Go Back   Mustang Forums at StangNet > Mustang Forums > Special Production > Mach 1
Reload this Page Can't find 3rd gear at the track...
Reply
(#1 (permalink))
Old
Angus's Avatar
Angry Can't find 3rd gear at the track... - 10-29-03, 09:39 PM
I went to the track tonight, and unfortunately could not get my transmission into 3rd gear 4 out of 8 runs.
Car only has 1700 miles on it, and shifted wonderfully before tonight. Shifts great if I shift at less than 6000 rpm or very slowly (but what fun is that???)
I'm going to check the Steeda Tri-Ax I installed @ 300 miles, but I doubt if I'll find anything.
Is there a real, documented fix for this "3rd gear lock-out" problem???
'03 DSG Mach 1
297.7 rwhp/309.0 rwtq
Best ET/MPH/60': 12.844 @ 107.75 mph (1.77 60')
Bassani '03 Cobra Catted X-Pipe,
Magnaflow Catback, Steeda Aluminum LCA's, K&N Aircharger, BFG Drag Radials,
4.30 gears/Eaton 31-spline posi/31-spline Superior axles/TA 8.8 Girdle, Raptor shift light,
MM Full-Length SF's/Clutch Quadrant/Firewall Adjuster & Adjustable Clutch Pedal.
(#2 (permalink))
Old
ttown's Avatar
10-30-03, 03:49 AM
The only time I have a problem is when I go back to grabbing the shifter, that's a NO NO on this car. Always use the palm of your hand when shifting to 3rd otherwise you'll miss 3rd or have to fight it.
You may want to check your stop bolts also.........good luck
(#3 (permalink))
Old
10-31-03, 06:30 AM
I have the same problem..I noticed while in second, I was holding the shifter hard to the right and would slam it up while keeping the pressure to the right and hit between 3rd and 5th. ( I think anyway) I used to shift this way in my 99 GT and could shift as fast as 1st to 2nd and 3rd to fourth. I just have to get used to it i guess?? I do have to shift slower to hit 3rd. How do I check the stop bolts? I have 1200 miles on my torch red ride now. Love the car, but I'm leary of third gear! lol
(#4 (permalink))
Old
ttown's Avatar
10-31-03, 07:42 AM
If you don't have an aftermarket shifter like the triax, pro 5, or UPR you won't have any. The stock shifter uses the stops in the 3650 tranny.
I grab to shift 1st to 2nd, Palm push 2nd to 3rd, Grab 3rd to 4th, and push 4th to 5th. Seems to work for me, you may try it but it's hard to break old habbits.
(#5 (permalink))
Old
10-31-03, 06:59 PM
Out of the three shifters you listed above, what is the best one. The price differance isn't worth mentioning. Also how much of a pain in the arse are they to install?
(#6 (permalink))
Old
ttown's Avatar
11-01-03, 03:37 PM
Quote:
They are all very good. I have the UPR $144, most will tell you the triax, haven't driven a pro 5 but they have a good following. I would buy my UPR again its just like the triax but cheaper and as good or better quality and no noise issues. I don't think it matters the one you get all are high quality.
Triax would win in a vote though.........
They are short throw shifters and most love them, they are much tigher on shifts than the stock shifter.
(#7 (permalink))
Old
BlkMachWon's Avatar
11-06-03, 11:13 AM
UPR here as well with no issues.
Any of the three shifters mentioned would be an improvement and installation is very easy.
(#8 (permalink))
Old
green68stang's Avatar
Official Member
11-27-03, 12:12 AM
I have a Tri-Ax in my GT and love it, but am getting a Pro 5.0 for the Mach 1, just to spread the love a little, and see if there are any noticeable differences between the two - which I don't really expect.
2004 Azure Blue Mustang Mach 1
Build Date 10/13/03
*Pro 5.0 Shifter
1999 Laser Red Mustang GT Convertible
*Flowmaster American Thunder 17312 Catback Exhaust Kit
*Bassani O/R X-pipe
*Eibach Pro-Kit Suspension Springs
*K&N Filter
*Bullitt Wheels
*Bullitt Pedals
*Steeda Tri Ax Shifter
*UPR "GT" Black Fuel Door w/Brushed Aluminum Bezel
*Aftermarket Smoke Headlights
*CDC Lightbar
*X2CMotorsports Rear Seat Delete
(#9 (permalink))
Old
34Ford's Avatar
11-27-03, 09:55 AM
My big complaint is sometimes I cant get into reverse.
Even if I go thru all of the forward gears it still want. Ill move forward, then let out the clutch in netural and all.
Been a few times where I am in traffic and the damn thing just refuses to budge. Then finally it will go.
(#10 (permalink))
Old
03-24-04, 01:09 PM
Try changing the shift knob. It worked for me. I have had 3 stangs, and changed the Knob in everyone of them. I have big hands so I went with the round cue ball type. It allows me to move my hand around at different angles when shifting into different gears. I havent tried any of the shifters that have been mentioned. The one thing I did do, was change the shifter handle. That helps also. In my last 2 stangs, i changed the to the MGW handle. It allows you to adjust the height and the angle of the handle. No more reaaaaching for 5th gear.
2003 Azure Blue Mach1
MRT shift knob
MGW shift handle
Saleen Replica HyperBlack wheels with 275x9/35 all around (DRESS SHOES)
Stock wheels and tires (dancing shoes)
13.2 @ 104 stock down to the paper filter.
GONE BUT NOT FORGOTTEN
2000 GT BLACK
AUTOMETER GAUGE CLUSTER
Steeda Sport Springs
Steeda underdrive pulleys
BASSANI X PIPE W/CATS
MAGNAFLOW/MAGNAPACK
Quad driving/fog lights
Upper/lower Speed Grill
Tint
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
