PDA
View Full Version : 94-95 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. DOES MAC AND BBK GET ALONG WITH EACH OTHER?
  2. Home porting gt-40 heads. What size gaskets to match and any tips?
  3. Hydraulic clutch in our cars?
  4. different o2 sensor question :)
  5. paint question??
  6. 3.55 Gears are In !!!!!!!
  7. I just got some MAC longtubes, now how do I put them in?
  8. f303
  9. What Headers for BBK X Pipe
  10. OT: Are car covers worth it?
  11. Our cars come with a 70mm maf stock>
  12. what does oil with fuel mixed in look like?
  13. help! clicking sound when engine gets hot: please throw some info in here.
  14. dunno if anyone knows: smog pump bypass w/ bbk underdrives!
  15. Brake Swap?
  16. Here it is! Pics of my Engine Install, and completed painted pics!
  17. Compression/Combination Issues
  18. has a stud mounted rocker ever came loose on you?
  19. intake valley (oil galley) 3/4" cup plug leaking - use sealant/RTV?
  20. question about speedo gauge cluster.
  21. Can TB be taken apart?
  22. 3.5" tips?
  23. prochamber vs O/R H?
  24. Let's settle this now...where officially is the THRUST WASHER go on Rollmaster TC...?
  25. Unknown Engine Noise
  26. 93 model to 95 model
  27. What would be better??
  28. Problems with OD
  29. Need help with gauge install
  30. hard starting?
  31. Bush Kerry Funny Video
  32. Fox valve cover, Vortech, and strut tower brace
  33. rear wheel spacers?
  34. Timing / Fuel Pressure Suggestions
  35. 95 GT vs 67 Fastback
  36. $300 for abs sensor install?
  37. COME ON GUYS GIVE ME SOME INPUT...
  38. I Need You, My People, For Help. SALEEN Rim Q!
  39. Just changed my look..removed the bodykit.
  40. Mass Air Sensor HELLLPP! Pics! easy question
  41. Ideas for major mods
  42. What kinda numbers, times would you expect w/this combo?
  43. get caster camber plates or no?
  44. who here is running an intake spacer
  45. BBK off road H
  46. Clutch Cable Woes
  47. What should i do
  48. OT..Special Favor/Request From All!!!
  49. Shatter/Clanking noise near Red Line
  50. pics of cars with pro kits an sportline springs.
  51. Door Bezel Finished (one side)..Zach, JR!!
  52. Brand New Pictures of my car. Much better than the last ones.
  53. which bellhousing?
  54. what choices will you make?
  55. 5.0-2/ 4.6-0
  56. Where'd you buy your clear fog lights?
  57. How come when My car gets hot, i can hear clicking under the valve covers?
  58. why is my car so fast/sexy?
  59. 351w cam help...
  60. Bolt kit for rear control arms
  61. 94-95 Cobra dyno at what stock?
  62. Will 4R70W bolt up to my 95GT
  63. EFI Help Needed Badly
  64. What size fuel pump
  65. E-brake for Decoration?
  66. Brake light switch not switching?
  67. Since it's a voting year, let's do one for yellow1995cobra
  68. Why is there so much hatred for the Stang?
  69. Where can i find this xenon bumper?
  70. The Time Is Here, Need Some Help....
  71. Trick Flow Intake Problem!!!!!!!!!!!
  72. New Rear Bumper Cover?
  73. Guys with Trick Flow Twisted Wedge post here
  74. Sorry guys but I change mind about AFR 165, I getting TFS Twisted Wedge
  75. Do you think my explorer injectors could be dumping too much fuel?
  76. Could i make my own MAF?
  77. is this a good deal on a clutch kit?
  78. Shifter Tri Axis vs Pro 5.0
  79. ATTENION - yellow5.0cobra
  80. outter panel removal
  81. Rack and Pinion?
  82. Distributors for 351w in 94/95
  83. 347 VS 351....the benchrace of a lifetime.
  84. Deep dish Bullitts!!
  85. exhaust advice
  86. 351w in a 94
  87. FRPP Ignition Coil
  88. Anyone using 1 3/4" Long Tube Headers in a 94-95? Advice needed...
  89. Whats gonna be louder?
  90. Thermo gasket
  91. Stangers with painted intake tell me what you did
  92. Help!!! Starter won't engage
  93. thermostat housings ?
  94. No More 5.0....
  95. NEED HELP W/ NEW UPGRADES!
  96. How much total coolant/water does the cooling system hold?
  97. Where to get A Pillar gauge for vert?
  98. How does this sound for a new Engine?
  99. Looking for Suggestions
  100. Billet Grill?
  101. Eibach Lowering Springs Hmm!
  102. Power seats PROBLEM....not a fuse i dont think
  103. What's this 95 5.0 engine worth??
  104. TFS street heat intake install ???????????
  105. OT: Digital camera recommendations?
  106. wtf?
  107. AFR heads and Stock H pipe questions
  108. please please help, next mod
  109. Will blocked off EGR trip a CE light?
  110. fr500 steering wheel
  111. Whats involved in swapping to an A9L computer?
  112. Inner Fender/Wheel Well Liner Removal
  113. Battery Gauge
  114. Window motor installation help
  115. 306 emblems??
  116. proper way to heat up my tires
  117. What do you think if i were to say im wanting to get 24''s?
  118. clear headlights with black housings
  119. Wasnt there an article about 99+ chin spoilers fit our cars?
  120. OK, this I want to do on my own! (help me!!!) SUSPENSION
  121. need mach 460 info and help!!!
  122. She runs....
  123. tech guys, check out these pics, please tell me if you see anything....
  124. Help me find rims
  125. destroyed Maximum Motorsports bushings with pics
  126. Removing Smog, P/S, A/C?
  127. EGR Valve Regulator Replacement – Any Advice?
  128. shortbelt/ e.t.?
  129. BBK / Elderock Throttle Body 70mm
  130. Headers Burnt Clutch Cable
  131. need help with over heating
  132. New Owner/Member
  133. Cobra Intake pre-install questions.
  134. SP Water/Methanol injection
  135. Whats this bucking/missing
  136. reply
  137. Bassani Side exhaust?
  138. How to Remove Cruise control?
  139. How to masure valve size on a set of heads.
  140. What do the mustang cobra 1.7 roller rockers look like?
  141. OT: anyone going to ATCO on Aug 13,14,15?
  142. interior a/c fan/blower problems !
  143. A/C problems and a few other questions
  144. Help me make a plan
  145. Finally
  146. tweecer
  147. rear control arm question
  148. aftermarket chip
  149. Cruise not working
  150. Code Reader Test Results
  151. Oil on spark plugs - but not on firing tip of the insulator
  152. red racing stripes
  153. H/C/I is finally done and running!!!!
  154. Those who have degreed a cam: not asking how to...just asking what to do?
  155. Dynoed the Cobra yesterday.
  156. Pics of Convertable Hardtop
  157. Installing push button ignition, need help!!!
  158. dyno results are in...
  159. what size cap for .....
  160. help all you s/c guys!
  161. Heads and cam or supercharger?
  162. Tranny is on its last leg... time for a new one
  163. A month...LT's still not here
  164. Headers and GT40P heads
  165. Ricer video
  166. Torque specs for top strut mount
  167. HELP - Extreme lean condition above 4500
  168. Mechanical Or Electrical Guages
  169. funny ricer video... Must See !
  170. Wingless - Opinions Please...
  171. Yellow1995Cobra Commercial
  172. 351W Info
  173. whos got the blue/red vert gt?
  174. I NEED Loud exhaust
  175. idle ajustment
  176. Where is the best shift point ?????
  177. flowmasters questions
  178. What is most needed next for my motor?
  179. VA and NC guys, a yes or no question
  180. ENGINE COMBO HELP
  181. Losing boost somewhere, this is soooo aggravating.
  182. JR, RC, anyone else... Gauge cluster question
  183. 75mm Maf or 70MM TB or Both? help choose
  184. TrickFlow Intake Question
  185. quick question on painted mirrors
  186. question about brakes
  187. OT kinda:: cheap flux cored welder?
  188. How on earth do you hook up a boost gauge?
  189. Finally, More pictures of completed stang..
  190. Why can i keep adding timing? Im at 20 deg!
  191. Vent..got in a wreck...not really my fault, but...
  192. Help me to choose cam for my Stang
  193. How did you run your wires up to the clock pod?
  194. goin' with magnaflow exhaust, tip suggestions?
  195. Taillight Bezel Restoration
  196. what clutch cable are you guys running??
  197. Using STP Fuel Injection Cleaner
  198. picture
  199. HELP QUICK PLEASE
  200. Roush 3-piece intake install madness!!!
  201. somewhat off topic
  202. running sluggish....no codes also
  203. RC has inspired me to paint my A/C bezel
  204. fox swap. what do i need?
  205. The Bling of Intake Manifolds
  206. how much is my stock TB,MAF,Fuel pump, FPR holding me back?
  207. what mod would you go with next
  208. 10th anny cobra brakes
  209. oil pan gasket
  210. which guage???
  211. Bezel Painted...Sony Installed...Must See JR!
  212. Need some help!!!!
  213. do i need to break in my new cam?
  214. Replacing ball joint on 95
  215. rocky motor?
  216. got my new rims, what do you think
  217. Went to the track... ended up being a long night
  218. speedo gear...please help
  219. sensor meaning
  220. Tomorrow is the day
  221. 11pm, Just Fired it up! YAY!!
  222. Need help timing ajustment
  223. BBK Long tube header install problem
  224. These Are My New Rims!!
  225. I bet you can't find another site with this bumper
  226. Everyone check this out
  227. spark plug wire troubles...
  228. oil change mystery
  229. would a 335/35 tire fit our cars in the rear?
  230. Repost...idle problems
  231. New 275/40 Nitto 555RII's on car. Pics!
  232. I'm Sill Alive! Very Strange Dyno Results Inside
  233. getting hot with the a/c
  234. FINALLY
  235. clutch pedal feels weird after new cable
  236. OT Why can't I post pics???
  237. PAINTED The Calipers TODAY TAKE A LOOK PICS
  238. General Maintenance…?
  239. Best bumper for our cars
  240. Intuitive or Moronic? You tell me. [Long]
  241. carbon build up
  242. TKO-500/600 install
  243. Starter Solenoid Seprate from Starter?
  244. Polished the Stang up....Took a couple pics!
  245. Carb swap??
  246. Proper way to Flush and Bleed Brakes
  247. '95 Carbon Fiber Cobra R hood?
  248. Went to the track for the first time
  249. vibration through shifter....Driveshaft??
  250. superchargers
