| Notices |
StangNet.com is 10 years old!
Come on! Help us celebrate this fantastic feat by stopping in and letting us know how StangNet has shaped your experience surrounding the Ford Mustang! |
This THREAD brought to you by... |
Just Died...!!! -
08-25-03, 05:56 PM
My daughters 93 4 cly just died on her today. It would crank, but wouldn't try to start. Went back 3 hours later still wouldn't start. Called a tow truck, got it home. Then it decides to start. Checked the codes, nothing pointing to a serious problem.  Any ideas????
K&N, AOD, Motorsport 4.10 Gears,
Moser everything else in the rear end
Ford Racing Aluminum Drive Shaft
FlowMaster exhaust, MAC Headers,
Hi-Flow Cats, Underdrive pullys
08-25-03, 09:26 PM
This SCREAMS TFI module.
1986 Mustang SVO
2.3 Turbo, 225 RWHP, 258 RWTQ
why can't you turn and face me
you ****ing dissapoint me
08-25-03, 10:10 PM
TFI was my first thought, but it restarted agian.
They are killed by heat, so I guess it is possible for it to work after cooling down.
Did you notice if the tach moved when you couldn't start it? if it didn't move, there is a good chance it was the TFI and it is definatly ignition related
Brian.
I must be totally confused.... my daily driver is a 5sp w/v8 and my toy is an automatic 4cyl. Guess which one is faster?
88 4cyl stang: 12.97@105mph
97 GT: 14.27@96.5mph in perfect weather (street tires, stock minus OR H-pipe)
08-25-03, 11:23 PM
It DIDN'T restart bhuff..
I'd say timing belt since it's not throwing codes. If the belt is ok then it is most likely the TFI.
Stinger
08-26-03, 05:33 AM
It did restart. So I know it's not the timeing belt or anything else that would be "broke". I'll check the TFI module tonight.
Thanks,
08-26-03, 06:25 AM
Quote:
Thanks,
What's up 90GT? Good to see another Louisville mustang driver on here!
'93 Civic Hatchback
'07 Accord SE
08-26-03, 07:08 AM
re-starting after it cools down is a symptom
08-26-03, 07:13 AM
my 84 did the exact same thing numerous times and it ended up being the TFI
08-26-03, 09:57 AM
Is the TFI the samething as a ignition module?
08-26-03, 10:29 AM
Yes. TFI=Thick Tilm Ignition modual.
It is attached to the distributer. You will need a special tool to get it out (cheap). Be sure to coat the back of the new TFI with plenty of heat transfer grease.
Brian.
Official Member
08-27-03, 05:12 PM
that happened to me once, didn't know what the hell it was, came home was reading on SN about a similar problem, hell went outside checked it out and she cranked ....weird stuff
1993 Red LX 2.3L
Current Mods:
Removed Air Silencer
Custom CAI with coned K&N
Added Sony CD Player
08-27-03, 05:33 PM
That took care of the problem. Replaced it last night. It was 100 degrees today. Drove the car allday with no problems.
Thanks for the input.
Official Member
08-27-03, 08:32 PM
Same thing happend to my Bronco II(125k Miles) infront of target one day. It would turn but wouldnet start, it was the Ignition Moduel (TFI).
Official Member
01-11-04, 10:40 PM
mine did this awhile back, fuel pump relay went out or it was bad wiring for it, couldnt figure it out. i cut some wires from my ecu and ran them into a 30 amp fuse. that kept going out so i jus wired it straight to the fuse box.
1996 Limited Grand Cherokee V8 5.2L 4WD
1989 GT 5.0 5 Speed (Sold)
1993 Mustang LX 2.3L 5 Speed (Sold)
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
