Go Back   Mustang Forums at StangNet > Mustang Forums > Special Production > Mach 1
Reload this Page Power shuts off!
Notices
Reply
(#1 (permalink))
Old
Official Member
Power shuts off! - 03-05-03, 09:26 AM
running up some rpms at full throttle (2nd gear) to get around a truck on a hill the power suddendly felt like someone cut the throttle cable. When I backed off and shifted to 3rd the problem went away. What the heck is that - anyone experience this one?
Chas.
(#2 (permalink))
Old
SmokyBurnOut's Avatar
Administrator
03-05-03, 11:55 AM
Did you hit the rev limiter?
If not, maybe traction control kicked in? Damn, I'm glad I don't have that in my car now.
StangNet System Administrator / Programmer
1999 Supercharged Mustang GT
2007 F-150 SuperCrew Lariat
(#3 (permalink))
Old
94BossGT's Avatar
TC - 03-06-03, 05:17 AM
Yes, the rev limiter is around 7200 RPM could have done it, BUT...
The Complaint has been Traction CONTROL!!! It is ON by DEFAULT and you downshift or try to chirp the tires, it will back the engine spark/rpm fuel down!!!! And feel like it want's to stall or something....many discussions over on the http://www.Mach1Registry.com/forums on this very topic!!
David Wagner
Founder/Admin
dave@mach1registry.com
www.mach1performance.org Parts & Accessories
(#4 (permalink))
Old
34Ford's Avatar
Re: Power shuts off! - 03-07-03, 02:28 PM
Quote:
Originally posted by Charles Smiley
running up some rpms at full throttle (2nd gear) ?
Chas.
2nd gear, full throttle! Goodness. You know good'n well the T/C kicked in
But that could have been a good thing. Might have kept you from swapping ends.
Dennis
2003 Torch Red Mach 1
I sell iac restrictor plates
MRT Street Performance Springs
Steeda Tri-Ax Shifter
AFS 18x9 Chrome/Black Retro Rims
Nitto 285/35 & 265/35 555's
2 1/2" Catback w/2 chamber Flows
3 1/2" Magnaflow rolled Tips
MRT Street Smart CAI
Click to see my 03 Mach 1 and '34 coupe
Blue Ridge Mustang Club of Asheville
brmcoa.org
(#5 (permalink))
Old
Official Member
03-07-03, 03:24 PM
I doubt I went much above about 5600. But I don't know the accuracy of the tach. I can't see swapping ends in 2nd gear going straight - just not enough power. But I could imagine a traction control going brezerk at the wrong moment and inducing the problem - scary thought to rely on machines with such things.
Are there any known problems with the TC? Overall it seems to work and do something useful. I like the idea of stealthy dicing with other cars and NOT attracting attention (police) with howling tires.
Chas.
(#6 (permalink))
Old
TR03Mach1's Avatar
GoldMember
03-07-03, 03:52 PM
My advise would be to only use T/C when the conditions deem it necessary, ie wet, ice, snow, sand, otherwise shut it off! On one occasion I forgot I had it on, shifted into second and you might have thought I slammed on the brakes and turned the motor off and the same time!! The car did a nose dive that about threw me thru the windshield! On dry pavement Traction Control IS NOT your friend.
5-speed, Interior Upgrade Package
C&L 85mm Mass air, with Mach 1 airbox and K&N Filter
C&L True Flow intake pipe
Borla Stinger catback
Nitrous Express wet kit 125 shot
Hurst Shifter
Spec stage 2 clutch
Ram billet steel flywheel
Custom Predator nitrous tune
MMR Rear Seat Delete
Visus Rear Louvers
My Car
13.19 @105 - bone stock
Stock Dyno 03/13/04
SAE 297.62 rwhp 327.22 rwtq
STD 306.98 rwhp 337.52 rwtq
(#7 (permalink))
Old
Official Member
03-07-03, 05:23 PM
98BlackGTvert,
Very interesting. I wish I could set the default to be normall-off somehow.
Chas.
(#8 (permalink))
Old
94BossGT's Avatar
Kit - 03-07-03, 05:30 PM
There is a kit you can install that will switch the Traction Control to the OFF position automatically when the car is started....
I think we will be offering it on the Mach1Registry.com soon.
Keep checking.
David Wagner
Founder/Admin
(#9 (permalink))
Old
03-11-03, 06:37 AM
A pretty similar thing happened to me. I was riding through town one night and somebody in a 4 cylinder ranger was trying to be cool and make all kinds of noise so I was pulling up to a red light going down a hill and I thought I shift her down in to first and let em here it( I was only going like twenty or so) and when I did I thought i'd blew it up. It started cutting the throttle and what was gonna make my car sound cool just made it look like a piece.
(#10 (permalink))
Old
Administrator
03-11-03, 04:22 PM
5600RPM in 2nd gear? If you're having traction problems at 55MPH, you might want to look into better tires. Are these Mach1's really that strong, or is the T/C that crappy?
BTW, I thought I remember reading that the T/C in the Mustang won't activate if you are at WOT. There is a name for that feature, but I can't remember it.
-Chad
(#11 (permalink))
Old
Official Member
03-11-03, 05:13 PM
If it doesn't work in WOT, it could suddenly switch back on if you lift the gas slightly to upshift gears. Since I don't powershift that's the case. I drive to match the rpms to the next gear from racing on roadrace tracks for years.
So maybe the TC can't react favorably to that condition if it switches off for WOT. Another reason to not use it! In some ways I like it -- so you can launch out from a stop with no wheelspin and not attract tickets.
Chas.
(#12 (permalink))
Old
Administrator
03-11-03, 05:35 PM
Ok, I found some literature on it. This is from an old Road&Track article on the '99 GT.
Quote:
The Bosch 5.3 system has a "power start" feature that allows aggressive starts on a good traction surface, permitting a fair amount of wheelspin, and can tell the difference between attempting the same on a slippery surface.
So, perhaps it's just a feature from a stop?
All I know is, I'm now glad I didn't get that option from all the complaints I hear about it.
(#13 (permalink))
Old
Traction Control - 01-14-04, 02:22 PM
Quote:
Chas.
Yup...it's the traction control, and it operates at any throttle setting. Feels like someone jammed a wood block under the accelerator and the car does all sorts of strange things, like brakingthe spinning wheel(s), until the wheels get full traction and then it's back to normal. Best bet is to shut off the traction control every time you start the car unless it's raining or slick out. There is a module available for about $60 that remembers the last setting YOU chose for the traction control off when you start the vehicle.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
