Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Tech
Reload this Page skinnies on a 96 cobra....
Reply
(#1 (permalink))
Old
juicedsnake's Avatar
Question skinnies on a 96 cobra.... - 10-18-03, 09:18 AM
hi guys new guy here I was wondering if 15" draglites will fit on the front of my cobra looking at going 3.5" wide. will it clear the rotor? I know if it was 8" wide it wouldnt. if any of you have them on your cobra and can tell me the back spacing that would be great. thanks.
Justin
(#2 (permalink))
Old
missouri_guy197's Avatar
10-18-03, 10:52 AM
Get a 30mm H&R Spacer from Maximummotorsports.com and they'll work just fine...
(#3 (permalink))
Old
10-18-03, 02:10 PM
thanks for the help
(#4 (permalink))
Old
white99gt's Avatar
10-18-03, 07:51 PM
http://forums.modulardepot.com/showt...&threadid=1006
Shows exactly what you need and if you have to modify anything.
90 lx 306w/- H/C/I 301rwhp~331rwtq
tmoss ported explorer intake,70mm tbody,80mm lmaf,STOCK airbox,performer 5.0 heads,navigator 25lb injectors,comp xe270hr-14 cam,fms 1.6 rr,bbk longtubes,o/r hpipe,flowmaster catback,TKO 500 ,3:73's dcc fan kit,bilstein shocks,mm cc plates,h&r ss vert springs,mm bumpsteer kit,sct tuned by tonyg @ www.hp-performance.com
2V 2.2 Kenne bell
600rwhp~533rwtq <-SOLD
"It ain't braggin if you can back it up"
(#5 (permalink))
Old
SWEET94COBRA's Avatar
11-03-03, 03:29 PM
O.K. I saw alot of Ideas here. I DO NOT want to grind so what do I need for a 94 cobra front skinnies. Should I get the prostars or bogarts. What is lighter and a easier setup.
(#6 (permalink))
Old
11-03-03, 04:49 PM
The easiest setup would be with the H&R Spacers and Prostars...That way you don't need to grind, and you won't need longer lugnuts up front...The Bogarts don't need any grinding, but you do need longer studs to have enough thread to put the lug nut on...
The Prostars and H&R's would still be cheaper than if you got the Bogarts and longer studs too...
(#7 (permalink))
Old
11-05-03, 05:36 AM
Grinding is not something I want to do.
1996 Cobra:
NX 150 SHOT
4.10 GEARS
KENNE BROWN SUB FRAMES
STEEDA TRI-AX SHIFTER
K&N FIPK
SALEEN 18X9(FRONT) 18X10(BACK) RIMS
FRPP ALUM DRIVE SHAFT
MOSER 31 SPLINE AXLES
EATON 31 SPLINE LSD
MEGABITE JR. UPPER/LOWERS
MSD WIRES
FLOWMASTER 3 CHAMBER CAT BACK
BBK X-PIPE (SLP in the mail)
COBRA RR HOOD, SALEEN SR800 WING
INTRAX LOWERING SPRINGS (2" DROP)
TOKICO 5-WAY ADJUSTABLE
STEEDA TIMING ADJUSTER
BFGOODRICH COMP T/A DRAG SLICKS ON 15X8" RIMS
(#8 (permalink))
Old
11-05-03, 05:38 AM
Oh this is what my car looks like
1996 Cobra:
NX 150 SHOT
4.10 GEARS
K&N FIPK
EATON 31 SPLINE LSD
MSD WIRES
(#9 (permalink))
Old
Skinnies - 11-05-03, 05:41 PM
Which one is safer. Are those spacers with the bolts built in them the safest. I don't want the front end to come down and snap those things!!! Are they safe for the street. I went to the weldracing site and I'm not sure which skinny I need. There are three 3.5's to choose from . I know it is 4.5 bolt pattern but how about the diameter? Is there a weight difference between the draglites and prostars? Any differences. I know alot of questions but I do appreciate the help. Thanks
(#10 (permalink))
Old
11-05-03, 07:20 PM
I would think that the safest setup would be longer studs with Bogart skinnies that have the spacer welded to them...I believe that's the only 'true' NHRA legal way to run skinnies, although most tracks don't check on that stuff unless you are racing in a big event or something...
But many people use the H&R spacers, and I think a lot of road racers/auto-x guys use them also to widen the cars stance for better cornering...
(#11 (permalink))
Old
03-08-04, 12:26 PM
I am going through the same thing with my 97 cobra. I just bought 17x10.5 cobra r's and they slowed me down 2 tenths so I want draglites. I want to keep mine on for street use, so should I go with a 15x5 or 15x7 up front instead of the skinnies?
(#12 (permalink))
Old
white99gt's Avatar
03-08-04, 05:04 PM
Quote:
Sorry but i got to call on that.they are not much heavier than the stock wheels and tires.
for you to lose a full two tenths you would have to add a good 100+ pounds of weight.
2V 2.2 Kenne bell
(#13 (permalink))
Old
103's Avatar
103 103 is offline
03-08-04, 06:25 PM
It isn't just the added weight, but also the extra friction and movement on the top end of the track. Smart guy...
# 473 of 3867
Best ET: 12.53 @ 109.3
Member of Modern Mustangs of Gainesville and Modern Mustangs of Jacksonville
(#14 (permalink))
Old
03-08-04, 06:40 PM
Quote:
Plus not to mention the added rotational mass...
(#15 (permalink))
Old
white99gt's Avatar
03-08-04, 08:33 PM
I understand all that but its not gonna hurt to the tune of 2 TENTHS.
Just because he lost doesnt mean it was the tires.It could be track conditions, weather conditions,traction issues.
DA effects quarter mile times.
So unless they were installed and ran against stockers on the same day ,its not a valid point.
2V 2.2 Kenne bell
(#16 (permalink))
Old
103's Avatar
103 103 is offline
03-09-04, 06:26 AM
Two tenths sounds completely believable in a close to stock car. Remember that .2 when you're in the 13s or high 12s is not difficult to lose...
# 473 of 3867
(#17 (permalink))
Old
03-09-04, 09:52 AM
My car is stock except for off-road H and flowmasters. I was running consistent 8.90's in the 1/8th now im running 9.10-9.20 with the same 60ft's and both were in cool temeratures. My car weighed 3200lbs before the wheel swap, haven't been back to the scale since, maybe I'll do that today out of curiosity. Either way, I still want welds, but are skinnies safe for the street with the spacers?
(#18 (permalink))
Old
03-09-04, 01:58 PM
what tires were you running on stock wheels and what tires are you running now? There's no way going from a 8" wheel to a 10.5" wheel is gonna add 2/10's unless the new tires won't hook like the old ones did.
99 SVT Cobra coupe
best 1/8th 7.99@85.2 w/ 1.65 60ft
best 60ft: 1.60
296.2 rwhp and 292.6 rwtq
S-trim on the way!
93 5.0 5-speed coupe
Cars For Sale:
93 LX, red w/ black int. 5.0 5-speed, $5900
706-965-RACE www.sextonsperformance.com
Nitrous refills $2.40/lb , Propane refills.
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
