AND IT WAS ME!!!
Heres the deal... my car has nooo power. It hesitates, stutters, and makes popping sounds from the exhaust, kinda like its backfiring. I've pulled codes and all it said was:
14 (c): Intermittent PIP signal operation. Suspect PIP sensor or TFI module, or grounding or interference problems at the TFI module. Y1
54 (orc*): ACT (air Charge Temperature) sensor voltage too high. DA10, DA90
I changed the ACT sensor, it didnt look too bad, had some oil on it though. Car ran ok, but still stuttered. Then it started popping again. The weird thing is... the car runs PERFECT when its in test mode.... I've disabled the EGR, new cap and rotor, new wires, plugs look fine (eleeto splitfire plugs BTW), compression test was even and high, timing is perfect at 12...
im getting tired of replacing EVERYTHING on my car just to get it working. Autozone are a bunch of homo's and wont let me return sensors because they dont warranty electronics cuz they dont know if I've burned them or not... my autozone sucks.
and uhmm... it was more like a "cmon baby... work for me" kick to the bumper... which i wiped off cuz my shoe left a scuff mark...
