View Full Version : 94-95 Tech
- weird
- How or where can I host video
- I cant decide?
- what are the ill effects of old and tired, fuel pumps, and filter
- Spintech and side exhaust?
- SN95 waterneck same as FOX?
- dumb question
- Ah yes the new shortblock is here... few pics
- 24's big enough for a 393?
- Automatic Transmission Trouble...
- Finally some new pics!!!!!!!!!
- Finally got to dyno with the N2O today
- Anyone have a parts car?
- Pics of Silver/Gray stangs!!
- Need a quick favor
- Installing a Ford racing Tach
- HEY CAR IS RUNNING!! Got a few problems, overheating, oil leak,HIT 5#'s!!!
- Going to look at another Stang...Question about 4:10's & Milage
- new intake vs new exhaust
- Screen in MAF
- Will this fit?
- idle issues and sudden bucks!! please help
- I finally graduated!!
- got dyno tuned. VERY unhappy, need suggestions quick
- 93 MAF meter on a 95?
- turn signal light out
- Cobra brake installation
- What could be causing pinging/detonation?
- shaker systems?
- Raced a 96 GT
- Read these for me....
- I can't find....
- 10.5's ????????
- paint color/scheme ideas needed
- FMU Question
- Fuel Pressure Question
- In a Pickle
- Overdrive alternator puller (anyone heard of this)?
- OT: Ordered me a new toy today...
- Smog Pump removal
- wierd lights today
- What to look for when getting used aluminum heads?
- Ok, so who's broken something with DRs?
- Bumper/headlight panel issues...
- Side skirts
- **overheating problems**
- HELP... Car dies at idle sometimes
- Might possibly buy a used C4 tranny...
- Air conditioning vents not working right!
- OT: The "man's" House/garage/shop
- Some pictures of my toys...
- What should I do with this???
- Best Bang for My Buck?
- Do I need to re-torque again?
- RC pics for you meng
- Haynes or Chiltons
- another exhaust question
- Tranny Question
- OT: Back from my cruise in Alaska
- Where do I get spec clutch?
- How do I?..TPS Voltage & Cleaning
- clutch cause of power loss, whats good?
- Exhaust drone
- RPMS
- i have to beat him
- SS Radiator Covers
- 02 sensor dilema
- Coil Over's VS Lakewood - Help me choose
- My car is alive again!!!
- trick flow street kit
- I need to vent!!!
- Throttle body question
- RPM Extender, Did I screw up?
- How well does your vert ac work
- Set my gap
- Deer crash update!! (PICS)
- Nitrous switch panel
- Anyone got a AIC Sensor?
- Nite-Shades
- Are there any down sides of getting a set of gt-40y heads?
- 94'Gt timing question.
- Window wont go back up and its starting to rain
- 351w computer question?
- relocating fan!
- sorry, real dumb one, what's the diff. between GT and cobra headlights?
- Could you help me out with a few post-s/c install probs?
- use anti-seize on rocker stud-to-head threads?
- Fuel Pump (MIL On)
- Ran an NSX
- Need places to mount a/f r gauge!!
- My 95 feels like crap odd idle.
- Might need a new fuel pump?
- Easy Rust Removal?
- Ground cleanance issues may force me to keep stock suspension!!!
- Summer Upgrades
- 95 cobras come with subframe connectors?
- MPG and you! All because of gas prices.
- no pull after 4k
- how to get air bag light to stop blinking
- What cam with a rebuilt cobra long block and explorer intake?
- Mustang Mag "Babe of the Month"
- Is this a good deal on a rebuilt cobra long block?
- How much more ??
- pcv catch can package for oil consumption through pcv
- need your vote - paint mirrors or no
- Can someone please please run a car fax for me, i might be buying the car tomorrow.
- Spare tire- Clear Bullit Brakes
- rocker arm came loose... how much damage? :(
- New Pump??(30lb inj cal to a pro-m maf)
- What fuel pump to get??
- Cutoff Tool+spare upper+curiosity=pics ofstock intake ports inside
- lets see some street car roll bar pics
- I need drag/street suspension EVERYTHING!
- Dyno #'s are in needs some big changes.
- Fuel rail fitting size
- Look what I've been collecting...
- any way to tell the difference bewteen a 4cyl rear end an the 8cyl?
- Jumper Wire?!
- temp?
- This is the way I see it.
- for [b]Chefster[/b] - 80 roll...best technique to dump suvs
- gettin new heads, emission testing.....what to get?
- stock header gasket residue
- Got the baseline dyno done today
- magnaflow or Mac? I want 3.5" tips...
- Water pump pully hitting balancer? HELP!
- Where To Get Polished Valve Covers
- What if you had...
- Are 275x50x15 Drag Radials the biggest 50 for a 15" rim?
- one piece headlights
- Finally finished!! 1 1/2yr. project (valve noise Q??)
- Ground wire questions????? (PICS)
- nasty sound(please help)
- Edelbrock Performer 5.0 (Bolts??)
- 96+ C&L MAF on a 95 5.0?
- Mustang Exhaust on a Lincoln
- How much would it cost me to rebuild my engine or go 306+?
- Wheel Sizing Questions
- Tokico Springs??? They offer a kit just like the Bullitt Kit
- Tweecer help needed ASAP!
- Opinions on Chrome Headers
- NITTO NT555R 275 40 R17
- What do you guys think about this combo?
- courtesy lights
- Selling 03 GT for a 5.0 project car
- Hood pins: Yes or No???
- Stock heads vs. intake. What is more restrictive?
- OT but what is everyone paying for gas
- Anyone know this guy?????
- OT. Chrysler 300C
- Heading to the dyno tomorrow, hope the cluth will hold
- what should i get for $1000
- My future turbo car pic...
- awnsering what "skeet skeet skeet" stands for
- warm stahling problem...please help
- Another AFR/FTI/Edelbrock Bandwagon Jumper...*DUW*
- have you heard of a freeze plug?
- $1,100 for AFR 165's and 185's
- Fuel Pressure adjusting/Autometer wires
- Should i get a 5.8 litre?
- anyone know?
- What happened to the aftermarket rim thread?
- Which Caster camber plates?
- funny little story
- Sideskirt-less. Picture inside
- Hand brake bracket rubbing?
- FAN ????????????
- Problem in the maybe of install..
- Quesition about adding Mobil 1 synthetic to a car thats never had synthetic oil befor
- Down shifting at intermittent times
- Can some one tell me about the oillines/ fittings on my vortech???<<confused
- Help, I need some convincing.
- Where to find Bare 302 Block
- Sixth Times a Charm!
- walbro vs t-rex... Interesting
- Cobra headlights ang foglights!!
- Wanna screw? (tb)
- Fog Lights?
- Post pics of WHITE stangs!
- Intake Manifold
- ditching a/c and smog pump, need help!!
- Matching up Throttle Bodies and MAF sensors
- Here's My CarDomain site for u all to see
- car temp(not what you think)
- Explorer Intake done - hmmmmm
- Odd overheating problem
- Gettin The Nitrious Tomorrow!
- Ok finally time for a new top...
- Lookie Lookie who i found on Mustangworld.com
- Car back from shop
- Buying A Radiator Which One?
- Show me pics of your lowered stang!
- I'm having a garage sale!!!!
- post your billet grills
- Coolest Golf Cart EVER!
- Width of a 94-98 decklid?
- HOW MUCH POWER LOST WITH BAD 02 SENSOR
- aluminum drive shaft
- Found Oil in Upper Eddy intake
- FoxBody Conversion for intake.??
- ps / ac bracket
- New clutch in, is it acting normal?
- Anybody have extra seat brackets?
- Question on putting heads back on??
- New dyno results: Not good but not really bad.
- P-51 Mustang?
- Who has pics of a White conv with a double stack wing?
- GT 40's and an E cam, good combo?
- Finally got pics [95gt]
- Those with custom exhaust pipes...
- Best Shift Kit?
- Verdicts in: Dynomax Bullet Race Mufflers
- Got Power but wont crank
- Wheel size considerations?
- charcoal gas chamber box
- how many o2 sensors on 5.o cobra ezhaust
- remote entry?
- MSD 6A Rev Limiter?
- Er'Body In The Club Gettin' "Tips"?
- spotted new stangs on road..and gt 40!
- another MAF question
- MAC tailpipes
- Mach 460 replacement speakers?
- Vibration at speeds of 90+!! Need help!!
- Will a new stall convertor absorb the effects of a shift kit?
- Possible Mods
- Fixed part of my problem
- Quick question about removing the throttle body..
- Track Days
- 5.0
- power steering pump install
- More proof that the 5.0 based engine is not close to dead ...
- Anyone else ever hear of this???(cheap alluminum d/s)
- people suck....vent....
- Yea, so my Bullit suspension install led to new brakes, wheels and 2 tires... (pics)
- Stang counds like a chevy!
- Guess what I find under my Stang this morning
- Should I get diffrent sideskirts as well?
- Lightning Heads
- Help With Stereo Selection
- header install question
- Summit Radiator Owners! Come on down!
- Looking for a p1sc or vortech
- quick egr question
- T45 in a 95?
- Checking tps, rolling idle
- Anyone have the hardened input shaft from performance automotive?
- Need to know a price
- just got destroyed by a Talon TSI
- Got issues!!
