Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Tech
Reload this Page 2003 Cobra 3.10" Steeda pulley question
Reply
(#1 (permalink))
Old
Official Member
2003 Cobra 3.10" Steeda pulley question - 09-25-03, 07:17 AM
I talked to Steeda, and my contact there said that for the 3.10" pulley, you don't need the Diablosport delta chip. However, on the Steeda website it says that both the 2.81 and the 3.10 pulley requires it.
Anyone have an educated guess on this? Maybe they only put that up on the website to play it safe. My guess would be you could just boost another psi or two out of the supercharger without chipping, as the guy from Steeda told me.
(#2 (permalink))
Old
Official Member
09-25-03, 09:18 AM
Anyone?
(#3 (permalink))
Old
Official Member
09-25-03, 12:59 PM
who did you talk to at Steeda? I would think you would be fine with out the chip but, the chip is going to give you the most out of the car.
God Bless
1998 Steeda Cobra S/N 98-009
Eats Corvettes for breakfast
Vipers for lunch
Diablos for dinner
Ferraris for desert
(#4 (permalink))
Old
01SilverL's Avatar
09-25-03, 03:20 PM
I am running a 3.2 with no chip. I think it's just about at it limits without a custom tune. My dyno sheet is on www.svtperformance.com run a search with my user name "03shadowcobra". As others have said you will get the most out of the car with a custom tune but you will lose your warranty. You can try a 3.1 but definetly put it on a dyno and check the A/F ratio. South Florida Pulley HQ sells 3.4, 3.2, 3.1, 3.0..... and so on for pulley sizes if you want something bigger than 3.1.
03 DSG Cobra Coupe
twin screwed.
(#5 (permalink))
Old
vipergts281's Avatar
Mr. Metrosexual
09-25-03, 03:37 PM
With a 3.1 pulley I would recommend a chip. I'm sure some cars won't need a chip, but the majority will.
(#6 (permalink))
Old
09-25-03, 06:58 PM
I personally would gert a chip with a 3.1 or lower, but if you are getting a chip, might as well go for the 2.93"
2003 Black Cobra:
Bassani Catted X, Borla Stinger Catback, Pro 5.0 shifter, Diablo Predator,
GordsFord Heat Exchanger, JLT CAI, 00R Brembo Brake kit, MM Full Length SFCs,
H&R Race Springs, Full Saleen Extreme appearance upgrade. 451/433 rwhp/tq SAE
(#7 (permalink))
Old
92gt5.0's Avatar
09-25-03, 07:04 PM
What is the diameter of the stock pulley?
Dont let anyone drive your car that cant shift good!
92 GT T5 Will miss it (not too much)
1/4 time 13.88 @100.33
92 Gt Gone! Traded in for 03 White Cobra
Borla Stinger cat back Drop in K&N
397.4RWHP 382.5 RWTQ
13.04 @110.52 (stock goodyears)
(#8 (permalink))
Old
Mr. Metrosexual
09-25-03, 07:07 PM
Quote:
3.65
(#9 (permalink))
Old
92gt5.0's Avatar
09-25-03, 07:55 PM
Thanks Viper So a 3.4 pulley would not need a chip and would give you 12 pounds boost maybe?? Maybe good for 30 to 40 rwhp?
(#10 (permalink))
Old
Mr. Metrosexual
09-25-03, 08:02 PM
No.
You shouldn't need a chip with a 3.4, it is only slightly smaller than stock. I have heard you will get about 2 lbs of boost with it and about 10 rwhp.
And like someone else said, if you DO get a chip, you mine as well go with a really small pulley.....2.93 or 2.81 for example.
(#11 (permalink))
Old
01SilverL's Avatar
09-25-03, 08:08 PM
A 3.4 won't give you 30-40hp, it's more like 10-15. With a cat-back and CAI you will definetly notice a difference with the 3.4 though.
03 DSG Cobra Coupe
twin screwed.
(#12 (permalink))
Old
Mr. Metrosexual
09-25-03, 08:11 PM
Quote:
Yeah, I see your sig. Awesome #'s with your mods. You have almost the same exact mods I will be getting. I already have the CAI.
(#13 (permalink))
Old
01MustangMan's Avatar
01-02-04, 08:31 PM
I think I was told 3.2 is the smallest you can go without a chip... I would just get the 2.93 lighting pullie and a chip to go with it. You will see about 4psi extra with the lighting pullie for a total of about 12psi. Thats what I am doing, I hope for 450rwhp with my mods
2003 COBRA
Production #2,088/8394
Born 8-14-2002
12.32@117.5 2.05 60'
Performance Mods
9" K&N Filter w/heat shield, 95mm C&L mass air meter, 65mm Twin BBK throttle Body, 2 1/2" BBK X-Pipe w/ Highflow cats, 2 1/2" Magnaflow Catback w/ 3 1/2" tips, 2.93 Non-Slip Pulley, Metco idler pulley's, NGK Spark plugs, Predator tune
(#14 (permalink))
Old
Benny's Avatar
01-03-04, 07:50 AM
I have a steeda 3.1 pulley with a gatorback 74.5 belt
I was told by alot of techs that 3.1 is about the border line for no chip. Try it and have it dynoed. These car do run pig rich so your A/F could be fine. If you decide to chip it spend the money on the Predator. You won't be sorry.
(#15 (permalink))
Old
95GTS's Avatar
01-03-04, 08:09 AM
When I ran my 3.2" pulley, my air-fuel from 2500rpm to 4000rpm was a bit high, IMO. Started at 14:1 and slowly dipped to 12.3:1 or so. After 4000rpm, it dropped to below 10:1 by 6000rpm. I then swapped it out for a 2.93" where the air-fuel was unacceptably high. It seems I'm one of the few that use the Afterbuner eFPC to tune my air-fuel. It allows me to alter my fuel pressure in 400rpm increments. It's more of a safety net than a performance booster. Being that I haven't changed my timing curves, I've left a lot of torque on the table as well as some performance. Regardles, I'm sastisfied with the performance so far.
2005 C6 Corvette Z51
2003 Cobra-gone but not forgotten
2004 Nissan Maxima SL
1992 Explorer
(#16 (permalink))
Old
Uncle Meat's Avatar
01-04-04, 03:52 AM
Have you ever had your car dyno'ed before? Do you even know where your A/F ratio is with your current mods? I don't know why people feel a need to take a chance and run smaller pulleys (any diameter) without getting their A/F checked! Just doesn't make sense to me. I know that 90% of all stock '03 Cobra's are pig rich right out of the factory, but what happens when you get one like mine that isn't? 3.4, or 3.2, or 3.1... doesn't matter, you should get the A/F checked and the car tuned for the pulley.
My 2 cents...
U.M.
Stangnet's resident curmudgeon.
'03 Cobra SOLD!
Actively searching for my next mid-life crisis car.
(#17 (permalink))
Old
grey03cobra's Avatar
01-04-04, 04:14 PM
That seems kind of strange to me. I actually drove my 03 to Pompano Fl to have Steeda install my pulley. I ended up with the 2.81, but while I was debating which pulley to go with I specifically asked them if I would need the chip with the 3.1 pulley. I was told "if you want to be on the safe side, you should have the chip installed". I guess it's better to spend $280 for the chip instead of $11,000 for a new engine.
Besides, with the chip you will maximize the power output of your engine.
612rwhp 632rwtq
Mods are in my garage
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
