Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Reload this Page Error Code P0172 System Running Rich Bank 1
Reply
(#1 (permalink))
Old
DAZ's Avatar
DAZ DAZ is offline
Error Code P0172 System Running Rich Bank 1 - 07-08-03, 08:37 PM
Recently pulled code P0172 System Running Rich Bank 1
Can anybody suggest diagnostics I can perform to determine cause of the error code.
2000 V8 Convertible
K&N Cold Air Kit
Diablo Tuner
(#2 (permalink))
Old
SonicBlue02-3.8's Avatar
Official Member
07-09-03, 04:51 PM
When that code came up on my old 1990 T-bird, I remember having to replace an 02 sensor. How many miles are on your stang? They might have to be replaced. Hope that helped a little.
(#3 (permalink))
Old
Lsredy2kstang's Avatar
Look, I'm special, dammit
07-09-03, 05:53 PM
It is a o2 sensor problem. Which one, I have no clue. but go to autozone and they will be able to pull the codes and help you determine which one it is.
Travis.
Laser Red V6 and proud!
194 RWHP
220 RWTQ
**Exterior**-Have some, just ask
**Interior**-Have some just ask
**Engine**-Have some just ask
**Ignition**-Have some just ask
**Suspension**-Have some just ask
**Drivetrain**-Have some just ask
If it's not a Stang, then why the hell are you driving it!
(#4 (permalink))
Old
DAZ's Avatar
DAZ DAZ is offline
07-10-03, 04:51 AM
Quote:
Replaced all O2 sensors last month when I changed plugs and wires. Thought this would help the fuel consumption.... no effect.
2000 V8 Convertible
K&N Cold Air Kit
Diablo Tuner
(#5 (permalink))
Old
mkonor's Avatar
07-10-03, 06:41 PM
Quote:
This fault has multiple causes...faulty MAF, leaking intake, faulty fuel injectors, bad IAT, among others.
Even though you replaced the O2 sensors doesn't mean that they are properly sending the readings to the ECM. Bad wires and connections can also cause that fault.
Time to troubleshoot.
Oh yes, question, how is your gas mileage? How does the car idle? Acceleration?
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, SSX SPI Intake, ProMotion T-5, SPEC Stage 3 Clutch, Sparco Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump & Tank, SCT MicroTuner, FMS 4.10 Gears, MAC LTRs, (remainder deleted due to 500 character limit)
(#6 (permalink))
Old
DAZ's Avatar
DAZ DAZ is offline
07-10-03, 07:26 PM
SUCKS! ROUGH & HIGH! SLUGGUSH for first two to three seconds.
2000 V8 Convertible
K&N Cold Air Kit
Diablo Tuner
(#7 (permalink))
Old
mamastang's Avatar
01-03-04, 11:46 AM
dkhorse I need some help can you help
DEE.
(#8 (permalink))
Old
01-03-04, 02:12 PM
Bank 1 = Passenger side.
Because it's only one bank, I'd be inclined to check things like the O2 sensor wiring first, before you go looking at things like MAF that would effect both banks. The simplest explanation is that you have a bad wire somewhere from the O2 sensor (since you just replaced those) that's making intermittent contact and feeding the EEC a slightly rich signal. I'd inspect all the wiring very carefully, and if you really felt like some fun, I might swap the O2 sensors, clear the code, and see if it comes back and on which bank. If it comes back on Bank 2 this time, it's probably just the O2. If it comes back on Bank 1 again, it's either the wiring, or something worse.
(#9 (permalink))
Old
Jamez's Avatar
01-03-04, 02:50 PM
I got that for left bank too and it turned out to be a faulty MAF. Just so many things that could cause it will give you lots of guesses.
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
