View Full Version : 94-95 Tech
- Made my first video, check it out...
- longtubes/emissions
- OT: IS THE NEW VIPER SLOW???
- HP vs TORQUE? What's better??
- TwEECer guys post here, I need help with Timing (Spark)
- Eaton Posi in, Gear lube question
- Went to the track with the Cobra again..
- OT: Air Compressor? Thinking about buying one....
- went to the track new best et
- My pinging is so bad a mini van passed me.
- What DRs to get?
- Got my Edge converter in.
- what gt40 heads are these???HELP
- pics of new seats...
- almost 12's..
- Oct 3--Bitter Sweet Day...Part of Me is Gone!
- tweecer forums?
- Getting there.
- Do Powerpipes really work?
- 97 cobra question
- Clutch/Tranny Issues, can i get an idea on what i need?
- Looking for my pip sensor...what the $@#% am I doing?
- 1996 cobra engine into a GT
- Almost ready to swap....few last questions
- car weight stuff
- Which hood for my car?
- Iron gt-40 heads, tfs-1 cam what valve springs?
- New Wheels
- New Fog Lights---Is Preventative Maintenance Needed?
- stall/surge/sometimes high idle PROBLEMS
- Confused on exhaust back pressure.
- only starts on 2nd try
- quick ?
- PBS Motor World about new Mustang
- powerdyne bd-11
- Looking for High Flow CAT's & headers for 95GT
- question about cutout placement
- Big trouble...
- Went back to the dyno.
- HP loss in T5 trans. w/3.55 gears?
- loosing weight
- nasty tranny problem :(
- Stator? Is that why I have no spark?
- rear main
- Smog Pump is Noisy! Should I be concerned???
- Header Question
- Need some ideas
- what to expect with new setup
- SVT??
- What A Night....
- Triax Help?
- running warm i think????
- Power steering problem? and maybe something wrong with the exhaust.
- seafoam engine cleaner, what vaccume line?
- AODE to 5-speed swap...
- Guys with Kenne Bell supercharger post your pics of engine bay
- throttle position sensor stuck
- What coil ....
- Will someone photoshop my car black?
- I need the stator install Process
- Leather Shift Boot - Attachment
- Qs about putting in a Cam??!!!??
- Hot start and surge problems...etc.
- Latest Pics of my Car
- The brightest stinkin fog light bulb!
- Advice needed on converter and stall.
- 95 owners, where is your MSD mounted?
- CAI, now check engine light
- f'ed my timing.....
- Where can I get the right replacement cats?
- keep up with an EVO?
- T56 question
- Time for Paint and Body work..Ideas/Input!
- 05 Mustang burnout, 05 Mustang burnout
- 94SC50
- convertible top ripping...
- dynomax bullet mufflers
- 95 Gt Spark Rattle
- Where can you get a rear view mirror for $34.95?
- Rare Car
- manual valve body
- DIY Caliper Painting (W/PICS)
- What do I need to put a 2000+ V6 T5 into car?
- widest wheel
- SQ Vortec-->114k miles??
- Will a t-56 give me a higher highway gear?
- Fuel Pump
- RIP seat bracket
- power seat? and tps?
- Dynomax questions
- My 95 loves oil :(
- Converter going in on saturday. Any install tips?
- SSM lift bar & diff. susp.??
- Decided to sell the stang
- I need some legal help with my tranny
- SUSPENSION EXPERTS, NEED HELP!!!
- Help With Convertible Top
- Distributor question
- If you are involved in the street racing culture...
- Nitto DRs 275/40/17 vs ET Street's 26 x 10.5 x 16
- Car died while driving - I have no spark...
- bast MAF for mustang gt convert w/AODE
- Magnaflow Cat-back Pictures
- R.I.P T-5
- finally made it to the track!
- Finally got the car on car domain..check it out
- Radiator fan died
- high rpm cutout in 1st gear
- Put the car on the dyno.
- Best Maf for 94 Gt Aode
- ProCarParts Reverse-Glow Gauges
- Why does my car run so damn cold?
- Look What I got
- need a new water pump? which one?
- 89 gt40 heads/intake fit 95???HELP!!!!!need advice
- how loud will it be with this exhuast?
- Causing potential harm?
- cam and surging and loping
- Can't find this part.. where the Mach 460 tweeters are
- Recommended fuel pressure gauge?
- How can I keep the "NEW" look???
- installed the AFPR, what fuel pressure?
- problems w/ digital clock
- Hooking up a/f ratio gauge???
- Passed CA smog!!!!
- Cobra inatake?
- Some Pics Of My Stang...
- valve cover clearance?
- I don't remember being this PO!
- Putting Supercharger soon... dilemma
- well...changing head setup
- HELP!! oil spitting out my dipstick hole.
- Please help me with this leak..
- Loops at HOT start HUGE problem
- BURNOUT
- How much could I get out of a T4MO?
- Check engine light NEED HELP
- Wiring Diagram for 94 Cobra..
- one inch wheel spacers..pros and cons
- 05 stang show
- triple black
- Can't believe Joe is selling the Stang
- Passenger Air Back Cover
- Manual Brake Master Cylinder
- Anyone here running iridium plugs?
- anyone got access to CARFAX?
- suspension set up pictures, please???
- Which one should i get?
- Making myself a new CAI
- where can i get a tq converter
- Cobra Strut Tower Brace
- How do you adjust a timing chain to get +-4*?
- Got cam used, No cam card, am i ok?
- Poor MPG
- appearence changes 94-95 vs 96-98
- spark plug gap on a 10:1 compression engine
- Off road h-pipe collectors are bent, where to go ?
- 94-95 bbk vert springs...fit cobra coupe?
- Ordered a new front bumper & need pics
- What are the benifits of using forged pistions?
- What is this?
- suspension systems
- Hehehehe look what i did!
- 911 turbo
- question about panhard bar and rear swaybar
- loud fan
- Attn: Rio, how bout some pics?
- 94/95 Gt price
- Wind Shield Decal Question
- DriveShaft Rubing??
- New Project
- Need help, can't remember stock gear ratio
- swapping gears
- First dyno numbers for GT40 setup
- 94 GT v.s. RX-7
- intake/head combos
- spark plugs
- is your oil pressure guage working?
- Clutch Issues (Exciting!)
- Anybody know what size or rachet I need to lose pinion nut
- Need pic of throttle cabel bracket...
- PICS! Installed wheel spacers - Need Opinions...Stick out too much?!?!?
- TPS set, car idles right now, as for the PMS now!
- holy hotness batman!
- OT- some funny vids
- Trick Flow H/C/I Installation update on 95GT
- Wheel Spacers on...NEED OPINIONS...TOO MUCH?
- what to do about 95 cobra ECU
- Will I lose power going from prochamber to x-pipe
- Needed new clutch again ,BTW Cobra clutch kit su#&$
- 94 GT Convertible
- AWESOME Deal On Ebay....Need to See!!
- found my steering prob,,any ideas how to fix?
- Q's about vortech YS-trim
- Some Questions About Wiring Gauges....
- Vortech V-2SQ
- whats the best shift points for auto
- Clutch / Front End Suspension Questions...
- Need help. Supercharger vs heads cam & intake
- WINNERS: King Of The 60' Contest
- Need timing cover gasket help
- AOD-E question
- squeeking in the front end
- 1995 Mustang GT... Manual v. Auto
- Why the Fox Conversions?
- Cleaned Headlights
- Anyone using 1.7 rr on intake and 1.6 on exhaust with gt-40 heads?
- How do you know if my 1.7 rr will work with my extra set of vc's?
- need a cam but i live in cali
- 6000rpms launch HERE WE GO AGAIN
- Shift points with TFS TW heads and bigger car
- What is this and where does it go??
- top starter bolt
- Thermostat leak.
- bored, waiting for this hurricane to hit, did a photoshop
- Who sells steel stock 94-95 cobra vc's with cobra stamped on them?
- Transmission mount???
- Thinking about going EFI
- My Speedo Needle Wont Move...Why???
- Do I Have Gears?
- Video of recent 1/4 mile pass
- Cleaning Headlights
- Need help quick... felpro rear main teflon seal question
- Problems with the GT.
- OK, I'm pissed now, I'm not making the right power and oil is still in my intake
- OT: 05 Eleanor Kit
- Some questions after BBK LT install
- how much is she worth?
- will 5.4 lightning intake fit 5.0?
- Ran a 9.85 0-60 and 17.54 1/4!!!
- X2C Motorsports Fox Conversion Pics !!!
- What is the proper way to bleed the brakes and brake them in?
- Post pics of S-351 wings, just got mine
- My GT vs 96-97 V6
- Stupid Camaro driver
- Installing a summit radiator.
- New times, Complete street trim.
- Just me.... or is this stupid?
- Quick: How important is it to have the flywheel resurfaced...
- What sound's a bad balancer make
- In need of TQ specs of flywheel and pressure plate
- Atco Track Times as of 9/25/04
- Need opinions on buying a cobra
- new 1/4 mile time
- Harmonic Balancer torque spec?
- Question about timing?
- Quick Question
- Airbag Code 61
- STEEDA AND TFS 1 CAM CLIP WHO HAVE ONE ?????
- Before I get ripped off...
