View Full Version : 94-95 Tech
- code 511
- Who has aftermarket valve covers?
- hairycanary??
- Any differences in these Fox and SN95 stuff...?
- got my @ss handed to me by buick Grand National
- Mild Overheating and pinging?
- Best off the shelf cam
- what do ur run ur timing at?
- Anyone switch from auto to 5 speed and still using the auto computer?
- BEST CLUTCH AND PRESSURE PLATE ?
- Seperating Fan from fan motor
- Tweecer Question
- Guys who have been scammed in the classifieds or just want some "ease of mind"
- cutting out in first
- If only I was one of the more "talkative" guys on this forum
- Suggestions for Polishing stock VCs
- Idler pully Squeeking up a storm
- How can I adjust my idle?
- Heads and cam
- Rear brake problem
- First IN car video and one of my scariest runs...
- PMS Users, need your help!!
- BBK WP U/D pulley wrong size, common?
- I like to see a V6 done right for once
- More power - Trickflow Street Intake vs. BBK LT's?
- idle speed
- who had the fastest 1/4 mile time with auto stock in here
- please help me with exhaust questions
- broke the plastic tip on one of the fuel injectors..
- OT: Rice or not
- 5 Questions?
- Which gas?
- Street legal H or X pipes?
- Cobra rear brakes--whats the smallest rim size so I can run slicks?
- Clutch Removal...
- starter keeps starting...
- OT: Somebody kill this 95 Stang
- Stock Cam or FTI?
- ATTN: Guys who let their cars sit until the weekend...
- xYoung347X, check your PMs
- Oil Dipstick Quesiton
- Brake question... yes im a new B.
- Shift points
- New paint, new hood, new sides, new rear, NEW PICS!
- What in the drivetrain causes a squeking, and then a clicking?
- Electronic fuel pressure gauges...
- CCRM Module
- Upgrading a 94GT
- ABS problem
- Thinking of Rachet shifter? Pros/Cons!!!
- 75mm too much??
- How much does the Cobra fog assembly weigh?
- ULTIMATE MUSTANG SHOOTOUT
- How do you check for a bad balancer?
- H/C/I Help
- I have the best boyfriend ever, look what he got me!
- Well...back at college for the semester...
- Fuel Pump Relay location
- Anyone have experience with BBK ceramic long tubes?
- 331 or 393 stroker?
- Vortech
- wire for 12 v dash light
- Aftermarket struts/shocks which are a good choice?
- Pulley Question...noise? alum vs steel?
- Best place to buy Flaming River?
- how can make a cheep home cold air intake
- Cobra Computer
- How much could I get out of this stuff?
- Throttle body, intake, MAF and exhaust added, do I need fuel system upgrade?
- Have big problem with Clutch Release / Throwout Bearing which one is good to buy
- OK Stangnet changed again!
- which nitros for 94 Cobra?
- code 10
- The computer in our cars is T4MO right?(94 5speed)
- Advice/help on 302 or 351 build up?
- If you ever owned a sn95 and a fox body, come in!!!
- questions about tranny conversion
- Question
- Eibach drag launch kit on verts, doable?/ Who likes these springs?
- post your 1/8 mile times.
- Which heads?
- Problems
- need some advice
- Ordered Tweecer R/T!!
- Dumb rear disc brake question from a Classic guy building a Cobra
- What should I do? (scammed and need help)
- Charging problem
- i have a friend who car knocks?
- wanna go 347 but dont know which way to go
- which is better for aode 3.27, 3,73 or 4.10
- Anyone know the F/R weight distribution on our cars?
- Anyone using 18x9 FR500 wheels?
- 94 gT AIR FUEL AND WATER TEMP GAUGE INSTALLATION HELP ????
- Update on my budget engine. How much hp/tq?
- Where To Buy: Heavy Duty Clutch?
- Playing catch up to z28's...
- 95 351w headers?
- Scored some 04 Cobra brakes. Good or bad??
- 03 cobra spoiler fitament on our decklids?
- MASS AIR AND FUEL TABLES
- Blackstangers please read......................
- driveshaft
- Which Intake if ported?
- Is it just me or did the search function disapear?
- A pillar water temp gauge
- weirdest thing happened today
- Just bought some 4:10's
- Tire sizes for 17x9 and 17x10.5
- have new mods what u think that it do in 1/4
- EEC Analyser???
- Sometimes I don't know why we do it (long)
- EGR codes 33 & 332.......Help...
- 96-98 Cobra Fan in a 94-95
- i dont think my car has the original engine?
- need spoiler pics? Boss, S351?
- harmonic balancer bolt???
- Alarm System - HELP!
- Does a 96 cobra have a 351w in it
- our cars make a good get away car!
- just to help out
- How do you tell a GTS...
- TOP SPEED ANYONE???
- Need help
- Vortech Owners...Pictures of Maf setup please
- Air Conditioner Drips on LT's
- B&M Hammer shifter installed (some pics and and comments)
- Name that hose!!!
- 98 seats in 95 ?
- Track Times from 8/28/04
- Borla Side exhaust/SVO side skirts
- next mod
- Blacking out Taillights on the Cobra?...
- Where did the HP calculator go?
- Check out My CarDomain site
- Turbo- Carb set up
- Went to the track tonight
- Wanna Remove power steering all together.
- How do I get the P/S pump pulley off?
- speedo broken
- Vibration at high speed, Rear end?
- Why are ppl using AFR's instead of Canfields?
- Spark plug and gapping need help
- Tail Lights help
- Tweecer people??
- Need pictures of Y2K Cobra R in 18's FMS
- Look what Mazda is thinking about doing!
- Quick question on lifters for a 351 non roller from factory....
- Looking for New Side Skirts.
- GT/GTS
- Throttle body/intake clean-up procedure
- How much HP
- Off topic paint question
- Squeaking throw out bearing?
- Metal Window Motor Bushings?
- guess my wieght?
- Got the GTS weighed today... Wow
- Holley fuel pressure regulator
- Door doesn't unlock w/ key
- Need some help
- What mods to get Cobra R radiator to fit
- Anyone rebuild their tloc
- subframe connectors
- tweecer guys check this out!
- Descent Night at the track.
- I see low 10s in my future!!!
- ODB 1 or 2 ???
- Battery light on!!
- Going to the track tonight... Need advise
- what product use to keep engine shiny and also post engine pics here !!!
- AACCKKK!!??? Car won't start!!
- You might be a stangnet member if...
- transmission t5 bearing
- Recommend a timing for my 95.
- Codes 311, 314 THERMACTOR
- 10 minutes Sway Bar removal!
- Odd little button on the dash...
- MAF Question
- Got a Photo Layout / Article in Mustang Enthusiast
- What should I budget for 4.10s
- 94 & 95 cobra guys....gas mileage?
- check engine light
- HELP OVERHEATAGE
- Smoke Through A/C Vents?
- Brake Sheilds
- AFM's PMS vs Tweecer RT??
- Size 34 battery and our Stangs
- roller lifter question
- ???? for you engine experts
- how many miles is too much for a used intake
- Trackbite PLEASE help!
- What's it worth
- wheel spacers 1" enough? pics?
- rpms at idle
- anybody have throttle return spring
- Need front control arm info!!!
- MSD6al mounting question??
- Good Deal-SN95 vert
- 1994 mustang tire&wheel ?'s
- do u have to unhook the battery when u unhook any sensor
- Ordered my Trick Flow kit today
- Beehive valve springs (comp cams 26918) on AFR165's? Dave?
- Need your help with my valve spring / head damage
- New toys, what do you think
- oil press
- Need help installing interlock cable with B&M hammer shifter!!!!!!!!
- test drove a car today a 95 gt stock 5 speed
- Polishing..Anyone Ever Use these Wheels?
- Cheapest Shortblock?
- no first or second gear...
- What mass air ?
- traction control on new mustangs
- Desperate, tempted to sell!
- Guys with weld wheels, I need help.
- how to identify aod tranny
- Battery Cables?
- 6500 for a 95
- Will control arms drop 2/10's?
- Flowmaster D-Port? Just a special "x-pipe"????
- NEED HELP QUICK!!!!!!!!
- Need advice selling parts
- my car with timing at 10*
- Vacuum ?
- Got a Performer RPM intake
- how much quicker will a shift kit make u
- Polishing intake manifold
- how can i get my car in the mid 14s cheep
- what 1/4 mile time car sould run
- timing and octane relationship
- what is a torque converter, and what does it do
- My Car Died Yesterday, Help
- T-stat, is it bad or is it normal??
- Finally decided to install new suspension, using lift but still need help
- What Intake should i get?
- Codes help
- NEW BBK INTAKE
- HELP must find all fords red paint codes for my 94!
- New 1/4 times
- low mustang 1994
- dumb question in my opinion but thought id ask
- I am mr deals...
- 5.0 vs. 4.6
- My car finally idles right...WOOHOO
- ANYBODY HAVE AIR CLEANER BOX RUBBER TUNNEL
- Picked My SFC's
- Alternator pulley question?
- 5.0 Emblem Question
- Polished Motors Pics
- Easy question
- Chip Qs?
- stupid question lol
