heads back from shop
- who put the virus on stangnet?
- SPANKED!
- HELP ASAP CAR WONT START
- fox shocks and struts??
- long time no see! need help, pronto
- t-5 input shaft???
- A Good Race! :)
- Battery Trunk location
- How do I turn on fogs
- MM caster/camber plates
- creaky rear end
- Burning Oil
- Broken Drivers side Mirror.
- Electrical Gremlins.....help
- New AFR/FTI Times - End of Season
- OT: Just saw Farenheit 9/11!!! WOW!!!
- Which one would look better??
- Worm Gear and Odometer gear
- replacing idler pulley ... simple?
- Bad Weekend (kind of long)
- Pro-m optimizer
- rims/gas/passengers are hp killers
- feels like it bogs down at WOT
- Computer Help
- feel retarded asking this
- winter belt?
- Stang has to sell!!!!!!!!!! But no luck
- oinkaodeoink
- which cam
- Overspeed
- Burnout pics! / couple random pics
- Blend door stuck
- feels like tranny vibration
- Picked up a sonic blue 04
- Exhaust questions
- Front sway bar mounts w/ 7qt oil pan
- Rear Speaker Replacement in Vert (Mach 460)
- My 99 Cobra
- Really bad OBD I problem! Please help!
- need help with transmission problem
- Quick Light Question
- Rear differential and axles setup, comments please!
- Some misc. questions...
- suggestions on a new chunk
- quick question on door light switch
- Tranny?
- RPMs climb
- which short throw shifter
- those of you with styling/light bars on ur verts
- Anyone have stock 94-95 front and rear brake assemblies they're looking to sell?
- bushing squeal? when turning wheels
- A little help with cooling/heating system, please
- show me pics
- help finding a noise!
- Took some pics of the stang **56k Warning**
- New Track times. Good ending point for the year.
- Quick intake question
- any other intake to buy??
- Cheapest Place 2 Get BBK Throttle Body?
- Why is my car so slow???
- Turbo with ported heads
- Dome Light Problem!
- Friend's Cobra's goin to the track
- difference between stock cobra heads and gt 40
- how much power?
- New best time :)
- i need a picture of..
- GT40 heads?
- 400WHP with Procharger?
- is it missing or something else?
- yet another "combo" question...
- Help Model # for 95 Cobra ECU
- Snapped Rear Sway bar?
- Timing Mark ???
- BBK upper and lower control arms?
- ported lower intake on 94 cobra
- Tuning Question - Do I need one after basic mods?
- Do I need 24# Injectors with these mods? - opinions please!!
- A Mere Observation
- Shocks/Struts...help me decide!
- 95 auto power down window (driver) does not work
- Saw the new 05 Stang
- MGW new Short Throw Shifter?
- 65 mm throttle body
- losing power with load, tuning question.
- OT: Ford Pulls plug on next gen Lightning
- Need help ASAP posting pics of my car
- Goin to the track tomorrow.
- tunning? keep injectors?
- Trans cooler fitting on radiator is dripping- use teflon tape?
- alright...debating on what to buy next
- off topic: CARDS WON!!!!!!!!!!!!!!!!
- AODE - Shift Kit or Valve Body?
- low oil light
- sears????
- what exhaust set up?
- Steeda wheels
- doin it,engine torn down to block
- Posting a pic
- Oil Change Question - What Oil and Filter do YOU use?
- 4 Cats?
- Pro-M 75mm good choice?
- SpeedCal users please enter...
- What do you think about these subframes? (pic/link)
- TweecerRT...worth the money for me?
- Some info on you guys, probably been asked before
- High Pressure Isolator Question
- This is what I get for trying to be nice, I just had to post this!!!
- Overheating: How do I check a radiator fan and sending unit?
- Headlight problem 95 GTs
- 1993 Cobra Intake or 94-95 Cobra Intake
- Where and what is the spout???????????????
- pro3i anygood?
- .054 or .060
- ABS light come on, getting code for bad rear right ABS sensor , NEED help
- Lets see Issue's on your Stang
- rear gear oil
- HELP!!!
- help with tires Kumho ECSTA 711
- wtf is a gts
- No A/C...why?
- cooling issue 94 s/c cobra
- goofy idle problem, bad ecu possibly?
- New shifter and headlights.
- AODE
- Bye Injection and AODE
- Rut RO!!!
- C/C Plates
- Help me solve my coolant/heater issue...
- Maf & injector questionl
- OT: OMG I am so pissed!!! I can't believe some people!!!
- 95GT vs Older model M3 (the 240hp one)
- What should be my next mod?
- Bad Day For Mustangs
- Big tires and wide rims
- Stupid Question: 96-98 Tailights in 94-95 GT?
- Whining from my tranny or rear end, which one is it and what can be?
- WeEkEnD RaCeRs ¿ ! ¿ ! ¿
- what will advancing/retarding timing do for me..
- Would my car run with 3* timing???
- ATTN CIVICEATER
- 3.73 or 4.10 Gears Which Are Better
- Help on transmission problem...
- 3G Performance
- Pullys ¿ ¿ ¿
- Good Write up for Cam Install
- hi, new here
- Hey Guys
- BLOWN HG...What to do to prevent it again?
- i put a 90-92 trans in my 94 big problems help!!!
- OT but anyway to turn off the ALfred E newman??
- Will a 93 Cobra intake fit inside a 94 GT Convertible?
- Buying another mustang
- Easy Horse Power
- t-5 to AODE...what do i need?
- timing
- cracked tank... fluidine it is, but where? $$$?
- How to Remove A/C Center Bezel? ASAP
- OT: HairyCanary == Rootus
- New Member
- Non Export Taillight ?
- Computer swap?
- radiator hose kit?
- New to my 5.0, need some help
- Cam Gears
- lost thread? cup holder mod
- True Oil Pressure Gauge
- Painting tailight bezels??
- Painting taillight bezels
- does 1 3/4 hood clear 351W??
- Why does my car only run good with a very rich fuel mixture?
- ILLINOIS WHO?
- Slicks on Stock Axles?
- How dangerous to run drag radials on stock 28 spline axles?
- Computer went up in smoke.. Literally
- Guy's w/315/35/17's c'mon in
- K&N filter or CAI which is better
- speakers pop
- cervinis stalker question
- Street Edge Group Buy and my video - Expires Nov. 15th!!
- Got my 03 Cobra wheels on, and an incredible experience today...long post!
- Moving Front seats fruther back?(legroom)
- autox springs
- can i make my performer intake flow up to 6000rpm??
- 3550 vibration?
- 04 SVT Cobra vs. 04 Sti
- taking apart my 94 cobra 5.0
- Post your beater
- Look out Snoozer, you have some stiff competition...
- What leakdown tester do I want?
- Painted interior parts
- Which rims/tires do you like better?
- Selling my car
- 5.0 Fuel Efficeincy
- What do you think of mix-matched body parts??(Poll)
- Pics of a lowered SN95 on waffles?
- Sqeeling when moving
- I wish they made the 05 mustang look like this.
- NEW HEADS AND CAM!!
- What red looks best w/ black top??
- RACED A 2004 BMW M3 SMG!
- Pics of my New Truck
- Need help with swapping 99+ GT/V6 front brakes on my Stang
- Offset/offset, offset/center? Which
- exhaust question about x-pipes...
- WTF!? I cant believe this!
- alright... car is ticking me off...
- AODE's: Torque converters? Shift Kits?
- cobra r front bumper/hood
- Hesitation, help
- new member, here's some pics of my stang
- Rear Defrost Delete question...
- Lakewood Traction Action Lift Bars
- Please anylise 1/8 mile timeslip, estimates on 1/4?
- Titanium pistons and push rods?
- Do I have a T5 world class or not
- New england Dragway results 10/17
- 12 second pass finally, improved my times by .57 seconds
- New AFM Meth/Water Injection Kit...Opinions?
- What clutch do you all recomend
- Life is good!
- springs
