Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Reload this Page when porting and polishing heads and intake??
Reply
(#1 (permalink))
Old
when porting and polishing heads and intake?? - 06-30-03, 01:53 AM
i posted this at other forums, so i can get different views and opinions from alot different people, because the more information i can get the better it is for me so i dont end up screwing up and making a costly mistake.
i plan on buying a set of 1.8 roller rockers soon and placed and order for 1/2" intake spacers. i thought since im going this mod why not do some other free mods that will complament the ones im paying for.
so i plan on porting and polishing my heads and intake and half shafting my TB. i pretty much get the jist of the process. but (like always) i have some questions.
i only plan on doing like a mild port work like mostly gasket matching however, alot of polishing work.
1) should i use aluminum polish on the runners, TB, heads, and inlet to get a good smooth finish?
2) will i have to replace my gaskets or can i reuse my old ones?
3) for the time being i will have a N/A set up (when i get boost, i will buy fully ported intake and heads that will flow alot more), so just for now while i have my N/A setup, should i taper down the lower intake like gasket match on the upper/lower part and slightly port on head/lower side? or just gasket match through out it?
i read that when it tapers like that it helps air velocity.
4) the heads seem alittle tricky to me, any tips on how to do the combustion chambers?
5) any other tips and/or advise with removal, installation, and the work it self?
-umesh
Wheels:
-American Racing Longboard Rims 18x8" front; 18x10" rear
-Nitto NT555 tires 245/40/18 front; 275/35/18 rear
Looks:
-ABC front Cobra R bumper
-ABC front Cobra R hood
Performance:
-2 Flowmaster 40 Series with dumps and 2.25" True Dual Exhuast with H pipe
-K&N air filter
-Steeda short shifter
-Ford Racing 3.73 gears
-Auburn Gear T-lock
-Fordchip.com F-4 chip with flip switch
Suspension:
-Progress Sport Springs 1.7"drop front; 1.5"drop rear
-Maximum Motorsports lower control arm, pan hard bar, swaybar end links with polyurathane bushings, K member brace, caster camber plates, full lenght subframe connectors
-Ford Racing Parts Heavy Duty upper control arms, with hard rubber bushings
-Steeda Rear sway bar, Front sway bar, rack & pinion off set bushings, A Arm offset polyurathane bushings
-Tokico gas struts and shocks
System:
-Kenwood 919 deck
-MBQuart PSD 216 front speakers
-MBQuart DCD 157 rear speakers
-JL 10" W7 sub
-Pheonix Gold Tantrum 500.2 for the sub
-Pheonix Gold Tantrum 600.4 for the interior speakers
(#2 (permalink))
Old
07-01-03, 07:54 PM
anyone?
(#3 (permalink))
Old
GREENBIOCH's Avatar
07-01-03, 08:21 PM
Well I had looked into doing the work myself once, now I'm not so sure, looks to be a difficult task on the heads, but not impossible.
I would attempt the intakes myself but not the heads, I would leave it to a professional.
Get new gaskets for sure, don't re-use old ones. If you port the intakes to much you will lose air velocity and hurt performance.
There is alot to it, I would be careful though. Knowing what I know now I would pay someone else just in case I was to F it up!
Good Luck
Performance Mods
-K&N Filter, Snorkel Delete, Magnapack Catback Exhaust, UPR OR X Pipe, XCAL2, 4.10 FFRP, BFG KDW's.
Looks Good Mods
-35% window tint, Shorty Antenna, Sequential Tail Lights.
(#4 (permalink))
Old
silverstangman's Avatar
Official Member
07-01-03, 08:53 PM
porting and polishing isnt for a novice,believe me it takes skill and time and patience.i would seriously recommend u getting someone to do it for you,dont do it yourself.plus if you have any problems after the work is done u have warranty so they will have to fix it for u.just my opinion.later.
Packhouse Performance
Modified Mustangs
1989 Hatchback W/ 420 Windsor On The Bottle
The Street Car That Will Rape Your Street Car
GOT 8's?????
http://profile.myspace.com/index.cfm...endid=48138546
(#5 (permalink))
Old
77sleeper's Avatar
GO BUCS!
07-01-03, 09:43 PM
DO NOT polish the intake ports, it will cause puddling, but ALWAYS polish the exhaust ports
U.S.A.F. Veteran
A country that does not defend its borders, cannot long control its destiny
(#6 (permalink))
Old
12-15-03, 07:33 PM
Quote:
umm yea, it would cause puddling, if there was any fuel in the intake on a ford 3.8. dude, the injectors are in the head go look at your motor right now. there is never any fuel in any of the intake runners. in a carburated motor, i would definitly say leave the walls rough cast, becuase it would give better fuel atomization, but with these dry intake manifolds, it doesnt really matter.
(#7 (permalink))
Old
BABstangV6's Avatar
Smater than the average bear!
12-15-03, 07:40 PM
Quote:
Yea I am with everyone else, not to port your own heads. I could see maybe the intake manifold.
(and the owned thing I am just giving you a hard time )
(#8 (permalink))
Old
97v6Silver's Avatar
it came to $4.56 and i got $0.44 change from a 5, man, they must be dumb
12-16-03, 06:50 AM
it's a hell of alotta work to do it by hand, either get done by a rpo or get to know your dremel too real well
04 GMC Sierra
-97 v6 mustang **sold**
-15.168 @ 90.73 mph
-Teh Modz: JVC KD-S590 sytem, Bazooka Speakers, 35% platinum Tint, p&p upper and lower, 3:73's & t-lok, Shorty Headers, Mac CAI, UnderDrive Pullies, Mac Short Shifter, Mac O/R X, Ravins
Quote:
Originally Posted by Kilgore Trout
Damn... Seriously? Owned by 97V6silver??? Man, I am slipping. That sux. Are you sure? Damn...
(#9 (permalink))
Old
slowjoe's Avatar
Banned
Location: Good o'l New Mexico, Next to the cereal isle.
03-04-04, 05:45 PM
nevermind
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
