Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Reload this Page HELP Grille and Side Scoop Removal
Reply
(#1 (permalink))
Old
Question HELP Grille and Side Scoop Removal - 02-14-03, 10:34 PM
I just got a chrome grille and scoop inserts for my 2000 GT. Anyone have any good tips for removing the plastic screws that hold the radiator cover/grille assembly in place?
Also, I have to remove my side scoops (the entire piece, not just the insert) to put my new ones in. What's the best way to do it without scratching the paint?
(#2 (permalink))
Old
Red2000GT's Avatar
02-14-03, 11:29 PM
I don't know about the grille but the side scoops only come out one way,by reefing on them hard!!
(#3 (permalink))
Old
trents99's Avatar
02-15-03, 02:22 PM
http://mustangworld.com/ourpics/fcar/scoops.htm
(#4 (permalink))
Old
02-15-03, 11:29 PM
I'll offer up help on the grille, don't know about the scoops.
Getting those retainer screws out is a little tricky (if it's the same ones I'm thinking of). You've just gotta unscrew them as normal, but put a tad bit of pressure on them while turning counterclockwise. Once you see the head of the screw start to come up above the surrounding area, you can let off with the pressure, and just remove as normal.
Be careful in doing so though, if you plan to reuse them. They're plastic, and they strip rather easy. I stripped 2 myself when I took the honeycomb grille out of my '99 to replace with the eliminator kit. Thank goodness I only needed 2 screws to hold that in instead of 4.
PS: I have some pictures of the process, but I don't know how good they'd be in assisting you in the actual job. It took me about an hour to do the grille swap...could've been quicker if I had a secure-torx bit (you won't need that though if you're just changing grilles).
(#5 (permalink))
Old
Wolfhound's Avatar
02-17-03, 04:33 PM
I added Bullitt side scoops and put on the MAch 1 grill delete. The side scoops come off by pulling them. Take a screwdriver and put a cloth around it to pry it out a little so you can your fingers in there to pull it off.
The grill is a little more difficult. You might as well go ahead and buy you some new plastic screws. They were impossible for me to get out without destroying them.
(#6 (permalink))
Old
01-23-04, 03:48 PM
I was looking into removing/replacing the side scoops on my 2003 GT with a kit to make them functional as rear brake coolers. Does anyone know if this type of kit exists or if anyone has done this type of customization.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
